Metal thin film chip resistors
(wide temperature range)
■RGT series
AEC-Q200 Compliant
Features
・ Wide temperature operation (Upper category temperature :175°C)
・ Long term stability with inorganic passivation
・ Resistance tolerance : ±0.1% , TCR : ±10ppm/°C
RGT s eries
Thin film surface mount resistors
・ Thin film structure enabling low noise and anti-sulfur
Applications
・ Automotive electronics
・ Industrial measurement instrumentation, industrial machines
・ Wide temperature operation machines
◆Part numbering system
RGT 2012
N - 105 - B - T5
Packaging quantity :
T5(5,000pcs) T10(10,000pcs)
Series code
Size: RGT1005, RGT1608, RGT2012, RGT3216
Nominal resistance value
(E-24: 3 digit, E-96: 4 digit, RGT3216 : all 4 digit)
Temperature coefficient of resistance
◆Electrical Specification
Type
Temperature
coefficient
of resistance
Power
ratings
Resistance range(Ω)
±0.1%(B)
(ppm/℃)
±10(N)
RGT1005
RGT1608
RGT2012
RGT3216
47≦R≦100k
1/32W
1/16W
1/10W
1/8W
±0.5%(D)
Maximum
voltage
±25(P)
47≦R≦150k
±10(N)
47≦R≦270k
±25(P)
47≦R≦1M
±10(N)
47≦R≦470k
±25(P)
47≦R≦2.7M
±10(N)
47≦R≦1M
±25(P)
47≦R≦5.1M
Resistance
value series
Operating
temperature
Packaging
quantity
T5
50V
T10* 1
100V
E-24, E-96
-55℃∼ 175℃
T5
150V
200V
*1:Resistance tolerance ± 0.5% (D) of RGT1005 is available only at T10
◆Dimensions
L
Type
Size
(inch)
L
W
a
RGT1005
0402
1.00+0.1/-0.05
0.50±0.05
0.20±0.10
0.25±0.05
0.35±0.05
RGT1608
0603
1.60±0.20
0.80+0.25/-0.20
0.30±0.20
0.30±0.20
0.40+0.15/-0.10
RGT2012
0805
2.00±0.20
1.25+0.25/-0.20
0.40±0.20
0.40±0.20
0.40+0.15/-0.10
RGT3216
1206
3.20±0.20
1.60±0.25
0.50±0.25
0.50±0.20
0.40+0.15/0.10
b
t
W
a
t
b
(unit:mm)
17
◆Reliability specification
Test items
Condition( IEC60115-1/JIS C5201-1)
Standard
※1
Short time overload
2.5 x rated voltage, 5 seconds
Life (biased)
125℃, rated voltage , 90min. ON/ 30min. OFF, 1000hours
±(0.25%+0.05Ω)
High temperature high humidity
85℃、85%RH, 1/10 of rated power, 90min. ON/ 30min. OFF, 1000hours
±(0.25%+0.05Ω)
Temperature shock
-55℃ (30min) ∼ 125℃(30min) 1000 cycles
±(0.1%+0.01Ω)
High temperature exposure
175℃, no baias, not mounted, 1000h
±(0.1%+0.01Ω)
Resistance to soldering heat
260±5℃, 10seconds (reflow)
±(0.05%+0.01Ω)
±(0.05%+0.01Ω)
※1
RxP
E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W)
If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage.
○High temperature exposure
RGT1608-680Ω
0.15
RGT1608-10kΩ
RGT1608-100kΩ
0.10
Resistance drift (%)
○ Biased life test
0.30
0.25
0.20
0.15
0.10
0.05
0.00
-0.05
-0.10
-0.15
-0.20
-0.25
-0.30
RGT s eries
◆ Reliability test data
RGT1608-680Ω
*1 Rated voltage is given by E=
RGT1608-10kΩ
RGT1608-100kΩ
0.05
0.00
-0.05
-0.10
-0.15
1
10
100 1000
Test duration (h)
1 10 100
Test duration (h)
1000
Ratio to rated power (%)
◆Derating Curve
100
50
100 125 150 175
Ambient temperature (℃)
18
很抱歉,暂时无法提供与“RGT2012P-54R9-B-T5”相匹配的价格&库存,您可以联系我们找货
