SiT9367
220 MHz to 725 MHz Ultra-low Jitter Differential Oscillator
Description
Features
The SiT9367 is a 220.000001 MHz to 725 MHz differential
MEMS XO engineered for low-jitter applications. Utilizing
SiTime’s unique DualMEMS® temperature sensing and
TurboCompensation® technology, the SiT9367 delivers
exceptional dynamic performance by providing resistance
to airflow, thermal gradients, shock and vibration. This
device also integrates multiple on-chip regulators to filter
power supply noise, eliminating the need for a dedicated
external LDO.
Any frequency between 220.000001 MHz and 725 MHz,
accurate to 6 decimal places.
For HCSL output signaling, maximum frequency is
500 MHz. Contact SiTime for higher frequency options.
(For additional frequencies, refer to SiT9366 and SiT9365
datasheets)
The SiT9367 can be factory programmed for any
combination of frequency, stability, voltage, and output
signaling. Programmability enables designers to optimize
clock configurations while eliminating long lead times and
customization costs associated with quartz devices
where each frequency is custom built.
LVPECL, Low-swing LVPECL, LVDS and HCSL output
signaling
0.1ps RMS phase jitter (random) for Ethernet applications
Frequency stability as low ±10 ppm
Wide temperature range from -40°C to 105°C
Contact SiTime for higher temperature range options
Industry-standard packages: 3.2 x 2.5 mm2, 7.0 x 5.0 mm2
and 5.0 x 3.2 mm2 package
The wide frequency range and programmability makes
this device ideal for telecom, networking, and industrial
applications that require a variety of frequencies and
operate in noisy environments.
Applications
100 Gbps Ethernet, SONET, SATA, SAS,
Fibre Channel
Telecom, networking, instrumentation, storage, servers
Refer to Manufacturing Notes for proper reflow profile,
tape and reel dimension, and other manufacturing
related information.
Related products for automotive applications.
Block Diagram
Package Pinout
For aerospace and defense applications SiTime recommends
using only Endura™ SiT9347.
1
6
VDD
NC
2
5
OUT-
GND
3
4
OUT+
Figure 2. Pin Assignments (Top view)
(Refer to Table 6 for Pin Descriptions)
Figure 1. SiT9367 Block Diagram
Rev 1.72
OE/NC
1 January 2023
www.sitime.com
SiT9367 220 MHz to 725 MHz Ultra-low Jitter Differential Oscillator
Ordering Information
SiT9367AC - 1B2-33E322.265625T
Part Family
Packaging
“SiT9367”
“T”, “Y”, “D” or “E”
Refer to table below for packing method
[1]
Leave Blank for Bulk
Revision Letter
“A” is the revision of Silicon
Frequency
220.00001 to 725 MHz for LVDS and
LVPECL output drivers
[2]
220.00001 to 500 MHz for HCSL driver
Temperature Range
“C”: Extended Commercial, -20 to 70°C
“I”: Industrial, -40 to 85°C
“B”: -40 to 95°C
“E”: Extended Industrial, -40 to 105°C
Feature Pin
“N”: No Connect
“E”: Output Enable
Signalling Type
“1”: LVPECL
“2”: LVDS
“4”: HCSL
“5”: Low-swing LVPECL
Voltage Supply
“25”: 2.5 V ±10%
“28”: 2.8 V ±10%
“30”: 3.0 V ±10%
“33”: 3.3 V ±10%
Package Size
“B”: 3.2 x 2.5 mm
“C”: 5.0 x 3.2 mm with center pad
“E”: 7.0 x 5.0 mm with center pad
Frequency Stability
“F”:
“1”:
“2”:
“3”:
±10 ppm
±20 ppm
±25 ppm
±50 ppm
Notes:
1. Bulk is available for sampling only.
2. Contact SiTime for higher frequency HCSL options.
Table 1. Ordering Codes for Supported Tape & Reel Packing Method
Device Size
(mm x mm)
8 mm T&R
(3ku)
8 mm T&R
(1ku)
12 mm T&R
(3ku)
12 mm T&R
(1ku)
16 mm T&R
(3ku)
16 mm T&R
(1ku)
7.0 x 5.0
T
Y
T
Y
5.0 x 3.2
3.2 x 2.5
Rev 1.72
D
E
Page 2 of 16
www.sitime.com
TABLE OF CONTENTS
Description ................................................................................................................................................................................... 1
Features ....................................................................................................................................................................................... 1
Applications .................................................................................................................................................................................. 1
Block Diagram .............................................................................................................................................................................. 1
Package Pinout ............................................................................................................................................................................ 1
Ordering Information .................................................................................................................................................................... 2
Electrical Characteristics .............................................................................................................................................................. 4
Waveform Diagrams..................................................................................................................................................................... 9
Timing Diagrams ........................................................................................................................................................................ 10
Termination Diagrams ................................................................................................................................................................ 11
LVPECL and Low-swing LVPECL ....................................................................................................................................... 11
LVDS................................................................................................................................................................................... 12
HCSL .................................................................................................................................................................................. 12
Dimensions and Patterns ― 3.2 x 2.5 mm2................................................................................................................................ 13
Dimensions and Patterns ― 5.0 x 3.2 mm2................................................................................................................................ 13
Dimensions and Patterns ― 7.0 x 5.0 mm2................................................................................................................................ 14
Additional Information................................................................................................................................................................. 15
Revision History ......................................................................................................................................................................... 16
Rev 1.72
Page 3 of 16
www.sitime.com
All Min and Max limits in the Electrical Characteristics tables are specified over temperature and rated operating voltage
with standard output termination shown in the termination diagrams. Typical values are at 25°C at nominal supply voltage.
Table 2. Electrical Characteristics – Common to LVPECL, Low-swing LVPECL, LVDS and HCSL
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Range
Output Frequency Range
f
220.000001
725
MHz
Accurate to 6 decimal places
Frequency Stability
Frequency Stability
F_stab
-10
+10
ppm
-20
+20
ppm
-25
+25
ppm
-50
+50
ppm
Inclusive of initial tolerance, operating temperature, rated power
supply voltage and load variations
First Year Aging
F_1y
-0.7
±0.4
+0.7
ppm
At 85°C
5 Year Aging
F_5y
-1.1
±0.7
+1.1
ppm
At 85°C
10 Year Aging
F_10y
-1.3
±0.8
+1.3
ppm
At 85°C
20 Year Aging
F_20y
-1.5
±1.0
+1.5
ppm
At 85°C
Temperature Range
Operating Temperature Range
T_use
-20
+70
°C
Extended Commercial
-40
+85
°C
Industrial
-40
+95
°C
-40
+105
°C
Extended Industrial
Supply Voltage
Supply Voltage
Vdd
2.97
3.30
3.63
V
2.70
3.00
3.30
V
2.52
2.80
3.08
V
2.25
2.50
2.75
V
Input Characteristics
Input Voltage High
VIH
70%
Vdd
Pin 1, OE
Input Voltage Low
VIL
30%
Vdd
Pin 1, OE
Input Pull-up Impedance
Z_in
100
kΩ
Pin 1, OE logic high or logic low
Output Characteristics
Duty Cycle
DC
45
55
Startup and OE Timing
Startup Time
OE Enable/Disable Time
Rev 1.72
T_start
3.0
ms
Measured from the time Vdd reaches its rated minimum value.
T_oe
3.8
µs
f = 322.265625 MHz. Measured from the time OE pin reaches rated
VIH and VIL to the time clock pins reach 90% of swing and high-Z.
See Figure 8 and Figure 9
Page 4 of 16
www.sitime.com
Table 3. Electrical Characteristics – LVPECL Specific
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Current Consumption
Idd
94
mA
Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V
OE Disable Supply Current
I_OE
63
mA
OE = Low
Output Disable Leakage Current
I_leak
0.15
A
OE = Low
I_driver
33
mA
Maximum average current drawn from OUT+ or OUT-
Current Consumption
Maximum Output Current
Output Characteristics for LVPECL
Output High Voltage
VOH
Vdd-1.15
Vdd-0.7
V
See Figure 4
Output Low Voltage
VOL
Vdd-2.0
Vdd-1.5
V
See Figure 4
V_Swing
1.2
1.6
2.0
V
See Figure 5
Tr, Tf
225
330
ps
20% to 80%, see Figure 5
Output Differential Voltage Swing
Rise/Fall Time
Output High Voltage
VOH
Output Characteristics for Low-swing LVPECL
Vdd-1.2
Vdd-0.75
V
See Figure 4
Output Low Voltage
VOL
Vdd-1.8
Vdd-1.25
V
See Figure 4
V_Swing
0.4
1
1.2
V
Output frequency 1 to 220 MHz, See Figure 5
0.4
1
1.6
V
Output frequency greater than 220 MHz, See Figure 5
225
320
ps
20% to 80%. See Figure 5
Swing
Rise/Fall Time
Tr, Tf
Jitter – 7.0 x 5.0 mm Package
RMS Period Jitter[3]
T_jitt
1.0
1.6
Ps
f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V
RMS Phase Jitter (random)
T_phj
0.220
0.270
Ps
f = 322.265625 MHz, Integration bandwidth = 12 kHz to 20 MHz,
all Vdd levels, includes spurs. Temperature ranges -20 to 70ºC and
-40 to 85ºC.
0.220
0.300
Ps
all Vdd levels, includes spurs. Temperature ranges -40 to 95ºC and
-40 to 105ºC
0.1
Ps
f = 322.265625 MHz, IEEE802.3-2005 10GbE jitter mask
integration bandwidth = 1.875 MHz to 20 MHz, Includes spurs, all
Vdd levels
Jitter – 5.0 x 3.2 and 3.2 x 2.5 mm Packages
T_jitt
1.0
1.6
Ps
T_phj
0.225
0.282
ps
-40 to 85ºC.
0.225
0.315
ps
-40 to 105ºC
0.1
ps
Vdd levels
Notes:
3. Measured according to JESD65B.
Rev 1.72
Page 5 of 16
www.sitime.com
Table 4. Electrical Characteristics – LVDS Specific
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Current Consumption
Idd
85
mA
I_OE
63
mA
OE = Low
I_leak
0.15
A
OE = Low
Current Consumption
VOD
300
450
mV
See Figure 6
ΔVOD
50
mV
See Figure 6
VOS
1.125
1.375
V
See Figure 6
VOS Magnitude Change
ΔVOS
50
mV
See Figure 6
Rise/Fall Time
Tr, Tf
370
470
ps
Measured with 2 pF capacitive loading to GND, 20% to 80%,
see Figure 3
RMS Period Jitter[4]
T_jitt
0.92
1.6
ps
T_phj
0.215
0.265
ps
-40-85ºC.
0.215
0.280
ps
all Vdd levels, includes spurs. Temperature ranges are -40 to 95ºC
and -40 to 105ºC.
0.1
ps
integration bandwidth = 1.875 MHz to 20 MHz. Includes spurs for
all Vdd levels.
Differential Output Voltage
VOD Magnitude Change
Offset Voltage
T_jitt
0.92
1.6
ps
T_phj
0.235
0.282
ps
-40-85ºC.
0.235
0.310
ps
and -40 to 105ºC.
0.1
ps
all Vdd levels.
Notes:
4. Measured according to JESD65B.
Rev 1.72
Page 6 of 16
www.sitime.com
Table 5. Electrical Characteristics – HCSL Specific
Parameter
Symbol
Min.
Typ.
Max.
Unit
Condition
Current Consumption
Idd
97
mA
I_OE
63
mA
OE = Low
I_leak
0.15
A
OE = Low
I_driver
35
mA
Current Consumption
Output High Voltage
VOH
0.60
0.90
V
See Figure 4
Output Low Voltage
VOL
-0.05
0.08
V
See Figure 4
V_Swing
1.2
1.4
1.9
V
See Figure 5
Rise/Fall Time
Tr, Tf
360
505
ps
see Figure 4
RMS Period Jitter[5]
T_jitt
1.0
1.6
ps
T_phj
0.215
0.265
ps
-40 to 85ºC
0.215
0.282
ps
all Vdd levels, includes spurs. Temperature range ranges -40 to
95ºC and -40 to 105ºC
0.1
ps
Vdd levels
T_jitt
1.0
1.6
T_phj
0.235
0.282
ps
ps
0.235
0.305
ps
-40 to 105ºC
0.1
ps
integration bandwidth = 1.875 MHz to 20 MHz, Includes spurs for
all Vdd levels.
-40 to 85ºC
Note:
5. Measured according to JESD65B
Table 6. Pin Description
Pin
1
Map
OE/NC
Top View
Functionality
[6]
Output Enable
(OE)
H : specified frequency output
L: output is high impedance
Non Connect
(NC)
H or L or Open: No effect on output frequency or other device
functions.
OE/NC
1
6
VDD
NC
2
5
OUT-
GND
3
4
OUT+
No Connect; Leave it floating or connect to GND for better
heat dissipation
2
NC
NA
3
GND
Power
VDD Power Supply Ground
4
OUT+
Output
Oscillator output
5
OUT-
Output
Complementary oscillator output
6
VDD
Power
Power supply voltage[7]
Figure 3. Pin Assignments
Notes:
6. In OE mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven.
7. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the
best phase jitter performance.
Rev 1.72
Page 7 of 16
www.sitime.com
Table 7. Absolute Maximum Ratings
Caution: Attempted operation outside the absolute maximum ratings may cause permanent damage to the part.
Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Parameter
Min.
Max.
Unit
-0.5
4.0
V
Vdd + 0.3V
V
150
ºC
Maximum Junction Temperature
130
ºC
Soldering Temperature (follow standard Pb-free soldering guidelines)
260
ºC
Vdd
VIH
VIL
-0.3
Storage Temperature
-65
V
Table 8. Thermal Considerations[8]
Package
JA, 4 Layer Board (°C/W)
JC, Bottom (°C/W)
3225, 6-pin
80
30
5032, 6-pin
53
7050, 6-pin
52
19
Notes:
8. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table.
Table 9. Maximum Operating Junction Temperature[9]
Max Operating Temperature (ambient)
70°C
95°C
85°C
110°C
95°C
120°C
105°C
130°C
Notes:
9.
Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 10. Environmental Compliance
Test Conditions
Value
Unit
Mechanical Shock Resistance
Parameter
MIL-STD-883F, Method 2002
10,000
g
Mechanical Vibration Resistance
MIL-STD-883F, Method 2007
70
g
Soldering Temperature (follow standard Pb free soldering guidelines)
MIL-STD-883F, Method 2003
260
°C
Moisture Sensitivity Level
MSL1 @ 260°C
Electrostatic Discharge (HBM)
HBM, JESD22-A114
2,000
V
Charge-Device Model ESD Protection
JESD220C101
750
V
Latch-up Tolerance
Rev 1.72
JESD78 Compliant
Page 8 of 16
www.sitime.com
Waveform Diagrams
OUT-
VOH
OUT+
VOL
GND
Figure 4. LVPECL, Low-swing LVPECL, and HCSL Voltage Levels per Differential Pin (i.e. OUT+, or OUT-)
V
80%
80%
V_ Swing
0V
t
20%
20%
Tr
Tf
Figure 5. LVPECL, Low-swing LVPECL, and HCSL Voltage Levels Across Differential Pair (i.e. OUT+ minus OUT-)
Rev 1.72
Page 9 of 16
www.sitime.com
Waveform Diagrams (continued)
OUT-
VOD
OUT+
VOS
GND
Figure 6. LVDS Voltage Levels per Differential Pin (i.e. OUT+, or OUT-)
V
80%
80%
0V
t
20%
20%
Tr
Tf
Figure 7. LVDS Differential Waveform (i.e. OUT+ minus OUT-)
Timing Diagrams
Vdd
OE Voltage
Vdd
VIH
VIL
T_oe_hw
OE Voltage
T_oe_hw
OUT-
OUT-
90%
HZ
HZ
OUT+
OUT+
GND
GND
Figure 8. Hardware OE Enable Timing
Rev 1.72
Figure 9. Hardware OE Disable Timing
Page 10 of 16
www.sitime.com
OUT+
Shunt Bias Termination
network 0.1μF
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
LVPECL
0.1μF
RB
RB
VDD
50 Ω
50 Ω
RB
3.3 V 100 Ω
VT
2.5 V 48.7 Ω
Figure 10. LVPECL and Low-swing LVPECL with AC-coupled Termination
VDD
Thevenin-equivalent
Termination network
R1
LVPECL
R1
OUT+
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
VDD
R1
R2
R2
3.3 V 127 Ω
82.5 Ω
2.5 V 250 Ω
62.5 Ω
R2
Figure 11. LVPECL and Low-swing LVPECL DC-coupled Load Termination with Thevenin Equivalent Network
Y-Bias Termination
network
LVPECL
OUT+
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
R1
VDD
R1
R2
R3
3.3 V
50 Ω
50 Ω
50 Ω
2.5 V
50 Ω
50 Ω
18 Ω
C1
0.1μF
R2
R3
Figure 12. LVPECL and Low-swing LVPECL with Y-Bias Termination
OUT+
Shunt Bias
Termination network
Zo = 50Ω
D+
OUT-
Zo = 50Ω
D-
LVPECL
50 Ω
50 Ω
VT=VDD-2V
Figure 13. LVPECL and Low-swing LVPECL with DC-coupled Parallel Shunt Load Termination
Rev 1.72
Page 11 of 16
www.sitime.com
Termination Diagrams (continued)
LVDS
LVDS
Zo = 50Ω
OUT+
OUT+
100 Ω
Zo = 50Ω
OUT-
OUT-
Figure 14. LVDS Single DC Termination at the Load
LVDS
0.1μF
Zo = 50Ω
OUT+
OUT+
100 Ω
100 Ω
0.1μF
Zo = 50Ω
OUT-
OUT-
Figure 15. LVDS double AC Termination with Capacitor Close to the Load
LVDS
Zo = 50Ω
OUT+
OUT+
100 Ω
100 Ω
Zo = 50Ω
OUT-
OUT-
Figure 16. LVDS Double DC Termination
HCSL
R1
OUT+
OUT-
Zo = 50Ω
D+
Zo = 50Ω
D-
R2
50Ω
50Ω
R1 = R2 = 33 Ω
Figure 17. HCSL Interface Termination
Rev 1.72
Page 12 of 16
www.sitime.com
Package Size – Dimensions (Unit: mm)[10]
3.2 x 2.5 x 0.85 mm
Recommended Land Pattern (Unit: mm)[11]
3.2 x 2.5 x 0.85 mm
1.00
1.6
2.25
0.65
1.05
5.0 x 3.2 x 0.85 mm[12]
Notes:
10. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of
the device.
11. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the
12. The center pad has no electrical function. Soldering down the center pad to the GND is recommended for best thermal dissipati on, but is optional.
Rev 1.72
Page 13 of 16
www.sitime.com
Package Size – Dimensions (Unit: mm)[13]
7.0 x 5.0 x 0.85 mm[15]
Recommended Land Pattern (Unit: mm)[14]
Notes:
13. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the as sembly location of
the device.
14. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the
15. The center pad has no electrical function. Soldering down the center pad to the GND is recommended for best thermal dissipation, but is optional.
Rev 1.72
Page 14 of 16
www.sitime.com
Table 11. Additional Information
Document
Description
Download Link
ECCN #: EAR99
Five character designation used on the
commerce Control List (CCL) to identify dual
use items for export control purposes.
HTS Classification Code: A Harmonized Tariff Schedule (HTS) code
developed by the World Customs Organization
8542.39.0000
to classify/define internationally traded goods.
Part number Generator
Tool used to create the part number based on
desired features.
https://www.sitime.com/part-number-generator
Manufacturing Notes
Tape & Reel dimension, reflow profile and
other manufacturing related info
https://www.sitime.com/sites/default/files/gated/Manufacturing-Notes-for-SiTimeProducts.pdf
Qualification Reports
RoHS report, reliability reports,
composition reports
http://www.sitime.com/support/quality-and-reliability
Performance Reports
Additional performance data such as phase
noise, current consumption and jitter for
selected frequencies
http://www.sitime.com/support/performance-measurement-report
Termination Techniques
Termination design recommendations
http://www.sitime.com/support/application-notes
Layout Techniques
Layout recommendations
Evaluation Boards
SiT6085/6EB rev. 3.0, SiT6085EB rev.3.1 and
SiT6097EB rev. 2.0 Evaluation Boards for
Differential Oscillators User Manual
https://www.sitime.com/support/user-guides
Rev 1.72
Page 15 of 16
www.sitime.com
Revision History
Table 12. Revision History
Revision
1.0
Release Date
21-Jul-2017
1.03
1.04
1.05
11-May-2018
25-Oct-2018
Change Summary
Initial draft
Corrected max frequency in ordering information table.
Added 5.0 x 3.2 package.
Added preliminary IPJ numbers for 5032 package. Will be updated after characterization.
Corrected minor errors.
Added Additional Information Table.
Performed minor edits and updated Ordering Information.
Removed “Contact SiTime” for ±10 ppm
Updated package Dimensions Drawings
Updated Table 8 Thermal Considerations for 5032 package
Updated Table 2 specification for First Year Aging
Added 5, 10, and 20 year aging specs
Added Evaluation Boards SiT6085EB reference in Additional Information
Rearranged layout, added Description, Block Diagram and TOC
Tightened LVDS minimum VOD specification
Added HTS code
Added low-swing LVPECL package code and specifications
1.06
17-Aug-2019
1.07
9-Mar-2021
Updated L1 and Dimple Width package dimensions for 3.2 x 2.5 mm package
Updated trademarks, hyperlinks and changed rev table date format
1.71
15-Jul-2021
Updated pin direction in package dimensions for 3.2 x 2.5 mm package
1.72
1-Jan-2023
Updated company disclaimer, links, references and icons
SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439
© SiTime Corporation 2017-2023. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liability for any loss, damage
or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect
or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or
(iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress.
Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by
operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing
or usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. This
product is not suitable or intended to be used in a life support application or component, to operate nuclear facilities, in military or aerospace applications, or in other mission critical
applications where human life may be involved or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below.
CRITICAL USE EXCLUSION POLICY
BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS: USED IN LIFE SUPPORT DEVICES, TO OPERATE NUCL EAR
FACILITIES, FOR MILITARY OR AEROSPACE USE, OR IN OTHER MISSION CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPER TY MAY BE
AT STAKE.
For aerospace and defense applications, SiTime recommends using only Endura™ ruggedized products.
SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does
not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale
of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly
prohibited.
Rev 1.72
Page 16 of 16
www.sitime.com
