46W-NWR2-CRO
46W-NWR2-CRO
    VCC
    LED-2P_D8.5X24MM_TM
    PMI .250 LED 2V WIRE CLEAR RED
46W-NWR2-CRO 数据手册
40 Series 0.250" (6.35mm) LED Panel Mount Indicator 40 Series with built-in long life LED offer superior construction and longer life Flush or Raised LED indicator with fresnel lens, single, bi-color, or tri-color LED Voltage: 2VDC - 120VAC Key features • Mounting hole size: .250” (6.35mm) • Prominent and flush lens options • Voltage: 2-60 VDC or 120VAC • Terminals: Cartridge, Bi-pin and wire leads (6” wire leads, 24 AWG) • Available with a variety of LEDs including AlInGaP and InGaN technology for high brightness applications, single color, bi-color and with integrated resistors • T-1 3/4 (5mm) LED • Available in six LED single colors: red, amber, green, orange, blue and white with or without lens • Available in one bi-color: red/green with or without lens • Available in two tri-color: red/amber/green or green/amber/red with or without lens • Seven lens colors available: red, amber, yellow, green, blue, water clear and smoke • Offered with a variety of lens options: hi-hat, wide hi-hat, flush, wide flush or hi-dome, all featured with fresnel pattern lens which provides excellent light focus and assures maximum light output • Low power consumption - uses up to 90% less energy than an incandescent indicator • Mounts with spring retainer and washer (included) • Offered with black bezel that enhances the LED contrast • Suitable for high vibration applications • LEDs operate significantly cooler than traditional lamps • Compliant with RoHS and REACH vcclite.com | 1.800.522.5546 40 Series | 03/19 Rev 1 | Page 1 of 5 40 Series .250" MOUNT PANEL LIGHTS vcclite.com | 1.800.522.5546 40 Series | 03/19 Rev 1 | Page 2 of 5 40 Series .250" MOUNT PANEL LIGHTS Hi-Hat Lens Hi-Dome Lens Flush Lens Wide Hi-Hat Lens Wide Flush Lens vcclite.com | 1.800.522.5546 40 Series | 03/19 Rev1 | Page 3 of 5 40 Series .250" MOUNT PANEL LIGHTS vcclite.com | 1.800.522.5546 40 Series | 03/19 Rev1 | Page 4 of 5 40 Series .250" MOUNT PANEL LIGHTS vcclite.com | 1.800.522.5546 40 Series | 03/19 Rev 1 | Page 5 of 5
46W-NWR2-CRO
物料型号: 40 Series LED Panel Mount Indicator,例如型号“41-BCG5H-CGO”。
器件简介: 40系列LED指示灯,具有优越的构造和更长的使用寿命,提供多种LED选项,包括AlInGaP和InGaN技术,适用于高亮度应用。
引脚分配: 提供了不同型号的引脚配置,例如PS40和PS44插座,用于不同型号的LED。
参数特性: 包括电压范围(2VDC - 120VAC)、多种LED颜色选项、不同强度等级、视角、以及与不同电压/电流设计的对应关系。
功能详解: 描述了LED的不同功能特性,如低功耗、适合高振动应用、与传统灯具相比LED运行温度更低等。
应用信息: 适用于多种应用场景,包括需要高亮度指示或特殊颜色的场合。
封装信息: 提供了详细的物理尺寸和安装信息,包括引脚长度、安装夹和垫圈等。
46W-NWR2-CRO 价格&库存
很抱歉,暂时无法提供与“46W-NWR2-CRO”相匹配的价格&库存,您可以联系我们找货
