AS5045-ASST
AS5045-ASST
    AMSOSRAM(艾迈斯半导体)
    SSOP-16
    旋转编码器 磁性 PWM
AS5045-ASST 数据手册
Product Document Published by ams OSRAM Group AS5045 12-Bit Programmable Magnetic Rotary Position Sensor General Description The AS5045 is a contactless magnetic position sensor for accurate angular measurement over a full turn of 360°. It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing in a single device. To measure the angle, only a simple two-pole magnet, rotating over the center of the chip, is required. The magnet may be placed above or below the IC. The absolute angle measurement provides instant indication of the magnet’s angular position with a resolution of 0.0879° = 4096 positions per revolution. This digital data is available as a serial bit stream and as a PWM signal. An internal voltage regulator allows the AS5045 to operate at either 3.3 V or 5 V supplies. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS5045, 12-Bit Programmable Magnetic Rotary Position Sensor are listed below: Figure 1: Added Value of Using AS5045 Benefits Features • Highest reliability and durability in harsh environments • Contactless absolute angle position measurement • Great flexibility during assembly • User programmable zero position • Operation safety • Diagnostic modes for magnet detection and power supply loss • Lower material cost (no magnetic shielding needed) • Immune to external magnetic stray fields • Two digital 12-bit absolute outputs: • Serial interface and • Pulse width modulated (PWM) output • Failure detection mode for magnet placement monitoring and loss of power supply • “Red-Yellow-Green” indicators display placement of magnet in Z-axis Datasheet, Public [v3-00] 2022-Mar-03 Page 1 Document Feedback AS5045 − General Description • Serial read-out of multiple interconnected AS5045 devices using Daisy Chain mode • Tolerant to magnet misalignment and airgap variations • Wide temperature range: - 40ºC to 125ºC • Small Pb-free package: SSOP-16 (5.3mm x 6.2mm) Applications The AS5045 is ideal for industrial applications like • Robotics, • Stepper motor control, • RC servo control and • Replacement of high-end potentiometers. Block Diagram The functional blocks of this device are shown below: Figure 2: AS5045 Block Diagram VDD3V3 VDD5V MagINCn MagDECn LDO 3.3V PWM Interface Sin Hall Array & Frontend Amplifier Mode Page 2 Document Feedback Cos PWM Ang DSP Mag Absolute Interface (SSI) DO CSn CLK OTP Register Prog_DI AS5045 Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Pin Assignment Pin Assignment Figure 3: Pin Assignment (Top View) 1 16 VDD5V MagDECn 2 15 VDD3V3 NC 3 14 NC NC 4 13 NC NC 5 12 PWM Mode 6 11 CSn VSS 7 10 CLK Prog_DI 8 9 DO AS5045 MagINCn Pin Description Figure 4 shows the description of each pin of the standard SSOP16 package (Shrink Small Outline Package, 16 leads, body size: 5.3mm x 6.2mmm; see Figure 3). Pins 7, 15 and 16 supply pins, pins 3, 4, 5, 6, 13 and 14 are for internal use and must not be connected. Pins 1 and 2 MagINCn and MagDECn are the magnetic field change indicators (magnetic field strength increase or decrease through variation of the distance between the magnet and the device). These outputs can be used to detect the valid magnetic field range. Furthermore those indicators can also be used for contact-less push-button functionality. Pin 6 Mode allows switching between filtered (slow) and unfiltered (fast mode). This pin must be tied to VSS or VDD5V, and must not be switched after power up. See Mode Input Pin. Pin 8 Prog is used to program the zero-position into the OTP. See Zero Position Programming. This pin is also used as digital input to shift serial data through the device in Daisy Chain configuration. See Daisy Chain Mode. Pin 11 Chip Select (CSn; active low) selects a device within a network of AS5045 magnetic position sensors and initiates serial data transfer. A logic high at CSn puts the data output pin (DO) to tri-state and terminates serial data transfer. This pin is also used for alignment mode and programming mode (see Figure 27). Datasheet, Public [v3-00] 2022-Mar-03 Page 3 Document Feedback AS5045 − Pin Assignment Pin 12 PWM allows a single-wire output of the 10-bit absolute position value. The value is encoded into a pulse width modulated signal with 1μs pulse width per step (1μs to 4096μs over a full turn). By using an external low pass filter, the digital PWM signal is converted into an analog voltage, making a direct replacement of potentiometers possible. Figure 4: Pin Description Pin Number Pin Name 1 MagINCn Pin Type Digital output open drain Description Magnet Field Magnitude INCrease; active low, indicates a distance reduction between the magnet and the device surface (see Figure 16). Magnet Field Magnitude DECrease; active low, indicates a distance increase between the device and the magnet see Figure 16). 2 MagDECn 3 NC - 4 NC - 5 NC - 6 Mode - Select between slow (low, VSS) and fast (high, VDD5V) mode. Internal pull-down resistor. Must be hard-wired on the PCB in application. 7 VSS Supply pin Negative Supply Voltage (GND) 8 Prog_DI Digital input pull-down OTP Programming Input and Data Input for Daisy Chain mode. Internal pull-down resistor (~74kΩ). Connect to VSS if not used 9 DO Digital output / tri-state Data Output of Synchronous Serial Interface 10 CLK Digital input, Schmitt-Trigger input Clock Input of Synchronous Serial Interface; Schmitt-Trigger input 11 CSn Digital input pull-up, Schmitt-Trigger input Chip Select, active low; Schmitt-Trigger input, internal pull-up resistor (~50kΩ) 12 PWM Digital output Pulse Width Modulation of approx. 244Hz; 1μs/step (optional 122Hz; 2μs/step) 13 NC - 14 NC - 15 VDD3V3 Must be left unconnected Must be left unconnected Supply pin 16 VDD5V Page 4 Document Feedback 3V-Regulator Output, internally regulated from VDD5V. Connect to VDD5V for 3V supply voltage. Do not load externally. Positive Supply Voltage, 3.0 to 5.5 V Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Parameter Min Max Units Comments Electrical Parameters DC supply voltage at pin VDD5V -0.3 DC supply voltage at pin VDD3V3 7 V 5 V Input pin voltage -0.3 VDD5V +0.3 V Input current (latchup immunity) -100 100 mA Except VDD3V3 EIA/JESD78 Class II Level A Electrostatic Discharge Electrostatic discharge ±2 kV JESD22-A114E Temperature Ranges and Storage Conditions Storage temperature -55 150 Package body temperature Relative humidity non-condensing Moisture sensitivity level (MSL) Datasheet, Public [v3-00] 2022-Mar-03 5 3 ºC Min -67ºF; Max 302ºF 260 ºC The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). 85 % Represents a maximum floor life time of 168h Page 5 Document Feedback AS5045 − Electrical Characteristics Electrical Characteristics T AMB = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation), unless otherwise noted. Figure 6: Electrical Characteristics Symbol Parameter Condition Min Typ Max Units 125 °C 16 21 mA 5.0 5.5 Operating Conditions T AMB Ambient temperature Isupp Supply current VDD5V Supply voltage at pin VDD5V VDD3V3 Voltage regulator output voltage at pin VDD3V3 VDD5V Supply voltage at pin VDD5V VDD3V3 Supply voltage at pin VDD3V3 -40°F to 257°F -40 4.5 5V operation 3.3V operation (pin VDD5V and VDD3V3 connected) V 3.0 3.3 3.6 3.0 3.3 3.6 V 3.0 3.3 3.6 DC Characteristics CMOS Schmitt-Trigger Inputs: CLK, CSn (CSn = Internal Pull-Up) VIH High level input voltage VIL Low level input voltage VIon- VIoff Normal operation 0.7 * VDD5V V 0.3 * VDD5V Schmitt Trigger hysteresis 1 V V ILEAK Input leakage current CLK only -1 1 μA IIL Pull-up low level input current CSn only, VDD5V: 5.0V -30 -100 μA VDD5V V DC Characteristics CMOS / Program Input: Prog VIH High level input voltage VPROG High level input voltage VIL Low level input voltage IIL High level input current Page 6 Document Feedback 0.7 * VDD5V During programming VDD5V: 5.5V Refer to programming conditions (Figure 10) 30 V 0.3 * VDD5V V 100 μA Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Electrical Characteristics Symbol Parameter Condition Min Typ Max Units VSS+0.4 V DC Characteristics CMOS Output Open Drain: MagINCn, MagDECn VOL IO IOZ Low level output voltage VDD5V: 4.5V 4 VDD5V: 3V 2 Output current mA Open drain leakage current 1 μA DC Characteristics CMOS Output: PWM VOH High level output voltage VOL Low level output voltage IO VDD5V0.5 V VSS+0.4 VDD5V: 4.5V 4 VDD5V: 3V 2 Output current V mA DC Characteristics Tri-state CMOS Output: DO VOH High level output voltage VOL Low level output voltage IO IOZ VDD5V0.5 V VSS+0.4 VDD5V: 4.5V 4 VDD5V: 3V 2 Output current Tri-state leakage current Datasheet, Public [v3-00] 2022-Mar-03 V mA 1 μA Page 7 Document Feedback AS5045 − Electrical Characteristics Magnetic Input Specification Two-pole cylindrical diametrically magnetized source: Figure 7: Magnetic Input Specification Symbol Parameter dmag Diameter tmag Thickness Conditions Recommended magnet: Ø 6mm x 2.5mm for cylindrical magnets Bpk Magnetic input field amplitude Required vertical component of the magnetic field strength on the die’s surface, measured along a concentric circle with a radius of 1.1mm Boff Magnetic offset Constant magnetic stray field Field non-linearity fmag_abs Input frequency (rotational speed of magnet) Min Typ 4 6 Max mm 2.5 45 Units mm 75 mT ± 10 mT Including offset gradient 5 % 146 rpm @ 4096 positions/rev.; fast mode 2.44 Hz 36.6rpm @ 4096 positions/rev.; slow mode 0.61 Disp Displacement radius Maximum offset between defined device center and magnet axis 0.25 mm Ecc Eccentricity Eccentricity of magnet center to rotational axis 100 μm Page 8 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Electrical Characteristics Electrical System Specifications Figure 8: Input Specification Symbol RES Parameter Resolution INLopt Integral non-linearity (optimum) Conditions Min Typ 0.088 deg Maximum error with respect to the best line fit. Centered magnet without calibration, TAMB = 25°C Max Units 12 bit ± 0.5 deg INLtemp Maximum error with respect to the best line fit. Centered magnet without calibration, TAMB = -40°C to 125°C ± 0.9 INL Integral non-linearity Best line fit = (Errmax – Errmin) / 2 Over displacement tolerance with 6mm diameter magnet, without calibration, TAMB = -40°C to 125°C ± 1.4 deg DNL Differential non-linearity 12-bit, No missing codes ±0.044 deg TN VON VOFF 1 sigma, fast mode (MODE = 1) 0.06 1 sigma, slow mode (MODE=0 or open) 0.03 Power-on reset thresholds: On voltage; 300mV typ. hysteresis 1.37 tdelay 2.2 2.9 DC supply voltage 3.3V (VDD3V3) Power-on reset thresholds: Off voltage; 300mV typ. hysteresis V 1.08 Fast mode (Mode = 1); until status bit OCF = 1 tPwrUp deg RMS Transition noise 1.9 2.6 20 ms Power-up time System propagation delay absolute output : delay of ADC, DSP and absolute interface Datasheet, Public [v3-00] 2022-Mar-03 Slow mode (Mode = 0 or open); until OCF = 1 80 Fast mode (MODE=1) 96 Slow mode (MODE=0 or open) 384 μs Page 9 Document Feedback AS5045 − Electrical Characteristics Symbol fS fS CLK Parameter Conditions TAMB = 25°C, slow mode (MODE=0 or open) Internal sampling rate for absolute output: Min Typ Max 2.48 2.61 2.74 Units kHz Internal sampling rate for absolute output TAMB = -40°C to 125°C, slow mode (MODE=0 or open) 2.35 2.61 2.87 TAMB = 25°C, fast mode (MODE = 1) 9.90 10.42 10.94 kHz TAMB = -40°C to 125°C, fast mode (MODE = 1) 9.38 10.42 Maximum clock frequency to read out serial data Read-out frequency 11.46 1 MHz Figure 9: Integral and Differential Non-Linearity (Example) 4095 α 12bit code 4095 Actual curve 2 TN DNL+1LSB 1 0 2048 Ideal curve INL 0.09° 2048 0 0° 180° 360 ° α [degrees] Integral Non-Linearity (INL) is the maximum deviation between actual position and indicated position. Differential Non-Linearity (DNL) is the maximum deviation of the step length from one position to the next. Transition Noise (TN) is the repeatability of an indicated position. Page 10 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Timing Characteristics Timing Characteristics Figure 10: Timing Characteristics Symbol Parameter Conditions Min Typ Max Units 100 ns Synchronous Serial Interface (SSI) Data output activated (logic high) Time between falling edge of CSn and data output activated tCLK FE First data shifted to output register Time between falling edge of CSn and first falling edge of CLK 500 ns TCLK / 2 Start of data output Rising edge of CLK shifts out one bit at a time 500 ns tDO valid Data output valid Time between rising edge of CLK and data output valid 357 tDO tristate Data output tristate After the last bit DO changes back to “tristate” tCSn Pulse width of CSn CSn = high; To initiate read-out of next angular position 500 fCLK Read-out frequency Clock frequency to read out serial data >0 tDO active 375 394 ns 100 ns ns 1 MHz Pulse Width Modulation Output Signal period = 4097μs ±5% at TAMB = 25°C fPWM 232 244 256 Hz PWM frequency Signal period = 4097μs ±10% at TAMB = -40 to 125°C 220 244 268 PWMIN Minimum pulse width Position 0d; Angle 0° 0.95 1 1.05 μs PWMAX Maximum pulse width Position 4095d; Angle 359.91° 3891 4096 4301 μs Datasheet, Public [v3-00] 2022-Mar-03 Page 11 Document Feedback AS5045 − Timing Characteristics Symbol Parameter Conditions Min Typ Max Units Programming Conditions tProg enable Programming enable time Time between rising edge at Prog pin and rising edge of CSn 2 μs 2 μs 250 ns tData in Write data start tData in valid Write data valid tLoad PROG Load programming data 3 μs tPrgR Rise time of VPROG before CLKPROG 0 μs tPrgH Hold time of VPROG after CLKPROG 0 CLKPROG Write data – programming CLKPROG Ensure that VPROG is stable with rising edge of CLK CLK pulse width During programming; 16 clock cycles Hold time of VPROG after programming Programmed data is available after next power-on Programming voltage, pin PROG Must be switched off after zapping 7.3 Programming voltage off level Line must be discharged to this level 0 Programming current Analog read CLK tPROG tPROG finished VPROG VProgOff IPROG CLKAread Vprogrammed Vunprogrammed Programmed Zener voltage (log.1) Unprogrammed Zener voltage (log. 0) Page 12 Document Feedback Write data at the rising edge of CLK PROG 1.8 2 5 μs 250 kHz 2.2 μs 2 μs 7.5 V 1 V During programming 130 mA Analog Readback mode 100 kHz VRef-VPROG during Analog Readback mode (see Analog Readback Mode) 100 mV 1 7.4 V Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Detailed Description The AS5045 is manufactured in a CMOS standard process and uses a spinning current Hall technology for sensing the magnetic field distribution across the surface of the chip. The integrated Hall elements are placed around the center of the device and deliver a voltage representation of the magnetic field at the surface of the IC. Through Sigma-Delta Analog / Digital Conversion and Digital Signal-Processing (DSP) algorithms, the AS5045 provides accurate high-resolution absolute angular position information. For this purpose a Coordinate Rotation Digital Computer (CORDIC) calculates the angle and the magnitude of the Hall array signals. The DSP is also used to provide digital information at the outputs MagINCn and MagDECn that indicate movements of the used magnet towards or away from the device’s surface. A small low cost diametrically magnetized (two-pole) standard magnet provides the angular position information (see Figure 30). The AS5045 senses the orientation of the magnetic field and calculates a 12-bit binary code. This code can be accessed via a Synchronous Serial Interface (SSI). In addition, an absolute angular representation is given by a Pulse Width Modulated signal at pin 12 (PWM). This PWM signal output also allows the generation of a direct proportional analogue voltage, by using an external Low-Pass-Filter. The AS5045 is tolerant to magnet misalignment and magnetic stray fields due to differential measurement technique and Hall sensor conditioning circuitry. Figure 11: Typical Arrangement of AS5045 and Magnet Datasheet, Public [v3-00] 2022-Mar-03 Page 13 Document Feedback AS5045 − Detailed Description Mode Input Pin The mode input pin activates or deactivates an internal filter that is used to reduce the analog output noise. Activating the filter (Mode pin = LOW) provides a reduced output noise of 0.03° rms. At the same time, the output delay is increased to 384μs. This mode is recommended for high precision, low speed applications. Deactivating the filter (Mode pin = HIGH) reduces the output delay to 96μs and provides an output noise of 0.06° rms. This mode is recommended for higher speed applications. The MODE pin should be set at power-up. A change of the mode during operation is not allowed. Switching the Mode pin affects the following parameters. Figure 12: Slow and Fast Mode Parameters 12-Bit Absolute Angular Position Output Parameter Slow Mode (Mode = Low) Fast Mode (Mode = High, VDD5V) Sampling rate 2.61 kHz (384 μs) 10.42 kHz (96μs) Transition noise (1 sigma) ≤ 0.03° rms ≤ 0.06° rms Output delay 384μs 96μs Max. speed @ 4096 samples/rev. Max. speed @ 1024 samples/rev. Max. speed @ 256 samples/rev. Max. speed @ 64 samples/rev. 38 rpm 153 rpm 610 rpm 2441 rpm 153 rpm 610 rpm 2441 rpm 9766 rpm Page 14 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Synchronous Serial Interface (SSI) Figure 13: Synchronous Serial Interface with Absolute Angular Position Data tCLKFE CSn TCLK/2 tCLKFE tCSn 1 CLK DO D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 OCF COF Mag Mag LIN INC DEC tDO valid tDO active Datasheet, Public [v3-00] 2022-Mar-03 Angular Position Data 1 18 8 Status Bits Even PAR D11 tDO Tristate Page 15 Document Feedback AS5045 − Detailed Description If CSn changes to logic low, Data Out (DO) will change from high impedance (tri-state) to logic high and the read-out will be initiated. • After a minimum time tCLK FE, data is latched into the output shift register with the first falling edge of CLK. • Each subsequent rising CLK edge shifts out one bit of data. • The serial word contains 18 bits, the first 12 bits are the angular information D[11:0], the subsequent 6 bits contain system information, about the validity of data such as OCF, COF, LIN, Parity and Magnetic Field status (increase/decrease). • A subsequent measurement is initiated by a “high” pulse at CSn with a minimum duration of tCSn. Data Content D11:D0 – absolute angular position data (MSB is clocked out first) OCF – (Offset Compensation Finished), logic high indicates the finished Offset Compensation Algorithm COF – (CORDIC Overflow), logic high indicates an out of range error in the CORDIC part. When this bit is set, the data at D9:D0 is invalid. The absolute output maintains the last valid angular value. This alarm may be resolved by bringing the magnet within the X-Y-Z tolerance limits. LIN – (Linearity Alarm), logic high indicates that the input field generates a critical output linearity. When this bit is set, the data at D9:D0 may still be used, but can contain invalid data. This warning may be resolved by bringing the magnet within the X-Y-Z tolerance limits. Even Parity – Bit for transmission error detection of bits 1 …17 (D11 …D0, OCF, COF, LIN, MagINC, MagDEC). Placing the magnet above the chip, angular values increase in clockwise direction by default. Data D11:D0 is valid, when the status bits have the following configurations. Figure 14: Status Bit Outputs OCF 1 COF 0 LIN MagINC MagDEC 0 0 0 1 1 0 1(1) 1(1) 0 Parity Even checksum of bits 1:15 Note(s): 1. MagInc=MagDec=1 is only recommended in YELLOW mode (see Figure 16). Page 16 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Z-Axis Range Indication (Push Button Feature, Red/Yellow/Green Indicator) The AS5045 provides several options of detecting movement and distance of the magnet in the Z-direction. Signal indicators MagINCn and MagDECn are available both as hardware pins (pins 1 and 2) and as status bits in the serial data stream. Additionally, an OTP programming option is available with bit MagCompEn (see Figure 23) that enables additional features. In the default state, the status bits MagINC, MagDec and pins MagINCn, MagDECn have the following function. Figure 15: Magnetic Field Strength Variation Indicator Status Bits Hardware Pins OTP: Mag CompEn = 0 (default) MagINC MagDEC MagINCn MagDECn Description 0 0 Off Off No distance change Magnetic input field OK (in range, ~45mT to 75mT) 0 1 Off On Distance increase; pull-function. This state is dynamic and only active while the magnet is moving away from the chip. 1 0 On Off Distance decrease; push- function. This state is dynamic and only active while the magnet is moving towards the chip. 1 1 On On Magnetic field is ~~75mT. It is still possible to operate the AS5045 in this range, but not recommended Datasheet, Public [v3-00] 2022-Mar-03 Page 17 Document Feedback AS5045 − Detailed Description When bit MagCompEn is programmed in the OTP, the function of status bits MagINC, MagDec and pins MagINCn, MagDECn is changed to the following function. Figure 16: Magnetic Field Strength Red-Yellow-Green Indicator (OTP Option) Status Bits Hardware Pins OTP: Mag CompEn = 1 (Red-Yellow-Green Programming Option) Mag INC Mag DEC LIN Mag INCn Mag DECn Description 0 0 0 Off Off No distance change Magnetic input field OK (GREEN range, ~45mT to 75mT) 1 1 0 On Off YELLOW range: magnetic field is ~ 25mT to 45mT or ~75mT to 135mT. The AS5045 may still be operated in this range, but with slightly reduced accuracy. 1 1 1 On On RED range: magnetic field is ~~135mT. It is still possible to operate the AS5045 in the red range, but not recommended. All other combinations n/a n/a Not available Note(s): 1. Pin 1 (MagINCn) and pin 2 (MagDECn) are active low via open drain output and require an external pull-up resistor. If the magnetic field is in range, both outputs are turned off. The two pins may also be combined with a single pull-up resistor. In this case, the signal is high when the magnetic field is in range. It is low in all other cases (see Figure 15 and Figure 16). Page 18 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Daisy Chain Mode The Daisy Chain mode allows connection of several AS5045’s in series, while still keeping just one digital input for data transfer (see “Data IN” in Figure 17). This mode is accomplished by connecting the data output (DO; pin 9) to the data input (PROG; pin 8) of the subsequent device. An RC filter must be implemented between each PROG pin of device n and DO pin of device n+1, to prevent then magnetic position sensors to enter the alignment mode, in case of ESD discharge, long cables, not conform signal levels or shape. Using the values R=100R and C=1nF allow a max. CLK frequency of 1MHz on the whole chain. The serial data of all connected devices is read from the DO pin of the first device in the chain. The length of the serial bit stream increases with every connected device, it is n * (18+1) bits: For e.g., 38 bit for two devices, 57 bit for three devices, etc. The last data bit of the first device (Parity) is followed by a dummy bit and the first data bit of the second device (D11), etc. (see Figure 18). Figure 17: Daisy Chain Hardware Configuration CSn CLK DO CSn CLK DI MCU 100R PROG CSn CLK DO 1nF GND AS5045 100R PROG CSn CLK DO 1nF GND AS5045 PROG GND AS5045 Figure 18: Daisy Chain Mode Data Transfer CSn TCLK/2 tCLK FE 1 CLK 8 D11 D10 D9 DO D8 D7 D6 D5 D4 18 D3 D2 D1 D0 OCF COF LIN Mag Mag Even INC DEC PAR D 1 2 3 D11 D10 D9 tDO valid tDO active Angular Position Data Status Bits 1st Device Datasheet, Public [v3-00] 2022-Mar-03 Angular Position Data 2nd Device Page 19 Document Feedback AS5045 − Detailed Description Pulse Width Modulation (PWM) Output The AS5045 provides a pulse width modulated output (PWM), whose duty cycle is proportional to the measured angle: (EQ1) Position = ton ⋅ 4097 (ton + toff ) − 1 The PWM frequency is internally trimmed to an accuracy of ±5% (±10% over full temperature range). This tolerance can be cancelled by measuring the complete duty cycle as shown above. Figure 19: PWM Output Signal Angle PWMIN 0 deg (Pos 0) 1µs 4097µs PWMAX 359.91 deg (Pos 4095) 4096µs 1/fPWM Changing the PWM Frequency The PWM frequency of the AS5045 can be divided by two by setting a bit (PWMhalfEN) in the OTP register (see Programming the AS5045). With PWMhalfEN = 0, the PWM timing is as shown in Figure 20. Figure 20: PWM Signal Parameters (Default mode) Symbol Parameter Typ Unit Note fPWM PWM frequency 244 Hz Signal period: 4097μs PWMIN MIN pulse width 1 μs - Position 0d - Angle 0 deg PWMAX MAX pulse width 4096 μs - Position 4095d - Angle 359.91 deg Page 20 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description When PWMhalfEN = 1, the PWM timing is as shown in Figure 21. Figure 21: PWM Signal Parameters with Half Frequency (OTP Option) Symbol Parameter Typ Unit Note fPWM PWM frequency 122 Hz PWMIN MIN pulse width 2 μs • Position 0d • Angle 0 deg PWMAX MAX pulse width 8192 μs • Position 4095d • Angle 359.91 deg Signal period: 8194μs Analog Output An analog output can be generated by averaging the PWM signal, using an external active or passive low pass filter. The analog output voltage is proportional to the angle: 0°= 0V; 360° = VDD5V. Using this method, the AS5045 can be used as direct replacement of potentiometers. Figure 22: Simple 2nd Order Passive RC Low Pass Filter Pin12 R2 R1 analog out PWM VDD C1 C2 0V Pin7 0º 360º VSS Figure 22 shows an example of a simple passive low pass filter to generate the analog output. (EQ2) R1, R2 ≥ 4k7C1, C2 ≥ 1μF / 6V R1 should be greater than or equal to 4k7 to avoid loading of the PWM output. Larger values of Rx and Cx will provide better filtering and less ripple, but will also slow down the response time. Datasheet, Public [v3-00] 2022-Mar-03 Page 21 Document Feedback AS5045 − Detailed Description The benefits of AS5045 are as follows: • Complete system-on-chip • Flexible system solution provides absolute and PWM outputs simultaneously • Ideal for applications in harsh environments due to contactless position sensing • No calibration required Programming the AS5045 After power-on, programming the AS5045 is enabled with the rising edge of CSn and Prog = logic high. 16 bit configuration data must be serially shifted into the OTP register via the Prog pin. The first “CCW” bit is followed by the zero position data (MSB first) and the Mode setting bits. Data must be valid at the rising edge of CLK (see Figure 23). After writing the data into the OTP register it can be permanently programmed by rising the Prog pin to the programming voltage V PROG. 16 CLK pulses (tPROG) must be applied to program the fuses (see Figure 24). To exit the programming mode, the chip must be reset by a power-on-reset. The programmed data is available after the next power-up. Note(s): During the programming process, the transitions in the programming current may cause high voltage spikes generated by the inductance of the connection cable. To avoid these spikes and possible damage to the IC, the connection wires, especially the signals Prog and VSS must be kept as short as possible. The maximum wire length between the VPROG switching transistor and pin Prog should not exceed 50mm (2 inches). To suppress eventual voltage spikes, a 10nF ceramic capacitor should be connected close to pins VPROG and VSS. This capacitor is only required for programming, it is not required for normal operation. The clock timing t clk must be selected at a proper rate to ensure that the signal Prog is stable at the rising edge of CLK (see Figure 23). Additionally, the programming supply voltage should be buffered with a 10μF capacitor mounted close to the switching transistor. This capacitor aids in providing peak currents during programming. The specified programming voltage at pin Prog is 7.3 ~ 7.5V. Refer to programming conditions in Figure 10. To compensate for the voltage drop across the V PROG switching transistor, the applied programming voltage may be set slightly higher (7.5 ~ 8.0V, see Figure 25). Page 22 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description OTP Register Contents CCW: Counter Clockwise Bit ccw=0 – angular value increases in clockwise direction ccw=1 – angular value increases in counter clockwise direction Z [11:0]: Programmable Zero Position PWM dis: Disable PWM output MagCompEn: When set, activates LIN alarm both when magnetic field is too high and too low (see Figure 16) PWMhalfEn: When set, PWM frequency is 122Hz or 2μs / step (when PWMhalfEN = 0, PWM frequency is 244Hz, 1μs / step) Zero Position Programming Zero position programming is an OTP option that simplifies assembly of a system, as the magnet does not need to be manually adjusted to the mechanical zero position. Once the assembly is completed, the mechanical and electrical zero positions can be matched by software. Any position within a full turn can be defined as the permanent new zero position. For zero position programming, the magnet is turned to the mechanical zero position (e.g. the “off”-position of a rotary switch) and the actual angular value is read. This value is written into the OTP register bits Z11:Z0 (see Figure 23) and programmed (see Figure 24). The zero position value may also be modified before programming, e.g. to program an electrical zero position that is 180° (half turn) from the mechanical zero position, just add 2048 to the value read at the mechanical zero position and program the new value into the OTP register. Repeated OTP Programming Although a single AS5045 OTP register bit can be programmed only once (from 0 to 1), it is possible to program other, unprogrammed bits in subsequent programming cycles. However, a bit that has already been programmed should not be programmed twice. Therefore it is recommended that bits that are already programmed are set to “0” during a programming cycle. Datasheet, Public [v3-00] 2022-Mar-03 Page 23 Document Feedback AS5045 − Detailed Description Non-Permanent Programming It is also possible to re-configure the AS5045 in a non-permanent way by overwriting the OTP register. This procedure is essentially a “Write Data” sequence (see Figure 23) without a subsequent OTP programming cycle. The “Write Data” sequence may be applied at any time during normal operation. This configuration remains set while the power supply voltage is above the power-on reset level (see Electrical System Specifications). See Application Note AN5000-20 for further information. Figure 23: Programming Access – Write Data (Section of Figure 24) CSn t Datain Prog CCW Z 11 Z 10 Z9 Z8 Z7 1 CLKPROG t Prog enable t Datain valid Z6 Z5 Z4 Z3 Z2 Z1 Z0 PWM dis Mag PWM Comp half EN EN 8 16 t clk PWM and status bit modes Zero Position Figure 24: Complete Programming Sequence Write Data Programming Mode Power Off CSn Prog Data 1 16 7.5 V VDD VProgOff 0V CLKPROG t Load PROG Page 24 Document Feedback t PrgH t PrgR t PROG t PROG finished Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Figure 25: OTP Programming Connection of AS5045 (Shown with AS5045 Demoboard) AS5045 Demoboard 1 MagINCn 2 MagDECn 3 NC 4 NC 5 6 VDD5V 16 VDD3V3 15 NC 14 NC Mode 7 VSS 8 Prog_DI 10n AS5045 USB For programming , keep these 6 wires as short as possible! max. length = 2 inches (5cm) IC1 3V3 NC 13 12 PWM 11 CSn 10 CLK 9 DO + 7 6 5 4 3 2 1 22k PROG CSN DO CLK 5VUSB VDD3V3 VSS µC GND 1µF connect to USB interface on PC 3 VPROG 2 + 1 10µF VSS GND 7. 5 … 8.0V only required for OTP programming Cap only required for OTP programming Analog Readback Mode Non-volatile programming (OTP) uses on-chip zener diodes, which become permanently low resistive when subjected to a specified reverse current. The quality of the programming process depends on the amount of current that is applied during the programming process (up to 130mA). This current must be provided by an external voltage source. If this voltage source cannot provide adequate power, the zener diodes may not be programmed properly. In order to verify the quality of the programmed bit, an analog level can be read for each zener diode, giving an indication whether this particular bit was properly programmed or not. To put the AS5045 in Analog Readback Mode, a digital sequence must be applied to pins CSn, PROG and CLK as shown in Figure 26. The digital level for this pin depends on the supply configuration (3.3V or 5V) (see 3.3V / 5V Operation). The second rising edge on CSn (OutpEN) changes pin PROG to a digital output and the log. high signal at pin PROG must be removed to avoid collision of outputs (grey area in Figure 26). The following falling slope of CSn changes pin PROG to an analog output, providing a reference voltage V ref, that must be saved as a reference for the calculation of the subsequent programmed and unprogrammed OTP bits. Datasheet, Public [v3-00] 2022-Mar-03 Page 25 Document Feedback AS5045 − Detailed Description Following this step, each rising slope of CLK outputs one bit of data in the reverse order as during programming (see Figure 23: Md0-MD1-Div0,Div1-Indx-Z0…Z11, ccw). If a capacitor is connected to pin PROG, it should be removed during analog readback mode to allow a fast readout rate. If the capacitor is not removed the analog voltage will take longer to stabilize due to the additional capacitance. The measured analog voltage for each bit must be subtracted from the previously measured V ref, and the resulting value gives an indication on the quality of the programmed bit: a reading of 1V indicates a properly unprogrammed bit. A reading between 100mV and 1V indicates a faulty bit, which may result in an undefined digital value, when the OTP is read at power-up. Following the 18 th clock (after reading bit “ccw”), the chip must be reset by disconnecting the power supply. Figure 26: OTP Register Analog Read ProgEN OutpEN Power- onReset; turn off supply Analog Readback Data at PROG CSn Vprogrammed Vref Internal test bit digital PROG PWM halfEN Mag Comp EN PWM Dis Z0 Vunprogrammed Z7 Z8 Z9 Z10 Z11 CCW Prog changes to Output 1 CLK t LoadProg Page 26 Document Feedback 16 CLKAread Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Alignment Mode The alignment mode simplifies centering the magnet over the center of the chip to gain maximum accuracy. Alignment mode can be enabled with the falling edge of CSn while Prog = logic high (see Figure 27). The Data bits D11-D0 of the SSI change to a 12-bit displacement amplitude output. A high value indicates large X or Y displacement, but also higher absolute magnetic field strength. The magnet is properly aligned, when the difference between highest and lowest value over one full turn is at a minimum. Under normal conditions, a properly aligned magnet will result in a reading of less than 128 over a full turn. The MagINCn and MagDECn indicators will be = 1 when the alignment mode reading is < 128. At the same time, both hardware pins MagINCn (#1) and MagDECn (#2) will be pulled to VSS. A properly aligned magnet will therefore produce a MagINCn = MagDECn = 1 signal throughout a full 360° turn of the magnet. Stronger magnets or short gaps between magnet and IC may show values larger than 128. These magnets are still properly aligned as long as the difference between highest and lowest value over one full turn is at a minimum. The alignment mode can be reset to normal operation by a power-on-reset (disconnect / re-connect power supply) or by a falling edge on CSn with Prog = low. Figure 27: Enabling the Alignment Mode PROG CSn 2µs min. AlignMode enable Read-out via SSI exit AlignMode Read-out via SSI 2µs min. Figure 28: Exiting the Alignment Mode PROG CSn Datasheet, Public [v3-00] 2022-Mar-03 Page 27 Document Feedback AS5045 − Detailed Description 3.3V / 5V Operation The AS5045 operates either at 3.3V ±10% or at 5V ±10%. This is made possible by an internal 3.3V Low-Dropout (LDO) Voltage regulator. The internal supply voltage is always taken from the output of the LDO, meaning that the internal blocks are always operating at 3.3V. For 3.3V operation, the LDO must be bypassed by connecting VDD3V3 with VDD5V (see Figure 29). For 5V operation, the 5V supply is connected to pin VDD5V, while VDD3V3 (LDO output) must be buffered by a 2.2...10μF capacitor, which is supposed to be placed close to the supply pin (see Figure 29). The VDD3V3 output is intended for internal use only It must not be loaded with an external load (see Figure 29). Figure 29: Connections for 5V / 3.3V Supply Voltages 5V Operation 3.3V Operation 2.2... 10µF VDD3V3 VDD3V3 100n VDD5V 100n LDO Internal VDD VDD5V LDO Internal VDD DO DO 4.5 - 5.5V VSS I N T E R F A C E PWM - - + + CLK 3.0 - 3.6V CSn PROG VSS I N T E R F A C E PWM CLK CSn PROG A buffer capacitor of 100nF is recommended in both cases close to pin VDD5V. Note that pin VDD3V3 must always be buffered by a capacitor. It must not be left floating, as this may cause an instable internal 3.3V supply voltage which may lead to larger than normal jitter of the measured angle. Page 28 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Choosing the Proper Magnet Typically the magnet should be 6mm in diameter and ≥2.5mm in height. Magnetic materials such as rare earth AlNiCo/SmCo5 or NdFeB are recommended. The magnetic field strength perpendicular to the die surface has to be in the range of ±45mT to ±75mT (peak). The magnet’s field strength should be verified using a gauss-meter. The magnetic field Bv at a given distance, along a concentric circle with a radius of 1.1mm (R1), should be in the range of ±45mT to ±75mT (see Figure 30). Figure 30: Typical Magnet (6x3mm) and Magnetic Field Distribution typ. 6mm diameter N S Magnet axis R1 Magnet axis Vertical field component Bv Vertical field component (45…75mT) 0 N 360 S R1 concentric circle; radius 1.1mm Datasheet, Public [v3-00] 2022-Mar-03 Page 29 Document Feedback AS5045 − Detailed Description Physical Placement of the Magnet The best linearity can be achieved by placing the center of the magnet exactly over the defined center of the chip as shown in the drawing below. Figure 31: Defined Chip Center and Magnet Displacement Radius 3.9mm 3.9mm 2.4325mm 1 Defined center 2.4325mm Rd Area of recommended maximum magnet misalignment Magnet Placement. The magnet’s center axis should be aligned within a displacement radius Rd of 0.25mm from the defined center of the IC. The magnet may be placed below or above the device. The distance should be chosen such that the magnetic field on the die surface is within the specified limits (see Figure 30). The typical distance “z” between the magnet and the package surface is 0.5mm to 1.5mm, provided the use of the recommended magnet material and dimensions (6mm x 3mm). Larger distances are possible, as long as the required magnetic field strength stays within the defined limits. However, a magnetic field outside the specified range may still produce usable results, but the out-of-range condition will be indicated by MagINCn (pin 1) and MagDECn (pin 2), see Figure 4. Page 30 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Failure Diagnostics The AS5045 also offers several diagnostic and failure detection features: Magnetic Field Strength Diagnosis By Software: The MagINC and MagDEC status bits will both be high when the magnetic field is out of range. By Hardware: Pins #1 (MagINCn) and #2 (MagDECn) are open-drain outputs and will both be turned on (= low with external pull-up resistor) when the magnetic field is out of range. If only one of the outputs are low, the magnet is either moving towards the chip (MagINCn) or away from the chip (MagDECn). Power Supply Failure Detection By Software: If the power supply to the AS5045 is interrupted, the digital data read by the SSI will be all “0”s. Data is only valid, when bit OCF is high, hence a data stream with all “0”s is invalid. To ensure adequate low levels in the failure case, a pull-down resistor (~10kΩ) should be added between pin DO and VSS at the receiving side. By Hardware: The MagINCn and MagDECn pins are open drain outputs and require external pull-up resistors. In normal operation, these pins are high ohmic and the outputs are high (see Figure 15). In a failure case, either when the magnetic field is out of range of the power supply is missing, these outputs will become low. To ensure adequate low levels in case of a broken power supply to the AS5045, the pull-up resistors (~10kΩ) from each pin must be connected to the positive supply at pin 16 (VDD5V). By Hardware, PWM Output: The PWM output is a constant stream of pulses with 1kHz repetition frequency. In case of power loss, these pulses are missing. Datasheet, Public [v3-00] 2022-Mar-03 Page 31 Document Feedback AS5045 − Detailed Description Angular Output Tolerances Accuracy Accuracy is defined as the error between measured angle and actual angle. It is influenced by several factors: • The non-linearity of the analog-digital converters • Internal gain and mismatch errors • Non-linearity due to misalignment of the magnet As a sum of all these errors, the accuracy with centered magnet = (Err max – Errmin)/2 is specified as better than ±0.5 degrees @ 25°C (see Figure 33) Misalignment of the magnet further reduces the accuracy. Figure 32 shows an example of a 3D-graph displaying non-linearity over XY-misalignment. The center of the square XY-area corresponds to a centered magnet (see dot in the center of the graph). The X- and Y- axis extends to a misalignment of ±1mm in both directions. The total misalignment area of the graph covers a square of 2x2 mm (79x79mil) with a step size of 100μm. For each misalignment step, the measurement as shown in Figure 33 is repeated and the accuracy (Errmax – Errmin)/2 (e.g. 0.25°) is entered as the Z-axis in the 3D-graph. Figure 32: Example of Linearity Error over XY Misalignment Linearity Error over XY-misalignment [°] 6 5 4 3 800 500 2 200 1 -100 -800 -1000 -1000 -400 -600 0 -700 -200 200 600 y Page 32 Document Feedback x -400 400 1000 800 0 Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description The maximum non-linearity error on this example is better than ±1 degree (inner circle) over a misalignment radius of ~0.7mm. For volume production, the placement tolerance of the IC within the package (±0.235mm) must also be taken into account. The total nonlinearity error over process tolerances, temperature and a misalignment circle radius of 0.25mm is specified better than ±1.4 degrees. The magnet used for this measurement was a cylindrical NdFeB (Bomatec® BMN-35H) magnet with 6mm diameter and 2.5mm in height. Figure 33: Example of Linearity Error over 360° Linearity error with centered magnet [degrees] 0.5 0.4 0.3 0.2 transition noise 0.1 Errmax 0 -0.1 1 -0.2 55 109 163 217 271 325 379 433 487 541 595 Errmin 649 703 757 811 865 919 973 -0.3 -0.4 -0.5 Transition Noise Transition noise is defined as the jitter in the transition between two steps. Due to the nature of the measurement principle (Hall sensors + Preamplifier + ADC), there is always a certain degree of noise involved. This transition noise voltage results in an angular transition noise at the outputs. It is specified as 0.06 degrees rms (1 sigma)1 in fast mode (pin MODE = high) and 0.03 degrees rms (1 sigma) in slow mode (pin MODE = low or open). This is the repeatability of an indicated angle at a given mechanical position. 1. Statistically, 1 sigma represents 68.27% of readings, 3 sigma represents 99.73% of readings. Datasheet, Public [v3-00] 2022-Mar-03 Page 33 Document Feedback AS5045 − Detailed Description The transition noise has different implications on the type of output that is used: • Absolute Output; SSI Interface: The transition noise of the absolute output can be reduced by the user by implementing averaging of readings. An averaging of 4 readings will reduce the transition noise by 6dB or 50%, e.g. from 0.03°rms to 0.015°rms (1 sigma) in slow mode. • PWM Interface: If the PWM interface is used as an analog output by adding a low pass filter, the transition noise can be reduced by lowering the cutoff frequency of the filter. If the PWM interface is used as a digital interface with a counter at the receiving side, the transition noise may again be reduced by averaging of readings. High Speed Operation Sampling Rate: The AS5045 samples the angular value at a rate of 2.61k (slow mode) or 10.42k (fast mode, selectable by pin MODE) samples per second. Consequently, the absolute outputs are updated each 384μs (96μs in fast mode). At a stationary position of the magnet, the sampling rate creates no additional error. Absolute Mode: At a sampling rate of 2.6kHz/10.4kHz, the number of samples (n) per turn for a magnet rotating at high speed can be calculated by (EQ3) nslow mod e = 60 rpm ⋅ 384 μs (EQ4) n fast mod e = 60 rpm ⋅ 96 μs The upper speed limit in slow mode is ~6.000rpm and ~30.000rpm in fast mode. The only restriction at high speed is that there will be fewer samples per revolution as the speed increases. Regardless of the rotational speed, the absolute angular value is always sampled at the highest resolution of 12 bit. Propagation Delays The propagation delay is the delay between the time that the sample is taken until it is converted and available as angular data. This delay is 96μs in fast mode and 384μs in slow mode. Using the SSI interface for absolute data transmission, an additional delay must be considered, caused by the asynchronous sampling (0 … 1/f sample) and the time it takes the external control unit to read and process the angular data from the chip (maximum clock rate = 1MHz, number of bits per reading = 18). Page 34 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Angular Error Caused by Propagation Delay: A rotating magnet will cause an angular error caused by the output propagation delay. This error increases linearly with speed: (EQ5) esampling, = rpm ∗ 6 * prop.delay Where: e sampling = angular error [°] rpm = rotating speed [rpm] prop.delay = propagation delay [seconds] Note(s): Since the propagation delay is known, it can be automatically compensated by the control unit processing the data from the AS5045. Internal Timing Tolerance The AS5045 does not require an external ceramic resonator or quartz. All internal clock timings for the AS5045 are generated by an on-chip RC oscillator. This oscillator is factory trimmed to ±5% accuracy at room temperature (±10% over full temperature range). This tolerance influences the ADC sampling rate and the pulse width of the PWM output. • Absolute Output; SSI Interface: A new angular value is updated every 96μs (typ.) in fast mode and every 384μs (typ.) in slow mode. • PWM Output: A new angular value is updated every 400μs (typ.). The PWM pulse timings T on and T off also have the same tolerance as the internal oscillator. If only the PWM pulse width T on is used to measure the angle, the resulting value also has this timing tolerance. However, this tolerance can be cancelled by measuring both T on and T off and calculating the angle from the duty cycle. (EQ6) Position = ton ⋅ 4097 (ton + toff ) − 1 Temperature Magnetic Temperature Coefficient: One of the major benefits of the AS5045 compared to linear Hall sensors is that it is much less sensitive to temperature. While linear Hall sensors require a compensation of the magnet’s temperature coefficients, the AS5045 automatically compensates for the varying magnetic field strength over temperature. The magnet’s temperature drift does not need to be considered, as the AS5045 operates with magnetic field strengths from ±45…±75mT. Example: An NdFeB magnet has a field strength of 75mT @ -40°C and a temperature coefficient of -0.12% per Kelvin. The temperature change is from -40° to 125° = 165K. The magnetic field change is: 165 x -0.12% = -19.8%, which corresponds to 75mT at -40°C and 60mT at 125°C. Datasheet, Public [v3-00] 2022-Mar-03 Page 35 Document Feedback AS5045 − Detailed Description The AS5045 can compensate for this temperature related field strength change automatically, no user adjustment is required. Accuracy over Temperature: The influence of temperature in the absolute accuracy is very low. While the accuracy is ≤ ±0.5° at room temperature, it may increase to ≤±0.9° due to increasing noise at high temperatures. Timing Tolerance over Temperature: The internal RC oscillator is factory trimmed to ±5%. Over temperature, this tolerance may increase to ±10%. Generally, the timing tolerance has no influence in the accuracy or resolution of the system, as it is used mainly for internal clock generation. The only concern to the user is the width of the PWM output pulse, which relates directly to the timing tolerance of the internal oscillator. This influence however can be cancelled by measuring the complete PWM duty cycle instead of just the PWM pulse. Differences Between AS5045 and AS5040 All parameters are similar for AS5045 and AS5040, except for the parameters given below: Figure 34: Differences Between AS5045 and AS5040 Building Block AS5045 AS5040 Resolution 12bits, 0.088°/step 10bit, 0.35°/step Data length Read: 18bits (12bits data + 6 bits status) OTP write: 18 bits (12bits zero position + 6 bits mode selection) Read: 16bits (10bits data + 6 bits status) OTP write: 16 bits (10bits zero position + 6 bits mode selection) Not used Pin 3: not used Pin 4: not used Quadrature, step/direction and BLDC motor commutation modes Pin 3: incremental output A_LSB_U Pin 4: incremental output B_DIR_V MagINCn, MagDECn: same feature as AS5040, additional OTP option for red-yellow-green magnetic range MagINCn, MagDECn indicate in-range or out-of-range magnetic field plus movement of magnet in z-axis MODE pin, switch between fast and slow mode Pin 6: Index output Incremental signals Pins 1 and 2 Pin 6 Page 36 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Detailed Description Building Block AS5045 AS5040 Pin 12 PWM output: frequency selectable by OTP: 1μs / step, 4096 steps per revolution, f=244Hz 2μs/ step, 4096 steps per revolution, f=122Hz PWM output: 1μs / step, 1024 steps per revolution, 976Hz PWM frequency Sampling frequency Selectable by MODE input pin: 2.5kHz, 10kHz Fixed at 10kHz @10bit resolution 384μs (slow mode) 96μs (fast mode) 48μs 0.03 degrees max. (slow mode) 0.06 degrees max. (fast mode) 0.12 degrees Zero position, rotational direction, PWM disable, 2 Magnetic Field indicator modes, 2 PWM frequencies Zero position, rotational direction, incremental modes, index bit width. Propagation delay Transition noise (rms; 1sigma) OTP programming options Datasheet, Public [v3-00] 2022-Mar-03 Page 37 Document Feedback AS5045 − Package Drawings & Mark ings Package Drawings & Markings The device is available in 16-pin SSOP. Figure 35: Package Drawings and Dimensions YYWWMZZ AS5045 @ Symbol Min Nom Max A A1 A2 b c D E E1 e L L1 L2 R Q N 1.73 0.05 1.68 0.22 0.09 5.90 7.40 5.00 0.55 0.09 0º 1.86 0.13 1.73 0.315 0.17 6.20 7.80 5.30 0.65 BSC 0.75 1.25 REF 0.25 BSC 4º 16 1.99 0.21 1.78 0.38 0.25 6.50 8.20 5.60 0.95 8º RoHS Green Note(s): 1. Dimensions and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles are in degrees. Figure 36: Marking: YYWWMZZ YY WW M ZZ @ Year Manufacturing week Plant identifier Assembly traceability code Sublot identifier Page 38 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Package Drawings & Markings Figure 37: Vertical Cross Section of SSOP-16 Note(s): 1. All dimensions in mm. Datasheet, Public [v3-00] 2022-Mar-03 Page 39 Document Feedback AS5045 − Package Drawings & Mark ings Recommended PCB Footprint Figure 38: PCB Footprint Recommended Footprint Data Symbol mm inch A B C D E Page 40 Document Feedback 9.02 6.16 0.46 0.65 5.01 0.355 0.242 0.018 0.025 0.197 Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Ordering & Contact Information Ordering & Contact Information The devices are available as the standard products shown in Figure 39. Figure 39: Ordering Information Ordering Code Description Package Delivery Form Delivery Quantity AS5045 12-Bit Programmable Magnetic Position Sensor 16-pin SSOP Tape & Reel 500 pcs/reel Buy our products or get free samples online at: www.ams.com/Products Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/Contact Headquarters ams-OSRAM AG Tobelbader Strasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com Datasheet, Public [v3-00] 2022-Mar-03 Page 41 Document Feedback AS5045 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams-OSRAM AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br/Cl): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) and do not contain Chlorine (Cl not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams-OSRAM AG knowledge and belief as of the date that it is provided. ams-OSRAM AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams-OSRAM AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams-OSRAM AG and ams-OSRAM AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 42 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams-OSRAM AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams-OSRAM AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams-OSRAM AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams-OSRAM AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams-OSRAM AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams-OSRAM AG for each application. This product is provided by ams-OSRAM AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams-OSRAM AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams-OSRAM AG rendering of technical or other services. Datasheet, Public [v3-00] 2022-Mar-03 Page 43 Document Feedback AS5045 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 44 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams-OSRAM AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams-OSRAM AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Revision Information Revision Information Changes from 2-01 (2017-Jul-13) to current revision 3-00 (2022-Mar-03) Page Updated Figure 39 41 Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. Datasheet, Public [v3-00] 2022-Mar-03 Page 45 Document Feedback AS5045 − Content Guide Content Guide 1 1 2 2 General Description Key Benefits & Features Applications Block Diagram 3 3 Pin Assignment Pin Description 5 Absolute Maximum Ratings 6 8 8 Electrical Characteristics Magnetic Input Specification Electrical System Specifications 11 Timing Characteristics 13 14 14 15 16 Detailed Description Mode Input Pin Synchronous Serial Interface (SSI) Data Content Z-axis Range Indication (Push Button Feature, Red/Yellow/Green Indicator) Daisy Chain Mode Pulse Width Modulation (PWM) Output Changing the PWM Frequency Analog Output Programming the AS5045 Zero Position Programming Repeated OTP Programming Non-Permanent Programming Analog Readback Mode Alignment Mode 3.3V / 5V Operation Choosing the Proper Magnet Physical Placement of the Magnet Failure Diagnostics Magnetic Field Strength Diagnosis Power Supply Failure Detection Angular Output Tolerances Accuracy Transition Noise High Speed Operation Propagation Delays Internal Timing Tolerance Temperature Accuracy over Temperature: Differences between AS5045 and AS5040 18 19 19 20 21 22 22 23 24 26 27 28 29 30 30 30 31 31 32 33 33 34 34 35 35 Page 46 Document Feedback Datasheet, Public [v3-00] 2022-Mar-03 AS5045 − Content Guide Datasheet, Public [v3-00] 2022-Mar-03 37 39 Package Drawings & Markings Recommended PCB Footprint 40 41 42 43 44 Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Page 47 Document Feedback
AS5045-ASST
物料型号:AS5045
器件简介: AS5045是一款无接触式磁性旋转位置传感器,能够准确测量360°范围内的角度。它是一个系统级芯片,集成了霍尔元件、模拟前端和数字信号处理。测量角度时,只需要一个简单的双极磁铁在芯片中心上方或下方旋转即可。
引脚分配: - MagINCn(16号引脚)和MagDECn(2号引脚):磁场变化指示器,可检测磁场范围的有效性。 - Mode(6号引脚):选择过滤(慢)和未过滤(快)模式。 - Prog_DI(8号引脚):用于在Daisy Chain模式下串行数据传输和OTP编程。 - CSn(11号引脚):片选信号,用于选择传感器网络中的设备并启动串行数据传输。 - PWM(12号引脚):提供绝对位置值的单线输出,通过脉冲宽度调制信号编码。
参数特性: - 分辨率:0.0879°,即每圈4096个位置。 - 工作温度范围:-40ºC至125ºC。 - 封装:SSOP-16(5.3mm x 6.2mm)。
功能详解: - 支持Daisy Chain模式,允许多个AS5045设备串联。 - 容错设计,能够容忍磁铁的不对准和气隙变化。 - PWM输出允许通过外部低通滤波器将数字PWM信号转换为模拟电压,实现电位计的直接替代。
应用信息: - 适用于工业应用,如机器人技术、步进电机控制、遥控伺服控制以及高端电位器的替代。
封装信息: - AS5045采用16引脚的SSOP封装,尺寸为5.3mm x 6.2mm。
AS5045-ASST 价格&库存
很抱歉,暂时无法提供与“AS5045-ASST”相匹配的价格&库存,您可以联系我们找货
