EMZR6R3ARA331MF61G
EMZR6R3ARA331MF61G
    NCC(贵弥功)
    AEC-D6.3X5.8MM_SM
    330 µF 6.3 V 铝电解电容器 径向,Can - SMD 260 毫欧 @ 100kHz 105°C 时为 2000 小时
EMZR6R3ARA331MF61G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MZR - Series Low ESR, 105℃ MZS ・Downsizing and Lower ESR, 2,000hours at 105℃ ・Rated voltage range : 6.3 to 50V, Nominal capacitance range : 22 to 2,200μF ・Solvent resistant type(see PRECAUTIONS AND GUIDELINES) ・Vibration resistance structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. Higher capacitance MZR Downsized MZJ ◆SPECIFICATIONS Items Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life Surge Voltage Test Characteristics -55 to +105℃ 6.3 to 50Vdc (at 20℃, 120Hz) ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V tanδ(Max.) 0.26 0.19 0.16 0.14 0.12 0.10 (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V Z(-25℃)/Z(+20℃) 2 2 2 2 2 2 Z(-40℃)/Z(+20℃) 3 3 3 3 3 3 Z(-55℃)/Z(+20℃) 4 4 4 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 105℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charging with the specified surge voltage for 30±5 seconds through a protective resistor (as required for RC=0.1±0.05sec) and open-circuiting for 5.5 minutes at a room temperature of 15 to 35℃. Rated voltage (Vdc) 6.3 10 16 25 35 50 7.2 12 18 29 40 58 Surge voltage (Vdc) Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value (Caution) Surge Voltage Test intends to evaluate capacitors in durability of an exceptional excessive voltage under specific conditions.It does not imply long-term use at all. ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size A±0.2 B±0.2 φD±0.5 P C±0.2 0.3max. L±0.3 (Note) W 0.3max. Vent for JA0 W B±0.2 φD±0.5 Vent for JA0 Code : G(Vibration resistant structure) code : F61 to JA0 Size code P C±0.2 Code : A code : E61 to JA0 E61 F61 F80 HA0 JA0 D 5 6.3 6.3 8 10 L A B C 5.8 5.3 5.3 5.9 5.8 6.6 6.6 7.2 7.7 6.6 6.6 7.2 10.0 8.3 8.3 9.0 10.0 10.3 10.3 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.4 1.9 1.9 3.1 4.5 A±0.2 L±0.3 (Note) Note : L±0.5 for HA0 and JA0 Note : L±0.5 for HA0 and JA0 : Dummy terminals ◆MARKING EX) 35V330µF 3Q 330 VZR ● Rated voltage symbol Rated voltage (Vdc) Symbol 6.3 j 10 A 16 C 25 E 35 V 50 H Applying voltage over the rated voltages causes the capacitors to have short lifetime. Besides, applying voltage over the specified surge voltages may cause to have short circuit failure. A protection circuit should be used if applied voltage will exceed the rated voltages. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS MZRSeries TM AIchip Low ESR, 105℃ - ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E MZ R AAA A RA AAA M AAA G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 220µF:221, 470µF:471) Taping code Terminal code (A, G) Voltage code (ex. 6.3V:6R3, 10V:100, 35V:350) Series code Category Please refer to "Product code guide (surface mount type)" ◆STANDARD RATINGS WV (Vdc) Cap (µF) 220 330 680 1,500 2,200 150 220 470 1,000 1,500 100 220 330 680 1,000 68 100 220 470 820 47 100 150 330 560 22 47 100 220 330 6.3 10 16 25 35 50 Size code tanδ ESR (Ω max./20℃, 100kHz) Rated ripple current (mArms/105℃, 100kHz) Part No. E61 F61 F80 HA0 JA0 E61 F61 F80 HA0 JA0 E61 F61 F80 HA0 JA0 E61 F61 F80 HA0 JA0 E61 F61 F80 HA0 JA0 E61 F61 F80 HA0 JA0 0.26 0.26 0.26 0.26 0.26 0.19 0.19 0.19 0.19 0.19 0.16 0.16 0.16 0.16 0.16 0.14 0.14 0.14 0.14 0.14 0.12 0.12 0.12 0.12 0.12 0.10 0.10 0.10 0.10 0.10 0.36 0.26 0.16 0.08 0.06 0.36 0.26 0.16 0.08 0.06 0.36 0.26 0.16 0.08 0.06 0.36 0.26 0.16 0.08 0.06 0.36 0.26 0.16 0.08 0.06 0.88 0.68 0.34 0.18 0.12 240 300 600 850 1,190 240 300 600 850 1,190 240 300 600 850 1,190 240 300 600 850 1,190 240 300 600 850 1,190 165 195 350 670 900 EMZR6R3ARA221ME61G EMZR6R3□RA331MF61G EMZR6R3□RA681MF80G EMZR6R3□RA152MHA0G EMZR6R3□RA222MJA0G EMZR100ARA151ME61G EMZR100□RA221MF61G EMZR100□RA471MF80G EMZR100□RA102MHA0G EMZR100□RA152MJA0G EMZR160ARA101ME61G EMZR160□RA221MF61G EMZR160□RA331MF80G EMZR160□RA681MHA0G EMZR160□RA102MJA0G EMZR250ARA680ME61G EMZR250□RA101MF61G EMZR250□RA221MF80G EMZR250□RA471MHA0G EMZR250□RA821MJA0G EMZR350ARA470ME61G EMZR350□RA101MF61G EMZR350□RA151MF80G EMZR350□RA331MHA0G EMZR350□RA561MJA0G EMZR500ARA220ME61G EMZR500□RA470MF61G EMZR500□RA101MF80G EMZR500□RA221MHA0G EMZR500□RA331MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 22 to 150 220 to 560 680 to 2,200 120 0.40 0.50 0.60 1k 0.75 0.85 0.87 10k 0.90 0.94 0.95 100k 1.00 1.00 1.00 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
EMZR6R3ARA331MF61G 价格&库存
很抱歉,暂时无法提供与“EMZR6R3ARA331MF61G”相匹配的价格&库存,您可以联系我们找货
EMZR6R3ARA331MF61G
  • 1000+2.559851000+0.33272
  • 2000+2.380112000+0.30936
  • 3000+2.289403000+0.29757
  • 5000+2.188295000+0.28443
  • 7000+2.128847000+0.27670
  • 10000+2.0714210000+0.26924
库存:1655
EMZR6R3ARA331MF61G
  • 1+8.118031+1.05515
  • 10+5.1161710+0.66498
  • 50+3.8603950+0.50176
  • 100+3.46163100+0.44993
  • 500+2.77615500+0.36084
库存:1655
