HoARG0603-1/10W-620KR-0.1%-TCR25
    MILLIOHM(毫欧)
    陶瓷电阻 620KΩ ±0.1% 100MW
HoARG0603-1/10W-620KR-0.1%-TCR25 数据手册
系列号 HoARG 修订日期 HoARG贴片陶瓷系列规格书 2020-03-06 Ho-A0 版本号 ■Features -Advanced thin film technology -SMD Type designed for automatic insertion -Wide resistance range 1ohm ~ 2.49Mega ohm ■Applications -Medical Equipment -Testing / Measurement Equipment -Printer Equipment -Automatic Equipment Controller -Converters -Communication Device, Cell Phone, GPS, PDA ■Construction L D1 W     T  D2    Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Overcoat  Marking ■Dimensions Type ARG ARG ARG ARG Unit: mm Size (Inch) L W T D1 D2 0402 0603 0805 1206 1.00±0.05 1.60±0.10 2.00±0.15 3.10±0.15 0.50±0.05 0.80±0.10 1.25±0.15 1.55±0.15 0.30±0.10 0.45±0.10 0.50±0.10 0.55±0.10 0.20±0.10 0.30±0.20 0.30±0.20 0.42±0.20 0.20±0.10 0.30±0.20 0.40±0.20 0.35±0.25 Weight (g) (1000pcs) 0.54 1.83 4.71 9.02 ■Part Numbering Ho ARG 0402 1/16W 制造商 产品类别 封装 额定功率 毫欧电子 贴片陶瓷 5R 阻值 0402 1/16W 4.7Ω~255KΩ 0603 1/10W 1Ω~1MΩ 0805 1/8W 1Ω~2MΩ 1206 1/4W 1Ω~2.49MΩ 1% 精度 C=±0.25% D=±0.5% F=±1% G=±2% J=±5% 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 修订日期 . HoARG贴片陶瓷系列规格书 ■Derating Curve HoARG 2020-03-06 Ho-A0 版本号 Derating Curve Power ratio(%) 100 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) ■Standard Electrical Specifications Power Rating at 70°C Operating Temp. Range Max. Operating Voltage Max. Overload Voltage ARG0402 1/16W -55 ~ +155°C 50V 100V 4.7Ω – 255KΩ ±25 ±50 ARG0603 1/10W -55 ~ +155°C 75V 150V 1Ω - 1MΩ ±25 ±50 ARG0805 1/8W -55 ~ +155°C 150V 300V 1Ω - 2MΩ ±25 ±50 ARG1206 1/4W -55 ~ +155°C 200V 400V 1Ω - 2.49MΩ ±25 ±50 Item Type Resistance Range ±0.1% ±0.25% ±0.5% ±1% Operating Voltage=√(P*R) or Max. operating voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. overload voltage listed above, whichever is lower. (Lower Resistance:1~10Ω ; High Power Rating) 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn TCR (PPM/°C) 系列号 HoARG贴片陶瓷系列规格书 修订日期 HoARG 2020-03-06 版本号 Ho-A0 ■Environmental Characteristics Item Requirement Temperature Coefficient of Resistance As Spec. (T.C.R.) Test Method MIL-STD-202 Method 304 +25/-55/+25/+125/+25C Short Time Overload ΔR±0.2% JIS-C-5201-1 4.13 RCWV*2.5 or Max. overload voltage whichever is lower for 5 seconds Insulation Resistance >9999 MΩ MIL-STD-202 Method 302 Apply 100VDC for 1 minute Endurance ΔR±0.5% MIL-STD-202 Method 108A 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Damp Heat with Load ΔR±0.5% MIL-STD-202 Method 103B 402C, 90~95% R.H. RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF” Bending Strength ΔR±0.1% JIS-C-5201-1 4.33 Bending amplitude 3 mm for 10 seconds Solderability 95% min. coverage MIL-STD-202 Method 208H 2455C for 3 seconds Resistance to Soldering Heat ΔR±0.1% MIL-STD-202 Method 210E 260±5C for 10 seconds Dielectric Withstand Voltage By Type MIL-STD-202 Method 301 Max. overload voltage for 1 minute Thermal Shock ΔR±0.2% MIL-STD-202 Method 107G -55C ~150C, 100 cycles Low Temperature Operation ΔR±0.5% JIS-C-5201-1 4.36 1 hour, -65C, followed by 45 minutes of RCWV RCWV(Rated continuous working voltage)= √(P*R) or Max. Operating voltage whichever is lower Storage Temperature: 15~28C; Humidity < 80%RH ■Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260C:10s (2) Time of wave soldering at maximum temperature point 260C:10s (3) Time of soldering iron at maximum temperature point 410C:5s 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoARG 修订日期 HoARG贴片陶瓷系列规格书 2020-03-06 Ho-A0 版本号 ▓Marking 0603 3digit marking 3digit marking for Example: 14C=13K7Ω 14C 68B=4K99Ω 13C=13K3Ω 68X=49.9Ω Marking Table Code E96 Code E96 Code E96 Code E96 01 100 25 178 49 316 73 562 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 24 174 48 309 72 549 96 976 Code A B C D E F G H X Y Z Multiplier 100 101 102 103 104 105 106 107 10-1 10-2 10-3 Example: 101=100Ω 102=1KΩ 0603 3digit marking for E24 E24 10 11 12 0805~2512 4digit marking 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 Example Resistance 100Ω 2.2KΩ 10KΩ 49.9KΩ 100KΩ marking 1000 2201 1002 4992 1003 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 91 系列号 修订日期 HoARG贴片陶瓷系列规格书 版本号 HoARG 2020-03-06 Ho-A0 ■Packaging Packing Quantity & Reel Specifications Type ØA ØB Unit :mm ØC W T Paper Tape (EA) Emboss Plastic Tape (EA) 11.5±1.0 10,000 - 0402 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 0603 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 5,000 - 0805 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 5,000 - 1206 178.0±1.0 60.0+1.0 13.5±0.7 9.5±1.0 11.5±1.0 5,000 - Paper Tape Specifications Bottom Tape Top Tape ψ D0 E A F B T Paper Tape P1 Resistor P2 P0 W direction of unreeling Unit: mm A B W E F P0 P1 P2 ΦD0 T 0.70±0.05 1.16±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.55±0.05 0.40±0.03 0603 1.10±0.05 1.90±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 0.60±0.03 0805 1.60±0.05 2.37±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 0.75±0.05 1206 2.00±0.05 3.55±0.05 8.00±0.10 1.75±0.05 3.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.55±0.05 0.75±0.05 Type 0204 Peel force of top cover tape The peel speed shall be about 300mm/min±5% The peel force of top cover tape shall be between 8gf to 60gf Unit: mm 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoARG贴片陶瓷系列规格书 修订日期 版本号 ■Recommend Land Pattern 2020-03-06 Ho-A0 Unit: mm Type C B HoARG A B C ARG0402 0.50 0.50 0.60±0.2 ARG0603 0.80 1.00 0.90±0.2 ARG0805 1.00 1.00 1.35±0.2 ARG1206 2.00 1.15 1.70±0.2 A 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn
HoARG0603-1/10W-620KR-0.1%-TCR25 价格&库存
很抱歉,暂时无法提供与“HoARG0603-1/10W-620KR-0.1%-TCR25”相匹配的价格&库存,您可以联系我们找货
