HoRS1206-1/4W-910mR-1%
    MILLIOHM(毫欧)
    陶瓷电阻 910mΩ ±1% 250mW
HoRS1206-1/4W-910mR-1% 数据手册
系列号 修订日期 HoRS贴片陶瓷系列规格书 版本号 HoRS 2020-03-06 Ho-A0 ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -Low inductance -Highly reliable multilayer electrode construction -Higher component and equipment reliability -Reduced size of final equipment reliability -RoHS Compliance ■Construction ■Applications -Power Management Applications L -Switching Power Supply D1 -Over Current Protection in Audio Application -Voltage Regulation Module (VRM) W 3 4 5 6 T -DC-DC Converter, Battery Pack, Charger, Adaptor -Automotive Engine Control -Disk Driver 9 8 7 1 2 D2 1 Alumina Substrate 4 Edge Electrode 7 Resistor Layer 2 Bottom Electrode 5 Barrier Layer 8 Primary Overcoat 3 Top Electrode 6 External Electrode 9 Secondary Overcoat ■Dimensions L W T D1 D2 (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) Type Size (Inch) RS-02 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 RS-03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 RS-05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 RS-06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 RS-10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 RS-0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 RS-12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 地址:深圳市龙华新区观澜大布头路南通邦高新产业园 A 栋 8 楼 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS 修订日期 HoRS贴片陶瓷系列规格书 2020-03-06 Ho-A0 版本号 ■Part Numbering RS- 03 F Product Type Dimensions Resistance Tolerance F: ±1% J: ±5% RS 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 L 7 Function Code L: Standard P: High Power Packaging Code 4: 7” Reel 4Kpcs 6: 7” Reel 10Kpcs 7: 7” Reel 5Kpcs 9: 10” Reel 8Kpcs A: 10” Reel 10Kpcs B: 10” Reel 20Kpcs C: 13” Reel 40Kpcs D: 13” Reel 20Kpcs F: Bulk 0 R 0 4 7 Resistance - 0R047: 0.047Ω - - - 0R1: 0.1Ω “-“ to fill up 6 spaces ■Derating Curve . ■Recommend Land Pattern - 100 B Power ratio(%) C A Type A (mm) B (mm) C (mm) RS-02 0.50 0.45 0.60 RS-03 0.90 0.60 0.90 RS-05 1.20 0.70 1.30 RS-06 2.00 0.90 1.60 RS-10 2.00 0.90 2.80 RS-0A 3.80 0.90 2.80 RS-12 3.80 1.60 3.50 80 60 40 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature(℃) ■Soldering Condition IR Reflow Soldering Wave Soldering (Flow Soldering) (1) Time of IR reflow soldering at maximum temperature point 260°C:10s (2) Time of wave soldering at maximum temperature point 260°C:10s (3) Time of soldering iron at maximum temperature point 410°C:5s 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 180 系列号 修订日期 HoRS贴片陶瓷系列规格书 版本号 HoRS 2020-03-06 Ho-A0 ■Standard Electrical Specifications Item Power Rating at 70°C Operating Temp. Max. Operating Range Current Type Resistance Range (mΩ) ±1% TCR (PPM/°C) ±5% RS-02 (0402) 1/16W -55 ~ +155°C 1.11A 50 - 91 100 - 976 ±800 ±500 RS-03 (0603) 1/10W -55 ~ +155°C 2.23A 20 - 47 50 - 91 100 - 976 ±1200 ±800 ±500 RS-05 (0805) 1/8W -55 ~ +155°C 3.53A RS-06 (1206) 1/4W -55 ~ +155°C 5.00A 10 - 18 20 - 47 50 - 91 100 - 976 ±1500 ±1200 ±800 ±500 RS-10 (1210) 1/3W -55 ~ +155°C 5.77A RS-0A (2010) 3/4W -55 ~ +155°C 8.66A 10 - 18 20 - 91 100 - 976 ±1500 ±800 ±500 RS-12 (2512) 1W -55 ~ +155°C 10.0A Operating Voltage=√(P*R) ; Overload Voltage=2.5*√(P*R) ■High Power Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Max. Operating Range Current Resistance Range (mΩ) ±1% TCR (PPM/°C) ±5% RS-02 (0402) 1/10W -55 ~ +155°C 1.40A 50 - 91 100 - 976 ±800 ±500 RS-03 (0603) 1/8W -55 ~ +155°C 2.50A 20 - 47 50 - 91 100 - 976 ±1200 ±800 ±500 RS-05 (0805) 1/4W -55 ~ +155°C 5.00A RS-06 (1206) 1/2W -55 ~ +155°C 7.07A 10 - 18 20 - 47 50 - 91 100 - 976 ±1500 ±1200 ±800 ±500 RS-10 (1210) 1/2W -55 ~ +155°C 7.07A RS-0A(2010) 1W -55 ~ +155°C 10.0A 10 - 18 20 - 91 100 - 976 ±1500 ±800 ±500 RS-12 (2512) 2W -55 ~ +155°C 14.1A Operating Voltage=√(P*R) Overload Voltage=2.5*√(P*R) Operating Current=√(P/R) 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS贴片陶瓷系列规格书 修订日期 版本号 HoRS 2020-03-06 Ho-A0 ■Environmental Characteristics Requirement Item Temperature Coefficient of Resistance (T.C.R.) Short Time Overload Insulation Resistance Test Method ±5% ±1% JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. -55°C~+125°C, 25°C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 ±(1.0%+0.05Ω) ±(2.0%+0.05Ω) RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds, 2 seconds for High Power Series JIS-C-5201-1 4.6 IEC-60115-1 4.6 ≥10G Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 Endurance ±(1.0%+0.10Ω) ±(2.0%+0.10Ω) Damp Heat with Load ±(1.0%+0.10Ω) ±(2.0%+0.10Ω) Dry Heat ±(1.0%+0.05Ω) ±(1.5%+0.10Ω) 70±2°C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 40±2°C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155°C for 1000 hrs JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending Strength ±(1.0%+0.05Ω) Solderability 95% min. coverage Resistance to Soldering Heat ±(0.5%+0.05Ω) Voltage Proof ±(1.0%+0.05Ω) ±(1.0%+0.05Ω) No breakdown or flashover Bending once for 5 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 245±5°C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 260±5°C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 1.42 times Max. Operating Voltage for 1 minute Leaching Rapid Change of Temperature Individual leaching area ≦5% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Total leaching area ≦ 10% 260±5°C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55°C to +155°C, 5 cycles ±(0.5%+0.05Ω) ±(1.0%+0.05Ω) RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS 修订日期 HoRS贴片陶瓷系列规格书 2020-03-06 Ho-A0 版本号 ▓Packaging Reel Specifications & Packaging Quantity Type RS-02 Packaging Quantity Paper RS-03 RS-05 RS-06 Paper RS-10 RS-0A RS-12 Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 20K 8mm 13 inch 330±1.0 4K 12mm 7 inch 178.5±1.5 8K 12mm 10 inch 250±1.0 Bottom Tape Top Tape ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 60 60 60 +1/-0 +1/-0 Embossed Paper Tape Specifications ψ D0 E A F W B T Paper Tape Type A (mm) B (mm) W (mm) P1 Resistor E (mm) F (mm) P0 (mm) P2 P0 P1 (mm) Direction of unreeling P2 (mm) ΦD0 (mm) T (mm) RS-02 0.65±0.10 1.15±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 RS-03 1.10±0.10 1.90±0.10 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 RS-05 1.60±0.10 2.40±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS-06 1.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS-10 2.90±0.10 3.50±0.20 8.0±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn 系列号 HoRS 修订日期 HoRS贴片陶瓷系列规格书 2020-03-06 Ho-A0 版本号 Embossed Plastic Tape Specifications Top Tape ψ D0 E A F B W ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) P2 (mm) ΦD0 (mm) T (mm) RS-0A 2.8±0.10 5.5±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 RS-12 3.5±0.10 6.7±0.10 12.0±0.30 1.75±0.10 5.5±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 ■Marking No Marking for 0402 1%, 5% for 0805/1206/1210/2010/2512: 4 digits marking Example: Resistance Marking 47mΩ R047 75mΩ R075 15mΩ R015 750mΩ R750 820mΩ R820 5% for 0603: 3 digits marking in E24 1% for 0603: 3 digits marking with under-line in E96 (non-including E24 series) R10 3 digits marking for E24 or R value suffix is zero in E96: R10=100mΩ; R28=280mΩ 243 3 digits marking for E96: 243=243mΩ; 511=511mΩ 深圳市毫欧电子有限公司 | 电话: 0755-28153546 | 传真: 0755-22630181 | 网址: www.moolee.com.cn
HoRS1206-1/4W-910mR-1% 价格&库存
很抱歉,暂时无法提供与“HoRS1206-1/4W-910mR-1%”相匹配的价格&库存,您可以联系我们找货
