SR5100
SR5100
    JUXING(钜兴)
    DO-27(DO-201AD)
    电压:100V 电流:5A
SR5100 数据手册
SR520 THRU SR5200 SCHOTTKY BARRIER RECTIFIERS DO-201AD(DO-27) FEATURES · High current capability · High surge current capability · Low forward voltage drop · Exceeds environmental standards of MIL-S-19500/228 .937 23.8 · For use in low voltage, high frequency inverters free wheeling, and porlarlity protection applications MECHANICAL DATA Case: Molded plastic, DO-201AD .937 23.8 Epoxy: UL 94V-O rate flame retardant Lead: Axial leads, solderable per MIL-STD-202, method 208 guaranteed Polarity: Color band denotes cathode end Mounting position: Any Dimensions in inches and (millimeters) Weight: 0.04ounce, 1.1gram Maximum Ratings and Electrical Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Single phase, half wave, 60H Z, resistive or inductive load. For capacitive load, derate current by 20%. Symbols SR520 SR540 SR550 SR560 SR580 SR5100 SR5150 SR5200 Units Maximum Recurrent Peak Reverse Voltage VRRM 20 40 50 60 80 100 150 200 Volts Maximum RMS Voltage VRMS VDC 28 40 35 50 42 60 56 80 70 100 105 150 140 200 Volts Maximum DC Blocking Voltage 14 20 Maximum Average Forward Rectified Current .375"(9.5mm) Lead Length Volts I(AV) 5.0 Amp IFSM 150 Amp Peak Forward Surge Current, 8.3ms single half-sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 5.0A DC and 25℃ Maximum Reverse Current at TA=25℃ at Rated DC Blocking Voltage T A=100℃ Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Operating Junction Temperature Range Storage Temperature Range VF 0.55 0.70 0.5 IR CJ 500 Volts 380 pF RθJA 15 10 ℃/W TJ -55 to +125 -55 to +150 ℃ Tstg NOTES: http://www.trr-jx.com 0.95 mAmp 50 1- Measured at 1 MHZ and applied reverse voltage of 4.0 VDC. 2- Thermal Resistance From Junction to Ambient 0.375"(9.5mm) lead length P.C.B. Mounted version: 02 0.85 -55 to +150 ℃ SR520 THRU SR5200 SCHOTTKY BARRIER RECTIFIERS RATINGS AND CHARACTERISTIC CURVES version: 02 http://www.trr-jx.com
SR5100 价格&库存
很抱歉,暂时无法提供与“SR5100”相匹配的价格&库存,您可以联系我们找货
