DATA SHEET
ANTI-SULFURATED CHIP RESISTORS
AUTOMOTIVE GRADE
AA series
±5%, ±1%, ±0.5%
sizes 0201/0402/0603/0805/1206/
1210/1218/2010/2512
Product specification – December 08, 2015 V.3
RoHS compliant & Halogen free
2
Chip Resistor Surface Mount
SCOPE
This specification describes AA0201
to AA2512 chip resistors with leadfree terminations made by thick film
process.
AA
10
0201 to 2512
SERIES
ORDERING INFORMATION - GLOBAL PART NUMBER
Part number is identified by the series name, size, tolerance, packaging
type, temperature coefficient, taping reel and resistance value.
GLOBAL PART NUMBER
AA XXXX X X X XX XXXX L
APPLICATIONS
⚫ Car electronics
Engine control unit
Body control system
Safety devices
FEATURES
⚫ Superior resistance against sulfur
containing atmosphere
AEC-Q200 qualified
Moisture sensitivity level: MSL1
AA series soldering is compliant
with J-STD-020D
Halogen free epoxy
RoHS compliant
Reduce environmentally
hazardous waste
High component and equipment
reliability
The resistors are 100% performed
by automatic optical inspection
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0201 / 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512
(2) TOLERANCE
D =± 0.5%
F = ± 1%
J = ± 5% (for Jumper ordering, use code of J)
(3) PACKAGING TYPE
R = Paper/PE taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Base on spec
(5) TAPING REEL
07 = 7 inch dia. Reel
13 = 13 inch dia. Reel
(6) RESISTANCE VALUE
1Ω to 10 MΩ
There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no
need to mention the last zero after R/K/M, e.g.1K2, not 1K20.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance coding
Example
rule
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
976R = 976 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
XXMX
(10 MΩ)
10M = 10,000,000 Ω
O RDERING EXAMPLE
The ordering code for an AA0402 chip
resistor, value 100 KΩ with ±1%
tolerance, supplied in 7-inch tape reel is:
AA0402FR-07100KL
NOTE
1. All our R-Chip products are RoHS
compliant and Halogen free. "LFP" of the
internal 2D reel label states "Lead-Free
Process".
2. On customized label, "LFP" or specific
symbol can be printed.
www.yageo.com
Dec 08, 2015 V.3
AA
SERIES
3
10
0201 to 2512
MARKING
AA0201 / AA0402
No marking
ynsc007
Fig. 1
AA0603 / AA0805 / AA1206 / AA1210 / AA2010 / AA2512
03
Fig. 2
YNSC001
E-24 series: 3 digits, ± 5%
First two digits for significant figure and 3rd digit for number of zeros
Value=10 KΩ
AA0603
YNSC037
Fig. 3
E-24 series: 3 digits, ± 1%
One short bar under marking letter
Value = 24 Ω
E-96 series: 3 digits, ± 1%
First two digits for E-96 marking rule and 3rd letter for number of zeros
Fig. 4
Value = 12.4 KΩ
00
YNSC004
Both E-24 and E-96 series: 4 digits, ± 1%
First three digits for significant figure and 4th digit for number of zeros
Fig. 5 Value = 10 KΩ
AA1218
YNSC099
Fig. 6 Value = 10 KΩ
00
YNSC103
Fig. 7 Value = 10 KΩ
NOTE
For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AA series is the same as RC series.
www.yageo.com
Dec 08, 2015 V.3
AA
CONSTRUCTION
The resistors are constructed on top of an automotive
grade ceramic body. Internal metal electrodes are
added at each end and connected by a resistive glaze.
The resistive glaze is covered by a lead-free glass.
The composition of the glaze is adjusted to give the
approximately required resistance value and laser
trimming of this resistive glaze achieves the value within
tolerance. The whole element is covered by a protective
overcoat. Size 0603 and bigger is marked with the
resistance value on top. Finally, the two external
terminations (Ni / matte tin) are added, as shown in Fig.8.
4
10
0201 to 2512
SERIES
OUTLINES
marking layer
overcoat
protective glass
resistive layer
(Jumper chip is a conductor)
inner electrode
termination(Ni/matte tin)
inner electrode
ceramic substrate
YNSC088
Fig. 8 Chip resistor outlines
DIMENSIONS
Table 1 For outlines, please refer to Fig. 9
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
AA0201
0.60 ± 0.03
0.30 ± 0.03
0.23 ± 0.03
0.12 ± 0.05
0.15 ± 0.05
AA0402
1.00 ± 0.05
0.50 ± 0.05
0.35 ± 0.05
0.20 ± 0.10
0.25 ± 0.10
AA0603
1.60 ± 0.10
0.80 ± 0.10
0.45 ± 0.10
0.25 ± 0.15
0.25 ± 0.15
AA0805
2.00 ± 0.10
1.25 ± 0.10
0.50 ± 0.10
0.35 ± 0.20
0.35 ± 0.20
0.55 ± 0.10
0.45 ± 0.20
0.50 ± 0.20
0.50 ± 0.20
AA1206
3.10 ± 0.10
1.60 ± 0.10
AA1210
3.10 ± 0.10
2.60 ± 0.15
0.57 ± 0.10
0.45 ± 0.20
AA1218
3.10 ± 0.10
4.60 ± 0.10
0.57 ± 0.10
0.45 ± 0.20
0.50 ± 0.20
AA2010
5.00 ± 0.10
2.50 ± 0.15
0.57 ± 0.10
0.55 ± 0.20
0.55 ± 0.20
AA2512
6.35 ± 0.10
3.20 ± 0.15
0.57 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
For dimension, please refer to Table 1
AA0201 / AA0402
AA0603/0805/1206/
1210/2010/2512
I1
AA1218
Side view for all type
I1
I1
W
W
H
W
I2
Fig. 9 Chip resistor dimensions
L
L
L
YNSC096
www.yageo.com
Dec 08, 2015 V.3
AA
SERIES
5
10
0201 to 2512
ELECTRICAL CHARACTERISTICS
Table 2
CHARACTERISTICS
Operating
Max.
Max.
Dielectric
RESISTANCE
RANGE Temperature Range Working Overload Withstanding
Voltage Voltage
Voltage
TYPE
AA0201
25V
AA0402
AA0603
AA0805
AA1206
5% (E24)
1Ω≤ R ≤ 22MΩ
(0201: Max. 10MΩ.
1218: Max. 1MΩ)
0.5%, 1% (E24/E96)
1Ω≤ R ≤10MΩ
(1218: Max. 1MΩ)
Jumper < 50mΩ
50V
50V
50 V
100 V
100 V
75V
150 V
150 V
150 V
300 V
300 V
–55 °C to +155 °C
200 V
400 V
500 V
Temperature
Coefficient
of Resistance
1Ω ≤ R ≤10Ω, Rated Current 0.5A
-100/+400 ppm/°C
10Ω
很抱歉,暂时无法提供与“AA0402FR-0711KL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.0629710000+0.00808
- 国内价格
- 1+0.39460
- 100+0.25930
- 1000+0.17570
- 5000+0.12100
- 10000+0.08640
