RG050M221LO8*20TA-1A1E
    BERYL(绿宝石)
    CAP_D8X20.2MM_TM
    220UF ±20% 50V
RG050M221LO8*20TA-1A1E 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RG Series Low impedance,downsized Power Supply Output,105℃ 6000~10000hours ● RoHS2.0 Compliant ● ● ◆ 规格表 Specifications 项目Items 特性参数Characteristics 使用温度范围 Category Temperture Range -40 ~ +105℃ 额定工作电压范围 Rated Voltage Range 6.3 ~ 100V.DC 静电容量允许偏差 Capacitance Tolerance ±20%(M) (at 20℃,120Hz) I≤0.01CV or 3μA, 二者取最大值(施加额定工作电压2分钟后) Whichever is greater (After 2 minutes application of rated voltage ) 漏电流 Leakage Current Note: I=Max.leakage current (μA), C=Nominal capacitance(μF), V=Rated voltage(V) Rated voltage(V) 6.3 10 16 25 35 50 63 80 100 tanδ (Max.) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.09 0.08 损耗角正切值tanδ Dissipation Factor (at 20℃) 标称容量超过1000uF,则每增加1000uF,损耗角正切值增加0.02 When nominal capacitance exceeds 1000μF,add 0.02 to the value above for each 1000μF increase. (at 20℃,120Hz) 低温特性 Low Temperature Characteristics (Max.Impedance Ratio) 阻抗比值不得超过下表中列出的值 The impedance ratio shall not exceed the values listed in the below table. Rated voltage(V) 6.3 4 8 Z(-25℃)/Z(+20℃) Z(-40℃)/Z(+20℃) 10 3 6 16 2 4 25 2 3 35 2 3 50 2 3 63 2 3 80 2 3 100 2 3 (at 120Hz) 在105℃环境中,不超过额定电压的范围内叠加最大允许纹波电流,连续加载右表时间,经恢复到20℃后,电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored to 20℃ after applied within maximum allowable ripple current and not over rated voltage range for the time in the table at 105℃. 耐久性 6.3~10V 额定电压(Vdc) Endurance 16~100V 时间(hrs) Capacitance change ≦±30% of the initial value D.F.(tanδ) ≦200% of the initial specified value≦200% of the initial specified value Leakage current ≦The initial specified value Φ5 ~Φ6.3:6000 Φ8 ~Φ10:8000 ≥Φ13:10000 ≦±25% of the initial value ≦The initial specified value 在105℃环境中,不施加电压条件下储存1000小时,经恢复到20℃后,电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored at 20℃ after exposing them for 1000 hours at 105℃ without voltage applied. 高温储存特性 Shelf Life Capacitance change ≦±25% of the initial value D.F.(tanδ) ≦200% of the initial specified value Leakage current ≦200% of the initial specified value ◆ 尺寸图(单位:mm)DIMENSIONS (Unit:mm) L± α. Safety Vent (Φ8up) 15min. 5min. F±0.5 Vinyl sleeve Rubber end seal Φd±0.05 Tinned copper-ply wire 22 ~ 180 220 ~ 560 680 ~ 1,800 2,200 ~ 3,900 4,700 ~ 6.3 F 2.0 Φd 0.5 α ● 频率系数 Frequency Coefficient Capacitance(μF) 5 D±0.5 ◆ 纹波电流补正系数 Rated Ripple Current Coefficient Frequency(Hz) ΦD 120 1k 10k 100k 0.40 0.50 0.60 0.75 0.85 0.75 0.85 0.87 0.90 0.95 0.90 0.94 0.95 0.95 0.98 1.00 1.00 1.00 1.00 1.00 -25- 8 10 13 16 18 2.5 3.5 5.0 5.0 7.5 7.5 0.5 0.5/0.6 0.6 0.6 0.8 0.8 (L
RG050M221LO8*20TA-1A1E 价格&库存
很抱歉,暂时无法提供与“RG050M221LO8*20TA-1A1E”相匹配的价格&库存,您可以联系我们找货
