GBLC03CI-ES
GBLC03CI-ES
    ELECSUPER(静芯微)
    SOD-323
    ESD抑制器/TVS二极管 双向 3V 10A 200W SOD-323
GBLC03CI-ES 数据手册
GBLCxxCI Rev-1.1 www.elecsuper.com SuperESD - GBLCxxCI 1. Description The GBLCxxCI Series are ultra low capacitance transient voltage suppressor arrays, designed to protect applications such as portable electronics and SMART phones. This series is available bidirectional configurations and is rated at 350 Watts for an 8/20μs waveshape. At higher operating frequencies or faster edge rates, insertion loss and signal integrity are a major concern. This series offers a ultra low capacitance and low leakage current in a miniature SOD-323 package. 2. Features ⚫ ⚫ IEC 61000-4-2 Level 4 ESD Protection ⚫ RoHS compliance - ±25kV Contact Discharge ⚫ Bidirectional configuration - ±25kV Air Discharge ⚫ IO Capacitance: 0.8pF (Typical) IEC 61000-4-4 EFT Protection ⚫ Low clamping voltage ⚫ End Equipment ⚫ 40A (5/50ns) 200W Peak pulse Power (8/20us) 3. Applications ⚫ Interfaces - USB 2.0/1.1 - Industrial and Serve Robots - GPIO - Laptops and Desktops - Ethernet 10/100/1000 Mbps - TV and Monitors - Audio - Wearables 4. Ordering Information Part Number Package Material GBLCxxCI SOD323 Halogen free VRWM Marking Quantity per reel Tape & 3,000 PCS Reel Marking for the GBLCxxCI series 3V CC Table-1 Copyright© ElecSuper Incorporated Packing Flammability Rating Reel Size UL 94V-0 7 inches 5V 3B/LC Ordering information Contact Us 1 / 7 GBLCxxCI Rev-1.1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO Connect to IO Outline 1 Circuit Diagram 2 Marking 2 IO 1 2 Connect to IO Table-2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 200 W Peak pulse current (tp=8/20us)@25℃ IPP Refer to Table-5 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±25 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±25 kV TJ - 150 ℃ Operating temperature TOP -40 125 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 GBLCxxCI Rev-1.1 www.elecsuper.com 6.2. Electrical Characteristics Symbol Description VRWM Rated reverse stand-off voltage VBR Minimum breakdown voltage @IT = 1mA VCL Clamping voltage IPP Maximum peak pulse current IR Reverse leakage current @VRWM CO Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz) Table-4 Parameters Description At TA = 25℃ unless otherwise noted VRWM VBR VCL@I=1A IPP VCL@I=IPP IR CO (V) (V) (V) (A) (V) (uA) (pF) GBLC03CI 3.0 3.8 8.5 10.0 20.0 1.0 0.8 GBLC05CI 5.0 6.5 9.5 8.0 21.0 1.0 0.8 Part Number Table-5 Copyright© ElecSuper Incorporated Electrical Characteristics for All Series Contact Us 3 / 7 GBLCxxCI Rev-1.1 www.elecsuper.com 7. Typical Characteristic Non-repetitive peak pulse power vs. pulse time 8. Typical Application Pic-3 Copyright© ElecSuper Incorporated Typical Internet 1G Interface Application Contact Us 4 / 7 GBLCxxCI Rev-1.1 www.elecsuper.com 9. Dimension E A b D A1 E1 A2 θ C L Symbol A A1 A2 b C D E E1 L L1 θ L1 SOD323 Dimensions in Millimeters Min. Max. 1.000 0.000 0.100 0.800 0.900 0.250 0.350 0.080 0.150 1.200 1.400 1.600 1.800 2.550 2.750 0.475REF 0.250 0.400 0° 8° Table-6 Copyright© ElecSuper Incorporated Dimensions in Inches Min. Max. 0.039 0.000 0.004 0.031 0.035 0.010 0.014 0.003 0.006 0.047 0.055 0.063 0.071 0.100 0.108 0.019REF 0.010 0.016 0° 8° product dimensions Contact Us 5 / 7 GBLCxxCI Rev-1.1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only 4. Unit: mm Copyright© ElecSuper Incorporated Contact Us 6 / 7 GBLCxxCI Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
GBLC03CI-ES 价格&库存
很抱歉,暂时无法提供与“GBLC03CI-ES”相匹配的价格&库存,您可以联系我们找货
GBLC03CI-ES
  • 10+0.26979
  • 100+0.20531
  • 300+0.16956
  • 3000+0.14807
  • 6000+0.12939
  • 9000+0.11934
库存:16771
GBLC03CI-ES
  • 10+0.11761
库存:1916
GBLC03CI-ES
  • 1+0.62150
  • 200+0.20790
  • 1500+0.12980
  • 3000+0.10285
库存:4720
