18S141-40ML5
18S141-40ML5
    ROSENBERGER
    RF-CONN-1P_4X3.4MM_TM
    SMP,迷你型 连接器 插头,公引脚 50 欧姆 表面贴装型 焊接
18S141-40ML5 数据手册
Technical Data Sheet RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG Mini-SMP Straight Plug PCB Smooth Bore 18S141-40ML5 All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to MIL-STD-348 Mateable with GPPOTM (Gilbert Engineering Co., Inc.) and SSMPTM (Connectors Devices, Inc.) Documents PCB layout Tape & reel packaging B 204 VG45.1M500 Material and plating Connector parts Center contact Outer contact Dielectric Material Brass Brass PTFE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur®, gold plated AuroDur®, gold plated Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/2 Technical Data Sheet Mini-SMP Straight Plug PCB Smooth Bore 18S141-40ML5 Electrical data RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG Impedance Frequency Return loss Insertion loss Insulation resistance Center contact resistance Outer contact resistance Working voltage (at sea level) (at 70000 feet) 50  DC to 65 GHz  26 dB, DC to 12 GHz  20 dB, 12 GHz to 16 GHz  10 dB, 16 GHz to 26 GHz  0.05 x f(GHz) dB  5 G  6.0 m  2.0 m 325 V rms 125 V rms - VSWR in application depends decisive on PCB layout - Mechanical data  100 5N Mating cycles Center contact captivation Engagement force - smooth bore Disengagement force - smooth bore 11 N typical 11 N typical Environmental data Temperature range Thermal shock Vibration Shock Moisture resistance Climatic Category Max. soldering temperature RoHS -55°C to +155°C MIL-STD-202, Method 107, Condition B MIL-STD-202, Method 204, Condition A MIL-STD-202, Method 213, Condition A MIL-STD-202, Method 106 IEC 60068 55/155/21 IEC 61760-1, +260°C for 10 sec. compliant Tooling N/A Suitable cables N/A Weight Weight 0.2 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. For the installation of the electrotechnical equipment, particular electrotechnical expertise is required. Draft Date Approved Date Rev. Engineering change number Name Date Rong Fang 17.07.06 Chr. Janßen 21.10.20 f00 20-1927 S. Huber-Siegl 21.10.20 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/2
18S141-40ML5 价格&库存
很抱歉,暂时无法提供与“18S141-40ML5”相匹配的价格&库存,您可以联系我们找货
