RPC1206JT13K0-UP
RPC1206JT13K0-UP
    SEI
    RES, PULSE, 1206, 5%, 13 KOHM, 0
RPC1206JT13K0-UP 数据手册
RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • • • Excellent pulse withstanding performance Broad resistance range Higher anti-surge performance compared with RMCF Series Standard power RPC, 5% and wider tolerances, are untrimmed 1% and wider tolerances are qualified to AEC-Q200 RoHS compliant and halogen free REACH compliant Lower values may be available – contact Stackpole Electrical Specifications Power Rating (W) @ 70ºC Type/Code Maximum Working Voltage (V) Maximum Overload Voltage (V) Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) ±300 RPC0402 0.2 50 100 ±100 ±200 RPC0603 0.1 50 100 ±100 ±200 RPC0805 0.25 150 300 ±100 ±200 RPC1206 0.33 200 400 ±100 ±200 RPC1210 0.5 200 400 ±100 ±200 RPC2010 0.75 400 800 ±100 ±200 RPC2512 1.5 500 1000 ±100 Working Voltage = √(P*R) or Max. Working Voltage listed above, whichever is lower. Overload Voltage = 2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. 0.5% 100 - 1M 10 - 294 1% 1 - 19.6 20 - 1M 1 - 294 300 - 1M 1 - 294 10 - 294 5%, 10%, 20% 1 - 20 22 - 1M 10 - 270 1 - 270 300 - 20M 300 - 1M 10 - 20 1 - 20 20.5 - 20M 22 - 20M 10 - 20 1 - 20 20.5 - 20M 22 - 20M 10 - 20 1 - 20 20.5 - 20M 22 - 20M 10 - 20 1 - 20 20.5 - 20M 22 - 20M Electrical Specifications – High Power (HP) Power Rating (W) @ 70ºC Type/Code Maximum Working Voltage (V) Maximum Overload Voltage (V) RPC0603_-HP 0.25 75 150 RPC0805_-HP 0.4 150 300 RPC1206_-HP 0.5 200 400 RPC1210_-HP 0.75 RPC2010_-HP RPC2512_-HP (*) 1 2 200 400 500 Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±200 ±100 ±350 ±100 400 800 1000 0.5% 10 - 294 10 - 294 1% 1 - 294 300 - 1M 1 - 294 300 - 1M 10 - 20 5% 10 - 270 1 - 270 1 - 20 20.5 - 1M 22 - 1M 1 - 20 10 - 20 20.5 - 1M 22 - 1M 1 - 20 10 - 20 20.5 - 1M 22 - 1M 1 - 10 10 10.5 - 200K (*) Double-sided printed resistor element. Working Voltage = √(P*R) or Max. Working Voltage listed above, whichever is lower. Overload Voltage = 2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Electrical Specifications – Ultra High Power (UP) 0.33 Maximum Working Voltage (V) 75 Maximum Overload Voltage (V) 150 RPC0805_-UP 0.5 400 600 RPC1206_-UP 0.75 500 1000 Type/Code Power Rating (W) @ 70ºC RPC0603_-UP Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) 0.5% ±100 ±200 ±100 ±200 ±100 ± 100 1% 5% 300 - 1M 1 - 270 10 - 1M 10 - 294 RPC1210_-UP 1 200 400 Ultra High Power: double side printed resistor element. Working Voltage = √(P*R) or Max. Working Voltage listed above, whichever is lower. Overload Voltage = 2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. 1 - 294 300 - 1M 10 - 20 1 - 20 20.5 - 1M 10 - 1M 22 - 1M 22 - 1M Electrical Specifications – Ultra High Power Jumper Jumper Rated Current (A) RPC0603_-UP 5 RPC0805_-UP 6 RPC1206_-UP 10 Ultra High Power: double side printed resistor element. Type/Code Max. Resistance 0 Ω (≤ 8 mΩ) 0 Ω (≤ 5 mΩ) Mechanical Specifications Type/Code Weight (g) (1000 pcs) RPC0402 0.64 RPC0603 2.042 RPC0805 (-HP) 4.368 RPC0805 (-UP) 5.049 RPC1206 (-HP) 8.947 RPC1206 (-UP) 9.541 RPC1210 15.959 RPC2010 (-HP) 24.241 RPC2512 39.448 RPC2512 (-HP) 42 L Body Length 0.039 ± 0.002 1.00 ± 0.05 0.063 ± 0.004 1.60 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.122 ± 0.004 3.10 ± 0.10 0.122 ± 0.004 3.10 ± 0.10 0.122 ± 0.004 3.10 ± 0.10 0.197 ± 0.004 5.00 ± 0.10 0.250 ± 0.004 6.35 ± 0.10 0.250 ± 0.008 6.35 ± 0.20 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.004 1.25 ± 0.10 0.049 ± 0.004 1.25 ± 0.10 0.061 ± 0.004 1.55 ± 0.10 0.061 ± 0.004 1.55 ± 0.10 0.102 ± 0.006 2.60 ± 0.15 0.098 ± 0.006 2.50 ± 0.15 0.122 ± 0.006 3.10 ± 0.15 0.124 ± 0.006 3.15 ± 0.15 2 H Body Height 0.014 ± 0.002 0.35 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.024 ± 0.004 0.60 ± 0.10 D1 Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.008 0.35 ± 0.20 0.014 ± 0.008 0.35 ± 0.20 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 D2 Bottom Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Performance Characteristics Item Test Method Test Specification Temperature Coefficient of Resistance (T.C.R.) JIS-C-5201-1 4.8 IEC-60115-1 4.8 Within the specified tolerance Short Time Overload JIS-C-5201-1 4.13 IEC-60115-1 4.13 ± (1% + 0.05Ω) Test Condition At 25°C / -55°C and 25°C / + 125°C, 25°C is the reference temperature RCWV * 2.5 or max. overload voltage whichever is lower for 5 seconds Jumper: 2*Imax for 5 seconds JIS-C-5201-1 4.6 ≥ 10G Max. overload voltage for 1 minute IEC-60115-1 4.6 Endurance JIS-C-5201-1 4.25 70ºC ± 2°C, RCWV for 1000 hours ± (1% + 0.05Ω) Tolerances of 0.5%, 1% IEC-60115-1 4.25.1 with 1.5 hours "ON" and 0.5 hour "OFF" Endurance JIS-C-5201-1 4.25 70ºC ± 2°C, RCWV for 1000 hours ± (3% + 0.05Ω) Tolerances of 5%, 10%, 20% IEC-60115-1 4.25.1 with 1.5 hours "ON" and 0.5 hour "OFF" Damp Heat with Load JIS-C-5201-1 4.24 40ºC ± 2°C, 90~95% R.H, RCWV for 1000 hour ± (0.5% + 0.05Ω) Tolerances of 0.5%, 1% IEC-60115-1 4.24 with 1.5 hours "ON" and 0.5 hour "OFF" Damp Heat with Load JIS-C-5201-1 4.24 ± (3% + 0.05Ω) 40ºC ± 2°C, 90~95% R.H, RCWV for 1000 hours Tolerances of 5%, 10%, 20% IEC-60115-1 4.24 with 1.5 hours "ON" and 0.5 hour "OFF" Damp Heat with Load JIS-C-5201-1 4.24 ± (1% + 0.05Ω) Ultra High Power IEC-60115-1 4.24 Dry Heat JIS-C-5201-1 4.23 ± (0.5% + 0.05Ω) At +155°C for 1000 hours Tolerances of 0.5%, 1% IEC-60115-1 2.23.2 Dry Heat JIS-C-5201-1 4.23 ± (3% + 0.05Ω) At +155°C for 1000 hours Tolerances of 5%, 10%, 20% IEC-60115-1 2.23.2 JIS-C-5201-1 4.33 Bending once for 5 seconds Bending Strength ± (1% + 0.05Ω) IEC-60115-1 4.33 2010, 2512 sizes: 2mm; other sizes: 3mm JIS-C-5201-1 4.17 Solderability 95% min. coverage 245ºC ± 5°C for 3 seconds IEC-60115-1 4.17 Resistance to Soldering Heat JIS-C-5201-1 4.18 ± (0.5% + 0.05Ω) 260ºC ± 5°C for 10 seconds tolerances of 0.5%, 1% IEC-60115-1 4.18 Resistance to Soldering Heat JIS-C-5201-1 4.18 ± (1% + 0.05Ω) 260ºC ± 5°C for 10 seconds tolerances of 5%, 10%, 20% IEC-60115-1 4.18 JIS-C-5201-1 4.7 Voltage Proof No Breakdown or flashover 1.42 times max. operating voltage for 1 minute IEC-60115-1 4.7 JIS-C-5201-1 4.18 Individual leaching area ≤ 5% Leaching 260ºC ± 5°C for 30 seconds IEC-60068-2-58-8.2.1 Total leaching area ≤ 10% Rapid Change of Temperature JIS-C-5201-1 4.18 ± (0.5% + 0.05Ω) -55°C to + 150°C , 5 cycles tolerances of 0.5%, 1% IEC-60115-1 4.18 Rapid Change of Temperature JIS-C-5201-1 4.18 ± (1% + 0.05Ω) -55°C to + 150°C , 5 cycles tolerances of 5%, 10%, 20% IEC-60115-1 4.18 RCWV (Rated Continuous Working Voltage)= √ P*R or Max. Working Voltage whichever is lower. Storage Temperature: 15 ~ 28ºC; humidity < 80% R.H. Operating temperature range is - 55°C + 155°C Insulation Resistance Power Derating Curve: Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Soldering Condition Reflow Profiles Profile Feature Preheat Min. Temperature (Tsmin) Max. Temperature (Tsmax) Preheating time (ts) from Tsmin to Tsmax) Ramp-up rate (TL to Tp) Pb-Free Assembly Liquidous Temperature (TL) 217°C Time (tL) maintained above TL Min. Peak Temperature Max. Peak Temperature (Tp max) Time (tp) within 5°C of the specified classification temperature (Tc) Ramp-down rate (Tp to TL) Time 25°C to Peak Temperature 60-150 seconds 235°C 260°C 30 seconds max. 6°C/second max. 8 minutes max. 150°C 200°C 60-120 seconds 3°C/second max. Reel Specifications Type/Code Packaging Tape Width Reel Diameter RPC0402 RPC0603 RPC0805 Paper 8 mm RPC1206 7 inches RPC1210 RPC2010 Embossed 12 mm RPC2512 A 7.028 178.50 7.028 178.50 7.028 178.50 7.028 178.50 7.028 178.50 7.028 178.50 7.028 178.50 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± ± ± ± ± ± ± B 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 2.362 60 2.362 60 2.362 60 2.362 60 2.362 60 2.362 60 2.362 60 4 +0.039 / -0 +1 / -0 +0.039 / -0 +1 / -0 +0.039 / -0 +1 / -0 +0.039 / -0 +1 / -0 +0.039 / -0 +1 / -0 +0.039 / -0 +1 / -0 +0.039 / -0 +1 / -0 C 0.512 13.00 0.512 13.00 0.512 13.00 0.512 13.00 0.512 13.00 0.512 13.00 0.512 13.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.020 0.50 0.020 0.50 0.354 9.00 0.354 9.00 0.354 9.00 0.354 9.00 0.354 9.00 0.512 13.00 0.512 13.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± T 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.492 12.50 0.492 12.50 0.492 12.50 0.492 12.50 0.492 12.50 0.610 15.50 0.610 15.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Packaging Specifications - Paper Tape Type/Code RPC0402 RPC0603 RPC0805 RPC1206 RPC1210 A RPC0603 RPC0805 RPC1206 RPC1210 W E F Unit ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P0 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P2 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± ± ± T 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm inches mm Unit 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.018 0.45 0.028 0.70 0.033 0.85 0.033 0.85 0.033 0.85 ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm inches mm 0.002 0.05 0.002 0.05 inches mm inches mm Type/Code RPC0402 B 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.114 2.90 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Packaging Specifications – Embossed Plastic Tape Type/Code RPC2010 RPC2512 A 0.110 2.80 0.138 3.50 ± ± ± ± B 0.004 0.10 0.004 0.10 0.217 5.50 0.264 6.70 ± ± ± ± W 0.004 0.10 0.004 0.10 0.472 12.00 0.472 12.00 ± ± ± ± E 0.012 0.30 0.012 0.30 0.069 1.75 0.069 1.75 ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 ± ± ± ± Unit Type/Code P0 P1 P2 ØD0 T Unit RPC2010 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.059 ± 0.004 1.50 ± 0.10 0.047 - 0.000 1.20 - 0.00 inches mm RPC2512 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.059 ± 0.004 1.50 ± 0.10 0.047 - 0.000 1.20 - 0.00 inches mm Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Marking 1. 2. No marking for 0402 3-digit marking for 0603 in E24 3-digit marking for 0603 in E24 Example: 101 = 100 Ω 102 = 1K Ω 101 1st and 2nd digits are E24 code 3rd digit is the multiplier E24 Code 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 3. 4-digit marking for 0805-2512 Resistance Marking 4-digit marking for 0805-2512 100 Ω 2.2K Ω 10K Ω 100K Ω 1000 2201 1002 1003 1M Ω 1004 Recommended Pad Layout Type/Code RPC0402 RPC0603 RPC0805 RPC1206 RPC1210 RPC2010 RPC2512 a 0.020 0.50 0.035 0.90 0.047 1.20 0.079 2.00 0.079 2.00 0.150 3.80 0.193 4.90 Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. b 0.018 0.45 0.024 0.60 0.028 0.70 0.035 0.90 0.035 0.90 0.035 0.90 0.039 1.00 6 c 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 0.110 2.80 0.110 2.80 0.134 3.40 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Lightning Surge Resistors are tested in accordance with IEC 60115-1 using both 1.2 / 50 us and 10 / 700 pulse shapes. The limit of acceptance is a shift in resistance of less than 1% from the initial value. 1.2/50us Lightning Surge (*) RPC (Standard Power) tolerances of 0.5% and 1% RPC-HP (High Power) all tolerances RPC-UP (Ultra High Power) all tolerances (*) Note: Data provided shows typical performance and is for reference only. 1.2/50us Lightning Surge (*) RPC (Standard Power) Tolerances of 5%, 10% and 20% Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions 10/700us Lightning Surge (*) RPC (Standard Power) tolerances of 0.5% and 1% RPC-HP (High Power) all tolerances RPC-UP (Ultra High Power) all tolerances (*) Note: Data provided shows typical performance and is for reference only. 10/700us Lightning Surge (*) RPC (Standard Power) Tolerances of 5%, 10% and 20% (*) Note: Data provided shows typical performance and is for reference only. Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 9 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Pulse Withstand Capacity The single impulse graph is the result of 50 impulses of rectangular shape applied at one-minute intervals. The limit of acceptance was a shift in resistance of less than 1% from the initial value. The power applied was subject to the restrictions of the maximum permissible impulse voltage graph shown. Single Pulse Power (100 ohms) RPC (Standard Power) tolerances of 0.5% and 1% RPC-HP (High Power) all tolerances RPC-UP (Ultra High Power) all tolerances Single Pulse Power (100 ohms) RPC (Standard Power) Tolerances of 5%, 10% and 20% This data is for the 100 Ω resistance value for each size. Pulse power handling is dependent on the resistance value. For resistance values higher or lower than 100 Ω, contact Stackpole for advice on pulse handling characteristics of your particular resistance value of interest. Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 10 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Continuous Pulse The continuous load graph was obtained by applying repetitive rectangular pulses where the pulse period was adjusted so that the average power dissipated in the resistor was equal to its rated power at 70 ºC. Again, the limit of acceptance was a shift in resistance of less than 1% from the initial value. Continuous Pulse Power (100 ohms) RPC (Standard Power) tolerances of 0.5% and 1% RPC-HP (High Power) all tolerances RPC-UP (Ultra High Power) all tolerances Continuous Pulse Power (100 ohms) RPC (Standard Power) Tolerances of 5%, 10% and 20% Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 11 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions Pulse Voltage (100 ohms) RPC (Standard Power) tolerances of 0.5% and 1% RPC-HP (High Power) all tolerances RPC-UP (Ultra High Power) all tolerances Pulse Voltage (100 ohms) RPC (Standard Power) Tolerances of 5%, 10% and 20% RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 12 www.seielect.com marketing@seielect.com RPC Series Stackpole Electronics, Inc. Pulse Withstanding Thick Film Chip Resistor Resistive Product Solutions RoHS Compliance Status Standard Product Series RPC Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Pulse Withstanding Thick Film Surface Mount Chip Resistor SMD YES RoHS Compliant by means of exemption 7c-I 100% Matte Sn over Ni Jan-03 03/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order R P Product Series Code Description Pulse RPC Withstanding C 1 Power Rating Size W 0402 0.2 0603 0.1 0603(-HP) 0.25 0603(-UP) 0.33 0805 0.25 0805(-HP) 0.4 0805(-UP) 0.5 1206 0.33 1206(-HP) 0.5 1206(-UP) 0.75 1210 0.5 1210(-HP) 0.75 1210(-UP) 1 2010 0.75 2010(-HP) 1 2512 1.5 2512(-HP) 2 2 0 Tolerance Code Tol Value D 0.5% E96 F 1% E24 J 5% K 10% E24 M 20% Z Jumper Rev Date: 11/7/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 F Code T T 1 R Packaging Description Size Quantity 0402 10000 0603 7" Reel 0805 Paper Tape 5000 1206 1210 7" Reel 2010 4000 Plastic Tape 2512 13 2 0 - Resistance Value Four characters with the multiplier used as the decimal holder. 300 ohm = 300R 10.2 Kohm = 10K2 1 Mohm = 1M00 Zero ohm jumper = 0R00 H Code blank -HP -UP P Special Description Standard High Power Ultra High Power www.seielect.com marketing@seielect.com
RPC1206JT13K0-UP
物料型号:RPC Series,由Stackpole Electronics, Inc.生产,是一系列脉冲耐受厚膜芯片电阻。
器件简介:RPC系列电阻以其优异的脉冲耐受性能、宽广的电阻范围和较高的抗浪涌性能而著称。与RMCF系列相比,RPC系列具有更高的抗浪涌性能。这些电阻符合AEC-Q200标准,是RoHS合规的,无卤素,并符合REACH标准。
引脚分配:文档中没有提供具体的引脚分配信息,通常这需要查看具体的电路图或数据手册。
参数特性: - 电阻类型/代码:RPC0402、RPC0603、RPC0805、RPC1206、RPC1210、RPC2010、RPC2512等。 - 功率额定值:不同型号有不同的功率额定值,如RPC0402为0.2W,RPC0603为0.1W等。 - 最大工作电压和最大过载电压:每种型号都有其特定的电压限制。 - 温度系数(TCR):不同型号的电阻在不同温度范围内的电阻变化率。 - 欧姆范围和公差:提供了不同精度等级的电阻值范围和公差,如0.5%、1%、5%、10%和20%。
功能详解:RPC系列电阻设计用于承受高脉冲电流,适用于需要高脉冲耐受性能的电子设备中。
应用信息:适用于需要高脉冲耐受性的电子电路,如电源管理、电机驱动等。
封装信息:提供了多种封装尺寸,如0402、0603、0805、1206、1210、2010和2512等,每种封装都有详细的尺寸和重量信息。
RPC1206JT13K0-UP 价格&库存
很抱歉,暂时无法提供与“RPC1206JT13K0-UP”相匹配的价格&库存,您可以联系我们找货
RPC1206JT13K0-UP
  • 5000+0.317865000+0.04118
