电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
WF06H4221BTL
WF06H4221BTL
    WALSIN(华新科)
WF06H4221BTL 数据手册
Approval sheet WF12H, WF08H, WF06H, WF04H ±0.5%, ±0.1% Thick film high precision chip resistors Size 1206, 0805, 0603, 0402 *Contents in this sheet are subject to change without prior notice. Page 1 of 6 ASC_WFxxH_V02 Sep - 2011 Approval sheet FEATURE 1. Small size and light weight 2. High reliability and stability 3. Reduced size of final equipment 4. High precision 5. Higher component and equipment reliability 6. RoHS compliant & Lead free products. APPLICATION • Power supply • PDA • Digital meter • Computer • Palmtop computers DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to nominated value within tolerance which controlled by laser trimming of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a Tin (lead free) alloy. Fig 1. Construction of Chip-R Page 2 of 6 ASC_WFxxH_V02 Sep - 2011 Approval sheet QUICK REFERENCE DATA Item General Specification Series No. WF12H WF08H WF06H WF04H Size code 1206 (3216) 0805 (2125) 0603 (1608) 0402 (1005) Resistance Range 10Ω ~ 1MΩ ( E96+E24 series) ±0.5%, ±0.1% Resistance Tolerance TCR (ppm/°C) 10Ω≤ R ≤ 1MΩ ≤ ± 100 ppm/°C Max. dissipation at Tamb=70°C 1/4 W 1/8 W 1/10 W 1/16W Max. Operation Voltage (DC or RMS) 200V 150V 50V 50V Max. overload voltage (DC or RMS) 400V 300V 100V 100V Climatic category 55/155/56 Note : 1. This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower. 3. Non E96 series resistance upon requested. DIMENSIONS(unit : mm) Part No WF12H WF08H WF06H WF04H L 3.10 ± 0.1 2.0 ± 0.10 1.60 ± 0.10 1.00±0.05 W 1.60 ± 0.1 1.25 ± 0.10 0.80 ± 0.10 0.50±0.05 Tt 0.50 ± 0.2 0.40 ± 0.20 0.30 ± 0.10 0.20±0.10 Tb 0.45 ± 0.2 0.40 ± 0.20 0.30 ± 0.20 0.25±0.10 T 0.65 ± 0.15 0.5 ± 0.15 0.45 ± 0.15 0.35±0.05 MARKING  3-digits marking for 0603 size WFxxH has same marking rule as WRxx ±1%.  4-digits marking for 1206, 0805 size Each resistor is marked with a four digits code on the protective coating to designate the nominal resistance value. For values below 97Ω6 the R is used as a digit. For values of 100Ω or greater, the first 3 digits are significant, the fourth digit indicates the number of multiple to follow. Example  RESISTANCE 10Ω 12Ω 100Ω 6800Ω 47000Ω 4-digits marking 10R0 12R0 1000 6801 4702 No marking code for 0402 size Page 3 of 6 ASC_WFxxH_V02 Sep - 2011 Approval sheet FUNCTIONAL DESCRIPTION Product characterization Standard values of nominal resistance are taken from the E96 & E24 series for resistors with a tolerance of ±0.5%, ±0.1%. The values of the E24/E96 series are in accordance with “IEC publication 60063”. Derating The power that the resistor can dissipate depends on the operating temperature; see Fig.2 Figure 2. Maximum dissipation in percentage of rated power As a function of the ambient temperature SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 3. Fig 3. Infrared soldering profile for Chip Resistors CATALOGUE NUMBERS The resistors have a catalogue number starting with : WF06 H 3742 D T L Size code Type code Resistance code Tolerance Packaging code Termination code WF12 : 1206 E96+E24: D : ±0.5% T WF08 : 0805 H : High precision, 50ppm B : ±0.1% WF06 : 0603 3 significant digits followed by no. of zeros L = Sn base (lead free) WF04 : 0402  Reeled tape packaging 0402. Page 4 of 6 102Ω 37.4KΩ 220Ω : 7” Reeled taping =1020 =3742 =2200 : 8mm width paper taping 5000pcs per 7” reel for 1206/0805/0603, 10000pcs per 7” reel for ASC_WFxxH_V02 Sep - 2011 Approval sheet TEST AND REQUIREMENTS(JIS C 5201-1 : 1998) TEST PROCEDURE DC resistance DC resistance values measured at the test voltages specified below : Clause 4.5
WF06H4221BTL 价格&库存
很抱歉,暂时无法提供与“WF06H4221BTL”相匹配的价格&库存,您可以联系我们找货
