RMCS0603FT49K9
RMCS0603FT49K9
    SEI
    RES 49.9K OHM 1% 1/10W 0603
RMCS0603FT49K9 数据手册
RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • Inner terminations engineered to deter sulfur contamination Non-standard resistance values available Zero ohm available (max. resistance 0.05Ω) “-HP” denotes high power RoHS compliant and halogen free REACH compliant Electrical Specifications Maximum Overload 0.05 Maximum Working Voltage (V)(1) 25 Voltage (V)(2) 50 Maximum Current Jumper (A) 1 RMCS0402 0.063 50 100 1 RMCS0603 0.1 75 150 1 RMCS0805 0.125 150 300 2 RMCS1206 0.25 200 400 2 RMCS1210 0.33 200 400 2.5 RMCS2010 0.75 200 400 3.5 RMCS2512 1 250 500 4 Type/Code Power Rating (W) @ 70ºC RMCS0201 TCR (ppm/ºC) ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 Ohmic Range (Ω) and Tolerance 0.5% - 1% 5% 1 - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M (1) Lesser of √ P*R or maximum working voltage, whichever is lower. (2) 2.5* √ P*R or Max. Overload Voltage listed above, whichever is lower. Electrical Specifications – High Power Power Rating (W) Maximum Working Maximum Overload Type/Code TCR (ppm/ºC) @ 70ºC Voltage (V)(1) Voltage (V)(2) RMCS0201_-HP 0.083 25 50 ± 200 ± 200 RMCS0402_-HP 0.1 50 100 ± 100 ± 200 RMCS0603_-HP 0.25 75 150 ± 100 ± 200 RMCS0805_-HP 0.33 150 300 ± 100 ± 200 RMCS1206_-HP 0.5 200 400 ± 100 ± 200 RMCS1210_-HP 0.75 200 400 ± 100 ± 200 RMCS2010_-HP 1 200 400 ± 100 ± 400 RMCS2512_-HP 2 200 400 ± 100 (1) Lesser of √ P*R or maximum working voltage, whichever is lower. (2) 2.5* √ P*R or Max. Overload Voltage listed above, whichever is lower. (3) 0.5% tolerance for 0603 and 0805 requires lower power rating. Contact Stackpole for details. Rev Date: 1/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 Ohmic Range (Ω) and Tolerance 1% 5% 0.5%(3) 10 - 1M 1 - 9.76 10 - 1M 10 - 1M 1 - 9.76 10 - 1M 10 - 1M 1 - 9.76 10 - 1M 10 - 1M 1 - 9.76 10 - 1M 10 - 1M 1 - 9.76 10 - 1M 10 - 1M 1 - 9.76 10 - 1M 10 - 1M 1 - 9.76 10 - 1M 10 - 10M www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Mechanical Specifications Type/Code Weight (g) (1000 pieces) RMCS0201 0.15 RMCS0402 0.62 RMCS0603 2.042 RMCS0805 4.368 RMCS1206 8.947 RMCS1210 15.959 RMCS2010 24.241 RMCS2512 39.448 RMCS2512_-HP 39.448 L Body Length 0.024 ± 0.001 0.60 ± 0.03 0.039 ± 0.006 1.00 ± 0.15 0.063 ± 0.008 1.60 ± 0.20 0.079 ± 0.008 2.00 ± 0.20 0.122 ± 0.006 3.10 ± 0.15 0.122 ± 0.006 3.10 ± 0.15 0.197 ± 0.008 5.00 ± 0.20 0.248 ± 0.008 6.30 ± 0.20 0.248 ± 0.008 6.30 ± 0.20 W Body Width 0.012 ± 0.001 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.006 1.25 ± 0.15 0.061 ± 0.010 1.55 ± 0.25 0.102 ± 0.012 2.60 ± 0.30 0.098 ± 0.008 2.50 ± 0.20 0.124 ± 0.008 3.15 ± 0.20 0.126 ± 0.008 3.20 ± 0.20 H Body Height 0.009 ± 0.001 0.23 ± 0.03 0.014 ± 0.004 0.35 ± 0.10 0.018 ± 0.006 0.45 ± 0.15 0.020 ± 0.006 0.50 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.006 0.55 ± 0.15 0.024 ± 0.008 0.60 ± 0.20 a Top Termination 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.006 0.20 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.008 0.35 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.010 0.50 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.024 ± 0.012 0.60 ± 0.30 b Bottom Termination 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.006 0.20 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.022 ± 0.010 0.55 ± 0.25 0.024 ± 0.012 0.60 ± 0.30 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Short Time Overload Insulation Resistance Endurance Damp Heat with Load Dry Heat Bending Strength Solderability Resistance to Soldering Heat Voltage Proof Leaching Rapid change of Temperature Test Method JIS-C-5201-1 4.13 IEC-60115-1 4.13 ±1% and below ± (1% + 0.05Ω) Test Specification ±5% ± (2% + 0.05Ω) JIS-C-5201-1 4.6 ≥10G IEC-60115-1 4.6 JIS-C-5201-1 4.25 ± (2% + 0.1Ω) ± (3% + 0.1Ω) IEC-60115-1 4.25.1 JIS-C-5201-1 4.24 ± (2% + 0.1Ω) ± (3% + 0.1Ω) IEC-60115-1 4.24 JIS-C-5201-1 4.23 ± (1% + 0.05Ω) ± (1.5% + 0.1Ω) IEC-60115-1 4.23.2 JIS-C-5201-1 4.33 ± (1% + 0.05Ω) ± (1% + 0.05Ω) IEC-60115-1 4.33 JIS-C-5201-1 4.17 95% minimum coverage IEC-60115-1 4.17 JIS-C-5201-1 4.18 ± (0.5% + 0.05Ω) ± (1% + 0.05Ω) IEC-60115-1 4.18 JIS-C-5201-1 4.7 No breakdown or flashover IEC-60115-1 4.7 JIS-C-5201-1 4.18 Individual leaching area ≤ 5% IEC-60068-2-58 8.2.1 Total leaching area ≤ 10% JIS-C-5201-1 4.19 ± (0.5% + 0.05Ω) ± (1% + 0.05Ω) IEC-60115-1 4.19 Sulfur Test ASTM-B-809-95 ± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω) Jumper < 50mΩ Test Condition RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds, 2 seconds for high power series. Max. Overload Voltage for 1 minute < 100mΩ < 100mΩ 70ºC ± 2ºC, RCWV for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" 40ºC ± 2ºC, 90~95% R.H., RCWV for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" < 50mΩ At +125ºC/+155ºC for 1000 hours < 50mΩ Bending once for 5 seconds 2010, 2512 sizes: 2 mm / Other sizes: 3 mm 245ºC ± 5ºC for 3 seconds < 50mΩ 260ºC ± 5ºC for 10 seconds 1.42 times Max. Operating Voltage for 1 minute 260ºC ± 5ºC for 30 seconds < 50mΩ -55ºC to +125ºC/+155ºC, 5 cycles < 50mΩ H2S, 50ºC ± 2ºC, 91~93% R.H., no power rating for 1000 hours RCWV (Rated Continuous Working Voltage) = √ P*R or Max. Operating Voltage, whichever is lower. Storage Temperature: 15ºC ~ 28ºC. Humidity < 80% R.H. Operating temperature range is -55°C to +155°C Rev Date: 1/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Power Derating Curve: Packaging Specifications – Paper Tape Type/Code RMCS0201 RMCS0402 RMCS0603 RMCS0805 RMCS1206 RMCS1210 L ± 0.002 ± 0.05 ± 0.006 ± 0.15 ± 0.010 ± 0.25 ± 0.010 ± 0.25 ± 0.008 ± 0.20 ± 0.010 ± 0.25 P0 0.027 0.68 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± 0.079 2.00 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 Type/Code RMCS0201 RMCS0402 RMCS0603 RMCS0805 RMCS1206 RMCS1210 M 0.015 0.38 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.110 2.80 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 W ± 0.002 ± 0.05 ± 0.006 ± 0.15 ± 0.010 ± 0.25 ± 0.010 ± 0.25 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 ± ± ± ± ± ± ± ± ± ± ± ± Rev Date: 1/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.002 0.05 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 3 E ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P2 ± ± ± ± ± ± ± ± ± ± ± ± 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 F 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.017 0.42 0.018 0.45 0.028 0.70 0.033 0.85 0.033 0.85 0.030 0.75 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 Unit ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 K1 ± ± ± ± ± ± ± ± ± ± ± ± 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Packaging Specifications – Embossed Plastic Tape Type/Code RMCS2010 RMCS2512 0.110 2.80 0.138 3.50 L ± 0.008 ± 0.20 ± 0.008 ± 0.20 P0 0.217 5.50 0.264 6.70 0.157 4.00 0.157 4.00 ± ± ± ± 0.157 4.00 0.157 4.00 Type/Code RMCS2010 RMCS2512 0.004 0.10 0.004 0.10 M ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 ± ± ± ± 0.472 12.00 0.472 12.00 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 W ± 0.012 ± 0.30 ± 0.012 ± 0.30 P2 ± ± ± ± 0.002 0.05 0.002 0.05 E 0.069 ± 0.004 1.75 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 ØD0 0.059 +0.004 / -0 1.50 +0.10 / -0 0.059 +0.004 / -0 1.50 +0.10 / -0 0.217 5.50 0.217 5.50 0.047 1.20 0.047 1.20 F ± 0.002 ± 0.05 ± 0.002 ± 0.05 K2 - 0 0 0 0 Unit inches mm inches mm Unit inches mm inches mm Recommended Pad Layout Type/Code a b c Unit RMCS0201 0.012 0.30 0.010 0.25 0.012 0.30 inches mm 0.024 0.60 0.035 0.90 0.051 1.30 0.087 2.20 0.079 2.00 0.150 3.80 0.193 4.90 0.020 0.50 0.031 0.80 0.031 0.80 0.039 1.00 0.035 0.90 0.035 0.90 0.063 1.60 0.028 0.70 0.039 1.00 0.055 1.40 0.067 1.70 0.110 2.80 0.110 2.80 0.138 3.50 inches mm inches mm inches mm inches mm inches mm inches mm inches mm RMCS0402 RMCS0603 RMCS0805 RMCS1206 RMCS1210 RMCS2010 RMCS2512 Rev Date: 1/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Soldering Condition (1) Time of IR reflow soldering at maximum temperature point 260°C: 10 seconds (2) Time of wave soldering at maximum temperature point 260°C: 10 seconds (3) Time of soldering iron at maximum temperature point 410°C: 5 seconds Rev Date: 1/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Rev Date: 1/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Resistive Product Solutions 6 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Package / Termination Type Description Sulfur Resistant Thick Film SMD Surface Mount Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. RMCS Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order R M Product Series Sulfur Resistant RMCS C Size 0201 0402 0603 0805 1206 1210 2010 2512 S Power Rating (W) RMCS -HP 0.05 0.083 0.063 0.1 0.1 0.25 0.125 0.33 0.25 0.5 0.33 0.75 0.75 1 1 2 0 6 0 3 J T 4 K Tolerance Packaging Code Tol Value Code Description Size Quantity D 0.5% E96 0201, 0402 10000 7" Reel F 1% E96, E24 0603, 0805 Paper Tape 5000 T J 5% E24 1206, 1210 Z Jumper 7" Reel 2010, 2512 4000 Plastic Tape Rev Date: 1/12/2023 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 7 0 - Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 100 Kohm = 100K 1.02 Mohm = 1M02 Zero ohm jumper = 0R00 H P Special Code Description blank Standard -HP High Power www.seielect.com marketing@seielect.com
RMCS0603FT49K9
物料型号:RMCS系列,提供不同尺寸和功率等级的型号,如RMCS0201、RMCS0402、RMCS0603等。
器件简介:RMCS系列是Stackpole Electronics, Inc.生产的硫抵抗厚膜芯片电阻器,具有内端子设计以防止硫污染,提供非标准电阻值,包括零欧姆电阻,符合RoHS和REACH标准。
引脚分配:文档中未明确列出引脚分配,但通常这类电阻器为表面贴装器件,具有顶部和底部端子。
参数特性: - 功率等级:不同型号有不同的功率等级,如RMCS0201为0.05W,RMCS2512为1W或2W(高功率型号)。 - 最大工作电压和过载电压:各型号有不同规格,如RMCS0201为25V/50V,RMCS2512为250V/500V。 - 最大电流跳变:部分型号列出了此参数,如RMCS0201为1A。 - 温度系数(TCR):各型号的TCR值不同,通常为±200ppm/°C。 - 欧姆范围和公差:提供0.5%、1%和5%的公差选项。
功能详解:文档提供了详细的电阻器性能特性测试方法和规格,包括短时间过载、绝缘电阻、耐久性、湿热负载、干热、弯曲强度、焊接性、耐焊热、电压证明、浸出和快速温度变化测试。
应用信息:适用于需要抵抗硫污染的环境,如汽车和工业应用。
封装信息:提供了详细的机械规格,包括重量、身体长度、宽度、高度以及端子尺寸。
订购信息:提供了如何根据产品系列、电阻值、公差、包装和特殊要求进行订购的指南。
环保合规性:RMCS系列符合RoHS指令,通过100%的Sn覆盖Ni实现无铅端子,并符合REACH指令,确保所有被动组件不含高关注物质(SVHC)。
存储和操作温度范围:存储温度为15ºC至28ºC,湿度小于80% R.H.,操作温度范围为-55°C至+155°C。
RMCS0603FT49K9 价格&库存
很抱歉,暂时无法提供与“RMCS0603FT49K9”相匹配的价格&库存,您可以联系我们找货
RMCS0603FT49K9
