EMHS800ARA181MKE0S
EMHS800ARA181MKE0S
    NCC(贵弥功)
    AEC-D12.5X13.5MM_SM
    180 µF 80 V 铝电解电容器 径向,Can - SMD 170 毫欧 @ 100kHz 125°C 时为 5000 小时
EMHS800ARA181MKE0S 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MHS - High heat resistance, 125℃ Upgrade! Series ・Downsizing, High capacitance ・Endurance : 2,000 to 5,000 hours at 125℃ ・For high temperature and high reliability applications (Base station equipment, etc) ・High temperature reflow soldering ・Solvent resistant type(see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +125℃ 16 to 100Vdc (at 20℃, 120Hz) ±20% (M) HA0, JA0 I=0.01CV KE0 to MN0 I=0.03CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 16V 25V 35V 50V 63V 80V 100V HA0, JA0 0.20 0.16 0.14 0.14 0.14 0.12 tanδ (Max.) KE0 to MN0 0.18 0.14 0.14 0.14 0.14 0.12 0.10 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 16V 25V 35V 50V 63V 80V 100V Z(-25℃)/Z(+20℃) 2 2 2 2 2 2 HA0, JA0 Z(-40℃)/Z(+20℃) 4 4 3 3 3 3 Z(-25℃)/Z(+20℃) 3 2 2 2 2 2 2 KE0 to MN0 Z(-40℃)/Z(+20℃) 6 4 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for the specified time at 125℃. HA0, JA0 : 2,000hours Time KE0 to MN0 : 5,000hours Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size Vent (Except HA0) 0.3max. L±0.5 φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.5 A±0.2 HA0 JA0 KE0 KG5 LH0 LN0 MH0 MN0 W B±0.2 Vent (Except HA0) Code : G(Vibration resistant structure) Size code code : HA0 to MN0 P C±0.2 Code : A code : HA0 to MN0 A±0.2 φD 8 10 12.5 12.5 16 16 18 18 L 10.0 10.0 13.5 16.0 16.5 21.5 16.5 21.5 A 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 B 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 C 9.0 11.0 13.7 13.7 18.0 18.0 20.0 20.0 W 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 : Dummy terminals ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ◆MARKING 18 E MH S A A A A R A A A A M A A A S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 470µF:471, 1,000µF:102) Taping code Terminal code (A, G) Voltage code (ex. 16V:160, 35V:350) Series code Category EX) 35V470µF EX) 35V680µF 6d MHS 3Q 470 VHS ●Rated 680 35V voltage symbol (HA0, JA0) Rated voltage (Vdc) Symbol 16 C 25 E 35 V 50 H 63 J 80 K Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MHSSeries Upgrade! - ◆STANDARD RATINGS WV (Vdc) 16 25 35 50 63 80 100 Cap (µF) 680 1,000 1,500 2,000 2,700 3,600 4,700 6,200 470 680 1,000 1,300 1,800 2,400 3,300 4,300 220 270 470 680 820 1,200 1,500 2,000 2,400 100 150 180 360 470 560 750 1,000 1,300 68 82 100 120 240 330 430 560 680 910 47 68 82 180 240 270 360 430 560 110 150 160 200 240 330 Size code HA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 HA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 HA0 HA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 HA0 JA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 HA0 HA0 JA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 HA0 JA0 JA0 KE0 KG5 LH0 MH0 LN0 MN0 KE0 KG5 LH0 MH0 LN0 MN0 ESR (Ω max./100kHz) 20℃ −40℃ 0.19 2.6 0.13 1.7 0.087 1.1 0.070 0.84 0.057 0.59 0.055 0.44 0.037 0.39 0.036 0.28 0.19 2.6 0.13 1.7 0.087 1.1 0.070 0.84 0.057 0.59 0.055 0.44 0.037 0.39 0.036 0.28 0.19 2.6 0.19 2.6 0.13 1.7 0.087 1.1 0.070 0.84 0.057 0.59 0.055 0.44 0.037 0.39 0.036 0.28 0.65 8.1 0.45 4.6 0.45 4.6 0.16 2.0 0.12 1.5 0.088 0.94 0.085 0.78 0.056 0.61 0.053 0.45 0.65 8.1 0.65 8.1 0.45 4.6 0.45 4.6 0.17 2.5 0.13 1.8 0.098 1.3 0.091 0.98 0.063 0.80 0.059 0.59 0.65 8.1 0.45 4.6 0.45 4.6 0.17 2.5 0.13 1.8 0.098 1.3 0.091 0.98 0.063 0.80 0.059 0.59 0.17 2.5 0.13 1.8 0.098 1.3 0.091 0.98 0.063 0.80 0.059 0.59 Rated ripple current (mArms/125℃, 100kHz) 620 780 1,060 1,160 1,900 2,000 2,520 2,570 620 780 1,060 1,160 1,900 2,000 2,520 2,570 620 620 780 1,060 1,160 1,900 2,000 2,520 2,570 440 600 600 880 970 1,640 1,720 2,230 2,300 440 440 600 600 920 1,030 1,640 1,720 2,230 2,300 440 600 600 920 1,030 1,640 1,720 2,230 2,300 920 1,030 1,640 1,720 2,230 2,300 Part No. EMHS160□RA681MHA0G EMHS160□RA102MJA0G EMHS160□RA152MKE0S EMHS160□RA202MKG5S EMHS160□RA272MLH0S EMHS160□RA362MMH0S EMHS160□RA472MLN0S EMHS160□RA622MMN0S EMHS250□RA471MHA0G EMHS250□RA681MJA0G EMHS250□RA102MKE0S EMHS250□RA132MKG5S EMHS250□RA182MLH0S EMHS250□RA242MMH0S EMHS250□RA332MLN0S EMHS250□RA432MMN0S EMHS350□RA221MHA0G EMHS350□RA271MHA0G EMHS350□RA471MJA0G EMHS350□RA681MKE0S EMHS350□RA821MKG5S EMHS350□RA122MLH0S EMHS350□RA152MMH0S EMHS350□RA202MLN0S EMHS350□RA242MMN0S EMHS500□RA101MHA0G EMHS500□RA151MJA0G EMHS500□RA181MJA0G EMHS500□RA361MKE0S EMHS500□RA471MKG5S EMHS500□RA561MLH0S EMHS500□RA751MMH0S EMHS500□RA102MLN0S EMHS500□RA132MMN0S EMHS630□RA680MHA0G EMHS630□RA820MHA0G EMHS630□RA101MJA0G EMHS630□RA121MJA0G EMHS630□RA241MKE0S EMHS630□RA331MKG5S EMHS630□RA431MLH0S EMHS630□RA561MMH0S EMHS630□RA681MLN0S EMHS630□RA911MMN0S EMHS800□RA470MHA0G EMHS800□RA680MJA0G EMHS800□RA820MJA0G EMHS800□RA181MKE0S EMHS800□RA241MKG5S EMHS800□RA271MLH0S EMHS800□RA361MMH0S EMHS800□RA431MLN0S EMHS800□RA561MMN0S EMHS101□RA111MKE0S EMHS101□RA151MKG5S EMHS101□RA161MLH0S EMHS101□RA201MMH0S EMHS101□RA241MLN0S EMHS101□RA331MMN0S □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Size code HA0, JA0 KE0 to MN0 Frequency(Hz) Capacitance(µF) 47 220 680 110 220 680 2,400 4,700 to to to to to to to to 180 470 1,000 200 620 2,000 4,300 6,200 120 0.40 0.50 0.60 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
EMHS800ARA181MKE0S 价格&库存
很抱歉,暂时无法提供与“EMHS800ARA181MKE0S”相匹配的价格&库存,您可以联系我们找货
EMHS800ARA181MKE0S
  • 250+3.06459250+0.38295
  • 750+2.97576750+0.37185
  • 1250+2.931351250+0.36630
  • 2500+2.917522500+0.36458
  • 5000+2.842525000+0.35520
EMHS800ARA181MKE0S
  • 1+5.10840
  • 250+1.98720
  • 500+1.91160
  • 1000+1.87920
EMHS800ARA181MKE0S
  • 1+12.750331+1.59328
  • 10+8.2138110+1.02640
  • 50+6.3245550+0.79032
  • 100+5.72744100+0.71570
EMHS800ARA181MKE0S
  • 250+5.08988250+0.63603
  • 500+4.70067500+0.58740
  • 750+4.50432750+0.56286
  • 1250+4.285361250+0.53550
  • 1750+4.156631750+0.51941
  • 2500+4.032302500+0.50388
  • 3000+3.973183000+0.49649
  • 6000+3.773016000+0.47148
  • 6250+3.762356250+0.47015
