ZGY133/T10(PLT)
ZGY133/T10(PLT)
    CHAULIGHT(洲光源)
    插件
    光纤收发器 插件
ZGY133/T10(PLT) 数据手册
CHAU LIGHT Technical Data Sheet ZGY133/T10(PLT) Photo-link Light Transmitter Unit Descriptions The opto-electrical component is assembled with a 660nm AlGaInP LED and a driver IC. It transforms the electrical signal to optical signal and be transmitted by1mm diameter plastic optical fiber. The component is operated at +3~+5V and has good performance at low dissipation current, steady light output and efficient light coupling. Features     High speed signal transmission(16Mbps NRZ Signal) TTL interface compatible +3~+5V single power source The product itself will remain within RoHS compliant version. Applications    Digital audio equipment CD player DVD player Device Selection Guide GuangDong Chau Light Infrared Semiconductor Co., Ltd. www.zgy-led.com Phone: +86-0760-8850 4720 Mobile: +86-180 2201 9379 E-mail:tonny@zgy-led.com 第 1 页 共 5 页 CHAU LIGHT Technical Data Sheet Absolute Maximum Ratings (Ta=25℃) Notes: Soldering time≦10 seconds. Recommended Operating Conditions GuangDong Chau Light Infrared Semiconductor Co., Ltd. www.zgy-led.com Phone: +86-0760-8850 4720 Mobile: +86-180 2201 9379 E-mail:tonny@zgy-led.com 第 2 页 共 5 页 CHAU LIGHT Technical Data Sheet Electro-Optical Characteristics (Ta=25ºC,Vcc=5.0V, 16Mbps) *Note 1 : All Plastic Optical Fiber(980/1000um) *Circuit Layout Notice: When power is off, it must be cut off together in Vin and Vcc pin. If it only has Vcc power-off, LED will sure to be no output power. GuangDong Chau Light Infrared Semiconductor Co., Ltd. www.zgy-led.com Phone: +86-0760-8850 4720 Mobile: +86-180 2201 9379 E-mail:tonny@zgy-led.com 第 3 页 共 5 页 CHAU LIGHT Technical Data Sheet Measuring Method *1 Measuring method of optical output coupling fiber and dissipation current *2 Pulse response measuring method GuangDong Chau Light Infrared Semiconductor Co., Ltd. www.zgy-led.com Phone: +86-0760-8850 4720 Mobile: +86-180 2201 9379 E-mail:tonny@zgy-led.com 第 4 页 共 5 页 CHAU LIGHT Technical Data Sheet Package Dimension Pin Function:1.Vin 2.Vcc 3.GND 4.NC 5.NC Notes: 1.All dimensions are in millimeters. 2.General Tolerance :±0.3mm Using Method PCB Layout for Electrical Circuit Notes: 1. unit:mm 2. 2.Dimension Tolerance:±0.25mm 3. .Substrate Thickness:1.6mm GuangDong Chau Light Infrared Semiconductor Co., Ltd. www.zgy-led.com Phone: +86-0760-8850 4720 Mobile: +86-180 2201 9379 E-mail:tonny@zgy-led.com 第 5 页 共 5 页
ZGY133/T10(PLT) 价格&库存
很抱歉,暂时无法提供与“ZGY133/T10(PLT)”相匹配的价格&库存,您可以联系我们找货
