MBR20100CT-FCT-DC-CS
SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 100 V
Forward Current - 20 A
FEATURES
Low forward voltage
High current capability
High forward surge capability
Low power losses,High efficiency
Guarding for over voltage protection
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: TO-220AB/CT TO-220F/FCT TO-263/DC TO-252/CS
Solder bath temperature275℃maximum,10s per JESD22-106
Primary Characteristic
Io
2*10A
VRRM
100V
IFSM
250A
VF
0.68V
TJ Max
150°C
Maximum Ratings (Per Leg) at Ta=25°C unless otherwise specified
Symbols
Value
Units
Maximum Repetitive Peak Reverse Voltage
Parameter
VRRM
100
V
Maximum RMS voltage
VRMS
100
V
Maximum DC Blocking Voltage
VDC
100
V
Per Leg
Maximum Average Forward Rectified Current
Total
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
IFSM
Operating Temperature Range
Storage Temperature Range
Typical Thermal Resistance (Note1)
TO-220AB,TO-263 TO-220F TO252
10
Io
A
A
TJ
-55 ~ +150
°C
TSTG
-55 ~ +150
°C
RθJA/ RθJC
2/4
°C/W
Value
Units
Note1: Thermal resistance from Junction to case per leg mounted on heatsink.
Electrical Characteristics (Per Leg) unless otherwise specified
Characteristics
Symbols
Forward Voltage Drop(Note2)
at IF=3A
at IF=5A
at IF=10A
Maximum Reverse Current at VR=100 V
TA=25°C
TA=125°C
TA=25°C
VF
Typ
Max
0.69
0.60
0.74
V
TA=125°C
0.61
TA=25°C
0.82
0.85
TA=125°C
0.68
TA=25°C
1.5
10
uA
1
mA
TA=125°C
IR
Note2:Pulse test: 300 μs pulse width, 1 % duty cycle
www.yfwdiode.com
1/4
Dongguan YFW Electronics Co, Ltd.
RATINGS AND CHARACTERISTIC CURVES
FIG. 2 MAXIMUM NON-REPETITIVE
FORWARD SURGE CURRENT PER LEG
FIG.1 MAXIMUM FORWARD CURRENT DERATING
CURVE
400
350
PEAK FORWARD SURGE CURRENT(A)
AVERAGE FORWARD CURRENT (A)
15
10
5
300
8.3ms Single Half Sine Wave
JEDEC Method
250
200
150
100
50
50
75
100
125
150
1
175
10
FIG. 3 TYPICAL FORWARD CHARACTERISTICS
PER LEG
FIG. 4 TYPICAL REVERSE CHARACTERISTICS PER LEG
100000
10000
REVERSE LEAKAGE CURRENT(uA)
INSTANTANEOUS FORWARD CURRENT (A)
50
TA=125℃
5
TA=25℃
0.5
0.1
0.3
0.5
0.7
100
NUMBER OF CYCLES AT 60 Hz
AMBIENT TEMPERATURE (℃)
TA=125℃
1000
100
10
1
TA=25℃
0.1
10
40
50
60
70
80
90
100
PERCENT OF VBR(V)
FORWARD VOLTAGE (V)
Marking on the body
Ordering information
Part Number
Package
Unit Weight
Base Quantity
Delivery mode
MBR20100CT
TO-220AB
0.07oz(1.96g)
50 pcs / tube
1000pcs/box 5000pcs/carton
MBR20100FCT
TO-220F
0.06oz(1.74g)
50 pcs / tube
MBR20100DC
TO-263
0.04oz(1.16g)
50 pcs / tube
MBR20100DC-R
O-263
0.04oz(1.16g)
800 pcs / reel
800pcs/box4000pcs/carton
MBR20100CS
TO-252
0.011oz(0.32g)
2500 pcs / reel
2500pcs/box 12500pcs/carton
Note: For Halogen Free molding compound, add "H" suffix to part number above.
www.yfwdiode.com
2/4
Package Outline Dimensions millimeters
www.yfwdiode.com
3/4
www.yfwdiode.com
4/4
很抱歉,暂时无法提供与“MBR20100CS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.62749
- 50+1.31308
- 500+1.01023
- 1000+0.99508
- 2500+0.93538
- 国内价格
- 5+1.79356
- 50+1.44707
- 150+1.29862
- 500+1.11332
- 2500+1.03083
- 5000+0.98127
