SIT2001BIFS-XXS
SIT2001BIFS-XXS
    SITIME(赛特时脉)
    SOT-23-5
    OSC MEMS PROGRAMMABLE XXV
SIT2001BIFS-XXS 数据手册
SiT2001B Single-Chip, SOT23 Oscillator Features ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Applications Any frequency between 1 MHz and 110 MHz accurate to 6 decimal places Operating temperature from -40°C to 85°C. Refer to SiT2018 for -40°C to 85°C option and SiT2020 for -55°C to 125°C option Excellent total frequency stability as low as ±20 ppm Low power consumption of 3.5 mA typical Fast start-up time of 5 ms LVCMOS/HCMOS compatible output 5-pin SOT23-5: 2.9 mm x 2.8 mm Pb-free, RoHS and REACH compliant For AEC-Q100 SOT23 Oscillators, refer to SiT2024 and SiT2025 ◼ ◼ Industrial, medical, automotive, avionics and other high temperature applications Industrial sensors, PLC, motor servo, outdoor networking equipment, medical video cam, asset tracking systems, etc. Related products for automotive applications. For aerospace and defense applications SiTime recommends using only Endura™ SiT2044. Electrical Specifications All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. Table 1. Electrical Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 1 – 110 MHz Frequency Stability and Aging Frequency Stability F_stab -20 – +20 ppm -25 – +25 ppm -50 – +50 ppm Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load (15 pF ±10%). Operating Temperature Range Operating Temperature Range (ambient) T_use -20 – +70 °C Extended Commercial -40 – +85 °C Industrial Supply Voltage and Current Consumption Supply Voltage Current Consumption OE Disable Current Standby Current Rev 1.03 Vdd Idd I_od I_std 1.62 1.8 1.98 V 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 3.8 4.5 mA No load condition, f = 20 MHz, Vdd = 2.8 V, 3.0 V or 3.3 V – 3.7 4.2 mA No load condition, f = 20 MHz, Vdd = 2.5 V – 3.5 4.1 mA No load condition, f = 20 MHz, Vdd = 1.8 V – – 4.3 mA Vdd = 2.5 V to 3.3 V, OE = Low, Output in high Z state. – – 4.1 mA Vdd = 1.8 V, OE = Low, Output in high Z state. – 2.6 4.3 A Vdd = 2.8 V to 3.3V, ST = Low, Output is weakly pulled down – 1.4 2.5 A Vdd = 2.5 V, ST = Low, Output is weakly pulled down – 0.6 1.3 A Vdd = 1.8 V, ST = Low, Output is weakly pulled down 1 January 2023 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator Table 1. Electrical Characteristics (continued) Parameters Symbol Min. Typ. Max. Unit Condition LVCMOS Output Characteristics Duty Cycle Rise/Fall Time DC 45 – 55 % All Vdds Tr, Tf – 1.0 2.0 ns Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V, 20% - 80% – 1.3 2.5 ns Vdd = 1.8 V, 20% - 80% – – 2.0 ns Vdd = 2.25 V - 3.63 V, 20% - 80% IOH = -4 mA (Vdd = 3.0 V or 3.3 V) IOH = -3 mA (Vdd = 2.8 V or 2.5 V) IOH = -2 mA (Vdd = 1.8 V) IOL = 4 mA (Vdd = 3.0 V or 3.3 V) IOL = 3 mA (Vdd = 2.8 V or 2.5 V) IOL = 2 mA (Vdd = 1.8 V) Output High Voltage VOH 90% – – Vdd Output Low Voltage VOL – – 10% Vdd Input High Voltage VIH 70% – – Vdd Pin 3, OE or ST Input Low Voltage VIL – – 30% Vdd Pin 3, OE or ST Input Pull-up impedance Z_in 50 87 150 k Pin 3, OE logic high or logic low, or ST logic high 2 – – M Pin 3, ST logic low Input Characteristics Startup and Resume Timing Startup Time Enable/Disable Time Resume Time T_start – – 5 ms T_oe – – 130 ns Measured from the time Vdd reaches its rated minimum value f = 110 MHz. For other frequencies, T_oe = 100 ns + 3 * clock periods T_resume – – 5 ms Measured from the time ST pin crosses 50% threshold Jitter RMS Period Jitter T_jitt Peak-to-peak Period Jitter T_pk RMS Phase Jitter (random) T_phj – 1.8 3 ps f = 75 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 1.8 3 ps f = 75 MHz, Vdd = 1.8 V – 12 20 ps f = 75 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 14 25 ps f = 75 MHz, Vdd = 1.8 V – 0.5 0.9 ps f = 75 MHz, Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps f = 75 MHz, Integration bandwidth = 12 kHz to 20 MHz Table 2. Pin Description Pin Symbol 1 GND Power 2 NC No Connect Top View Functionality Output Enable OE / / NC NC GND Electrical ground No connect H[1]: specified frequency output L: output is high impedance. Only output driver is disabled. H or Open[1]: specified frequency output 3 OE/ ST ̅ ̅ ̅ /NC Standby No Connect L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. Any voltage between 0 and Vdd or Open[1]: Specified frequency output. Pin 3 has no function. 4 VDD Power Power supply voltage[2] 5 OUT Output Oscillator output VDD OUT Figure 1. Pin Assignments Notes: 1. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 3 is not externally driven. If pin 3 needs to be left floating, use the NC option. 2. A capacitor of value 0.1 µF or higher between Vdd and GND is required. Rev 1.03 Page 2 of 16 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator Table 3. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maxi mum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C Vdd -0.5 4 V Electrostatic Discharge – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C – 150 °C Junction Temperature [3] Note: 3. Exceeding this temperature for extended period of time may damage the device. Table 4. Thermal Consideration[4] Package JA, 4 Layer Board JC, Bottom (°C/W) (°C/W) SOT23-5 421 175 Note: 4. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. Table 5. Maximum Operating Junction Temperature[5] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 70°C 80°C 85°C 95°C Note: 5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 6. Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev 1.03 Page 3 of 16 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator Test Circuit and Waveform Vout Test Point Vdd tr 15 pF (including probe and fixture capacitance) 80% Vdd 4 5 1 2 tf 0.1µF 3 50% Power Supply 20% Vdd High Pulse (TH) Period Vdd 1kΩ Low Pulse (TL) OE/ST Function Figure 2. Test Circuit[6] Figure 3. Output Waveform[6] Note: 6. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams 90% Vdd Vdd Vdd 50% Vdd [7] T_start Pin 4 Voltage No Glitch during start up T_resume ST Voltage CLK Output CLK Output HZ HZ T_start: Time to start from power-off T_resume: Time to resume from ST Figure 6. Standby Resume Timing ( ST Mode Only) Figure 4. Startup Timing (OE/ ST Mode) Vdd Vdd 50% Vdd OE Voltage 50% Vdd T_oe OE Voltage T_oe CLK Output CLK Output HZ HZ T_oe: Time to put the output in High Z mode T_oe: Time to re-enable the clock output Figure 7. OE Disable Timing (OE Mode Only) Figure 5. OE Enable Timing (OE Mode Only) Note: 7. SiT2001 has “no runt” pulses and “no glitch” output during startup or resume. Rev 1.03 Page 4 of 16 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator Performance Plots[8] 1.8 2.5 2.8 3.0 3.3 6.0 Frequency (ppm) 5.5 Idd (mA) 5.0 4.5 4.0 3.5 3.0 10 20 40 60 70 80 100 110 Temperature (°C) Frequency (MHz) Figure 8. Idd vs Frequency 1.8 2.5 2.8 3.0 Figure 9. Frequency vs Temperature 1.8 3.3 2.5 2.8 3.0 3.3 55 RMS period jitter (ps) 54 Duty cycle (%) 53 52 51 50 49 48 47 46 0 10 30 40 70 45 90 0 Frequency (MHz) 20 30 40 50 60 70 80 90 100 110 Frequency (MHz) Figure 11. Duty Cycle vs Frequency Fall time (ns) Rise time (ns) Figure 10. RMS Period Jitter vs Frequency Temperature (°C) Temperature (°C) Figure 12. 20%-80% Rise Time vs Temperature Rev 1.03 10 Figure 13. 20%-80% Fall Time vs Temperature Page 5 of 16 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator IPJ (ps) IPJ (ps) Performance Plots[8] 10 30 50 70 90 110 10 30 50 70 90 110 Frequency (MHz) Frequency (MHz) Figure 14. RMS Integrated Phase Jitter Random (12 kHz to 20 MHz) vs Frequency[9] Figure 15. RMS Integrated Phase Jitter Random (900 kHz to 20 MHz) vs Frequency[9] Notes: 8. All plots are measured with 15 pF load at room temperature, unless otherwise stated. 9. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is up to 5 MHz for carrier frequencies below 40 MHz. Rev 1.03 Page 6 of 16 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator Programmable Drive Strength The SiT2001 includes a programmable drive strength feature to provide a simple, flexible tool to optimize the clock rise/fall time for specific applications. Benefits from the programmable drive strength feature are: Improves system radiated electromagnetic interference (EMI) by slowing down the clock rise/fall time. ◼ Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time. ◼ Ability to drive large capacitive loads while maintaining full swing with sharp edge rates. For more detailed information about rise/fall time control and drive strength selection, see the SiTime Application Notes section. ◼ The SiT2001 can support up to 60 pF in maximum capacitive loads with drive strength settings. Refer to the Rise/Tall Time Tables (Table 7 to 11) to determine the proper drive strength for the desired combination of output load vs. rise/fall time. SiT2001 Drive Strength Selection Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage. 1. Select the table that matches the SiT2001 nominal supply voltage (1.8 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V). 2. Select the capacitive load column that matches the application requirement (5 pF to 60 pF) 3. Under the capacitive load column, select the desired rise/fall times. 4. The left-most column represents the part number code for the corresponding drive strength. 5. Add the drive strength code to the part number for ordering purposes. EMI Reduction by Slowing Rise/Fall Time Figure 16 shows the harmonic power reduction as the rise/fall times are increased (slowed down). The rise/fall times are expressed as a ratio of the clock period. For the ratio of 0.05, the signal is very close to a square wave. For the ratio of 0.45, the rise/fall times are very close to neartriangular waveform. These results, for example, show that the 11th clock harmonic can be reduced by 35 dB if the rise/fall edge is increased from 5% of the period to 45% of the period. trise=0.05 trise=0.1 trise=0.15 trise=0.2 trise=0.25 trise=0.3 trise=0.35 trise=0.4 trise=0.45 10 Harmonic amplitude (dB) 0 -10 -20 Calculating Maximum Frequency Based on the rise and fall time data given in Tables 7 through 11, the maximum frequency the oscillator can operate with guaranteed full swing of the output voltage over temperature can be calculated as the following: 5 x Trf_20/80 where Trf_20/80 is the typical value for 20%-80% rise/fall time. -30 Example 1 -40 Calculate fMAX for the following condition: -50 -60 -70 -80 1 Max Frequency = 1 3 5 7 9 11 Harmonic number Figure 16. Harmonic EMI reduction as a Function of Slower Rise/Fall Time ◼ Vdd = 1.8 V (Table 7) ◼ Capacitive Load: 30 pF ◼ Desired Tr/f time = 3 ns (rise/fall time part number code = E) Part number for the above example: Jitter Reduction with Faster Rise/Fall Time SiT2001BIES2-18E-66.666660 Power supply noise can be a source of jitter for the downstream chipset. One way to reduce this jitter is to speed up the rise/fall time of the input clock. Some chipsets may also require faster rise/fall time in order to reduce their sensitivity to this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to Table 11) to determine the proper drive strength. Drive strength code is inserted here. Default setting is “-” High Output Load Capability The rise/fall time of the input clock varies as a function of the actual capacitive load the clock drives. At any given drive strength, the rise/fall time becomes slower as the output load increases. As an example, for a 3.3 V SiT2001 device with default drive strength setting, the typical rise/fall time is 1 ns for 15 pF output load. The typical rise/fall time slows down to 2.6 ns when the output load increases to 45 pF. One can choose to speed up the rise/fall time to 1.83 ns by then increasing the drive strength setting on the SiT2001. Rev 1.03 Page 7 of 16 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator Rise/Fall Time (20% to 80%) vs CLOAD Tables Table 8. Vdd = 2.5 V Rise/Fall Times for Specific CLOAD Table 7. Vdd = 1.8 V Rise/Fall Times for Specific CLOAD Drive Strength \ CLOAD L A R B T E U F or "‐": default Rise/Fall Time Typ (ns) 5 pF 15 pF 30 pF 45 pF 60 pF Drive Strength \ CLOAD 6.16 3.19 2.11 1.65 0.93 0.78 0.70 0.65 31.27 16.01 10.77 8.18 4.66 4.09 3.68 3.35 39.91 21.52 14.47 11.08 6.48 5.74 5.09 4.56 L A R B T E or "‐": default U F 11.61 6.35 4.31 3.23 1.91 1.66 1.48 1.30 22.00 11.00 7.65 5.79 3.32 2.94 2.64 2.40 Table 9. Vdd = 2.8 V Rise/Fall Times for Specific CLOAD 4.13 2.11 1.45 1.09 0.62 0.54 0.43 0.34 8.25 4.27 2.81 2.20 1.28 1.00 0.96 0.88 12.82 7.64 5.16 3.88 2.27 2.01 1.81 1.64 45 pF 60 pF 21.45 11.20 7.65 5.86 3.51 3.10 2.79 2.54 27.79 14.49 9.88 7.57 4.45 4.01 3.65 3.32 Table 10. Vdd = 3.0 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD Rise/Fall Time Typ (ns) 5 pF 15 pF 30 pF Rise/Fall Time Typ (ns) L A R B T 5 pF 3.77 1.94 1.29 0.97 0.55 15 pF 7.54 3.90 2.57 2.00 1.12 30 pF 12.28 7.03 4.72 3.54 2.08 45 pF 19.57 10.24 7.01 5.43 3.22 60 pF 25.27 13.34 9.06 6.93 4.08 Drive Strength \ CLOAD L A R B T or "‐": default 5 pF 3.60 1.84 1.22 0.89 0.51 15 pF 7.21 3.71 2.46 1.92 1.00 30 pF 11.97 6.72 4.54 3.39 1.97 45 pF 18.74 9.86 6.76 5.20 3.07 60 pF 24.30 12.68 8.62 6.64 3.90 E or "‐": default U F 0.44 0.34 0.29 1.00 0.88 0.81 1.83 1.64 1.48 2.82 2.52 2.29 3.67 3.30 2.99 E U F 0.38 0.30 0.27 0.92 0.83 0.76 1.72 1.55 1.39 2.71 2.40 2.16 3.51 3.13 2.85 Table 11. Vdd = 3.3 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD L A R B 5 pF 3.39 1.74 1.16 0.81 15 pF 6.88 3.50 2.33 1.82 30 pF 11.63 6.38 4.29 3.22 45 pF 17.56 8.98 6.04 4.52 60 pF 23.59 12.19 8.34 6.33 T or "‐": default E U F 0.46 0.33 0.28 0.25 1.00 0.87 0.79 0.72 1.86 1.64 1.46 1.31 2.60 2.30 2.05 1.83 3.84 3.35 2.93 2.61 Rev 1.03 Page 8 of 16 www.sitime.com SiT2001B Single-Chip, SOT23 Oscillator Pin 1 Configuration Options (OE, ST ̅ ̅ ̅ , or NC) Output on Startup and Resume Pin 3 of the SiT2001 can be factory-programmed to support three modes: Output Enable (OE), standby ( ST ) or No Connect (NC). The SiT2001 comes with gated output. Its clock output is accurate to the rated frequency stability within the first pulse from initial device startup or resume from the standby mode. Output Enable (OE) Mode In addition, the SiT2001 supports “no runt” pulses, and “no glitch” output during startup or resume as shown in the waveform captures in Figure 17 and Figure 18. In the OE mode, applying logic Low to the OE pin only disables the output driver and puts it in Hi-Z mode. The core of the device continues to operate normally. Power consumption is reduced due to the inactivity of the output. When the OE pin is pulled High, the output is typically enabled in
SIT2001BIFS-XXS
物料型号:SiT2001B
器件简介: - 该振荡器可提供1 MHz至110 MHz的任意频率,精确到小数点后六位。 - 工作温度范围从-40°C至85°C,另有SiT2018和SiT2020型号适用于更宽的温度范围。 - 具有出色的总频率稳定性,低至±20 ppm。 - 低功耗,典型值为3.5 mA。 - 快速启动时间5毫秒。 - LVCMOS/HCMOS兼容输出。 - 封装为5引脚SOT23-5,尺寸为2.9 mm x 2.8 mm。 - 符合无铅、RoHS和REACH标准。
引脚分配: - 1号引脚:GND(电源地) - 2号引脚:NC(无连接) - 3号引脚:OE/ST/NC(输出使能/待机/无连接) - 4号引脚:VDD(电源电压) - 5号引脚:OUT(振荡器输出)
参数特性: - 频率范围:1 MHz至110 MHz - 频率稳定性:包括初始容差、25°C下1年老化以及在工作温度、额定电源电压和负载(15pF±10%)变化下的变化,范围从-20 ppm至+50 ppm不等。 - 电源电压:1.62 V至3.63 V - 电流消耗:在20 MHz频率、不同电源电压下,无负载条件下的范围从3.5 mA至4.5 mA - 启动时间:5 ms - 抖动性能:包括RMS周期抖动和峰峰周期抖动
功能详解: - 提供了可编程的驱动强度特性,以优化特定应用中的时钟上升/下降时间。 - 包括了电磁干扰(EMI)降低、抖动降低、高输出负载能力和最大频率计算的详细说明。
应用信息: - 适用于工业、医疗、汽车、航空和其他高温应用,例如工业传感器、PLC、电机伺服、户外网络设备、医疗视频摄像头、资产跟踪系统等。
封装信息: - SOT23-5封装,尺寸为2.9 mm x 2.8 mm,提供了详细的封装尺寸和布局图案。
SIT2001BIFS-XXS 价格&库存
很抱歉,暂时无法提供与“SIT2001BIFS-XXS”相匹配的价格&库存,您可以联系我们找货
