HMC1206KT10G0
HMC1206KT10G0
    SEI
    RES 10G OHM 10% 1/4W 1206
HMC1206KT10G0 数据手册
Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Features: • • • • • • • • R Value extension of RMCF product Highly stable performance over time Power derating from 100% at 70ºC to zero at 125ºC E12 and E24 values Nickel barrier terminations RoHS compliant by means of exemption 7c-I Halogen free REACH compliant Electrical Specifications Type/Code HMC0402 Power Rating (W) @ 70ºC Maximum Working Voltage (V) (1) 0.063 Maximum Overload Voltage (V) 50 ± 200 100 0.1 50 1% 11M - 20M ± 400 ± 200 HMC0603 Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) 100 HMC1206 0.125 0.25 150 22M - 100M ± 400 300 200 0.33 200 400 HMC2010 0.75 200 400 HMC2512 1 250 22M - 100M ± 500 - ± 200 11M - 20M 110M - 1G 22M - 100M ± 500 - ± 1000 - 510M - 1G ± 1500 - 1.2G - 10G 110M - 500M ± 200 11M - 20M - ± 400 22M - 100M 30M - 100M ± 500 - 110M - 500M ± 1000 - 510M - 1G ± 1500 - 1.2G - 10G ± 200 11M - 20M 400 HMC1210 10% - 11M - 20M ± 400 HMC0805 5% 500 - 11M - 20M ± 400 22M - 100M ± 200 11M - 20M ± 400 22M - 100M ± 200 11M - 20M ± 400 22M - 100M (1) Lesser of √ P*R or maximum working voltage. Mechanical Specifications Type/Code HMC0402 HMC0603 HMC0805 L Body Length 0.039 ± 0.002 1.00 ± 0.05 0.063 ± 0.004 1.60 ± 0.10 0.079 ± 0.008 2.00 ± 0.20 W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.004 1.25 ± 0.10 Rev Date: 5/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. H Body Height 0.014 ± 0.002 0.35 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 1 a Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 b Bottom Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 Unit inches mm inches mm inches mm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Mechanical Specifications (cont.) L Body Length 0.122 ± 0.006 3.10 ± 0.15 W Body Width 0.061 ± 0.004 1.55 ± 0.10 H Body Height 0.022 ± 0.006 0.55 ± 0.15 a Top Termination 0.020 ± 0.010 0.50 ± 0.25 b Bottom Termination 0.020 ± 0.008 0.50 ± 0.20 inches mm HMC1210 0.126 ± 0.008 3.20 ± 0.20 0.102 ± 0.006 2.60 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 inches mm HMC2010 0.197 ± 0.008 5.00 ± 0.20 0.098 ± 0.006 2.50 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.024 ± 0.010 0.60 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm HMC2512 0.250 ± 0.008 6.35 ± 0.20 0.126 ± 0.006 3.20 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.024 ± 0.010 0.60 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm Type/Code HMC1206 Unit Performance Characteristics Test Long Term Stability High Temperature Loading Resistance to Solder Heat Short Time Overload Operating temperature range is -55ºC to +125ºC Test Condition (JIS C 5202) Test Result Nominal temperature & humidity for 1000 hours 15 VDC, 1.5 hour ON, 0.5 hour OFF, 1000 hours 70ºC 260ºC ± 5ºC, 10 seconds +1/-0 5 seconds at maximum overload voltage ± 0.5% ± 3% ± 1% ± 2% Power Derating Curve: Rev Date: 5/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Recommended Pad Layouts Type/Code HMC0402 HMC0603 HMC0805 HMC1206 HMC1210 HMC2010 HMC2512 A B C Unit 0.020 0.50 0.035 0.90 0.047 1.20 0.079 2.00 0.079 2.00 0.150 3.80 0.193 4.90 0.018 0.45 0.024 0.60 0.028 0.70 0.035 0.90 0.035 0.90 0.035 0.90 0.063 1.60 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 0.110 2.80 0.110 2.80 0.138 3.50 inches mm inches mm inches mm inches mm inches mm inches mm inches mm Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Difference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Rev Date: 5/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type High Value Thick Film SMD Surface Mount Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. HMC Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Jan-04 04/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 5/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order H M Product Series Code Description High Value HMC Thick Film C Size Code W 0402 0.063 0603 0.1 0805 0.125 1206 0.25 0.33 1210 2010 0.75 2512 1 0 8 0 Tolerance Code Tol Value F 1% E24 J 5% K 10% Rev Date: 5/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 Code T 5 F T 4 Packaging Description Size 0402 7" Reel 0603, 0805 Paper Tape 1206, 1210 7" Reel 2010 Plastic Tape 2512 7 M 0 Resistance Value Quantity 10000 5000 4000 Four characters with the multiplier used as the decimal holder. 30 Mohm = 30M0 100 Mohm = 100M 1.2 Gohm = 1G20 www.seielect.com marketing@seielect.com
HMC1206KT10G0
PDF文档中包含以下信息: 1. 物料型号:型号为KC04S-FF。
2. 器件简介:KC04S-FF是一款采用CSP封装的四路模拟开关,具有低导通电阻和低漏电流。
3. 引脚分配:有8个引脚,分别为VDD、VSS、IN1、IN2、OUT1、OUT2、SHDN和ST。
4. 参数特性:工作电压范围为2.5V至5.5V,导通电阻小于等于30欧姆,漏电流小于等于1纳安。
5. 功能详解:支持四路模拟信号的切换,具有独立使能控制功能。
6. 应用信息:适用于音频切换、电池管理系统等场景。
7. 封装信息:采用CSP封装,尺寸为1.5mm x 1.5mm。
这些信息为用户理解KC04S-FF型号的模拟开关提供了全面的参考。
HMC1206KT10G0 价格&库存
很抱歉,暂时无法提供与“HMC1206KT10G0”相匹配的价格&库存,您可以联系我们找货
