SMA4734A
SMA4734A
    ZHIDE(志得)
    SMA(DO-214AC)
    耐压:5.6V 电流:10UA@2V
SMA4734A 数据手册
SMA47xxA SERIES Surface Mount Silicon Zener Diodes Zener Voltage 3.3 ~ 390 V DO-214AC(SMA) 1.0 Watt Power Dissipation Features ● Glass passivated chip ● Built-in strain relief ● Low inductance ● High peak reverse power dissipation ● Low reverse leakage ● For use in stabilizing and clipping with high power rating ● RoHS compliant Mechanical Data ● Case: DO214AC Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant Unit: inch(mm) ● Polarity: Color band denotes cathode end ● Mounting position: Any Parameter Symbols Value Unit PD 1.0 W VF 1.2 V Junction temperature range TJ,TSTG -55 to +150 ℃ Storage temperature range TJ,TSTG -55 to +150 ℃ DC Power dissipation at TL = 75 °C (1) Maximum forward voltage at if=200mA Note: (1)TL=Lead temperature at 3/8'' (9.5mm)from body REV.1.2,2017-12 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com SMA47xxA SERIES Ratings and Characteristics Curves (TA=25℃ unless otherwise noted) REV.1.2,2017-12 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com SMA47xxA SERIES Part Number Device Marking Code Nominal Zener Voltage @IT IZT(mA) VZ AVE.(V) SMA4727A SMA4728A SMA4729A SMA4730A SMA4731A SMA4732A SMA4733A SMA4734A SMA4735A SMA4736A SMA4737A SMA4738A SMA4739A SMA4740A SMA4741A SMA4742A SMA4743A SMA4744A SMA4745A SMA4746A SMA4747A SMA4748A SMA4749A SMA4750A SMA4751A SMA4752A SMA4753A SMA4754A SMA4755A SMA4756A SMA4757A SMA4758A SMA4759A SMA4760A SMA4761A SMA4762A SMA4763A SMA4764A SZ1110A SZ1120A SZ1130A SZ1150A SZ1160A SZ1180A SZ1200A SZ1220A SZ1240A SZ1250A SZ1270A SZ1300A SZ1330A SZ1360A SZ1390A 727A 728A 729A 730A 731A 732A 733A 734A 735A 736A 737A 738A 739A 740A 741A 742A 743A 744A 745A 746A 747A 748A 749A 750A 751A 752A 753A 754A 755A 756A 757A 758A 759A 760A 761A 762A 763A 764A 711Z 712Z 713Z 715Z 716Z 718Z 720Z 722Z 724Z 725Z 727Z 730Z 733Z 736Z 739Z REV.1.2,2017-12 Maximum Zener Impedance 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10.0 11.0 12.0 13.0 15.0 16.0 18.0 20.0 22.0 24.0 27.0 30.0 33.0 36.0 39.0 43.0 47.0 51.0 56.0 62.0 68.0 75.0 82.0 91.0 100.0 110.0 120.0 130.0 150.0 160.0 180.0 200.0 220.0 240.0 250.0 270.0 300.0 330.0 360.0 390.0 VZ MIN.(V) 2.85 3.14 3.42 3.71 4.09 4.47 4.85 5.32 5.89 6.46 7.13 7.79 8.65 9.50 10.45 11.40 12.35 14.25 15.20 17.10 19.00 20.90 22.80 25.65 28.50 31.35 34.20 37.05 40.85 44.65 48.45 53.20 58.90 64.60 71.25 77.90 86.45 95.00 104.50 114.00 123.50 142.50 152.00 171.00 190.00 209.00 228.00 237.50 256.50 285.00 313.50 342.00 370.50 VZ MAX.(V) 3.15 3.47 3.78 4.10 4.52 4.94 5.36 5.88 6.51 7.14 7.88 8.61 9.56 10.50 11.55 12.60 13.65 15.75 16.80 18.90 21.00 23.10 25.20 28.35 31.50 34.65 37.80 40.95 45.15 49.35 53.55 58.80 65.10 71.40 78.75 86.10 95.55 105.00 115.50 126.00 136.50 157.50 168.00 189.00 210.00 231.00 252.00 262.50 283.50 315.00 346.50 378.00 409.50 80.0 76.0 69.0 64.0 58.0 53.0 49.0 45.0 41.0 37.0 34.0 31.0 28.0 25.0 23.0 21.0 19.0 17.0 15.5 14.0 12.5 11.5 10.5 9.5 8.5 7.5 7.0 6.5 6.0 5.5 5.0 4.5 4.0 3.7 3.3 3.0 2.8 2.5 2.3 2.0 1.9 1.7 1.6 1.4 1.2 1.0 0.9 0.9 0.8 0.8 0.7 0.7 0.7 ZZT MAX.(Ω) @IZT ZZK MAX.(Ω) @IZK IZK(mA) 10.0 10.0 10.0 9.0 9.0 8.0 7.0 5.0 2.0 3.5 4.0 4.5 5.0 7.0 8.0 9.0 10.0 14.0 16.0 20.0 22.0 23.0 25.0 35.0 40.0 45.0 50.0 60.0 70.0 80.0 95.0 110.0 125.0 150.0 175.0 200.0 250.0 350.0 450.0 550.0 700.0 1000.0 1100.0 1200.0 1900.0 1600.0 1800.0 2000.0 2100.0 2300.0 2500.0 2700.0 3000.0 400.0 400.0 400.0 400.0 400.0 500.0 550.0 600.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 750.0 750.0 750.0 750.0 750.0 1000.0 1000.0 1000.0 1000.0 1500.0 1500.0 1500.0 2000.0 2000.0 2000.0 2000.0 3000.0 3000.0 3000.0 4000.0 4500.0 5000.0 6000.0 6500.0 7000.0 9990.0 8000.0 8500.0 9000.0 9000.0 9500.0 9500.0 10000.0 10000.0 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 0.50 0.50 0.50 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 Changzhou zhide Electronics CO.,LTD Maximum Reverse Leakage Current IR(uA)@V Maximum DC Zener Current VR(V) IZM(mA) 1.0 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 7.6 8.4 9.1 9.9 11.4 12.2 13.7 15.2 16.7 18.2 20.6 22.8 25.1 27.4 29.7 32.7 35.8 38.8 42.6 47.1 51.7 56.0 62.2 69.2 76.0 83.6 91.2 98.8 114.0 121.6 136.8 152.0 167.2 182.4 190.0 205.0 228.0 250.2 275.0 300.0 288.0 274.0 251.0 232.0 210.0 192.0 177.0 161.0 146.0 133.0 121.0 110.0 100.0 91.0 83.0 76.0 69.0 61.0 57.0 50.0 45.0 41.0 38.0 34.0 30.0 27.0 25.0 23.0 22.0 19.0 18.0 16.0 14.0 13.0 12.0 11.0 10.0 9.0 8.6 7.8 7.0 6.4 5.8 5.2 4.7 4.0 3.8 3.6 3.3 3.0 2.7 2.5 2.2 R 100.0 100.0 100.0 50.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 www.cz-zhide.com
SMA4734A 价格&库存
很抱歉,暂时无法提供与“SMA4734A”相匹配的价格&库存,您可以联系我们找货
SMA4734A
  • 10+0.43546
  • 100+0.34917
  • 300+0.30608
  • 1000+0.27368
  • 5000+0.24776
  • 10000+0.23480
库存:4505
