XKB Connecitity
*15.30 [0.602]
XKB Connecitity
MATERIAL 材料:
HOUSING 外壳: LCP,UL94V-0,BLACK.
TERMINAL 端子: PHOSPHOR BRONZE T=0.35MM, GOLD PLATING ON CONTACT AREA
SHIELD 保护物 : C2680,T=0.20MM,20~50U'' MIN NICKEL PLATING ON ALL AREA.
MECHANICAL 机械:
DURABILITY 耐用性: 750 CYCLES MIN,12.5MM/MINUTE.
INSERTION FORCE 插入力:2.2KG.F MAX
RETENTION STRENGTH 保持力:7.7KG.F BETWEEN JACK AND PLUG.
OPERATING TEMPERATURE 工作温度 : -40°C~+85°C.
STORAGE TEMPERATURE 储存温度 : -40°C~+85°C.
ALL CRITICAL DIMENSIONS WITH "*"
ELECTRICAL电气:
VOLTAGE 电压: 125 VOLTS AC.
CURRENT RATING 电流额定值 : 1.5AMP.
DIELECTRIC STRENGTH 介电强度 : 1000 VAC RMS 50HZ OR 60HZ,1 MIN
INSULATION RESISTANCE 绝缘电阻 : 500 MEGA OHMS MIN.INITIAL
AFTER 500V DC FOR 1 MINUTE.
CONTACT RESISTANCE 接触电阻 :SINGLE TERMINAL 30 MILLIOHMS MAX.
INITIAL 50 MILLIOHMS MAX. AFTER
DURABILITY TEST.
1.10 [0.043]
2.00 [0.079]
8.00[0.315]
6.40[0.252]
LEFT SIDE VIEW
TOP VIEW
*16.30 [0.642]
GREEN
RIGHT
*11.10[0.437]
YELLOW
LEFT
RIGHT SIDE VIEW
14.15[0.557]
7.14[0.281]
1.02[0.040]
2.60[0.102]
8
6
4
2.29[0.090]
2
6.40[0.252]
8-Ø0.90[0.035]
12
7
11
5
3
1
10
R0
.9
4.20[0.165]
2.20[0.087]
0[0
.03
5]
0.70[0.028]
9
.039]
4-Ø1.00[0
14.00[0.551]
1.02[0.040]
PCB SIDE TO PHY
1.10[0.043]
5.32[0.209]
13.70[0.539]
4.00 [0.157]
FRONT VIEW
1
J1
2
J2
3
4
J3
J4
5
J5
6
J6
7
J7
Green
56 8nm
20mA
1.8 -2. 8 V
8
J8
Yellow
58 5nm
20mA
1.8 -2. 8 V
CABLE SIDE
4.20[0.165]
*2.00 [0.079]
Standard LED Color LED Wavelength Foward(A)
Foward(V)
16.08[0.633]
RECOMMENDED PCB LAYOUT
VIEWED FROM COMPONENT SIDE
7.14[0.281]
BOTTOM VIEW
X39ADAB1W1DB1075
1:AU=1U"
3:AU=3U"
4:AU=6U"
5:AU=15U"
6:AU=30U"
X
X
X
MARK
LED Specification
DATE
DESCRIPTION
REVISIONS
www.helloxkb.com
www.helloxkb.cn www.xk-dg.cn
REVISED
APPROVED
ANGLAR
L≤ 4
4
很抱歉,暂时无法提供与“X39ADAB1W1DB1075”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.13240
- 10+6.79320
- 30+6.05880
- 100+4.70448
- 500+4.37400
- 1000+4.22820
