HHXD630ARA220MF80G
HHXD630ARA220MF80G
    NCC(贵弥功)
    SMD,D6.3xL7.7mm
    22 µF 63 V 铝聚合物电容器 径向,Can - SMD 80 毫欧 105°C 时为 5000 小时
HHXD630ARA220MF80G 数据手册
CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXD Series ・High reliability and high voltage are realized by hybrid electrolyte ・Endurance with ripple current : 5,000 to 10,000 hours at 105℃ ・Rated voltage range : 16 to 80Vdc, Capacitance range : 6.8 to 560μF ・For high reliability applications. (Automotive equipment, Base station equipment, etc.) ・RoHS2 Compliant ・Halogen Free ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. HXC Higher temperature HXD ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ 16 to 80Vdc ±20% (M) I=0.01CV or 3μA, whichever is greater Where, I : Max. leakage current (μA) , C: Nominal capacitance(μF), V : Rated voltage(V) Rated voltage(Vdc) 16V 25V 35V 50V 63V 80V tanδ 0.16 0.14 0.12 0.10 0.08 0.08 (Max.) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.5 Z(-55℃)/Z(+20℃)≦2.0 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 10,000 hours (E61 and F61: 5,000 hours) at 105 ℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105 ℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage at 85℃, 85% RH for 2,000 hours. Appearance No significant damage Capacitance change ≦ ±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life Bias Humidity Test ◆DIMENSIONS [mm] ● Terminal Code : A ● Size code : E61 to JA0 ● Terminal Code : G(Vibration resistant structure) ● Size code : F61 to JA0 Vent for JA0 Vent for JA0 0.3max. W 0.3max. L±0.3 (Note) L±0.3 (Note) Note : L±0.5 for HA0 and JA0 A±0.2 Note : L±0.5 for HA0 and JA0 2 3 4 H HXD 5 6 7 8 9 10 RA 11 12 Size Code E61 F61 F80 HA0 JA0 φD 5 6.3 6.3 8 10 L 5.8 5.8 7.7 10.0 10.0 A 5.3 6.6 6.6 8.3 10.3 B 5.3 6.6 6.6 8.3 10.3 C 5.9 7.2 7.2 9.0 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.4 1.9 1.9 3.1 4.5 A±0.2 : Dummy terminals ◆MARKING ◆PART NUMBERING SYSTEM 1 P C±0.2 B±0.2 φD±0.5 P C±0.2 B±0.2 φD±0.5 W 13 14 M 15 16 17 18 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101) Taping code Terminal code Voltage code (ex. 35V:350, 50V:500) Series code Category EX) 35V47µF 26A 47 V HD ●Rated voltage symbol Rated voltage (Vdc) 16 25 35 50 63 80 Symbol C E V H J K Please refer to "Product code guide (conductive polymer hybrid type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXDSeries ◆STANDARD RATINGS WV (Vdc) 16 25 35 50 63 80 Cap (µF) Size code ESR (mΩmax./20℃, 100kHz) Rated ripple current (mArms/105℃, 100kHz) Part No. 47 82 100 150 180 270 330 470 560 33 47 56 68 100 150 220 270 330 390 22 27 47 47 68 100 150 150 270 10 15 22 33 33 47 56 68 82 100 120 6.8 10 10 22 22 33 33 47 56 82 100 27 56 E61 F61 F61 F80 F80 HA0 HA0 JA0 JA0 E61 F61 F61 F80 F80 HA0 HA0 JA0 JA0 JA0 E61 F61 F61 F80 F80 HA0 HA0 JA0 JA0 F61 F80 F61 F80 HA0 HA0 JA0 HA0 HA0 JA0 JA0 F61 F61 F80 F80 HA0 HA0 JA0 HA0 JA0 JA0 JA0 HA0 JA0 80 45 45 27 27 22 22 18 18 80 50 50 30 30 27 27 20 20 20 100 60 60 35 35 27 27 20 20 80 40 80 40 30 30 25 30 30 25 25 120 120 80 80 40 40 30 40 30 30 30 45 33 900 1,600 1,600 2,200 2,200 2,500 2,500 2,600 2,600 900 1,300 1,300 2,000 2,000 2,300 2,300 2,500 2,500 2,500 900 1,300 1,300 2,000 2,000 2,300 2,300 2,500 2,500 1,100 1,600 1,100 1,600 1,800 1,800 2,400 1,800 1,800 2,400 2,400 1,000 1,000 1,500 1,500 1,600 1,600 2,400 1,600 2,400 2,400 2,400 1,600 2,400 HHXD160ARA470ME61G HHXD160□RA820MF61G HHXD160□RA101MF61G HHXD160□RA151MF80G HHXD160□RA181MF80G HHXD160□RA271MHA0G HHXD160□RA331MHA0G HHXD160□RA471MJA0G HHXD160□RA561MJA0G HHXD250ARA330ME61G HHXD250□RA470MF61G HHXD250□RA560MF61G HHXD250□RA680MF80G HHXD250□RA101MF80G HHXD250□RA151MHA0G HHXD250□RA221MHA0G HHXD250□RA271MJA0G HHXD250□RA331MJA0G HHXD250□RA391MJA0G HHXD350ARA220ME61G HHXD350□RA270MF61G HHXD350□RA470MF61G HHXD350□RA470MF80G HHXD350□RA680MF80G HHXD350□RA101MHA0G HHXD350□RA151MHA0G HHXD350□RA151MJA0G HHXD350□RA271MJA0G HHXD500□RA100MF61G HHXD500□RA150MF80G HHXD500□RA220MF61G HHXD500□RA330MF80G HHXD500□RA330MHA0G HHXD500□RA470MHA0G HHXD500□RA560MJA0G HHXD500□RA680MHA0G HHXD500□RA820MHA0G HHXD500□RA101MJA0G HHXD500□RA121MJA0G HHXD630□RA6R8MF61G HHXD630□RA100MF61G HHXD630□RA100MF80G HHXD630□RA220MF80G HHXD630□RA220MHA0G HHXD630□RA330MHA0G HHXD630□RA330MJA0G HHXD630□RA470MHA0G HHXD630□RA560MJA0G HHXD630□RA820MJA0G HHXD630□RA101MJA0G HHXD800□RA270MHA0G HHXD800□RA560MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) to 15 to 47 to 220 to Frequency(Hz) 10 33 180 560 120 0.03 0.07 0.10 0.13 1k 0.30 0.30 0.40 0.45 5k 0.50 0.50 0.60 0.65 10k 0.60 0.60 0.70 0.75 20k 0.70 0.70 0.80 0.85 30k 0.75 0.75 0.80 0.85 100k to 500k 1.00 1.00 1.00 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming, Terminal and Packaging Options Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
HHXD630ARA220MF80G 价格&库存
很抱歉,暂时无法提供与“HHXD630ARA220MF80G”相匹配的价格&库存,您可以联系我们找货
HHXD630ARA220MF80G
    • 1+7.093651+0.91627
    • 10+3.9243310+0.50690
    库存:1245
    HHXD630ARA220MF80G
    • 900+4.02975900+0.51690
    • 1800+3.770191800+0.48361
    • 2700+3.639232700+0.46681
    • 4500+3.493224500+0.44808
    • 6300+3.407426300+0.43707
    • 9000+3.324559000+0.42644
    库存:1622
    HHXD630ARA220MF80G
    • 1+11.832371+1.51774
    • 10+7.5863910+0.97311
    • 50+5.8147450+0.74586
    • 100+5.25473100+0.67403
    库存:1622
    HHXD630ARA220MF80G
      • 1+10.201891+1.30860
      • 50+7.2978250+0.93610
      • 100+6.77894100+0.86954
      • 300+6.42744300+0.82445
      • 500+6.36049500+0.81586
      • 1000+6.310271000+0.80942
      • 2000+6.276802000+0.80513
      库存:700
