SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
MVL
Series
3000 to 5000-hours-life, 105℃
MVL
・Endurance : 3,000 to 5,000 hours at 105℃
・Suitable for applications requiring long life such as continuously operating
equipment, industrial applications, etc
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
Longer life
MVJ
◆SPECIFICATIONS
Items
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. impedance Ratio)
Endurance
Shelf Life
Characteristics
-40 to +105℃
6.3 to 50Vdc
(at 20℃,120Hz)
±20%(M)
I=0.03CV or 4µA, whichever is greater
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃, after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V
Max. tanδ
0.28 0.24 0.20 0.16 0.13 0.12
(at 20℃,120Hz)
Rated voltage(Vdc)
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
Z(-40℃)/Z(+20℃)
10
7
5
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for
specified time at 105℃.
D60 to F80:3,000 hours
Time
HA0 & JA0:5,000 hours
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
◆DIMENSIONS [mm]
●Terminal
◆PART NUMBERING SYSTEM
Code : A
1
P
C±0.2
B±0.2
φD±0.5
W
0.3max.
L±0.3 (Note)
A±0.2
Note : L±0.5 for HA0 and JA0
A
L
D
5.7 4.3
4
5.7 5.3
5
6.3 5.7 6.6
6.3 7.7 6.6
8 10.0 8.3
10 10.0 10.3
3
4
5
6
7
8
9
10
11
12
13
14
15
16
◆MARKING
17
EX) 16V47µF
18
E MV L AAA A RA AAA M AAA G
Vent for JA0
Size code
D60
E60
F60
F80
HA0
JA0
2
B
4.3
5.3
6.6
6.6
8.3
10.3
C
5.1
5.9
7.2
7.2
9.0
11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.0
1.4
1.9
1.9
3.1
4.5
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,10µF:100)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
9hL
47
16V
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001X 2023
TM
AIchip
MVLSeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
Cap
(µF)
Size code tanδ
22
47
100
220
330
1,000
33
220
10
22
47
100
470
33
47
100
330
D60
E60
F60
F80
HA0
JA0
E60
HA0
D60
E60
F60
F80
JA0
F60
F80
HA0
JA0
Rated ripple
current
(mArms/
105℃, 120Hz)
Part No.
22
36
60
101
160
313
35
141
18
30
50
81
254
48
63
116
238
EMVL6R3ARA220MD60G
EMVL6R3ARA470ME60G
EMVL6R3ARA101MF60G
EMVL6R3ARA221MF80G
EMVL6R3ARA331MHA0G
EMVL6R3ARA102MJA0G
EMVL100ARA330ME60G
EMVL100ARA221MHA0G
EMVL160ARA100MD60G
EMVL160ARA220ME60G
EMVL160ARA470MF60G
EMVL160ARA101MF80G
EMVL160ARA471MJA0G
EMVL250ARA330MF60G
EMVL250ARA470MF80G
EMVL250ARA101MHA0G
EMVL250ARA331MJA0G
0.28
0.28
0.28
0.28
0.28
0.28
0.24
0.24
0.20
0.20
0.20
0.20
0.20
0.16
0.16
0.16
0.16
Production of the products shown in
WV
(Vdc)
35
50
Cap
(µF)
4.7
10
22
33
220
1.0
2.2
3.3
4.7
10
22
33
47
100
Size code tanδ
D60
E60
F60
F80
JA0
D60
D60
D60
E60
F60
F80
HA0
HA0
JA0
0.13
0.13
0.13
0.13
0.13
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
Rated ripple
current
(mArms/
105℃, 120Hz)
15
25
42
57
216
6.2
11
14
19
30
49
77
92
151
Part No.
EMVL350ARA4R7MD60G
EMVL350ARA100ME60G
EMVL350ARA220MF60G
EMVL350ARA330MF80G
EMVL350ARA221MJA0G
EMVL500ARA1R0MD60G
EMVL500ARA2R2MD60G
EMVL500ARA3R3MD60G
EMVL500ARA4R7ME60G
EMVL500ARA100MF60G
EMVL500ARA220MF80G
EMVL500ARA330MHA0G
EMVL500ARA470MHA0G
EMVL500ARA101MJA0G
is scheduled to be discontinued.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
1.0
2.2 to 10
22 to 1,000
120
1.00
1.00
1.00
1k
1.50
1.30
1.05
10k
1.75
1.40
1.08
100k
1.80
1.50
1.08
The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer
to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note.
Product Guide
■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults
and accidents from occurring.
■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure
prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications.
■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for
use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or
property. In addition, our products are not intended to be used in specific applications that may cause a major social impact.
Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power
generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles,
trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized
information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose
applications.
■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations
and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment
systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You
should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and
determine whether or not our products suit your requirements according to the specifications of your equipment systems.
Therefore, you bear final responsibility regarding the use of our products.
Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention
measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction.
■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We
assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel
or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our
official sales channel.
■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this
catalog will be available in the future.
The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific
products
■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our
published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming
goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be
accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual
non-conforming product, or in other ways deemed necessary.
In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any
potential compensation.
Part Numbering System
Part Numbering System (Appendix)
Standardization
Available Items by Manufacturing Locations
Environmental Measures
Technical Note
Precautions and Guidelines
Recommended Soldering Conditions
Taping, Lead-preforming and Packaging
Available Terminals for Snap-in and Screw Mount Type
很抱歉,暂时无法提供与“EMVL160ADA470MF60G”相匹配的价格&库存,您可以联系我们找货
