SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
High heat resistance, 125℃
MHL
Series
・Downsized and Longer life from current MVH series
・Endurance : 2,000 to 4,000 hours at 125℃
・Rated voltage range : 10 to 35V. Nominal capacitance range : 47 to 680µF
・For automobile modules and other high temperature applications
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・Vibration resistant structure
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
MHL
Downsized
Longer life
MVH
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +125℃
10 to 35Vdc
(at 20℃, 120Hz)
±20%(M)
I=0.01CV
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage(Vdc)
10V 16V 25V 35V
tanδ(Max.)
0.24 0.20 0.16 0.14
(at 20℃, 120Hz)
Rated voltage(Vdc)
10V 16V 25V 35V
Z(-25℃)/Z(+20℃)
3
2
2
2
Z(-40℃)/Z(+20℃)
6
4
4
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified time
at 125℃.
F61 & F80 :2,000 hours
Time
HA0 & JA0:4,000 hours
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
Code : A
code : F61 to JA0
● Size
Code : G(Vibration resistant structure)
code : F61 to JA0
Size code
Vent for JA0
Vent for JA0
0.3max.
W
0.3max.
L±0.3 (Note)
L±0.3 (Note)
Note : L±0.5 for HA0 and JA0
A±0.2
2
3
4
5
6
7
8
9
10
11
12
A
φD
L
6.3 5.8 6.6
6.3 7.7 6.6
8 10.0 8.3
10 10.0 10.3
B
6.6
6.6
8.3
10.3
C
7.2
7.2
9.0
11.0
W
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.9
1.9
3.1
4.5
A±0.2
: Dummy terminals
◆PART NUMBERING SYSTEM
1
P
C±0.2
B±0.2
φD±0.5
P
C±0.2
B±0.2
φD±0.5
W
F61
F80
HA0
JA0
13
14
15
16
17
◆MARKING
18
E MH L A A A A R A A A A M A A A G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470,100µF:101)
Taping code
Terminal code (A, G)
Voltage code (ex. 35V:350)
Series code
Category
EX) 35V47µF
2Q
47
V HL
●Rated
voltage symbol
Rated voltage (Vdc) Symbol
A
10
C
16
E
25
V
35
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001X 2023
TM
AIchip
MHLSeries
◆STANDARD RATINGS
WV
(Vdc)
10
16
25
35
Cap
(µF)
Size code
100
220
330
470
680
47
100
220
330
470
680
47
100
220
330
47
100
220
330
F61
F80
HA0
HA0
JA0
F61
F61
F80
HA0
JA0
JA0
F61
F80
HA0
JA0
F61
F80
HA0
JA0
ESR
(Ω max./100kHz)
20℃
-40℃
1.2
0.60
0.30
0.30
0.20
1.2
1.2
0.60
0.30
0.20
0.20
1.2
0.60
0.30
0.20
1.2
0.60
0.30
0.20
22
12
5.5
5.5
3.6
22
22
12
5.5
3.6
3.6
22
12
5.5
3.6
22
12
5.5
3.6
Rated ripple current
(mArms/125℃, 100kHz)
110
220
296
296
440
110
110
220
296
440
440
110
220
296
440
110
220
296
440
Part No.
EMHL100 □ RA101MF61G
EMHL100 □ RA221MF80G
EMHL100 □ RA331MHA0G
EMHL100 □ RA471MHA0G
EMHL100 □ RA681MJA0G
EMHL160 □ RA470MF61G
EMHL160 □ RA101MF61G
EMHL160 □ RA221MF80G
EMHL160 □ RA331MHA0G
EMHL160 □ RA471MJA0G
EMHL160 □ RA681MJA0G
EMHL250 □ RA470MF61G
EMHL250 □ RA101MF80G
EMHL250 □ RA221MHA0G
EMHL250 □ RA331MJA0G
EMHL350 □ RA470MF61G
EMHL350 □ RA101MF80G
EMHL350 □ RA221MHA0G
EMHL350 □ RA331MJA0G
□ : Enter the appropriate terminal code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
47 to 680
120
0.93
1k
0.97
10k
1.00
100k
1.00
The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer
to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note.
Product Guide
■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults
and accidents from occurring.
■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure
prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications.
■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for
use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or
property. In addition, our products are not intended to be used in specific applications that may cause a major social impact.
Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power
generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles,
trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized
information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose
applications.
■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations
and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment
systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You
should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and
determine whether or not our products suit your requirements according to the specifications of your equipment systems.
Therefore, you bear final responsibility regarding the use of our products.
Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention
measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction.
■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We
assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel
or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our
official sales channel.
■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this
catalog will be available in the future.
The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific
products
■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our
published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming
goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be
accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual
non-conforming product, or in other ways deemed necessary.
In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any
potential compensation.
Part Numbering System
Part Numbering System (Appendix)
Standardization
Available Items by Manufacturing Locations
Environmental Measures
Technical Note
Precautions and Guidelines
Recommended Soldering Conditions
Taping, Lead-preforming and Packaging
Available Terminals for Snap-in and Screw Mount Type
很抱歉,暂时无法提供与“EMHL160ARA331MHA0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+15.577301+2.01419
- 10+10.1103510+1.30730
- 50+7.8435550+1.01419
- 100+7.12555100+0.92135
- 国内价格 香港价格
- 500+5.89088500+0.76171
- 1000+5.501971000+0.71142
- 1500+5.305811500+0.68606
- 2500+5.087142500+0.65778
- 3500+4.958613500+0.64116
- 5000+4.834465000+0.62511
