MCWR04W1R00FTL
MCWR04W1R00FTL
    MULTICOMP
    贴片电阻 0402 1Ω ±1% 1/16W -200~+400ppm/℃
MCWR04W1R00FTL 数据手册
Thick Film Chip Resistors Description: The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to within tolerance by laser cutting of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a Tin (lead free) alloy. Features: •  •  •  •  High reliability and stability Reduced size of final equipment Lower assembly costs Higher component and equipment reliability Application: Quick Reference Data •  Consumer electrical equipment •  EDP, Computer application •  Telecom application Item General Specification Series No. MCWR12 MCWR08 MCWR06 MCWR04 Size code 1206(3216) 0805(2012) 0603(1608) 0402(1005) Resistance Range 1Ω to10MΩ 1% tolerance Resistance Tolerance 1% E96/E24 TCR (ppm/°C) 10MΩ ≥R >10 R≤10Ω ≤ ± 100 -200 to +400 Max. dissipation @ Tamb=70°C 1/4 W 1/8 W 1/10 W 1/16 W Max. Operation Voltage (DC or RMS) 200V 150V 75V 50V Max. Overload Voltage (DC or RMS) 400V 300V 150V 100V Climatic category 55/155/56 Note : 1. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV =  Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower. 2. The resistance of Jumper is defined 1MΩ 4.7Ω =4R7_ 10Ω =100_ 220Ω =221_ Jumper =000_ ("_" means a blank) ±1%, E24+E96: 3 significant digits followed by no. of zeros 102Ω =1020 37.4KΩ =3742 G : 13" Reeled taping L Termination code L = Sn base (lead free) H : 13" reel 50Kpcs only for 0402 B : Bulk D : 7" reel 20Kpcs only for 0402 A : 7" reel 15Kpcs only for 0402 MCWR12, MCWR08, MCWR06: 1. Reeled tape packaging : 8mm width paper taping 5,000pcs per 7" reel, 10kpcs per 10" reel, 20kpcs per 13" reel. 2. Bulk packaging : 5,000pcs per poly-bag MCWR04: 1. Reeled tape packaging : 8mm width paper taping 10,000pcs per 7" reel, 20,000pcs per 10" reel. 70,000pcs per 13" reel. 2. Bulk packaging : 10,000pcs per poly-bag Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 09/09/19 V1.0 Thick Film Chip Resistors Test and Requirements: Essentially all tests are carried out according to the schedule of IEC publication 115-8, category LCT/UCT/56 (rated temperature range : Lower Category Temperature, Upper Category Temperature; damp heat, long term, 56 days). The testing also meets the requirements specified by EIA, EIAJ and JIS. The tests are carried out in accordance with IEC publication 68, "Recommended basic climatic and mechanical robustness testing procedure for electronic components" and under standard atmospheric conditions according to IEC 60068-1, subclause 5.3. Unless otherwise specified, the following value supplied : Temperature: 15°C to 35°C. Relative humidity: 45% to 75%. Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar). All soldering tests are performed with midly activated flux. Test Electrical Characteristics JISC5201-1: 1998 Clause 4.8 Procedure / Test Method Requirement Resistor 0Ω - DC resistance values measurement - Temperature Coefficient of Resistance (T.C.R) Within the specified tolerance Refer to t1 : 20°C+5°C/-1 °C; t2 : -55°C or +155°C "QUICK REFERENCE
MCWR04W1R00FTL 价格&库存
很抱歉,暂时无法提供与“MCWR04W1R00FTL”相匹配的价格&库存,您可以联系我们找货
MCWR04W1R00FTL
  • 50+0.02685
  • 500+0.02441
  • 5000+0.02115
  • 30000+0.02034
  • 90000+0.01953
