RNCP1206JTD15K0
RNCP1206JTD15K0
    SEI
    RES 15K OHM 5% 1/2W 1206
RNCP1206JTD15K0 数据手册
RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Features: • • • • • • • Higher power ratings than standard thick film chips TCR as low as 10 ppm/ºC Inner termination engineered to deter sulfur contamination Tolerance to ± 0.1% 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type/Code RNCP0402 RNCP0603 RNCP0805 RNCP1206 RNCP1210 RNCP2010 RNCP2512 Power Rating (W) @ 70°C 0.1 0.125 0.25 0.5 0.5 0.75 1 (1) Maximum Working Voltage (V)(2) Maximum Overload Voltage (V) 50 150V 200V 200V 200V 200V 200V TCR (ppm/ºC) ± 10 ± 15 ± 25 ± 50 ± 100 ± 10 ± 15 ± 25 ± 50 ± 100 ± 10 ± 15 ± 25 ± 50 ± 100 ± 10 ± 15 ± 25 ± 50 ± 100 ± 10 ± 15 ± 25 ± 50 ± 100 ± 10 ± 15 ± 25 ± 50 ± 100 ± 10 ± 15 ± 25 ± 50 ± 100 100 300V 400V 400V 400V 400V 400V Ohmic Range (Ω) and Tolerance 0.1% 0.25% 0.5% 1% 5% 10 - 10K - 2.49 - 10K 1 - 10K 4.7 - 10K - 1 - 10K 10 - 47K - 2.49 - 47K 1 - 47K 4.7 - 47K - 1 - 47K 10 - 100K - 2.49 - 100K 1 - 100K 4.7 - 100K - 1 - 100K 10 - 100K - 2.49 - 100K 1 - 100K 4.7 - 100K - 1 - 100K 10 - 100K - 2.49 - 100K 1 - 100K 4.7 - 100K - 1 - 100K 10 - 100K - 2.49 - 100K 1 - 100K 4.7 - 100K - 1 - 100K 10 - 100K - 2.49 - 100K 1 - 100K 4.7 - 100K - 1 - 100K (1) Power rating for each package size is valid if ambient temp ≤ 80ºC and terminal temp ≤105ºC (2) Lesser of √PR or maximum working voltage Certain resistance values will require a higher minimum order quantity. Contact Stackpole Customer Service for details. Please refer to the High-Power Resistor Application Note (page 5) for more information on designing and implementing high power resistor types. Rev Date: 12/2/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Mechanical Specifications L Body Length Type/Code RNCP0402 RNCP0603 RNCP0805 RNCP1206 RNCP1210 RNCP2010 RNCP2512 W Body Width H Body Height I1 Top Termination I2 Bottom Termination Unit 0.039 1.00 0.061 1.55 0.079 2.00 0.122 3.10 0.122 3.10 ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.008 0.20 0.006 0.15 0.008 0.20 0.006 0.15 0.020 0.50 0.031 0.80 0.049 1.25 0.059 1.50 0.098 2.50 ± ± ± ± ± ± ± ± ± ± 0.002 0.05 0.004 0.10 0.006 0.15 0.008 0.20 0.006 0.15 0.012 0.30 0.016 0.40 0.020 0.50 0.020 0.50 0.022 0.55 ± ± ± ± ± ± ± ± ± ± 0.002 0.05 0.006 0.15 0.006 0.15 0.006 0.15 0.004 0.10 0.010 0.25 0.012 0.30 0.016 0.40 0.022 0.55 0.018 0.45 ± ± ± ± ± ± ± ± ± ± 0.006 0.15 0.008 0.20 0.010 0.25 0.024 0.60 0.008 0.20 0.012 0.30 0.014 0.35 0.020 0.50 0.024 0.60 0.020 0.50 ± ± ± ± ± ± ± ± ± ± 0.006 0.15 0.010 0.25 0.012 0.30 0.012 0.30 0.008 0.20 inches mm inches mm inches mm inches mm inches mm 0.197 5.00 0.248 6.30 ± ± ± ± 0.006 0.15 0.006 0.15 0.098 2.50 0.126 3.20 ± ± ± ± 0.006 0.15 0.006 0.15 0.022 0.55 0.022 0.55 ± ± ± ± 0.004 0.10 0.004 0.10 0.024 0.60 0.024 0.60 ± ± ± ± 0.008 0.20 0.008 0.20 0.024 0.60 0.024 0.60 ± ± ± ± 0.008 0.20 0.008 0.20 inches mm inches mm Power Derating Curve: Performance Characteristics Test Item Reference Standard Procedure Requirements Temperature Coefficient of Resistance JIS-C 5201-1 4.8 IEC-60115-1 4.8 JIS-C 5201-1 4.13 IEC-60115-1 4.13 At 25/-55°C and 25°C /+125°C, 25°C is the reference temperature 2.5 times RCWV or max overload voltage whichever is less for 5 seconds Refer to Electrical Specifications ± (0.5% + 0.05Ω) No visual damage JIS-C-5201-1 4.6 IEC-60115-1 4.6 Apply 100 VDC for 1 minute ≥ 10GΩ Short Time Overload Insulation Resistance Solderability Resistance to Soldering Heat Leaching JIS-C-5201-1 4.17 IEC-60115-1 4.17 JIS-C-5201-1 4.18 IEC-60115-1 4.18 JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Rev Date: 12/2/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 245 ± 5°C for 3 seconds 260 ± 5°C for 10 seconds 260 ± 5°C for 30 seconds 2 > 95% coverage No visual damage ± (0.5% + 0.05Ω) No visual damage >95% coverage No visual damage www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Item Reference Standard Rapid Change of Temperature High Temperature Exposure JIS-C-5201-1 4.19 IEC-60115-1 4.19 JIS-C5201-1 4.25 IEC 60068-2-2 Procedure Requirements -55°C to +155°C, 300 cycles ± (0.5% + 0.05Ω) No visual damage At 155 ± 5°C for 1000 hours ± (0.5% + 0.05Ω) The tested resistor is immersed into isopropyl alcohol of 20~25°C for 60 seconds. Then the resistor is left in the room for 48 hours. 40 ± 2°C, 90~95% R.H. RCWV or max working JIS-C-5201-1 4.24 Damp Heat with Load voltage whichever is less for 1000 hours with 1.5 IEC-60115-1 4.24 hours "ON" and 0.5 hour "OFF" 1000 hours, 85°C / 85% RH, 10% of operating Based Humidity MIL-STD-202 Method 103 power. Measurement at 24 ± 4 hours after test conclusion. 70 ± 2°C, RCWV or max. working voltage JIS-C-5201-1 4.25 Load Life (Endurance) whichever is less for 1000 hours with 1.5 hours IEC-60115-1 4.25.1 "ON" and 0.5 hour "OFF" Bending once for 5 seconds D: 0402, 0603, 0805 = 5mm JIS-C-5201-1 4.33 Bending Strength 1206, 1210 = 3mm IEC-60115-1 4.33 2010, 2512 = 2mm ASTM B809-95 Sulfur Test (FoS) 105 ± 2°C, no power rating for 750 hours ANSI/EIA-977 AEC-Q200 test reports are available under request. Resistance to Solvent JIS-C-5201-1 4.29 ± (0.5% + 0.05Ω) No visual damage ± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω) No visual damage ± (2% + 0.001Ω) Recommended Soldering Parameters Rework temperature (hot air equipment): 350°C, 3~5 seconds Recommended reflow methods: • IR, vapor phase oven, hot air oven • If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Rev Date: 12/2/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Recommended Pad Layout Type/Code 0402 0603 0805 1206 1210 2010 2512 A B C Unit 0.016 0.40 0.026 0.65 0.039 1.00 0.079 2.00 0.079 2.00 0.150 3.80 0.193 4.90 0.059 1.50 0.083 2.10 0.118 3.00 0.165 4.20 0.173 4.40 0.260 6.60 0.319 8.10 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 0.106 2.70 0.106 2.70 0.134 3.40 inches mm inches mm inches mm inches mm inches mm inches mm inches mm Packaging Specifications Type Inches A ØB ØC ØD 0402 0603, 0805 1206, 1210 2010 2512 0.079 ± 0.020 2.00 ± 0.50 7" 0.531 ± 0.039 13.50 ± 1.00 0.827 ± 0.039 21.00 ± 1.00 2.362 ± 0.039 60.00 ± 1.00 W 0.453 11.50 0.453 11.50 0.630 16.00 ± ± ± ± ± ± 0.079 2.00 0.079 2.00 0.079 2.00 ØM Unit 7.008 ± 0.079 178.00 ± 2.00 Inches mm inches mm Inches mm Taping Specifications – Paper Tape Type 0402 0603 0805 1206 1210 A 0.028 0.70 0.041 1.05 0.061 1.55 0.075 1.90 0.112 2.85 ± ± ± ± ± ± ± ± ± ± B 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.047 1.20 0.071 1.80 0.091 2.30 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± ± ± W E F G H T ØD P Unit 0.004 0.018 ± 0.004 0.079 ± 0.004 inches 0.10 0.45 ± 0.10 2.00 ± 0.10 mm 0.008 0.024 ± 0.004 inches 0.20 0.60 ± 0.10 mm 0.008 0.315 ± 0.008 0.069 ± 0.004 0.138 ± 0.002 0.157 ± 0.004 0.079 ± 0.002 0.030 ± 0.004 0.059 +0.004/-0 0.157 ± 0.004 inches 0.20 8.00 ± 0.20 1.75 ± 0.10 3.50 ± 0.05 4.00 ± 0.10 2.00 ± 0.05 0.75 ± 0.10 1.50 +0.10/-0 4.00 ± 0.10 mm 0.008 0.030 ± 0.004 inches 0.20 0.75 ± 0.10 mm 0.008 0.030 ± 0.004 inches 0.20 0.75 ± 0.10 mm Rev Date: 12/2/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions Taping Specifications – Plastic Tape Type 2010 2512 A 0.110 2.80 0.134 3.40 Type 2010 2512 ± ± ± ± B 0.008 0.20 0.008 0.20 0.220 5.60 0.264 6.70 0.002 0.05 0.002 0.05 0.009 0.23 0.009 0.23 H 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± W 0.008 0.20 0.008 0.20 0.472 12.00 0.472 12.00 0.004 0.10 0.004 0.10 0.059 1.50 0.059 1.50 T ± ± ± ± ± ± ± ± E 0.004 0.10 0.004 0.10 ØD +0.004/-0 +0.10/-0 +0.004/-0 +0.10/-0 0.069 1.75 0.069 1.75 ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 ØD1 0.059 1.50 0.059 1.50 ± ± ± ± 0.004 0.10 0.004 0.10 ± ± ± ± G 0.002 0.05 0.002 0.05 0.157 4.00 0.157 4.00 0.006 0.15 0.006 0.15 0.157 4.00 0.157 4.00 T1 0.033 0.85 0.033 0.85 ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 inches mm inches mm 0.004 0.10 0.004 0.10 inches mm inches mm P ± ± ± ± Unit Peel-off Force Specifications Peel-off force of paper and blister tape is in accordance with “JIS-C5202”, that is, 0.1 to 0.7N at a peel-off speed of 300 mm/minute. High Power Chip Resistors and Thermal Management Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these resistors at the higher power ratings in their designs. The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than 105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR ½ 100 milliohms at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes would have less heat rise and therefore would be easier to implement for any given customer. Rev Date: 12/2/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under 105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any of these methods over another. Note: The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting pads and the amount of solder used. This is especially notable for resistance values ≤ 50 milliohms. This should be taken into account when designing. RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RNCP Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) High Power Anti-Sulfur Thin Film Chip Resistor SMD YES 100% Matte Sn over Ni Always Always Rev Date: 12/2/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com RNCP Series Stackpole Electronics, Inc. High Power Anti-Sulfur Thin Film Chip Resistor Resistive Product Solutions “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order R N Product Series High Power RNCP Anti-Sulfur Thin Film C Power Size 0402 0603 0805 1206 1210 2010 2512 P Rating W 0.1 0.125 0.25 0.5 0.5 0.75 1 0 6 Tolerance Code Tol Value B 0.1% C 0.25% E96, E24 D 0.5% F 1% J 5% E24 0 3 F T D 4 Packaging Code T Description 7" Reel - Paper Tape 7" Reel - Plastic Tape Size 0402 0603, 0805 1206, 1210 2010, 2512 Quantity 10000 5000 4000 K TCR Code ppm T 10 S 15 E 25 50 C D 100 7 5 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 47 Kohm = 47K0 100 Kohm = 100K Certain resistance values will require a higher minimum order quantity. Contact Stackpole Customer Service for details. Rev Date: 12/2/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com
RNCP1206JTD15K0
物料型号:RNCP系列
器件简介:该系列电阻器由Stackpole Electronics, Inc.生产,具有比标准厚膜芯片更高的功率等级,极低的TCR(温度系数),内端设计以防止硫污染,符合RoHS标准,无卤素,符合REACH标准。
引脚分配:文档中未明确提供引脚分配信息,但提供了机械规格,包括不同型号的尺寸数据。
参数特性: - 功率等级:不同型号有不同的功率等级,例如RNCP0402为0.1W,RNCP0603为0.125W,RNCP0805为0.25W等。 - 最大工作电压和过载电压:各型号有具体的最大工作电压和过载电压值。 - TCR:低至10ppm/°C。 - 欧姆范围和公差:提供0.1%至5%的公差范围。
功能详解:文档提供了详细的电气规格、机械规格、性能特性测试、推荐焊接参数、推荐布局图、包装规格等信息。
应用信息:适用于需要高功率和抗硫特性的应用场合。
封装信息:提供了详细的封装尺寸和推荐布局图,以确保电阻器在PCB板上的正确安装和性能。
RNCP1206JTD15K0 价格&库存
很抱歉,暂时无法提供与“RNCP1206JTD15K0”相匹配的价格&库存,您可以联系我们找货
RNCP1206JTD15K0
  • 5000+0.101615000+0.01272
RNCP1206JTD15K0
    • 5000+0.069205000+0.00866
    • 15000+0.0674315000+0.00844
    • 20000+0.0665420000+0.00833
    • 50000+0.0647750000+0.00811
    • 75000+0.0638875000+0.00800
