RGC0603FTC71K5
RGC0603FTC71K5
    SEI
    RES 71.5K OHM 1% 1/10W 0603
RGC0603FTC71K5 数据手册
RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • • Precision performance Highly stable performance over time Tolerances of 0.1% may be available - contact Stackpole for details Temperature coefficient of resistance as low as ± 50 ppm/ºC RoHS compliant and halogen free REACH compliant 0402 and 0603 package sizes are qualified to AEC-Q200 Electrical Specifications Power Rating (W) @ 70ºC Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) TCR (ppm/ºC) 0.1% 0.5% 1% RGC0201 0.05 25 50 ± 200 - 10 - 10M - RGC0402 0.063 50 100 ± 50 ± 100 - 10 - 1M ± 200 - 1.02M - 10M ± 50 10 - 1M ± 100 ± 200 - ± 50 10 - 1M Type / Code RGC0603 RGC0805 RGC1206 0.1 0.125 0.25 0.25 RGC1210 RGC2010 0.33 0.75 75 150 150 300 200 400 200 200 200 RGC2512 1 - ± 50 10 - 1M - 100 - 1M 1 - 1M - 10 - 10M 10 - 1M 1.02M - 10M 1 - 10M - 10 - 10M 10 - 1M 1.02M - 10M 1 - 10M 10 - 10M 10 - 1M 1.02M - 10M ± 100 10 - 1M 400 ± 50 ± 100 ± 200 - ± 50 ± 100 10 - 1M ± 200 - 1.02M - 10M - ± 100 ± 50 10 - 1M - 1 - 9.76 500 1 - 9.76 10 - 10M 10 - 1M 10 - 10M 1.02M - 10M 1 - 10M 10 - 10M 10 - 1M - - 10 - 10M 10 - 1M ± 100 ± 200 - 1 - 10M 400 400 250 ± 100 ± 200 ± 100 ± 200 400 200 Ohmic Range (Ω) and Tolerance 10 - 10M 1.02M - 10M - Note: (1) Lesser of √ P*R or maximum working voltage Mechanical Specifications Type / Code Weight (g) (1000 pc.) RGC0201 0.150 L Body Length 0.024 ± 0.001 0.60 ± 0.03 W Body Width 0.012 ± 0.001 0.30 ± 0.03 Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 H Body Height 0.009 ± 0.001 0.23 ± 0.03 a Top Termination 0.006 ± 0.002 0.15 ± 0.05 b Bottom Termination 0.006 ± 0.002 0.15 ± 0.05 Unit inches mm www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Mechanical Specifications (cont.) Type / Code Weight (g) (1000 pc.) RGC0402 0.620 RGC0603 2.042 RGC0805 4.368 RGC1206 8.947 RGC1210 15.959 RGC2010 24.241 RGC2512 39.448 L Body Length 0.039 ± 0.004 1.00 ± 0.10 0.063 ± 0.004 1.60 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.122 ± 0.006 3.10 ± 0.15 0.126 ± 0.010 3.20 ± 0.25 0.197 ± 0.008 5.00 ± 0.20 0.250 ± 0.008 6.35 ± 0.20 W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.004 1.25 ± 0.10 0.061 ± 0.004 1.55 ± 0.10 0.102 ± 0.006 2.60 ± 0.15 0.098 ± 0.006 2.50 ± 0.15 0.124 ± 0.008 3.15 ± 0.20 H Body Height 0.012 ± 0.004 0.30 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 0.024 ± 0.006 0.60 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 a Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.010 0.40 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 b Bottom Termination 0.010 ± 0.006 0.25 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.008 0.50 ± 0.20 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Test Specification ± 1% and below Temperature Coefficient of Resistance As specified. Short Time Overload ±(1% + 0.05Ω) Insulation resistance ≥ 10G Endurance ±(1% + 0.1Ω) Damp Heat with Load ±(1% + 0.1Ω) Dry Heat ±(1% + 0.05Ω) Bending Strength ±(1% + 0.05Ω) Solderability 95% minimum coverage Resistance to Soldering Heat ±(0.5% + 0.05Ω) Voltage Proof No breakdown or flashover Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 Test Method JIS-C-5201-1 4.8 IEC-60115-1 4.8 -55°C +125°C, 25°C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or max. overload voltage whichever is lower for 5 seconds; 2 seconds for high power series JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. overload voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 70 ± 2°C, RCWV for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" JIS-C-5201-1 4.24 IEC-60115-1 4.24 40 ± 2°C, 90 ~ 95% R.H., RCWV for 1000 hours with 1.5 hour "ON" and 0.5 hour "OFF" JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +125 / +155°C for 1000 hours JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 5 seconds 2010, 2512 sizes: 2 mm; other sizes: 3 mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 245 ± 5°C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 260 ± 5°C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 1.42 times max. operating voltage for 1 minute www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Test Specification ± 1% and below Individual leaching area ≤ 5% Total leaching area ≤ 10% Test Method JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 260 ± 5°C for 30 seconds JIS-C-5201-1 4.19 Rapid Change of Temperature ±(0.5% + 0.05Ω) IEC-60115-1 4.19 -55°C to +125 / +155°C, 5 cycles RCWV (Rated Continuous Working Voltage) = √ P*R or max. operating voltage whichever is lower Storage temperature: 25 ± 3ºC; humidity < 80% RH Operating temperature range for 0201 is -55°C to +125°C Operating temperature range for 0402 - 2512 is -55°C to 155°C Leaching Power Derating Chart: Recommended Pad Layout Type / Code RGC0201 RGC0402 RGC0603 RGC0805 RGC1206 a b c Unit 0.012 0.30 0.020 0.50 0.035 0.90 0.047 1.20 0.079 2.00 0.010 0.25 0.018 0.45 0.024 0.60 0.028 0.70 0.035 0.90 0.012 0.30 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 inches mm inches mm inches mm inches mm inches mm Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Recommended Pad Layout (cont.) Soldering Profiles (1) Time of IR reflow soldering at maximum temperature point 260ºC : 10 seconds (2) Time of wave soldering at maximum temperature point 260ºC : 10 seconds (3) Time of soldering iron at maximum temperature point 410ºC : 5 seconds Packaging Specifications Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com
RGC0603FTC71K5
物料型号:RGC系列
器件简介:RGC系列是由Stackpole Electronics, Inc. 提供的半精密厚膜芯片电阻器,具有高精度性能和随时间高度稳定的特性。
引脚分配:文档中没有提供具体的引脚分配图,但通常这类电阻器的引脚分配是对称的。
参数特性: - 功率额定值:不同型号的电阻器有不同的功率额定值,例如RGC0201为0.05W,RGC0402为0.063W。 - 最大工作电压和最大过载电压:每个型号都有其特定的电压限制。 - 温度系数:电阻的温度系数可以低至±50ppm/°C。 - 公差:电阻器的公差范围从±100到±200ppm,部分型号可能提供0.1%的公差。
功能详解: - 电阻器符合RoHS和无卤标准,也符合REACH标准。 - 0402和0603封装尺寸通过了AEC-Q200认证。
应用信息:文档中没有提供具体的应用案例,但这类电阻器通常用于需要高精度和稳定性的电子设备中。
封装信息: - 提供了多种封装尺寸,如0402、0603、0805、1206、1210、2010和2512。 - 每种封装的尺寸和重量都有详细的规格说明。
性能特性:包括电阻的温度系数、短时间过载、绝缘电阻、耐久性、湿热带负载、干热、弯曲强度、焊接性和耐焊接热等测试规范。
存储和操作温度:存储温度为25±3°C,湿度小于80%RH。操作温度范围根据型号不同而有所差异。
焊接曲线:提供了IR回流焊接、波峰焊接和烙铁焊接的最大温度点和时间。
包装规格:文档的最后部分提供了包装规格的图示,但具体内容未在摘要中提及。
推荐布局:提供了不同型号电阻器的推荐焊盘布局尺寸。
RGC0603FTC71K5 价格&库存
很抱歉,暂时无法提供与“RGC0603FTC71K5”相匹配的价格&库存,您可以联系我们找货
RGC0603FTC71K5
  • 5000+0.145575000+0.01877
