安徽富信半导体科技有限公司
ANH UI F OSAN SEMICONDUCTOR TECHNOLOGY CO., LTD .
5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
20 to 100 Volts
CURRENT
5.0 Ampere
FEATURES
DO-214AA(SMB)
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
.083(2.11)
.075(1.91)
.155(3.94)
.130(3.30)
.185(4.70)
.160(4.06)
MECHANICAL DATA
.012(0.31)
.006(0.15)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.093 grams
.096(2.44)
.083(2.13)
.008 MAX.
.050(1.27)
.030 (0.76)
(.203)
.220(5.59)
.200(5.08)
Dimensions in inches and (millimeters)
MAXIMUMRATINGSANDELECTRICALCHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS52
SS53
21
30
SS54
40
28
40
at TL=90 C
superimposed on rated load (JEDEC method)
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=100 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
SS56
50
35
50
60
42
60
SS58
SS59
SS510
80
56
80
90
63
90
100
70
100
120
0.55
0.1
0.70
5
0.85
0.02
2
380
16
-65 +150
-65 +150
UNITS
V
V
V
A
5.0
Peak Forward Surge Current, 8.3 ms single half sine-wave
Maximum Instantaneous Forward Voltage at 5.0A
SS55
A
V
mA
mA
pF
C/W
C
C
RATING AND CHARACTERISTIC CURVES (SS52 THRU SS510)
FIG.2-TYPICAL FORWARD
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
6.0
50
5.0
4.0
10
3.0
2.0
3.0
1.0
60
80
100
120
140
160
180
200
1.0
LEAD TEMPERATURE ( C)
Tj=25 C
P u ls e W id t h 3 0 0 u s
1% Duty Cyc le
0.1
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
150
.01
120
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARDVOLTAGE,(V)
90
Tj=25 C
8.3ms Si ngle Half
Sine Wave
60
JED EC method
30
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
10
50
100
100
NUMBER OF CYCLES AT 60Hz
FIG.4-TYPICAL JUNCTION CAPACITANCE
10
1.0
Tj=75 C
.1
Tj=2 5 C
.01
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
很抱歉,暂时无法提供与“SS510B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37120
- 100+0.31007
- 300+0.27951
- 3000+0.25661
- 6000+0.23825
- 9000+0.22907
