WS05-4R2PJ
WS05-4R2PJ
    WAYON(上海维安)
    DFN2510-10
    ESD抑制器 DFN2510-10L
WS05-4R2PJ 数据手册
Document: W03010180, Rev: C WS05-4R2PJ Transient Voltage Suppressor Features  Solid-state silicon-avalanche technology  Low operating and clamping voltage  Up to four I/O Lines of Protection  Ultra low capacitance: 0.3pF typical(I/O to GND)  Low Leakage  Low operating voltage:5V  Flow-Through design 1 DFN2510-10L IEC COMPATIBILITY (EN61000-4)  IEC 61000-4-2 (ESD) ±25kV (air), ±12kV (contact)  IEC 61000-4-4 (EFT) 40A (5/50ns)  IEC 61000-4-5 (Lightning) 3A (8/20μs) Mechanical Characteristics Applications  DFN2510-10L package  USB3.0/USB3.1  Marking: Marking Code  HDMI 2.0  Packaging: Tape and Reel  Digital Visual Interface(DVI)  RoHS Compliant  MDDI Ports  DisplayPortTM Interface  PCI Express  eSATA Interfaces Circuit Diagram Pin 1 Pin 2 Schematic & PIN Configuration Pin 4 Pin 5 Pin 3,8 1,2,4,5 4-Line Protection ©2019 WAYON Corporation Identificaion Input Lines 6,7,9,10 Output Lines (No Internal Connection) 3,8 Ground www.way-on.com 1/5 Transient Voltage Suppressor WS05-4R2PJ Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 39 Watts Peak Pulse Current ( tp =8/20μs ) Ipp 3 A Operating Temperature TJ -55 to + 125 °C TSTG -55 to +150 °C Storage Temperature Electrical Parameters (T=25°C) Symbol I Parameter IPP Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IF Reverse Stand-Off Voltage VC VBRVRWM Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IF Forward Current VF Forward Voltage @ IF V IR VF IT IPP Electrical Characteristics WS05-4R2PJ Parameter Reverse Stand-Off Voltage Reverse Breakdown Voltage Symbol Conditions VRWM Any I/O pin to ground VBR It = 1mA Any I/O pin to ground Reverse Leakage Current IR Clamping Voltage Vc ESD Clamping Voltage1 VC ESD Clamping Voltage1 VC Dynamic Resistance1,2 RDYN Minimum VRWM = 5V, T=25°C Any I/O pin to ground Ipp=3A, tp=8/20µs Any I/O pin to ground IPP = 4A, tp = 0.2/100ns (TLP) IPP = 16A, tp = 0.2/100ns (TLP) TLP=0.2/100ns Typical www.way-on.com Units 5.0 V 6.0 V 11.0 200 nA 13.0 V 10.5 V 20.0 V 0.75 Ω VR =1.5V, f = 1MHz 0.35 I/O pin to GND Junction Capacitance Cj VR = 1.5V, f = 1MHz 0.15 Between I/O pins, Notes:1、TLP Setting:tp=100ns, tr=0.2ns, ITLP and VTLP sample window:t1=70ns to t2=90ns. 2、Dynamic resistance calculated from IPP=4A to IPP=16A using “Best Fit”. ©2019 WAYON Corporation Maximum 0.45 pF 0.20 pF 2/5 Transient Voltage Suppressor WS05-4R2PJ Typical Characteristics Figure 2: Power Derating Curve Ppp – Peak Pulse Power - Ppp(W) Figure 1: Peak Pulse Power vs. Pulse Time 1000 Percent of Rated Power for Ipp 110 39W 8/20µs Waveform 100 10 1 100 90 80 70 60 50 40 30 20 10 0 td – Pulse Duration - µs Ambient Temperature - TA (℃) Figure 4: Normalized Junction Capacitance vs. Reverse Voltage 1.5 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 00 1.4 1.3 Cj(VR)/Cj(VR=0) Clamping Voltage -Vc(V) Figure 3: Clamping Voltage vs. Peak Pulse Current 1.2 1.1 1 0.9 0.8 0.7 0.6 1 2 3 0.5 4 0 1 Peak Pulse Current -Ipp(A) Figure 5: 8/20µs Pulse Waveform tr=8µs 4 5 6 25 Waveform Paramters tr=8µs td=20µs 90 80 70 60 50 40 Half Value Ipp/2 30 td=20µs 20 TLP Current (A) 100 Percent Ipp 3 Figure 6: TLP I-V Curve 110 20 2 Reverse Voltage -VR(V) 15 RDYN=0.75 Ohms 10 5 TLP Parameters: tp=100ns tr=0.2ns 0 10 -5 0 0 Time (µs) ©2019 WAYON Corporation 5 10 15 20 25 TLP Voltage (V) www.way-on.com 3/5 Transient Voltage Suppressor WS05-4R2PJ Soldering Parameters Pb – Free assembly Reflow Condition Pre Heat Temperature Min (Ts(min)) Temperature Max (Ts(max)) Time (min to max) (ts ) Average ramp up rate (Liquidus Temp) (TL) to peak TS(max) to TL——Ramp-up Rate Temperature (TL) (Liquidus) Reflow Temperature (tL) Peak Temperature (TP) 150°C 200°C 60 – 190 secs 5°C/second max 5°C/second max 217°C 60 – 150 seconds 260+0/-5 °C Time within actual peak Temperature (tp ) 20 – 40 seconds Ramp-down Rate Time 25°C to peak Temperature (TP) Do not exceed 5°C/second max 8 minutes Max. 280°C Reflow Condition ©2019 WAYON Corporation www.way-on.com 4/5 Transient Voltage Suppressor WS05-4R2PJ Outline Drawing –DFN2510-10L D 1 DFN2.5x1-10L E PIN1 INDICATOR (LASER MARK) DIMENSIONS DIM A A2 A1 b1xN1 b2 L 2 L2 L1 h 1 e MIN NOM MAX MIN NOM MAX 0.018 0.020 0.022 0.45 0.50 0.55 A1 0.000 0.001 0.002 0.00 0.02 0.05 0.006 D/2 0.15 b 0.006 0.008 0.010 0.15 0.20 0.25 b1 0.014 0.016 0.018 0.35 0.40 0.45 b2 0.008 0.010 0.018 0.20 0.25 0.45 D 0.096 0.098 0.100 2.45 2.50 2.55 E 0.037 0.039 0.041 0.95 1.00 1.05 e bxN MILLIMETERS A A2 R0.1 E/2 INCHES 0.020 BSC 0.50 BSC L 0.014 0.016 0.018 0.35 0.40 0.45 L1 0.000 0.003 0.004 0.00 0.075 0.10 L2 0.000 0.002 0.003 0.00 0.05 0.08 h 0.000 0.005 0.006 0.00 0.12 0.15 N 8 8 N1 2 2 DIMENSIONS P1 P Y C Y1 G X X1 DIM INCHES MILLIMETERS C 0.034 0.875 G 0.008 0.20 P 0.020 0.50 P1 0.039 1.00 X 0.010 0.25 X1 0.018 0.45 Y 0.027 0.675 Y1 0.061 1.55 Notes: Controlling Dimension: Millimeter. Marking Codes Part Number WS05-4R2PJ Marking Code 5R2P Package Information Qty:3k/Reel CONTACT INFORMATION No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207 Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com WAYON website: http://www.way-on.com For additional information, please contact your local Sales Representative. ® is registered trademark of Wayon Corporation. Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. ©2019 WAYON Corporation www.way-on.com 5/5
WS05-4R2PJ 价格&库存
很抱歉,暂时无法提供与“WS05-4R2PJ”相匹配的价格&库存,您可以联系我们找货
