EMHL100ARA471MHA0G
EMHL100ARA471MHA0G
    NCC(贵弥功)
    AEC-D8X10MM_SM
    470 µF 10 V 铝电解电容器 径向,Can - SMD 300 毫欧 @ 100kHz 125°C 时为 4000 小时
EMHL100ARA471MHA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MHL - Series ・Downsized and Longer life from current MVH series ・Endurance : 2,000 to 4,000 hours at 125℃ ・Rated voltage range : 10 to 35V. Nominal capacitance range : 47 to 680µF ・For automobile modules and other high temperature applications ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. MHL Downsized Longer life MVH ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +125℃ 10 to 35Vdc (at 20℃, 120Hz) ±20%(M) I=0.01CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage(Vdc) 10V 16V 25V 35V tanδ(Max.) 0.24 0.20 0.16 0.14 (at 20℃, 120Hz) Rated voltage(Vdc) 10V 16V 25V 35V Z(-25℃)/Z(+20℃) 3 2 2 2 Z(-40℃)/Z(+20℃) 6 4 4 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified time at 125℃. F61 & F80 :2,000 hours Time HA0 & JA0:4,000 hours Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size Code : A code : F61 to JA0 ● Size Code : G(Vibration resistant structure) code : F61 to JA0 Size code Vent for JA0 Vent for JA0 0.3max. W 0.3max. L±0.3 (Note) L±0.3 (Note) Note : L±0.5 for HA0 and JA0 A±0.2 Note : L±0.5 for HA0 and JA0 2 3 4 5 6 7 8 9 10 11 12 A φD L 6.3 5.8 6.6 6.3 7.7 6.6 8 10.0 8.3 10 10.0 10.3 B 6.6 6.6 8.3 10.3 C 7.2 7.2 9.0 11.0 W 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.9 1.9 3.1 4.5 A±0.2 : Dummy terminals ◆PART NUMBERING SYSTEM 1 P C±0.2 B±0.2 φD±0.5 P C±0.2 B±0.2 φD±0.5 W F61 F80 HA0 JA0 13 14 15 16 17 ◆MARKING 18 E MH L A A A A R A A A A M A A A G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470,100µF:101) Taping code Terminal code (A, G) Voltage code (ex. 35V:350) Series code Category EX) 35V47µF 2Q 47 V HL ●Rated voltage symbol Rated voltage (Vdc) Symbol A 10 C 16 E 25 V 35 Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MHLSeries - ◆STANDARD RATINGS WV (Vdc) 10 16 25 35 Cap (µF) Size code 100 220 330 470 680 47 100 220 330 470 680 47 100 220 330 47 100 220 330 F61 F80 HA0 HA0 JA0 F61 F61 F80 HA0 JA0 JA0 F61 F80 HA0 JA0 F61 F80 HA0 JA0 ESR (Ω max./100kHz) 20℃ -40℃ 1.2 0.60 0.30 0.30 0.20 1.2 1.2 0.60 0.30 0.20 0.20 1.2 0.60 0.30 0.20 1.2 0.60 0.30 0.20 22 12 5.5 5.5 3.6 22 22 12 5.5 3.6 3.6 22 12 5.5 3.6 22 12 5.5 3.6 Rated ripple current (mArms/125℃, 100kHz) 110 220 296 296 440 110 110 220 296 440 440 110 220 296 440 110 220 296 440 Part No. EMHL100 □ RA101MF61G EMHL100 □ RA221MF80G EMHL100 □ RA331MHA0G EMHL100 □ RA471MHA0G EMHL100 □ RA681MJA0G EMHL160 □ RA470MF61G EMHL160 □ RA101MF61G EMHL160 □ RA221MF80G EMHL160 □ RA331MHA0G EMHL160 □ RA471MJA0G EMHL160 □ RA681MJA0G EMHL250 □ RA470MF61G EMHL250 □ RA101MF80G EMHL250 □ RA221MHA0G EMHL250 □ RA331MJA0G EMHL350 □ RA470MF61G EMHL350 □ RA101MF80G EMHL350 □ RA221MHA0G EMHL350 □ RA331MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 47 to 680 120 0.93 1k 0.97 10k 1.00 100k 1.00 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
EMHL100ARA471MHA0G 价格&库存
很抱歉,暂时无法提供与“EMHL100ARA471MHA0G”相匹配的价格&库存,您可以联系我们找货
EMHL100ARA471MHA0G
  • 1+15.494751+2.00180
  • 10+10.0923510+1.30386
  • 50+7.8274650+1.01125
  • 100+7.11140100+0.91874
库存:848
EMHL100ARA471MHA0G
  • 500+5.89037500+0.76099
  • 1000+5.501351000+0.71073
  • 1500+5.305011500+0.68537
  • 2500+5.086212500+0.65710
  • 3500+4.957613500+0.64049
  • 5000+4.833425000+0.62444
库存:848
