RNCS0402BTE21K0
RNCS0402BTE21K0
    SEI
    RES 21K OHM 0.1% 1/16W 0402
RNCS0402BTE21K0 数据手册
RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Features: • • • • • • • • • • • Special passivation for moisture sensitive applications Absolute TCR’s to 15 ppm/ºC Test proven immunity to humidity and moisture corrosion Absolute tolerances to 0.1% Ideal replacement for costly Tantalum Nitride resistors Qualified to AEC-Q200 E192 values are not marked 100% RoHS compliant and lead free without exemption Halogen free REACH compliant For anti-sulfur version, refer to RNCS-AS specification The RNCS/RNCH series employs a special manufacturing process to ensure high power, high precision, ultra-stable performance, and long life in the harshest environments. In moisture comparison testing, the RNCS/RNCH series outperformed conventionally passivated Nichrome chip resistors and demonstrated the anti-corrosive claims characterized by Tantalum Nitride resistor products. Electrical Specifications - RNCS Type/Code Power Rating (W) @ 70ºC Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) TCR (ppm/ºC) Ohmic Range (Ω) and Tolerance 49.9 - 12K 0.1%, 0.25%, 0.5% RNCS0402 0.063 25 50 ±15 ±25 ±50 RNCS0603 0.063 50 100 ±15 ±25 ±50 25 - 332K RNCS0805 0.1 100 200 ±15 ±25 ±50 10 - 1M RNCS1206 0.125 150 300 ±15 ±25 ±50 10 - 1M 0.25 (2) (0.5) ±15 25 - 1M RNCS2010 150 300 ±25 ±50 10 - 1M 0.5 (1)(2) ±15 25 - 1M RNCS2512 150 300 ±25 ±50 10 - 1M 25 - 24.9K (1) Lesser of √ P*R or maximum working voltage (2) Higher power rating for each package size is valid if ambient temperature ≤ 80ºC and terminal temperature ≤ 105ºC Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Electrical Specifications - RNCH Power Rating (W) @ 70 ºC Type/Code Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) TCR (ppm/ºC) ±15 ±25 ±50 RNCH0603 0.1 75 150 RNCH0805 0.25 150 300 Ohmic Range (Ω) and Tolerance 0.1%, 0.25%, 0.5% 25 - 220K ±15 ±25 25 - 680K ±50 RNCH1206 0.33 200 ±15 ±25 ±50 400 25 - 1M (1) Lesser of √ P*R or maximum working voltage Mechanical Specifications Type/Code Weight (g) (1000 pc.) RNCS0402 0.55 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 1.85 4.76 9.11 RNCS2010 23.82 RNCS2512 38.46 L Body Length 0.039 ± 0.002 1.00 ± 0.05 0.061 ± 0.008 1.55 ± 0.20 0.079 ± 0.008 2.00 ± 0.20 0.120 ± 0.008 3.05 ± 0.20 0.193 ± 0.006 4.90 ± 0.15 0.248 ± 0.006 6.30 ± 0.15 W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.008 0.80 ± 0.20 0.049 ± 0.008 1.25 ± 0.20 0.061 ± 0.008 1.55 ± 0.20 0.094 ± 0.006 2.40 ± 0.15 0.122 ± 0.006 3.10 ± 0.15 H Body Height 0.012 ± 0.002 0.30 ± 0.05 0.018 ± 0.004 0.45 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 a Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 0.017 ± 0.012 0.42 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 b Bottom Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.010 0.40 ± 0.25 0.014 ± 0.010 0.35 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 Unit inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Specification 0603, 0805, 1206, 2010, 2512 ≤ ± 0.02% ≤ ± 0.2% for high power rating ≤ ± 0.05% ≤ ± 0.25% for high power rating ≤ ± 0.05% ≤ ± 0.25% for high power rating Test Test Method Short Time Overload JIS-C-5201-1 4.13 Endurance MIL-STD-202 Method 108A Damp Heat with Load MIL-STD-202 Method 103B Solderability MIL-STD-202 Method 208H Resistance to Soldering Heat MIL-STD-202 Method 210E ≤ ± 0.02% ≤ ± 0.1% 260 ± 5°C for 10 seconds Thermal Shock MIL-STD-202 Method 107G ≤ ± 0.02% ≤ ± 0.1% -55°C ~ 150°C, 100 cycles 0402 Test Condition RCWV * 2.5 or Max. overload voltage whichever is lower for 2 seconds 70 ± 2°C, RCWV for 1000 hours with ≤ ± 0.25% 1.5 hours "ON" and 0.5 hour "OFF" 40 ± 2°C, 90 ~ 95% R.H., RCWV for 1000 ≤ ± 0.5% hours with 1.5 hours "ON" and 0.5 hour "OFF" ≤ ± 0.1% 95% min. coverage 245 ± 5°C for 3 seconds RCWV (Rated Continuous Work Voltage) = √ P*R or Max. Operating voltage whichever is lower Operating temperature range is -55°C to +155°C Storage Temperature is 15°C to 28°C. Humidity < 80% R.H. Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Power Derating Curve: Soldering Condition: (1) Time of IR reflow soldering at maximum temperature point 260°C: 10 seconds (2) Time of wave soldering at maximum temperature point 260°C: 10 seconds (3) Time of soldering iron at maximum temperature point 410°C: 5 seconds Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Reel Specifications Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 RNCS2010 RNCS2512 A 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 ± ± ± ± ± ± ± ± ± ± ± ± B 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 ± ± ± ± ± ± ± ± ± ± ± ± C 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 ± ± ± ± ± ± ± ± ± ± ± ± W 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.028 0.70 0.374 9.50 0.374 9.50 0.374 9.50 0.374 9.50 0.531 13.50 0.531 13.50 ± ± ± ± ± ± ± ± ± ± ± ± T 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.453 11.50 0.453 11.50 0.453 11.50 0.453 11.50 0.610 15.50 0.610 15.50 ± 0.020 ± 0.50 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 D0 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.016 0.40 0.024 0.60 0.030 0.75 0.030 0.75 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 inches mm inches mm inches mm inches mm inches mm inches mm ± ± ± ± ± ± ± ± T 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm Unit ± ± ± ± ± ± ± ± 0.001 0.03 0.001 0.03 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm Packaging Specifications - Paper Tape Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 A B W E 0.028 0.70 0.043 1.10 0.063 1.60 0.079 2.00 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 P0 0.046 1.16 0.075 1.90 0.093 2.37 0.140 3.55 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 P1 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P2 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± 0.061 1.55 0.061 1.55 0.061 1.55 0.061 1.55 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 4 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 ± ± ± ± ± ± ± ± F 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 Unit www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Peel Force of Top Cover Paper Tape The peel speed shall be about 300 mm/min ± 5% The peel force of top cover tape shall be between 8gf to 60gf Packaging Specifications – Embossed Plastic Tape Type/Code RNCS2010 RNCS2512 A 0.112 2.85 0.134 3.40 Type/Code RNCS2010 RNCS2512 ± ± ± ± B 0.004 0.10 0.004 0.10 0.215 5.45 0.262 6.65 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.472 12.00 0.472 12.00 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 P1 ± ± ± ± ± ± ± ± E 0.004 0.10 0.004 0.10 0.069 1.75 0.069 1.75 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 P2 ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 0.004 0.10 0.004 0.10 0.039 1.00 0.039 1.00 D0 ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 inches mm inches mm 0.008 0.20 0.008 0.20 inches mm inches mm T ± ± ± ± Unit Peel Force of Top Cover Plastic Tape The peel speed shall be about 300 mm/min ± 5% The peel force of top cover tape shall be between 20gf to 80gf Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Recommended Pad Layout Type/Code RNCS0402 RNCS0603 RNCH0603 RNCS0805 RNCH0805 RNCS1206 RNCH1206 RNCS2010 RNCS2512 a b 0.020 0.50 0.031 0.80 0.039 1.00 0.079 2.00 0.142 3.60 0.193 4.90 0.020 0.50 0.039 1.00 0.039 1.00 0.045 1.15 0.055 1.40 0.063 1.60 c 0.024 0.60 0.035 0.90 0.053 1.35 0.067 1.70 0.098 2.50 0.122 3.10 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RNCH RNCS Description Anti-Corrosive Tantalum Nitride Replacement Surface Mount Chip Resistor Anti-Corrosive Tantalum Nitride Replacement Surface Mount Chip Resistor Lead-Free Package / Standard Lead-Free Lead-Free Termination Effective Date Termination Series RoHS Mfg. Effective Date Composition Code Type Compliant (Std Product Series) (YY/WW) SMD YES 100% Matte Sn over Ni Always Always SMD YES 100% Matte Sn over Ni May-04 04/18 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com RNCS / RNCH Series Stackpole Electronics, Inc. Moisture Resistant Precision Thin Film Chip Resistor Resistive Product Solutions Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order R N Product Series Moisture Resistant RNCS Precision Thin Fim Chip Resistor RNCH High Power C S Size Code W 0402 0.063 0603 0.063 0805 0.1 1206 0.125 2010 0.25 2010 0.5 (2) 2512 0.5 (2) 2512 1 0 8 0 5 D Tolerance Code Tol Value (1) B 0.1% E192, E96, C 0.25% E24 D 0.5% T E 4 Packaging Code T K Description Size Quantity 7" Reel 0402 10000 Paper Tape 0603, 0805, 1206 5000 7" Reel 2010, 2512 4000 Plastic Tape 7" Reel All Sizes 1000 K TCR Code ppm S 15 E 25 C 50 7 5 Resistance Value Four characters with the multiplier used as the decimal holder. 10 ohm = 10R0 800 Kohm = 800K 1 Mohm = 1M00 (1) E192 values are not marked, and may be subject to 20K MOQ (2) Higher power rating is valid if ambient temperature ≤ 80°C and terminal temperature ≤ 105°C Rev Date: 8/24/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com
RNCS0402BTE21K0
物料型号:RNCS / RNCH系列 器件简介:这些电阻器采用特殊制造工艺,确保在恶劣环境下具有高功率、高精度、超稳定性能和长寿命。在耐湿性测试中,RNCS/RNCH系列优于传统钝化镍铬芯片电阻器,显示出与钽氮化物电阻产品所描述的抗腐蚀特性。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻器为表面贴装器件,具有两个端子用于连接电路。
参数特性: - 特殊钝化,适用于潮湿敏感应用 - 绝对温度系数(TCR)可达15ppm/°C - 绝对容差可达0.1% - 通过AEC-Q200认证 - 符合RoHS标准,无铅,不含卤素,符合REACH标准
功能详解: - 该系列电阻器适用于需要高稳定性和耐腐蚀性的应用场合,如汽车电子、医疗设备等。 - 提供了不同功率等级和尺寸的电阻器,以满足不同设计需求。
应用信息: - 适用于高湿度或可能接触到水分的环境。 - 可以作为昂贵的钽氮化物电阻的替代品。
封装信息: - 提供了0402、0603、0805、1206、2010和2512等多种尺寸的封装选项。 - 每种封装的尺寸、重量、端子尺寸等详细信息都在文档中有具体说明。
RNCS0402BTE21K0 价格&库存
很抱歉,暂时无法提供与“RNCS0402BTE21K0”相匹配的价格&库存,您可以联系我们找货
