AA2512FK-074M7L
AA2512FK-074M7L
    YAGEO(国巨)
    RES SMD 4.7M OHM 1% 1W 2512
AA2512FK-074M7L 数据手册
DATA SHEET ANTI-SULFURATED CHIP RESISTORS AUTOMOTIVE GRADE AA series ±5%, ±1%, ±0.5% sizes 0201/0402/0603/0805/1206/ 1210/1218/2010/2512 Product specification – December 08, 2015 V.3 RoHS compliant & Halogen free 2 Product specification Chip Resistor Surface Mount SCOPE This specification describes AA0201 to AA2512 chip resistors with leadfree terminations made by thick film process. AA 10 0201 to 2512 SERIES ORDERING INFORMATION - GLOBAL PART NUMBER Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER AA XXXX X X X XX XXXX L APPLICATIONS ⚫ Car electronics ⚫ Engine control unit ⚫ Body control system ⚫ Safety devices FEATURES ⚫ Superior resistance against sulfur containing atmosphere ⚫ AEC-Q200 qualified ⚫ Moisture sensitivity level: MSL1 ⚫ AA series soldering is compliant with J-STD-020D ⚫ Halogen free epoxy ⚫ RoHS compliant ⚫ Reduce environmentally hazardous waste ⚫ High component and equipment reliability ⚫ The resistors are 100% performed by automatic optical inspection (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201 / 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE D =± 0.5% F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper/PE taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel (6) RESISTANCE VALUE 1Ω to 10 MΩ There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω 976R = 976 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω XXMX (10 MΩ) 10M = 10,000,000 Ω O RDERING EXAMPLE The ordering code for an AA0402 chip resistor, value 100 KΩ with ±1% tolerance, supplied in 7-inch tape reel is: AA0402FR-07100KL NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA SERIES 3 10 0201 to 2512 MARKING AA0201 / AA0402 No marking ynsc007 Fig. 1 AA0603 / AA0805 / AA1206 / AA1210 / AA2010 / AA2512 03 Fig. 2 YNSC001 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ AA0603 0 YNSC037 Fig. 3 E-24 series: 3 digits, ± 1% One short bar under marking letter Value = 24 Ω E-96 series: 3 digits, ± 1% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AA0805 / AA1206 / AA1210 / AA2010 / AA2512 00 YNSC004 Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ AA1218 YNSC099 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ 00 Both E-24 and E-96 series: 4 digits, ± 1% First three digits for significant figure and 4th digit for number of zeros YNSC103 Fig. 7 Value = 10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AA series is the same as RC series. www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA CONSTRUCTION The resistors are constructed on top of an automotive grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a lead-free glass. The composition of the glaze is adjusted to give the approximately required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added, as shown in Fig.8. 4 10 0201 to 2512 SERIES OUTLINES marking layer overcoat protective glass resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode ceramic substrate YNSC088 Fig. 8 Chip resistor outlines DIMENSIONS Table 1 For outlines, please refer to Fig. 9 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AA0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03 0.12 ± 0.05 0.15 ± 0.05 AA0402 1.00 ± 0.05 0.50 ± 0.05 0.35 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AA0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AA0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 0.55 ± 0.10 0.45 ± 0.20 0.50 ± 0.20 0.50 ± 0.20 AA1206 3.10 ± 0.10 1.60 ± 0.10 AA1210 3.10 ± 0.10 2.60 ± 0.15 0.57 ± 0.10 0.45 ± 0.20 AA1218 3.10 ± 0.10 4.60 ± 0.10 0.57 ± 0.10 0.45 ± 0.20 0.50 ± 0.20 AA2010 5.00 ± 0.10 2.50 ± 0.15 0.57 ± 0.10 0.55 ± 0.20 0.55 ± 0.20 AA2512 6.35 ± 0.10 3.20 ± 0.15 0.57 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 For dimension, please refer to Table 1 AA0201 / AA0402 AA0603/0805/1206/ 1210/2010/2512 I1 AA1218 Side view for all type I1 I1 W W H W I2 Fig. 9 Chip resistor dimensions L L L YNSC096 www.yageo.com Dec 08, 2015 V.3 Product specification Chip Resistor Surface Mount AA SERIES 5 10 0201 to 2512 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS Operating Max. Max. Dielectric RESISTANCE RANGE Temperature Range Working Overload Withstanding Voltage Voltage Voltage TYPE AA0201 25V AA0402 AA0603 AA0805 AA1206 5% (E24) 1Ω≤ R ≤ 22MΩ (0201: Max. 10MΩ. 1218: Max. 1MΩ) 0.5%, 1% (E24/E96) 1Ω≤ R ≤10MΩ (1218: Max. 1MΩ) Jumper < 50mΩ 50V 50V 50 V 100 V 100 V 75V 150 V 150 V 150 V 300 V 300 V –55 °C to +155 °C 200 V 400 V 500 V Temperature Coefficient of Resistance 1Ω ≤ R ≤10Ω, Rated Current 0.5A -100/+400 ppm/°C 10Ω
AA2512FK-074M7L
物料型号:YAGEO AA系列,尺寸从0201至2512,包括±5%、±1%、±0.5%的容差。
器件简介:这些是无铅端子的表面贴装芯片电阻,采用厚膜工艺制造,符合RoHS标准,无卤素。
引脚分配:文档中没有明确说明引脚分配,但通常贴片电阻为两个端子。
参数特性: - 工作温度范围:-55°C至+155°C - 最大电压:根据尺寸不同,从25V至500V不等 - 额定功率:根据尺寸不同,从1/20W至3/4W不等 - 电阻温度系数:根据尺寸和电阻值不同,范围从±100ppm/°C至±300ppm/°C - 湿度敏感等级:MSL1 - 符合J-STD-020D焊接标准
功能详解: - 这些电阻具有优越的抗含硫气氛能力,适用于汽车电子、引擎控制单元、车身控制系统和安全设备等。
应用信息: - 适用于汽车级应用,包括引擎控制单元、车身控制系统等。
封装信息: - 提供7英寸和13英寸的卷带包装,包括纸/聚乙烯卷带和压花卷带。
电阻值编码规则: - 电阻值由2到4位数字表示,R/K/M作为小数点,例如1K2表示1.2kΩ。
AA2512FK-074M7L 价格&库存
很抱歉,暂时无法提供与“AA2512FK-074M7L”相匹配的价格&库存,您可以联系我们找货
AA2512FK-074M7L
  • 1+5.352381+0.66946
  • 10+2.8631010+0.35811
  • 25+2.7891825+0.34887
  • 50+2.7135750+0.33941
  • 100+2.48089100+0.31031
  • 250+2.31108250+0.28907
  • 500+1.87214500+0.23417
  • 1000+1.737781000+0.21736
库存:3571
AA2512FK-074M7L
  • 4000+1.370524000+0.17142
  • 8000+1.350598000+0.16893
库存:3571
