RJ-3W-6R8-5X16-YH
RJ-3W-6R8-5X16-YH
    YH(缘和)
    插件
    插件电阻 插件 6.8Ω 3W
RJ-3W-6R8-5X16-YH 数据手册
YH CARBON Page 1 of 11 FILM RESISTORS DATE: 2009-4-29 广州市缘和电子有限公司 承認書 (APPROVAL SHEET) 客戶名稱 Client 品 名 Description CARBON CF1/6W FILM RESISTORS CF1/6W-CF5W ±5% 料 號 Part No 備 注 Remark 製造廠商: 核 準 Approval 李培元 使用廠商: 校 對 主 辦 Check By Prepared By 李培元 核 準 Approval 公 公 司 司 章 章 校 對 Check By 主 辦 Prepared By YH CARBON Page 2 of 11 FILM RESISTORS DATE: 2009-4-29 1.GENERAL INSTRUCTION: 1-1. SCOPE This specification applies to the Carbon Film Resistor MADE BY LGE ELECTRONICS IND.CORP. 1-2 .CLASSIFICATION Type CF CLASS number is described as 1/4W T POWER RATING SHAPE 2.NOMINAL RESISTANCE: follows. 1M OHM NOMINAL RESESTANCE VALUE J (±5%) TOLERANCE The nominal resistance shall be the resistance marked on the resistor body and identified, as a rule,in units,Ω,KΩ,MΩ. 3.NOMINAL RESISTANCE TOLERANCE. The nominal resistance tolerance is represented in one capital letter selected from G(±2%),J(±5%), K(±10%),M(±20%). 4.RATING: CF(CARBON FILM FIXED RESISTORS) STYLE MAX WORKING MAX OVERLOAD RESISTANCE VALUE RANGE CF1/6W / CF1/8W 200V 400V 0.1Ω~22MΩ CF1/4W / CF1/4WS 300V 600V 0.1Ω~22MΩ CF1/2W / CF1/2WS 350V 700V 0.1Ω~22MΩ CF1W / CF1WS 500V 1000V 0.1Ω~22MΩ CF2W / CF2WS 500V 1000V 0.1Ω~22MΩ CF3W / CF3WS 600V 1000V 0.1Ω~22MΩ CF5W / CF5WS 600V 1000V 0.1Ω~22MΩ 4-1. POWER RATING YH CARBON Page 3 of 11 FILM RESISTORS DATE: 2009-4-29 power rating is defined as maximum power rating continuously applied under ambient temperature at 70℃.when the ambient temperature exceeds 70℃,use chart 1. -30 4-2. RATED VOLTAGE Rated voltage is defined as the DC or (AC effective Value at commercial frequency example 50 C/S, 60 C/S) Voltage when rated power is applied and can be calculated By the following EQUATIONE=√P*R E=RATED VOLTAGE P=RQTED POWER (WATTS) R=NOMINAL RESISTANCE VALUE (OHM) When the calculated rated voltage exceeds the Maximum usable voltage flue shown in CHART 1,the Maximum usable voltage is defined as the voltage According to the power-decreasing curve shown in CHART1. ITEM (STANDARD) Resistance value Vs Temperature Characteristics PERFORMANCE AND/OR QUALIITY ACCEPTANCE For RX∠100KΩ +350~-500PPM/℃ 100KΩ≦RX ≦1MΩ 0~-700PPM/℃ 1 MΩ ∠ RX 0~-1500PPM/℃ TEST METHOD JIS-C-5202 5.2 Measure resistance (Ro ohm) at room Temperature(To ℃) Measure again the same at 100℃ Higher than room temperature R – RO 106 PPM = * RO (T0+100) –T0 YH CARBON Short time overload ITEM (STANDARD) Page 4 of 11 FILM RESISTORS DATE: 2009-4-29 JIS-C-5202 5.5 The resistance variation shall be Apply DC voltage 2.5times the rated within±(0.75% + 0.05 ohm) and there Voltage for 5 seconds Shall be no mechanical breakage The leave at room temperature for 30 Minutes then measure MAX overload Voltage 0.50W – 700V (DC) PERFORMANCE AND/OR QUALIITY ACCEPTANCE TEST METHOD JIS-C-5202 5.6 In V-BLOCK Lay the resistor on 90° angle metal V Block apply 100VDC between resistor Lead and V block for one Minute And Measure JIS-C-5202 5.7 Icy the resistor on the 90° angle metal V Block and apply reamed AC voltage for One Minute. Test voltage 0.25W – 500V (AC) 0.50W –700V(AC) JIS-C-5202 5.8 Apply AC voltage 4 times the rated voltage for 1 second and rest for 25 seconds and Repeat this cycle for 10000±200times leave resistor 30 minutes at room temperature after test and measure Maximum voltage for intermittent Overload.0.50W-700V(AC) Insulation resistance 1000M ohm or more Voltage endurance The resistance variation shall be within±(2% + 0.05ohm) and there shall be no mechanical breakage Intermittent overload Resistance variation shall be Within ±(2.00% + 0.05ohm) Terminal strength Resistance variation shall be within ±(0.5% + 0.05ohm) also there Shall be on mechanical breakage Heat resistively Against soldering Resistance variation shall be within ± JIS-C-5202 7.10 (1.0%+0.05ohm) also there Dip the lead in to a solder bath having a Shall be on mechanical breakage Temperature of 350℃ ± 10℃ up to 4±0.8mm from the body of the resistor at room temperature 3 hours after ,then Measure Solder ability More than 95% of the surface of the lead shall be covered by new solder after the leads are dipped in the Solder Humidity load test Resistance variation be Within ± (3.0% + 0.05ohm) Also there shall be mo mechanical breakage Pull test: apply 2.5kg force to the lead in the direction of lead axislor30±5 seconds. JIS-C-5202 6.5 Dip the lead in to a solder bath having a Temperature of 260℃±5℃ up to 4±0.8mm from the body of the resistor and hold it for 5 ± 0.5seconds then inspect JIS-C-5202 7.9 In temperature chamber having temperature 40℃±2℃,relative humidity 90 – 95%, Apply rated voltage 1.5hour and shut voltage 0.5 hour repeat this cycle for 1000 hours, leave in room temperature for lhour YH CARBON Load life test Page 5 of 11 FILM RESISTORS DATE: 2009-4-29 after test, then measure The variation of the resistance Shall be within ± (3%+0.05ohm) Also there shall be no mechanical Breakage JIS-C-5202 7.10 In the constant temperature chamber having Temperature70℃ ± 2℃,apply rated Dc voltage for 1.5hour and shut voltage for 0.5 hour and repeat thin cycle for 1000 hours, leave in room temperature lhour after test, then measure 5. Marking Color refer Color Black Brown Red Orange Yellow Green Blue Violet Grey White Gold Silver Tolerance Number of zeros or decimal multiplier 2 nd significant figure 1 st significant figure 1 st Band 0 1 2 3 4 5 6 7 8 9 6. Construction and Dimension 6-1. .Construction a. Tinned Copper Wire . b. Tinned Iron Caps. c. Carbon Film d. Ceramic Rod e. Epoxy Resin. 2 nd Band 0 1 2 3 4 5 6 7 8 9 3 rd Band 100 101 102 103 104 105 106 107 108 109 10-1 10-2 4 th Band ±2.0% ±5.0% ±10.0% YH CARBON f. Color Code 6-2 Page 6 of 11 FILM RESISTORS DATE: 2009-4-29 Dimensions TABLE: WATTS 1/6W 1/8W 1/16W 1/4WS 1/4W 1/2WS 1/2W 1WS 1W 2WS 2W 3WS 3W 5WS 5W 7. FORMED DIMENSIONS 7-1. M – TYPE L D H d ± 0.05mm PULLING (Kg) 3.3±0.3 1.8±0.3 28±2.0 0.33 2.5Kg - 30S 6.0±0.5 2.3±0.3 27.0±2.0 0.33 2.5Kg - 30S 8.0±0.5 2.5±0.3 26.0±2.0 0.40 2.5Kg - 30S 11.0±1.0 3.5±0.5 25.0±2.0 0.45 3Kg - 30S 15.0±1.0 4.0±0.5 33.0±2.0 0.50 5Kg - 30S 17.0±1.0 6.0±0.5 32.0±2.0 0.60 5Kg - 30S 24.0±1.0 8.0±1.0 28.0±2.0 0.70 5Kg - 30S YH CARBON Page 7 of 11 FILM RESISTORS WATTS DIMENSIONS (mm) P±1.0 D d±0.05 L 3.3±0.3 6.0±0.5 8.0±0.5 11.0±1.0 15.0±1.0 17.0±1.0 24.0±1.0 1/6W/1/8W/1/16W /1/4WS 1/4W/1/2WS 1/2W/1WS 1W/2WS 2W/3WS 3W/5WS 5W DATE: 2009-4-29 6 10 12.5 15 20 23 33 1.8±0.3 2.3±0.3 2.5±0.3 3.5±0.5 4.0±0.5 6.0±0.5 8.0±1.0 0.33 0.33 0.40 0.45 0.50 0.60 0.70 H±1.0 6.0 10 10 12.5 15.0 15.0 15.0 7-2 . MB – TYPE WATTS 1/2W/1WS 1W/2WS 2W/3WS 3W/5WS L 8.0±0.5 11.0±1.0 15.0±1.0 17.0±1.0 P±1.0 12.5 15 20 23 5W 24.0±1.0 33 DIMENSIONS (mm) D d±0.05 H1±1.0 2.5±0.3 0.60 6.0 3.5±0.5 0.60 6.0 4.0±0.5 0.60 10.0 6.0±0.5 0.70 10.0 8.0±1.0 0.70 10.0 H2±1.0 5.0 5.0 5.0 5.0 t±0.2 1.0 1.3 1.3 1.3 5.0 1.3 7 – 3. F – TYPE WATTS L 1/4W/1/2WS 6.0±0.5 8.0±0.5 1/2W/1WS 11.0±1.0 1W/2WS 15.0±1.0 2W/3WS 17.0±1.0 3W/5WS DIMENSIONS (mm) P±1.0 6 6 6 6 6 D 2.3±0.3 2.5±0.3 3.5±0.5 4.0±0.5 6.0±0.5 d±0.05 0.33 0.40 0.45 0.50 0.60 h±1.0 5.0 5.0 5.0 5.0 5.0 H±1.0 14 18 20 25 30 Emax 3 3.5 3.5 3.5 3.5 Page 8 of 11 YH CARBON FILM RESISTORS DATE: 2009-4-29 7 – 4. FK2-TYPE,FK1-TYPE AND FKK-TYPE WATTS 1/2W/1WS 1W/2WS 2W/3WS 3W L 8.0±0.5 11.0±1.0 15.0±1.0 17.0±1.0 DIMENSIONS(mm) D d±0.02 h+1/-0 P±1.0 2.5±0.3 3.5±0.5 4.0±0.5 6.0±0.5 6 6 6 6 0.40 0.45 0.50 0.60 H±1.0 5 5 5 5 Emax 18 20 25 30 3.5 3.5 3.5 3.5 8. Taping Dimensions E D1 D2 P z S T W WATTS Type T p±0.5 W±0.5 D1-D2 MAX 1/6W/1/8W T- 26 26±1.5 5 6 0.8 E Z S I MAX MAX MAX MAX 0 1.2 0.8 3.2 YH CARBON 1/16W/1/4WS T- T- T- T- T- T- T- 1/4W 1/2WS 1/2W/1WS 1W/2WS 2W/3WS 3W/5WS 5W Page 9 of 11 FILM RESISTORS DATE: 2009-4-29 52 26 52 52 73 73 73 52±1.5 26±1.5 52±1.5 52±1.5 73±1.5 73±1.5 73±1.5 5 5 5 5 5 10 10 6 6 6 6 6 6 6 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0 0 0 0 0 0 0 1.2 1.2 1.2 1.2 1.4 1.4 1.4 0.8 0.8 0.8 0.8 0.8 0.8 0.8 3.2 3.2 3.2 3.2 3.2 3.2 3.2 T- 73 73±1.5 10 6 0.8 0 1.4 0.8 3.2 9 .PACKING 9 - 1. TAPING TYPE LABEL SPECIFICATION 1. TYPE 2. WATTS TOLERANCE 3. RESISTANT QUANTITY LIEAN-GIMN ENTERPRISE CO, LTD 4. P/N 5. LOT NO. W LABEL 標簽 H VIEWHOLE 檢視窗 L TYPE WATTS W(mm) H(mm) L(mm) Q,TY(pcs) T-26 1/6W 1/8W 1/16W 1/4WS 50 72 260 5000 1/4W/ 1/2WS 53 103 260 5000 1/6W / 1/8W 1/16W 1/4WS 73 72 267 5000 1/4W/ 1/2WS 73 102 267 5000 T-52 YH CARBON T-73 9 – 2. BULK Page 10 of 11 FILM RESISTORS DATE: 2009-4-29 1/2W/ 1WS 73 57 255 1000 1W/ 2WS 92 83 267 1000 2WS/ 3WS 92 89 267 1000 3W/5WS 92 83 267 500 5W 92 83 267 500 W 標簽(LABEL) H L YH CARBON WATTS 1/6W 1/8W 1/16W 1/4WS 1/4W 1/2WS 1/2W 1WS 1W 2WS 2W 3WS Page 11 of 11 FILM RESISTORS TYPE P MOLDING P MOLDING P MOLDING P MOLDING P MOLDING L(mm) DATE: 2009-4-29 W(mm) H(mm) POLY BOG BOX(pcs) 250 140 67 1000 20000 250 140 67 500 10000 250 140 67 500 5000 250 140 67 200 2000 250 140 67 200 1000 250 140 67 100 1000 250 140 67 100 1000 P 3W/5WS MOLDING P 5W MOLDING
RJ-3W-6R8-5X16-YH 价格&库存
很抱歉,暂时无法提供与“RJ-3W-6R8-5X16-YH”相匹配的价格&库存,您可以联系我们找货
RJ-3W-6R8-5X16-YH
