SS18
SS18
    YFW(佑风微)
    SMA(DO-214AC)
    电压:80V 电流:1A
SS18 数据手册
SS12 THRU SS120 SMA Surface Mount Schottky Barrier Rectifier Pinning Reverse Voltage - 20 to 200 V 1.Cathode Forward Current - 1 A 2.Anode         1 FEATURES  Metal silicon junction, majority carrier conduction  For surface mounted applications  Low power loss, high efficiency   2     DO-214AC/SMA  High forward surge current capability Marking Code  For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications SS12 SS12 SS14 SS14  Lead free in comply with EU RoHS 2011/65/EU directives SS16 SS16 MECHANICAL DATA  Case: DO-214AC/SMA  Terminals: Solderable per MIL-STD-750, Method 2026 SS18 SS18 SS110 SS110 SS112 SS112 SS115 SS115 SS120 SS120  Approx. Weight: 0.07g / 0.002oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS12 SS14 SS16 SS18 SS110 SS112 SS115 SS120 Units Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method) IFSM Maximum Instantaneous Forward Voltage at 1 A VF Maximum Instantaneous Reverse Current TA = 25°C at Rated DC Reverse Voltage TA = 100°C IR Typical Junction Capacitance(1) Cj Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range 1.0 A 40 0.55 30 0.70 0.3 10 110 A 0.85 0.90 0.2 5 0.1 2 80 V mA pF RθJA 90 °C/W Tj -55 ~ +150 °C Tstg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. SS12 THRU SS120 SMA Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 10 4 T J =75°C 10 2 SS12/SS14 SS16-SS120 10 1 T J =25°C 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance 500 Junction Capacitance ( pF) 20 10 1.0 SS12/SS14 SS16/SS18 SS110/SS112 SS115/SS120 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 T J =25°C 200 100 50 SS12/SS14 20 SS16-SS120 10 1.8 0.1 Transient Thermal Impedance( °C /W) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 36 30 24 18 12 06 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz www.yfwdiode.com 1 100 10 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Instaneous Forward Current (A) T J =100°C 10 3 Fig.6- Typical Transient Thermal Impedance 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 Dongguan YFW Electronics Co, Ltd. SS12 THRU SS120 SMA DO-214AC SMA Package Outline A A Plastic surface mounted package; 2 leads c a VM e A HE g e E A D E HE c e g max 2. 42 4.5 2. 80 5.2 0.31 1.6 1.5 min . 1.98 4.0 2. 54 4.7 0.15 1.3 0.9 max 96 181 1 10 205 12 63 59 min 78 157 100 185 6 51 35 UNIT mm mil g e A D a 0.3 12 The recommended mounting pad size 2.4 (94) 1.8 (71) 1.8 (71) 1.8 (71) mm Unit : (mil) Summary of Packing Options Package DO-214AC SMA www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,11”reel 5000 EIA-481-1 Tape/Reel,7”reel 2000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
很抱歉,暂时无法提供与“SS18”相匹配的价格&库存,您可以联系我们找货
