S-19246E12H-V5T2U
S-19246E12H-V5T2U
    ABLIC(艾普凌科)
    TO-252-5S(A)
    线性稳压器/LDO
S-19246E12H-V5T2U 数据手册
S-19246xxxH Series www.ablic.com © ABLIC Inc., 2020 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 The S-19246xxxH Series developed by using high-withstand voltage CMOS process technology, is a positive voltage regulator with high-accuracy output voltage and high output current. A built-in overcurrent protection circuit to limit overcurrent of the output transistor and a built-in thermal shutdown circuit to limit heat are included. Also, the S-19246xxxH Series includes the soft-start function to adjust the output voltage rising time at power-on or at the time when the ON / OFF pin is set to ON. ABLIC Inc. offers a "thermal simulation service" which supports the thermal design in conditions when our power management ICs are in use by customers. Our thermal simulation service will contribute to reducing the risk in the thermal design at customers' development stage. ABLIC Inc. also offers FIT rate calculated based on actual customer usage conditions in order to support customer functional safety design. Contact our sales representatives for details. Caution This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for these purposes, it is imperative to contact our sales representatives.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Ripple rejection: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in soft-start circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free • AEC-Q100 qualified *2 1.0 V to 6.0 V, selectable in 0.05 V step 2.5 V to 10.0 V ±2.3% (Tj = −40°C to +105°C) 0.62 V typ. (3.0 V output product, at IOUT = 2000 mA) During operation: 120 μA typ., 150 μA max. (Tj = −40°C to +150°C) During power-off: 0.1 μA typ., 4.5 μA max. (Tj = −40°C to +105°C) Possible to output 2000 mA (at VIN ≥ VOUT(S) + 1.0 V)*1 60 dB typ. (at f = 1.0 kHz) Limits overcurrent of output transistor. Detection temperature 170°C typ. Adjusts output voltage rising time at power-on or at the time when ON / OFF pin is set to ON. tSS = 6.0 ms typ. (CSS = 10 nF) Soft-start time can be changed by the capacitor (CSS). Ensures long battery life Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. Ta = −40°C to +105°C *1. Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large. *2. Contact our sales representatives for details.  Applications • Constant-voltage power supply for telecommunication module • Constant-voltage power supply for home electric appliance • For automotive use (car body, headlight, ITS, accessory, car navigation system, car audio system, etc.)  Package • TO-252-5S(A) 1 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00  Block Diagram *1 VOUT VIN Overcurrent protection circuit Thermal shutdown circuit + ON / OFF circuit ON / OFF − *2 *3 Reference voltage circuit Soft-start circuit *1 SSC *1 VSS Product Type E F G H ON / OFF Logic Active "H" Active "H" Active "H" Active "H" Soft-start Time Changeable by capacitor (CSS) Changeable by capacitor (CSS) Changeable by capacitor (CSS) Changeable by capacitor (CSS) Discharge Shunt Function*2 Available Available Unavailable Unavailable Pull-down Resistor*3 Available Unavailable Available Unavailable *1. Parasitic diode *2. E / F type (With discharge shunt function): ON, G / H type (Without discharge shunt function): OFF *3. E / G type (With pull-down resistor): ON, F / H type (Without pull-down resistor): OFF Figure 1 2 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series  AEC-Q100 Qualified This IC supports AEC-Q100 for operation temperature grade 2. Contact our sales representatives for details of AEC-Q100 reliability specification.  Product Name Structure Users can select the product type, output voltage for the S-19246xxxH Series. Refer to"1. Product name" regarding the contents of product name, "2. Function list of product type" regarding the product type, "3. Package" regarding the package drawings and "4. Product name list" for details of product names. 1. Product name S-19246 x xx H - V5T2 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 V5T2: TO-252-5S(A), Tape Operation temperature H: Ta = −40°C to +105°C Set output voltage*2 10 to 60 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type*3 E to H *1. *2. *3. Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales representatives. Refer to "2. Function list of product type". 3 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 2. Function list of product type Table 1 3. Pull-down Resistor ON / OFF Logic E Active "H" Changeable by the capacitor (CSS) Available Available F Active "H" Changeable by the capacitor (CSS) Available Unavailable G Active "H" Changeable by the capacitor (CSS) Unavailable Available H Active "H" Changeable by the capacitor (CSS) Unavailable Unavailable Soft-start Time Package Table 2 Package Name TO-252-5S(A) 4 Discharge Shunt Function Product Type Dimension VA005-A-P-SD Package Drawing Codes Tape VA005-A-C-SD Reel VA005-A-R-SD Land VA005-A-L-SD AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series 4. Product name list 4. 1 S-19246xxxH Series E type ON / OFF logic Pull-down resistor : Active "H" : Available Output Voltage Discharge shunt function : Available Soft-start time : Changeable by CSS Table 3 TO-252-5S(A) 3.3 V ± 2.3% 5.0 V ± 2.3% Remark 4. 2 S-19246E33H-V5T2U S-19246E50H-V5T2U Please contact our sales representatives for products other than the above. S-19246xxxH Series F type ON / OFF logic Pull-down resistor : Active "H" : Unavailable Discharge shunt function : Available Soft-start time : Changeable by CSS Table 4 Output Voltage 3.3 V ± 2.3% 5.0 V ± 2.3% Remark 4. 3 TO-252-5S(A) S-19246F33H-V5T2U S-19246F50H-V5T2U Please contact our sales representatives for products other than the above. S-19246xxxH Series G type ON / OFF logic Pull-down resistor : Active "H" : Available Discharge shunt function : Unavailable Soft-start time : Changeable by CSS Table 5 Output Voltage TO-252-5S(A) 3.3 V ± 2.3% 5.0 V ± 2.3% Remark 4. 4 S-19246G33H-V5T2U S-19246G50H-V5T2U Please contact our sales representatives for products other than the above. S-19246xxxH Series H type ON / OFF logic Pull-down resistor : Active "H" : Unavailable Discharge shunt function : Unavailable Soft-start time : Changeable by CSS Table 6 Output Voltage 3.3 V ± 2.3% 5.0 V ± 2.3% Remark TO-252-5S(A) S-19246H33H-V5T2U S-19246H50H-V5T2U Please contact our sales representatives for products other than the above. 5 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00  Pin Configuration 1. TO-252-5S(A) Table 7 1 Top view Pin No. 3 1 VOUT Output voltage pin 2 ON / OFF ON / OFF pin 3 VSS GND pin 4 SSC*1 Soft-start pin 5 VIN Input voltage pin 2 4 Symbol Description 5 Figure 2 *1. Connect a capacitor between the SSC pin and the VSS pin. The soft-start time at power-on and at the time when the ON / OFF pin is set to ON can be adjusted according to the capacitance. 6 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series  Absolute Maximum Ratings Table 8 (Ta = +25°C unless otherwise specified) Item Symbol Absolute Maximum Rating VSS − 0.3 to VSS + 12 Unit VON / OFF VSS − 0.3 to VIN + 0.3 ≤ VSS + 12 V VSSC V VIN Input voltage V Output voltage VOUT VSS − 0.3 to VIN + 0.3 ≤ VSS + 12 VSS − 0.3 to VIN + 0.3 ≤ VSS + 12 Output current IOUT 2000 mA V Junction temperature Tj −40 to +150 °C Operation ambient temperature Topr −40 to +105 °C Storage temperature Tstg −40 to +150 °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 9 Item Symbol Condition Board A Board B Junction-to-ambient thermal resistance*1 θJA TO-252-5S(A) Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark Min. − − − − − Typ. 86 60 38 31 28 Max. − − − − − Unit °C/W °C/W °C/W °C/W °C/W Refer to " Power Dissipation" and "Test Board" for details. 7 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00  Electrical Characteristics Table 10 (1 / 2) Item Output voltage*1 Output current*2 Symbol VOUT(E) IOUT Dropout voltage*3 Vdrop Line regulation ΔVOUT1 ΔVIN • VOUT Load regulation Current consumption during operation ΔVOUT2 ISS1 Current consumption during power-off ISS2 Input voltage VIN 8 Condition (Tj = −40°C to +150°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VOUT(S) < 1.5 V VOUT(S) V 1 × 0.977 × 1.023 VIN = 2.5 V, IOUT = 100 mA, Tj = −40°C to +105°C VIN = VOUT(S) + 1.0 V, 1.5 V ≤ VOUT(S) IOUT = 100 mA, Tj = −40°C to +105°C 1.0 V ≤ VOUT(S) < 2.0 V VIN ≥ VOUT(S) + 1.8 V VIN ≥ VOUT(S) + 1.4 V 2.0 V ≤ VOUT(S) < 3.0 V VIN ≥ VOUT(S) + 1.0 V 3.0 V ≤ VOUT(S) ≤ 6.0 V 1.0 V ≤ VOUT(S) < 2.0 V IOUT = 300 mA, 2.0 V ≤ VOUT(S) < 2.6 V Ta = +25°C 2.6 V ≤ VOUT(S) ≤ 6.0 V 1.0 V ≤ VOUT(S) < 2.0 V IOUT = 2000 mA, 2.0 V ≤ VOUT(S) < 3.0 V Ta = +25°C 3.0 V ≤ VOUT(S) ≤ 6.0 V 2.5 V ≤ VIN ≤ 10 V, VOUT(S) < 2.0 V IOUT = 100 mA, Ta = +25°C VOUT(S) + 0.5 V ≤ VIN ≤ 10 V, 2.0 V ≤ VOUT(S) IOUT = 100 mA, Ta = +25°C VIN = VOUT(S) + 1.8 V, 1 mA ≤ IOUT ≤ 2000 mA, 1.0 V ≤ VOUT(S) < 2.0 V Ta = +25°C VIN = VOUT(S) + 1.4 V, 1 mA ≤ IOUT ≤ 2000 mA, 2.0 V ≤ VOUT(S) < 3.0 V Ta = +25°C VIN = VOUT(S) + 1.0 V, 1 mA ≤ IOUT ≤ 2000 mA, 3.0 V ≤ VOUT(S) ≤ 6.0 V Ta = +25°C VIN = 2.5 V, VOUT(S) < 1.5 V ON / OFF pin = ON, no load VIN = VOUT(S) + 1.0 V, 1.5 V ≤ VOUT(S) ON / OFF pin = ON, no load VIN = 2.5 V, ON / OFF pin = OFF, no load, VOUT(S) < 1.5 V Tj = −40°C to +105°C VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load, 1.5 V ≤ VOUT(S) Tj = −40°C to +105°C − VOUT(S) VOUT(S) VOUT(S) × 0.977 × 1.023 − − − V 1 mA mA mA V V V V V V 3 3 3 1 1 1 1 1 1 2000*5 2000*5 2000*5 − − − − − − 0.52 0.11 1.10 0.75 0.62 − − − − − − − − − − 0.05 0.2 %/V 1 − 0.05 0.2 %/V 1 − 15 30 mV 1 − 15 30 mV 1 − 15 30 mV 1 − 120 150 μA 2 − 120 150 μA 2 − 0.1 4.5 μA 2 − 0.1 4.5 μA 2 2.5 − 10 V − *4 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series Table 10 (2 / 2) Item ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" ON / OFF pin input current "H" ON / OFF pin input current "L" Ripple rejection Short-circuit current Symbol VSH VSL VIN = 2.5 V, RL = 1 kΩ, determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1 kΩ, determined by VOUT output level VIN = 2.5 V, RL = 1 kΩ, determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1 kΩ, determined by VOUT output level VOUT(S) < 1.5 V 2.1 − − V 4 1.5 V ≤ VOUT(S) 2.1 − − V 4 VOUT(S) < 1.5 V − − 0.6 V 4 1.5 V ≤ VOUT(S) − − 0.6 V 4 −0.1 0.8 − 2.5 0.1 7.8 μA μA 4 4 −0.1 − 0.1 μA 4 1.0 V ≤ VOUT(S) < 1.5 V − 60 − dB 5 1.5 V ≤ VOUT(S) < 2.0 V − 55 − dB 5 2.0 V ≤ VOUT(S) < 2.6 V − 55 − dB 5 2.6 V ≤ VOUT(S) ≤ 6.0 V − 50 − dB 5 1.0 V ≤ VOUT(S) < 2.0 V 330 460 590 mA 3 2.0 V ≤ VOUT(S) < 3.0 V 330 460 590 mA 3 3.0 V ≤ VOUT(S) ≤ 6.0 V 330 460 590 mA 3 Junction temperature − 170 − °C − Junction temperature − 135 − °C − E / F type − 100 − Ω 6 E / G type 1.3 4.0 12 MΩ 4 ISH VIN = 10 V, VON / OFF = 10 V ISL VIN = 10 V, VON / OFF = 0 V |RR| Ishort Thermal shutdown TSD detection temperature Thermal shutdown TSR release temperature Discharge shunt RLOW resistance during power-off ON / OFF pin pull-down resistance Condition RPD (Tj = −40°C to +150°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VIN = 3.0 V, f = 1 kHz, ΔVrip = 0.5 Vrms, IOUT = 100 mA VIN = VOUT(S) + 1.0 V, f = 1 kHz, ΔVrip = 0.5 Vrms, IOUT = 100 mA VIN = VOUT(S) + 1.8 V, ON / OFF pin = ON, VOUT = 0 V, Ta = +25°C VIN = VOUT(S) + 1.4 V, ON / OFF pin = ON, VOUT = 0 V, Ta = +25°C VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V, Ta = +25°C VIN = 10 V, VOUT = 0.1 V − F / H type E / G type *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 100 mA) and inputting 2.5 V or VOUT(S) + 1.0 V. *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V, and IOUT = 300 mA. VOUT3 is the output voltage when VIN complies with output current conditions, and IOUT = 2000 mA. *4. The dropout voltage is limited by the difference between the input voltage (min. value) and the set output voltage. In case of 1.0 V ≤ VOUT(S) < 1.5 V: 2.5 V − VOUT(S) = Vdrop In case of 1.5 V ≤ VOUT(S) < 2.0 V: (VOUT(S) + 1.0 V) − VOUT(S) = 1.0 V *5. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 9 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00  Test Circuits VIN + VOUT SSC ON / OFF V A + VSS Set to ON Figure 3 VIN Test Circuit 1 VOUT SSC ON / OFF VSS Set to VIN or + A GND Figure 4 VIN Test Circuit 2 VOUT SSC ON / OFF + A V + VSS Set to ON Figure 5 VIN + VOUT SSC A ON / OFF Figure 6 10 Test Circuit 3 V VSS Test Circuit 4 + RL AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series VIN VOUT SSC ON / OFF V + RL VSS Set to ON Figure 7 VIN Test Circuit 5 VOUT SSC ON / OFF A + V + VSS Set to GND Figure 8 Test Circuit 6 11 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00  Standard Circuit Input VIN CIN*1 Output VOUT ON / OFF CL SSC CSS *2 *3 VSS Single GND *1. *2. *3. GND CIN is a capacitor for stabilizing the input. CL is a capacitor for stabilizing the output. CSS is a capacitor for soft-start. Figure 9 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation including the temperature characteristics with an actual application to set the constants. 12 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series  Condition of Application Input capacitor (CIN): Output capacitor (CL): A ceramic capacitor with capacitance of 2.2 μF or more is recommended. A ceramic capacitor with capacitance of 2.2 μF or more is recommended. Caution Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. Perform thorough evaluation including the temperature characteristics with an actual application using the above capacitors to confirm no oscillation occurs.  Selection of Input Capacitor (CIN) and Output Capacitor (CL) The S-19246xxxH Series requires CL between the VOUT pin and the VSS pin for phase compensation. The operation is stabilized by a ceramic capacitor with capacitance of 2.2 μF or more. When using an OS capacitor, a tantalum capacitor or an aluminum electrolytic capacitor, the capacitance also must be 2.2 μF or more. However, an oscillation may occur depending on the equivalent series resistance (ESR). Moreover, the S-19246xxxH Series requires CIN between the VIN pin and the VSS pin for a stable operation. Generally, an oscillaiton may occur when a voltage regulator is used under the conditon that the impedance of the power supply is high. Note that the output voltage transient characteristics varies depending on the capacitance of CIN and CL and the value of ESR. Caution Perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL.  Selection of Capacitor for Soft-start (CSS) The S-19246xxxH Series requires the capacitor for soft-start (CSS) between the SSC pin and the VSS pin. Over the entire temperature range, the S-19246xxxH Series operates stably with a ceramic capacitor of 0.68 nF or more. According to CSS capacitance, the rising speed of the output voltage is adjustable. The time that the output voltage rises to 99% is 6.0 ms typ. at CSS = 10 nF. The recommended value for applications is 0.68 nF ≤ CSS ≤ 168 nF, however; define the values by sufficient evaluation including the temperature characteristics under the usage condition. 13 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00  Explanation of Terms 1. Low dropout voltage regulator This is a voltage regulator which made dropout voltage small by its built-in low on-resistance output transistor. 2. Output voltage (VOUT) This voltage is output at an accuracy of ±2.3% when the input voltage, the output current and the temperature are in a certain condition*1. *1. Differs depending on the product. Caution 3. If the certain condition is not satisfied, the output voltage may exceed the accuracy range of ±2.3%. Refer to " Electrical Characteristics" and " Characteristics (Typical Data)" for details. ΔVOUT1  ΔVIN • VOUT  Line regulation  Indicates the dependency of the output voltage against the input voltage. That is, the value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage against the output current. That is, the value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when the output voltage becomes 98% of the output voltage value (VOUT3) at VIN = VOUT(S) + 1.0 V, and IOUT = 300 mA after the input voltage (VIN) is decreased gradually. Vdrop = VIN1 − (VOUT3 × 0.98) 14 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series  Operation 1. Basic operation Figure 10 shows the block diagram of the S-19246xxxH Series to describe the basic operation. The error amplifier compares the feedback voltage (Vfb) whose output voltage (VOUT) is divided by the feedback resistors (Rs and Rf) with the reference voltage (Vref). The error amplifier controls the output transistor, consequently, the regulator starts the operation that keeps VOUT constant without the influence of the input voltage (VIN). VIN *1 Current supply VOUT Error amplifier Vref − + Rf Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 10 2. Output transistor In the S-19246xxxH Series, a low on-resistance P-channel MOS FET is used between the VIN pin and the VOUT pin as the output transistor. In order to keep VOUT constant, the on-resistance of the output transistor varies appropriately according to the output current (IOUT). Caution Since a parasitic diode exists between the VIN pin and the VOUT pin due to the structure of the transistor, the IC may be damaged by a reverse current if VOUT becomes higher than VIN. Therefore, be sure that VOUT does not exceed VIN + 0.3 V. 15 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 3. ON / OFF pin The ON / OFF pin controls the internal circuit and the output transistor in order to start and stop the regulator. When the ON / OFF pin is set to OFF, the internal circuit stops operating and the output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Note that the current consumption increases when a voltage of 0.6 V to VIN − 0.3 V is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figure 11 and Figure 12. 3. 1 S-19246xxxH Series E / G type Since the ON / OFF pin is internally pulled down to the VSS pin in the floating status, the VOUT pin is set to the VSS level. Refer to " Electrical Characteristics" for the ON / OFF pin current. 3. 2 S-19246xxxH Series F / H type Since the ON / OFF pin is neither pulled down nor pulled up, do not use these types in the floating status. When not using the ON / OFF pin, connect it to the VIN pin. Table 11 Product Type E/F/G/H E/F/G/H ON / OFF Pin "H" : ON "L" : OFF Internal Circuit Operate Stop VOUT Pin Voltage Constant value*1 Pulled down to VSS*3 Current Consumption ISS1*2 ISS2 *1. The constant value is output due to the regulating based on the set output voltage value. *2. Note that the IC's current consumption increases as much as current flows into the pull-down resistor when the ON / OFF pin is connected to the VIN pin and the S-19246xxxH Series E / G type is operating (refer to Figure 11). *3. The VOUT pin voltage of the S-19246xxxH Series E / F type is pulled down to VSS due to combined resistance (RLOW = 100 Ω typ.) of the discharge shunt circuit and the feedback resistors, and a load. VIN VIN ON / OFF ON / OFF VSS Figure 11 16 S-19246xxxH Series E / G type VSS Figure 12 S-19246xxxH Series F / H type AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series 4. Discharge shunt function (S-19246xxxH Series E / F type) The S-19246xxxH Series E / F type has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. Since the S-19246xxxH Series G / H type does not have a discharge shunt circuit, the VOUT pin is set to the VSS level through several hundred kΩ internal divided resistors between the VOUT pin and the VSS pin. The S-19246xxxH Series E / F type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt circuit. S-19246xxxH Series Output transistor: OFF *1 VOUT VIN Discharge shunt circuit : ON ON / OFF *1 ON / OFF circuit Output capacitor (CL) ON / OFF pin: OFF Current flow GND VSS *1. Parasitic diode Figure 13 5. Pull-down resistor (S-19246xxxH Series E / G type) The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC's current consumption increases as much as current flows into the pull-down resistor of 4.0 MΩ typ. when the ON / OFF pin is connected to the VIN pin. 17 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 6. Overcurrent protection circuit The S-19246xxxH Series has a built-in overcurrent protection circuit to limit the overcurrent of the output transistor. When the VOUT pin is shorted to the VSS pin, that is, at the time of the output short-circuit, the output current is limited to 460 mA typ. due to the overcurrent protection circuit operation. The S-19246xxxH Series restarts regulating when the output transistor is released from the overcurrent status. Caution 7. This overcurrent protection circuit does not work as for thermal protection. For example, when the output transistor keeps the overcurrent status long at the time of output short-circuit or due to other reasons, pay attention to the conditions of the input voltage and the load current so as not to exceed the power dissipation. Thermal shutdown circuit The S-19246xxxH Series has a built-in thermal shutdown circuit to limit overheating. When the junction temperature increases to 170°C typ., the thermal shutdown circuit becomes the detection status, and the regulating is stopped. When the junction temperature decreases to 135°C typ., the thermal shutdown circuit becomes the release status, and the regulator is restarted. If the thermal shutdown circuit becomes the detection status due to self-heating, the regulating is stopped and VOUT decreases. For this reason, the self-heating is limited and the temperature of the IC decreases. The thermal shutdown circuit becomes release status when the temperature of the IC decreases, and the regulating is restarted after the soft-start operation is finished, thus the self-heating is generated again. Repeating this procedure makes the waveform of VOUT into a pulse-like form. This phenomenon continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Note that the product may suffer physical damage such as deterioration if the above phenomenon occurs continuously. Caution When the heat radiation of the application is not in a good condition, the self-heating cannot be limited immediately, and the IC may suffer physical damage. Perform thorough evaluation with an actual application to confirm no problems happen. Table 12 Thermal Shutdown Circuit Release: 135°C typ.*1 Detection: 170°C typ.*1 *1. *2. *3. 18 VOUT Pin Voltage Constant value*2 Pulled down to VSS*3 Junction temperature The constant value is output due to the regulating based on the set output voltage value. The VOUT pin voltage is pulled down to VSS due to the feedback resistors (Rs and Rf) and a load. AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series 8. Soft-start function The S-19246xxxH Series has the built-in soft-start circuit to suppress the inrush current and overshoot of the output voltage generated at power-on or at the time when the ON / OFF pin is set to ON. The soft-start time (tSS) is the time period from when the output voltage rises slowly immediately after power-on or when the ON / OFF pin is set to ON until when the output voltage rises to 99%. Input voltage (VIN, VON / OFF) VIN SSC pin voltage (VSSC) VOUT(E) × 0.99 Output voltage (VOUT(E)) Soft-start time (tSS) t [ms] Figure 14 tSS can be adjusted by the external capacitor (CSS) connected between the SSC pin and the VSS pin, and is calculated by using the following calculation. tSS [ms] = Soft-start coefficient*1 [ms / nF] × CSS [nF] + tD0*2 [ms] *1. It is determined by charging the built-in constant current (approx. 2.1 μA) to CSS. *2. The delay time of internal capacitance. When the CSS value is sufficiently large, the tD0 value can be disregarded. When the ON / OFF pin is set to OFF, the electrical charge charged in CSS is discharged by the transistor of the discharge shunt circuit. Table 13 Operation Temperature Min. Typ. Max. Tj = +150°C 0.391 0.528 0.691 Tj = +105°C 0.398 0.539 0.690 Tj = +25°C 0.436 0.574 0.704 Tj = −40°C 0.467 0.604 0.717 Table 14 Delay Time of Internal Capacitnace (tD0) Operation Temperature Tj = −40°C to +150°C Caution Soft-start Coefficient [ms / nF] Min. Typ. Max. 0.032 ms 0.047 ms 0.108 ms The above calculation will not guarantee successful operation. Perform thorough evaluation using the actual application including the temperature characteristics under the actual usage conditions to determine CSS capacitance. Refer to " Condition of Application" and " Characteristics (Typical Data)" for details. 19 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00  Precautions • Generally, when a voltage regulator is used under the condition that the load current value is small (1 mA or less), the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the temperature is high, the output voltage may increase due to the leakage current of an output transistor. • Generally, when the ON / OFF pin is used under the condition of OFF, the output voltage may increase due to the leakage current of an output transistor. • Generally, when a voltage regulator is used under the condition that the impedance of the power supply is high, an oscillation may occur. Perform thorough evaluation including the temperature characteristics with an actual application to select CIN. • Generally, in a voltage regulator, an oscillation may occur depending on the selection of the external parts. The following use conditions are recommended in the S-19246xxxH Series; however, perform thorough evaluation including the temperature characteristics with an actual application to select CIN and CL. Input capacitor (CIN): A ceramic capacitor with capacitance of 2.2 μF or more is recommended. Output capacitor (CL): A ceramic capacitor with capacitance of 2.2 μF or more is recommended. • Generally, in a voltage regulator, the values of an overshoot and an undershoot depending on the variation factors of input voltage start-up, input voltage fluctuation, capacitance of CIN or CL and the value of the equivalent series resistance (ESR), which stable operation. Perform thorough evaluation including the temperature characteristics select CIN and CL. in the output voltage vary load fluctuation etc., or the may cause a problem to the with an actual application to • Generally, in a voltage regulator, an overshoot may occur in the output voltage momentarily if the input voltage steeply changes when the input voltage is started up, the soft-start operation is performed, the input voltage fluctuates, etc. Perform thorough evaluation including the temperature characteristics with an actual application to confirm no problems happen. • Generally, in a voltage regulator, if the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur in the VOUT pin due to resonance phenomenon of the inductance and the capacitance including CL on the application. The resonance phenomenon is expected to be weakened by inserting a series resistor into the resonance path, and the negative voltage is expected to be limited by inserting a protection diode between the VOUT pin and the VSS pin. • If the input voltage is started up steeply under the condition that the capacitance of CL is large, the thermal shutdown circuit may be in the detection status by self-heating due to the charge current to CL. • Make sure of the conditions for the input voltage, output voltage and the load current so that the internal loss does not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • When considering the output current value that the IC is able to output, make sure of the output current value specified in Table 10 in " Electrical Characteristics" and footnote *5 of the table. • Wiring patterns on the application related to the VIN pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. When mounting CIN between the VIN pin and the VSS pin and CL between the VOUT pin and the VSS pin, connect the capacitors as close as possible to the respective destination pins of the IC. • In the package equipped with heat sink of backside, mount the heat sink firmly. Since the heat radiation differs according to the condition of the application, perform thorough evaluation with an actual application to confirm no problems happen. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 20 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series  Characteristics (Typical Data) Output voltage vs. Output current (When load current increases) (Ta = +25°C) VOUT = 1.0 V VOUT [V] 1. 1 1. 2 3.6 1.0 3.0 0.8 VIN = 2.5 V 0.6 0.4 0.2 0.0 1. 3 VOUT = 3.0 V 1.2 VOUT [V] 1. VIN = 4.0 V 2.4 1.8 1.2 0.6 0.0 0 500 1000 1500 IOUT [mA] 2000 2500 0 500 1000 1500 IOUT [mA] 2000 2500 VOUT = 6.0 V 7.2 VOUT [V] 6.0 VIN = 7.0 V 4.8 3.6 2.4 1.2 0.0 Remark 0 500 1000 1500 2000 2500 IOUT [mA] In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 of Table 10 in " Electrical Characteristics" 2. Power dissipation Output voltage vs. Input voltage (Ta = +25°C) VOUT [V] 2. 1 VOUT = 1.0 V 2. 2 3.1 1.0 3.0 0.9 2.9 0.8 IOUT = 1 mA IOUT = 50 mA IOUT = 100 mA 0.7 0.6 0.5 2. 3 VOUT = 3.0 V 1.1 VOUT [V] 2. 0 1 2 3 4 5 6 VIN [V] IOUT = 1 mA IOUT = 50 mA IOUT = 100 mA 2.8 2.7 2.6 7 8 9 10 2.5 2 3 4 5 6 7 VIN [V] 8 9 10 VOUT = 6.0 V 6.1 VOUT [V] 6.0 5.9 5.8 5.7 IOUT = 1 mA IOUT = 50 mA IOUT = 100 mA 5.6 5.5 VIN [V] 21 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 3. Dropout voltage vs. Output current 3. 1 VOUT = 3.0 V 3. 2 1.00 1.00 Ta = +105°C Ta= +85°C 0.60 Ta = +25°C 0.40 0.20 Ta = +25°C 0.40 Ta = −40°C 0.00 0 500 1000 1500 IOUT [mA] 2000 2500 0 500 1000 1500 IOUT [mA] 2000 2500 Dropout voltage vs. Temperature 4. 1 VOUT = 3.0 V 4. 2 1.0 IOUT = 2000 mA Vdrop [V] Vdrop [V] 0.8 0.6 IOUT = 1000 mA 0.4 IOUT = 300 mA 0.2 IOUT = 2000 mA 0.6 0.4 IOUT = 1000 mA IOUT = 300 mA 0.2 0.0 0.0 −40 −25 0 25 50 Ta [°C] 75 105 Dropout voltage vs. Set output voltage (Ta = +25°C) 0.8 0.6 Vdrop [V] VOUT = 6.0 V 1.0 0.8 IOUT = 1000 mA 0.4 IOUT = 2000 mA IOUT = 300 mA 0.2 IOUT = 100 mA 0.0 2.5 22 Ta= +85°C 0.60 0.20 Ta = −40°C 0.00 5. Ta = +105°C 0.80 Vdrop [V] Vdrop [V] 0.80 4. VOUT = 6.0 V 3.0 3.5 4.0 4.5 VOUT [V] 5.0 5.5 6.0 −40 −25 0 25 50 Ta [°C] 75 105 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series 6. Output voltage vs. Junction temperature 6. 1 VOUT = 1.0 V 6. 2 VOUT = 3.0 V VIN = 2.5 V VIN = 4.0 V 3.30 3.20 1.05 VOUT [V] VOUT [V] 1.10 1.00 0.95 3.10 3.00 2.90 2.80 0.90 −40 −25 0 25 2.70 −40 −25 50 75 100 125 150 Tj [°C] 0 25 50 75 100 125 150 Tj [°C] VOUT = 6.0 V 6. 3 VIN = 7.0 V VOUT [V] 6.60 6.30 6.00 5.70 5.40 −40 −25 25 50 75 100 125 150 Tj [°C] Current consumption during operation vs. Input voltage (When ON / OFF pin is ON, no load) ISS1 [μA] 7. 1 VOUT = 1.0 V 7. 2 160 120 120 Tj = −40°C Tj = +25°C 80 40 0 7. 3 VOUT = 3.0 V 160 ISS1 [μA] 7. 0 1 2 3 4 5 6 VIN [V] Tj = +25°C 40 Tj = +150°C 0 Tj = −40°C 80 7 8 9 10 8 9 10 0 Tj = +150°C 0 1 2 3 4 5 6 VIN [V] 7 8 9 10 VOUT = 6.0 V 160 Tj = +150°C ISS1 [μA] 120 80 Tj = +25°C 40 0 Tj = −40°C 0 1 2 3 4 5 6 VIN [V] 7 23 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 8. Current consumption during operation vs. Junction temperature 8. 1 VOUT = 1.0 V 8. 2 VOUT = 3.0 V VIN = 4.0 V 160 160 120 120 ISS1 [μA] ISS1 [μA] VIN = 2.5 V 80 40 80 40 0 −40 −25 0 25 0 −40 −25 50 75 100 125 150 Tj [°C] 0 25 50 75 100 125 150 Tj [°C] VOUT = 6.0 V 8. 3 VIN = 7.0 V 160 ISS1 [μA] 120 80 40 0 −40 −25 9. 9. 1 0 25 50 75 100 125 150 Tj [°C] Ripple rejection (Ta = +25°C) 9. 2 VOUT = 1.0 V VIN = 3.0 V, CL = 2.2 μF 100 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 60 40 40 20 20 0 10 100 1k 10k Frequency [Hz] 100k 1M VOUT = 6.0 V VIN = 7.0 V, CL = 2.2 μF 100 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 80 60 40 20 0 10 24 VIN = 4.0 V, CL = 2.2 μF 100 80 0 9. 3 VOUT = 3.0 V 100 1k 10k Frequency [Hz] 100k 1M 10 100 1k 10k Frequency [Hz] 100k 1M AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series  Reference Data Characteristics of input transient response (Ta = +25°C) 1. 1 VOUT = 1.0 V 1. 2 IOUT = 100 mA, CL = 2.2 μF, VIN = 2.5 V ↔ 3.5 V, tr = tf = 5.0 μs 1.15 4.0 3.15 2.0 VIN 0.0 1.05 1.00 IOUT = 100 mA, CL = 2.2 μF, VIN = 4.0 V ↔ 5.0 V, tr = tf = 5.0 μs 6.0 3.20 VIN [V] VOUT [V] VOUT [V] 1.10 −2.0 VOUT −4.0 0.95 − t [μs] 1. 3 VOUT = 3.0 V 3.10 4.0 VIN 2.0 3.05 3.00 0.0 −2.0 VOUT 2.95 −4.0 2.90 − −6.0 VIN [V] 1. t [μs] VOUT = 6.0 V IOUT = 100 mA, CL = 2.2 μF, VIN = 7.0 V ↔ 8.0 V, tr = tf = 5.0 μs 6.40 9.0 6.20 8.0 7.0 VIN 6.0 6.10 6.00 VIN [V] VOUT [V] 6.30 5.0 VOUT 4.0 5.90 t [μs] 25 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 Characteristics of load transient response (Ta = +25°C) VOUT = 1.0 V VIN = 2.5 V, CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA 1.20 150 1.05 1.00 100 1.30 50 1.20 0 VOUT −50 1.10 1.00 400 0.95 −100 0.90 −400 −150 0.80 −600 t [μs] VOUT = 3.0 V VIN = 4.0 V, CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA 3.20 150 3.10 3.05 3.00 IOUT VIN = 4.0 V, CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA 3.40 600 100 3.30 50 3.20 IOUT [mA] VOUT [V] 3.15 VOUT [V] −200 0.90 2. 2 0 VOUT −50 3.10 3.00 400 200 IOUT 0 VOUT −200 2.95 −100 2.90 −400 2.90 −150 2.80 −600 t [μs] 2. 3 t [μs] VOUT = 6.0 V VIN = 7.0 V, CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA 6.20 150 6.05 100 6.50 50 6.30 0 VOUT VOUT [V] 6.10 IOUT VIN = 7.0 V, CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA 6.70 600 IOUT [mA] 6.15 VOUT [V] 0 VOUT t [μs] 6.10 400 200 IOUT VOUT 0 6.00 −50 5.95 −100 5.70 −400 5.90 −150 5.50 −600 t [μs] 26 200 IOUT IOUT [mA] VOUT [V] 1.10 IOUT IOUT [mA] VOUT [V] 1.15 VIN = 2.5 V, CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA 1.40 600 IOUT [mA] 2. 1 −200 5.90 t [μs] IOUT [mA] 2. AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series 3. Load transient response characteristics dependent on capacitance (Ta = +25°C) 3. 1 IOUT = 1.0 mA → 1500 mA VOUT = 3.0 V, VIN = 4.0 V, CIN = 2.2 μF 600 400 200 0 0 40 60 CL [μF] 80 3. 4 VOUT = 3.0 V, VIN = 4.0 V, CIN = 2.2 μF 600 400 200 0 0 20 40 60 CL [μF] 80 100 400 200 0 20 40 60 CL [μF] 80 100 IOUT = 2000 mA → 1.0 mA VOUT = 3.0 V, VIN = 4.0 V, CIN = 2.2 μF 1000 Overshoot [mV] 800 VOUT = 3.0 V, VIN = 4.0 V, CIN = 2.2 μF 600 0 100 IOUT = 1.0 mA → 2000 mA 1000 Undershoot [mV] 20 IOUT = 1500 mA → 1.0 mA 800 Overshoot [mV] Undershoot [mV] 800 3. 3 3. 2 800 600 400 200 0 0 20 40 60 CL [μF] 80 100 27 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 Transient response characteristics of ON / OFF pin (Ta = +25°C) VOUT [V] 4. 1 VOUT = 1.0 V VIN = 2.5 V, CIN = CL = 2.2 μF, CSS = 0.68 nF, IOUT = 2000 mA 5.00 3.0 4.00 2.0 8.00 4.0 3.00 1.0 6.00 2.0 2.00 1.00 0.0 VON / OFF −1.0 0.00 −2.0 VOUT −1.00 −200 0 200 400 600 VOUT = 3.0 V VIN = 4.0 V, CIN = CL = 2.2 μF, CSS = 0.68 nF, IOUT = 2000 mA 10.00 4. 2 800 −3.0 VOUT [V] 4. 4.00 2.00 0.0 VON / OFF −2.0 0.00 VOUT −2.00 −400 0 −4.0 400 t [μs] VOUT [V] 4. 3 12.0 16.00 8.0 12.00 4.0 8.00 4.00 0.00 0.0 VON / OFF −4.0 −8.0 VOUT −4.00 −400 0 400 800 1200 1600 −12.0 t [μs] 5. Soft-start time vs. Characteristics of operation ambient temperature VIN = 2.5 V, VON / OFF = 0 V → 2.5 V (VOUT(S) < 1.5 V), VIN = VOUT + 1.0 V, VON / OFF = 0 V → VOUT + 1.0 V (1.5 V ≤ VOUT(S)), CIN = CL = 2.2 μF, CSS = 10 nF 10.0 tSS [ms] 8.0 VOUT = 1.0 V 6.0 4.0 2.0 0.0 −40 −25 6. VOUT = 6.0 V VOUT = 3.0 V 0 25 50 75 100 125 150 Ta [°C] Soft-start time vs. Characteristics of soft-start capacitance (Ta = +25°C) VIN = 2.5 V, VON / OFF = 0 V → 2.5 V (VOUT(S) < 1.5 V), VIN = VOUT + 1.0 V, VON / OFF = 0 V → VOUT + 1.0 V (1.5 V ≤ VOUT(S)), CIN = CL = 2.2 μF 100.0 10.0 VOUT = 1.0 V VOUT = 3.0 V 1.0 VOUT = 6.0 V 0.1 0.1 28 1.0 800 t [μs] VOUT = 6.0 V VIN = 7.0 V, CIN = CL = 2.2 μF, CSS = 0.68 nF, IOUT = 2000 mA 20.00 10.0 CSS [nF] 100.0 1000.0 6.0 1200 1600 −6.0 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series 7. 7. 1 Inrush current characteristics (Ta = +25°C) VOUT = 1.0 V VIN = 2.5 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 1 nF 7. 2 VON / OFF VON / OFF VOUT VOUT IIN IIN VOUT = 3.0 V VIN = 4.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 1 nF 7. 3 VIN = 2.5 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 10 nF VIN = 4.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 10 nF VON / OFF VON / OFF VOUT VOUT IIN IIN VOUT = 6.0 V VIN = 7.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 1 nF VIN = 7.0 V, IOUT = 100 mA, CL = 2.2 μF, CSS = 10 nF VOUT VOUT IIN IIN 29 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION S-19246xxxH Series Rev.1.0_00 8. Output capacitance vs. Characteristics of discharge time (Ta = +25°C) VIN = 2.5 V, VON / OFF = 2.5 V → VSS (VOUT(S) < 1.5 V), VIN = VOUT + 1.0 V, VON / OFF = VOUT + 1.0 V → VSS (1.5 V ≤ VOUT(S)), IOUT = 1 mA, tf = 1 μs 30 25 VOUT(S) = 1.0 V tDSC [ms] 20 VSS 15 VOUT(S) = 3.0 V 10 tDSC VOUT VOUT(S) = 6.0 V 5 0 1 μs VON / OFF 0 20 40 60 80 CL [μF] 100 120 VOUT × 10% VIN = 2.5 V, VON / OFF = 2.5 V → VSS (VOUT(S) < 1.5 V), VIN = VOUT + 1.0 V, VON / OFF = VOUT + 1.0 V → VSS (1.5 V ≤ VOUT(S)) Figure 15 S-19246xxxH Series E / F type (with discharge shunt function) 9. Figure 16 Measurement Condition of Discharge Time Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 2.2 μF 100 VIN RESR [Ω ] VOUT CIN Stable ON / OFF 0 1.0 S-19246xxxH Series SSC VSS 2000 CSS CL*1 RESR IOUT [mA] *1. Figure 17 30 CL: TDK Corporation CGA6M2X8R1E225K (2.2 μF) Figure 18 AUTOMOTIVE, 105°C OPERATION, 10 V INPUT, 2000 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.0_00 S-19246xxxH Series  Power Dissipation TO-252-5S(A) Tj = +150°C max. Power dissipation (PD) [W] 5 E 4 D 3 C 2 B 1 A 0 0 25 50 75 100 125 150 175 Ambient temperature (Ta) [°C] Board Power Dissipation (PD) A 1.45 W B 2.08 W C 3.29 W D 4.03 W E 4.46 W 31 TO-252-5S Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. TO252-5S-A-Board-SD-1.0 enlarged view ABLIC Inc. TO-252-5S Test Board (4) Board D IC Mount Area Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Thermal via 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Copper foil layer [mm] 1 2 3 4 (5) Board E Copper foil layer [mm] Thermal via 1 2 3 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. TO252-5S-A-Board-SD-1.0 ABLIC Inc. 6.5±0.2 5.8 1.2±0.1 (5.2) 0.80 0.6±0.1 0.22±0.05 1.27 No. VA005-A-P-SD-2.0 TITLE TO-252-5S-A-PKG Dimensions VA005-A-P-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 +0.1 ø1.5 -0.0 0.2±0.05 ø1.7±0.1 8.0±0.1 1.5±0.1 6.9±0.1 5 1 Feed direction No. VA005-A-C-SD-1.0 TITLE TO-252-5S-A-C a r r i e r T a p e No. VA005-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 60° 13.4±1.0 Enlarged drawing in the central part ø21±0.8 17.4±1.0 2±0.5 ø13±0.2 No. VA005-A-R-SD-1.0 TO-252-5S-A-Reel TITLE VA005-A-R-SD-1.0 No. ANGLE UNIT QTY. mm ABLIC Inc. 4,000 6.0 0.8 2.54 1.27 No. VA005-A-L-SD-1.0 TITLE TO-252-5S-A -Land Recommendation No. VA005-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-19246E12H-V5T2U 价格&库存
很抱歉,暂时无法提供与“S-19246E12H-V5T2U”相匹配的价格&库存,您可以联系我们找货
