Approval sheet
WF12H, WF08H, WF06H, WF04H
±0.5%, ±0.1%
Thick film high precision chip resistors
Size 1206, 0805, 0603, 0402
*Contents in this sheet are subject to change without prior notice.
Page 1 of 6
ASC_WFxxH_V02
Sep - 2011
Approval sheet
FEATURE
1. Small size and light weight
2. High reliability and stability
3. Reduced size of final equipment
4. High precision
5. Higher component and equipment reliability
6. RoHS compliant & Lead free products.
APPLICATION
Power supply
PDA
Digital meter
Computer
Palmtop computers
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are
added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The
composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to
nominated value within tolerance which controlled by laser trimming of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For
ease of soldering the outer layer of these end terminations is a Tin (lead free) alloy.
Fig 1. Construction of Chip-R
Page 2 of 6
ASC_WFxxH_V02
Sep - 2011
Approval sheet
QUICK REFERENCE DATA
Item
General Specification
Series No.
WF12H
WF08H
WF06H
WF04H
Size code
1206 (3216)
0805 (2125)
0603 (1608)
0402 (1005)
Resistance Range
10Ω ~ 1MΩ ( E96+E24 series)
±0.5%, ±0.1%
Resistance Tolerance
TCR (ppm/°C) 10Ω≤ R ≤ 1MΩ
≤ ± 100 ppm/°C
Max. dissipation at Tamb=70°C
1/4 W
1/8 W
1/10 W
1/16W
Max. Operation Voltage (DC or RMS)
200V
150V
50V
50V
Max. overload voltage (DC or RMS)
400V
300V
100V
100V
Climatic category
55/155/56
Note :
1.
This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication
60115-8”
2.
Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
3.
Non E96 series resistance upon requested.
DIMENSIONS(unit : mm)
Part No
WF12H
WF08H
WF06H
WF04H
L
3.10 ± 0.1
2.0 ± 0.10
1.60 ± 0.10
1.00±0.05
W
1.60 ± 0.1
1.25 ± 0.10
0.80 ± 0.10
0.50±0.05
Tt
0.50 ± 0.2
0.40 ± 0.20
0.30 ± 0.10
0.20±0.10
Tb
0.45 ± 0.2
0.40 ± 0.20
0.30 ± 0.20
0.25±0.10
T
0.65 ± 0.15
0.5 ± 0.15
0.45 ± 0.15
0.35±0.05
MARKING
3-digits marking for 0603 size
WFxxH has same marking rule as WRxx ±1%.
4-digits marking for 1206, 0805 size
Each resistor is marked with a four digits code on the protective coating to designate the nominal resistance
value. For values below 97Ω6 the R is used as a digit. For values of 100Ω or greater, the first 3 digits are
significant, the fourth digit indicates the number of multiple to follow.
Example
RESISTANCE
10Ω
12Ω
100Ω
6800Ω
47000Ω
4-digits marking
10R0
12R0
1000
6801
4702
No marking code for 0402 size
Page 3 of 6
ASC_WFxxH_V02
Sep - 2011
Approval sheet
FUNCTIONAL DESCRIPTION
Product characterization
Standard values of nominal resistance are taken from the E96 & E24 series for resistors with a tolerance of
±0.5%, ±0.1%. The values of the E24/E96 series are in accordance with “IEC publication 60063”.
Derating
The power that the resistor can dissipate depends on the operating temperature; see Fig.2
Figure 2. Maximum dissipation in percentage of rated power
As a function of the ambient temperature
SOLDERING CONDITION
The robust construction of chip resistors allows
them to be completely immersed in a solder bath
of 260°C for 10 seconds. Therefore, it is possible
to mount Surface Mount Resistors on one side of
a PCB and other discrete components on the
reverse (mixed PCBs).
Surface Mount Resistors are tested for
solderability at 235°C during 2 seconds. The test
condition for no leaching is 260°C for 30 seconds.
Typical examples of soldering processes that
provide reliable joints without any damage are
given in Fig 3.
Fig 3. Infrared soldering profile for Chip Resistors
CATALOGUE NUMBERS
The resistors have a catalogue number starting with :
WF06
H
3742
D
T
L
Size code
Type code
Resistance code
Tolerance
Packaging code
Termination code
WF12
: 1206
E96+E24:
D : ±0.5%
T
WF08
: 0805
H : High precision,
50ppm
B : ±0.1%
WF06
: 0603
3 significant digits followed
by no. of zeros
L = Sn base (lead
free)
WF04
: 0402
Reeled tape packaging
0402.
Page 4 of 6
102Ω
37.4KΩ
220Ω
: 7” Reeled taping
=1020
=3742
=2200
: 8mm width paper taping 5000pcs per 7” reel for 1206/0805/0603, 10000pcs per 7” reel for
ASC_WFxxH_V02
Sep - 2011
Approval sheet
TEST AND REQUIREMENTS(JIS C 5201-1 : 1998)
TEST
PROCEDURE
DC resistance
DC resistance values measured at the test voltages specified below :
Clause 4.5
很抱歉,暂时无法提供与“WF06H8661BTL”相匹配的价格&库存,您可以联系我们找货
