BK13C06-32DS/2-0.35V(895)
    HRS(广濑)
    SMD,P=0.35mm
    板对板连接器 立贴 针脚数:32Pin 间距:0.35mm 排数:2
BK13C06-32DS/2-0.35V(895) 数据手册
BK13 Series Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Product Page https://www.hirose.com/en/product/series/BK13C/ Aug. 2023 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Features 1. Hybrid ‌ Power Supply Capacity and Space-saving Design Conventional Product (P=0.35mm) Signal 64pos. Equipped with two power contacts capable of handling up to 5A, reducing the number of signal contacts to save mounting space. 13.7mm BK13 Signal 32pos.+ Power 2pos. Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 43% Reduced 5.85mm Reduced 5A Power Contact 7.85mm 5A Power Contact Power lines typically diverted to multiple signal contacts are concentrated into 2 power contacts (Up to 5A/line) High Current (5A) 2. Robust Design Fully armored guides prevent housing damage due to misalignment when mating. Only Partially Covered with Metal No metal Exposed Housing Housing Covered by Metal Fully Armored Design 3. Enhanced PCB Peeling Strength Back Side of the Receptacle Both the geader and receptacle have 3 soldering areas at each power contact for greater PCB peeling strength. A' < A' > A Back Side of the Header B 2 B' 3 Solder Areas on Each Power Contact < B' > BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A 4. High Contact Reliability Both power and signal contacts have a two-point contact design, ensuring high contact reliability. 5. Superior Mating Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Wide self-alignment range with metal guides offers enhanced mating operation. (0.3mm in pitch direction, 0.22mm in width direction) Additionally, a clear tactile click generated by the unique locking contact design secures complete mating. 6. Halogen-Free All materials and substances used to produce this product Comply with Halogen-free standards. *As defined by IEC 61249-2-21 Br : 900ppm max., Cl : 900ppm max., Br+Cl : 1,500ppm max. 3 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Product Specifications Signal Contact : 0.3A (Note 1) Rated Current 30V AC/DC Items Storage Temperature (Note 3) -10 to +60℃ 20 to 80% Storage Humidity Range (Note 3)(Note 4) Specifications Contact Resistance Insulation Resistance Withstanding Voltage Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. -55 to +85℃ Operating Humidity Range (Note 4) Power Contact : 5A Rated Voltage Operating Temperature (Note 2) Mating Durability Vibration Resistance Conditions Signal Contact : 90mΩ Max. Power Contact : 30mΩ Max. Measured at 20mV AC, 1kHz, 1mA No flashover or insulation breakdown 100V AC for 1 min. 50MΩ Min. Measured at 100V DC Contact Resistance : Signal ‌ Contact : 90mΩ Max. Power Contact : 30mΩ Max.  No damage, crack or looseness of parts 10 mating cycles No electrical discontinuity of 1µs or more No damage, crack or looseness of parts Frequency: 10 to 55Hz, single amplitude 0.75mm, 10 cycles in each of 3 axis directions for 5 minutes/cycle Contact Resistance : Signal ‌ Contact : 90mΩ Max. Power Contact : 30mΩ Max. Insulation Resistance : 50MΩ Min. No damage, crack or looseness of parts 96 hours at temperature of 40±2℃ and humidity range from 90 to 95% No electrical discontinuity of 1µs or more No damage, crack or looseness of parts Shock Resistance Humidity Resistance Temperature Cycle Acceleration : 490m/s2, duration of pulse: 11ms at 3 times for 3 directions.   Contact Resistance : Signal ‌ Contact : 90mΩ Max. Power Contact : 30mΩ Max. Insulation Resistance : 50MΩ Min. No damage, crack or looseness of parts -55℃ for 30min. → +85℃ for 30 min. for 5 Cycles. (Stabilizing Time In Chamber : Within 2 to 3 min.) Contact Resistance : Signal ‌ Contact : 90mΩ Max. Power Contact: 30mΩ Max. No damage, crack or looseness of parts Sulphur Dioxide 40 to 70% Exposed in 25 PPM for 96h at 25℃, 75±5%RH. (Test standard : JIS C 60068) (Note 1) The total current capacity for the signal contacts is 12A Max. (Note 2) Includes temperature rise caused by current flow. (Note 3) ‌The term “storage” refers to long-term-storage of unused items before they are mounted on the PCB. Operating temperature / humidity range applies to the product in a temporary storage state such as non-powered after mounting on the PCB during transportation, etc. (Note 4) Range identified without condensation. Materials / Finish Part Header Receptacle Component Material Insulator LCP Power Contact Copper Alloy Signal Contact Black Copper Alloy Finish Gold Plated over Nickel Underplating Gold Plated over Nickel Underplating UL Standard UL94V-0 - Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Header/Receptacle BK13C 06 - 32 DP / 2 - 0.35 V (800) 1 1 Series Name 2 Stacking Height 2 3 Number of Signal Contacts 4 Connector Type 3 BK13 4 5 0.6mm 6, 10, 12, 16, 24, 32, 40, 50, 60pos. DP : Double-row Header DS : Double-row Receptacle 6 7 8 5 Number of Power Contacts 2pos. 7 Terminal Type V : Straight SMT 6 Contact Pitch 8 Packaging 4 0.35mm (800) : Standard, ‌ Embossed tape packaging (20,000pcs per reel) (895) : ‌Embossed tape packaging (1,000pcs per reel) (For trial production) BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Header Part No. HRS No. BK13C06-40DP/2-0.35V(800) BK13C06-50DP/2-0.35V(800) BK13C06-60DP/2-0.35V(800) Part No. CL0673-0142-0-00 CL0480-0663-0-00 CL0480-0665-0-00 CL0480-0725-0-00 BK13C06-40DP/2-0.35V(895) BK13C06-50DP/2-0.35V(895) BK13C06-60DP/2-0.35V(895) 6 0.70 1.60 1.665 12 2 3.40 1.75 1.80 2.175 2 24 2 32 2 40 2 4.10 5.50 6.90 8.30 1.40 2.45 3.85 5.25 6.65 10.05 11.80 10.15 Signal Contact Power Contact A CL0480-0719-0-95 10 2 2 CL0480-0721-0-95 16 2 CL0480-0727-0-00 HRS No. CL0673-0144-0-00 CL0480-0663-0-95 CL0480-0665-0-95 CL0480-0725-0-95 CL0480-0727-0-95 50 3.05 2 CL0480-0895-0-95 BK13C06-32DP/2-0.35V(895) 2.35 16 BK13C06-12DP/2-0.35V(895) BK13C06-24DP/2-0.35V(895) 2 CL0480-0721-0-00 CL0480-0798-0-95 BK13C06-16DP/2-0.35V(895) D 2 BK13C06-6DP/2-0.35V(895) (Note 1) BK13C06-10DP/2-0.35V(895) C 10 CL0480-0895-0-00 BK13C06-32DP/2-0.35V(800) B CL0480-0719-0-00 BK13C06-12DP/2-0.35V(800) BK13C06-24DP/2-0.35V(800) A Power Contact CL0480-0798-0-00 BK13C06-16DP/2-0.35V(800) No. of Pos. Signal Contact BK13C06-6DP/2-0.35V(800) (Note 1) BK13C06-10DP/2-0.35V(800) Unit : mm 60 2 No. of Pos. 6 12 24 32 40 50 60 2 2 2 2 2 2 (Note 1) The power contacts of BK13C06-6DP/2-0.35V have an embossed design. (Note 2) This connector has no polarity. 5 8.40 1.60 1.80 1.80 1.80 1.80 1.80 2.365 3.415 4.815 6.215 9.365 11.115 B C D 2.35 0.70 1.60 1.665 3.40 1.75 1.80 2.175 4.10 5.50 6.90 8.30 10.05 11.80 1.40 2.45 3.85 5.25 6.65 8.40 10.15 1.60 1.80 1.80 1.80 1.80 1.80 1.80 20,000pcs per reel 7.615 1.80 3.05 Purchase Unit Purchase Unit 2.365 3.415 4.815 6.215 7.615 9.365 11.115 1,000pcs per reel BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Header Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Recommended PCB Layout ● Recommended Metal Mask Dimensions (Mask Thickness : 0.08mm) Part No. Unit : mm No. of Pos. B E F G H I 2 0.70 2.12 1.56 1.8 1.06 0.23 2 1.75 3.17 2.61 2.1 1.26 0.28 Signal Contact Power Contact BK13C06-10DP/2-0.35V(8##) 10 2 BK13C06-16DP/2-0.35V(8##) 16 BK13C06-6DP/2-0.35V(8##) BK13C06-12DP/2-0.35V(8##) BK13C06-24DP/2-0.35V(8##) BK13C06-32DP/2-0.35V(8##) BK13C06-40DP/2-0.35V(8##) BK13C06-50DP/2-0.35V(8##) BK13C06-60DP/2-0.35V(8##) (Note) This connector has no polarity. 6 12 24 32 40 50 60 1.40 2 2.45 2 3.85 2 5.25 2 6.65 2 8.40 2 10.15 6 2.82 3.87 5.27 6.67 8.07 9.82 11.57 2.26 3.31 4.71 6.11 7.51 9.26 11.01 1.8 2.1 2.1 2.1 2.1 2.1 2.1 1.06 1.26 1.26 1.26 1.26 1.26 1.26 0.23 0.28 0.28 0.28 0.28 0.28 0.28 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle Part No. HRS No. BK13C06-40DS/2-0.35V(800) BK13C06-50DS/2-0.35V(800) BK13C06-60DS/2-0.35V(800) Part No. CL0673-0143-0-00 CL0480-0664-0-00 CL0480-0666-0-00 CL0480-0726-0-00 BK13C06-40DS/2-0.35V(895) BK13C06-50DS/2-0.35V(895) BK13C06-60DS/2-0.35V(895) 6 1.62 12 2 4.35 1.75 2.67 2 24 2 32 2 40 2 5.05 6.45 7.85 9.25 1.40 2.45 3.85 5.25 6.65 3.37 4.77 6.17 10.15 11.07 Signal Contact Power Contact A B C CL0480-0720-0-95 10 2 2 3.30 0.70 1.62 CL0480-0722-0-95 16 2 4.35 1.75 2.67 HRS No. CL0673-0145-0-00 CL0480-0664-0-95 CL0480-0666-0-95 CL0480-0726-0-95 CL0480-0728-0-95 2 No. of Pos. 6 12 2 24 2 32 2 40 2 50 2 60 2 4.00 5.05 6.45 7.85 9.25 11.00 12.75 (Note 1) The power contacts of BK13C06-6DS/2-0.35V have a dimpled design. (Note 2) BK13C06-6DS/2-0.35V and BK13C06-10DS/2-0.35V have a metal reinforcement in the center of the product. (Note 3) This connector has no polarity. 7 1.40 2.45 3.85 5.25 6.65 8.40 10.15 20,000pcs per reel 7.57 12.75 60 8.40 Purchase Unit 2.32 11.00 CL0480-0728-0-00 50 4.00 2 CL0480-0896-0-95 BK13C06-32DS/2-0.35V(895) 0.70 16 BK13C06-12DS/2-0.35V(895) BK13C06-24DS/2-0.35V(895) 3.30 CL0480-0722-0-00 CL0480-0799-0-95 BK13C06-16DS/2-0.35V(895) 2 2 BK13C06-6DS/2-0.35V(895) (Note 1, 2) BK13C06-10DS/2-0.35V(895) (Note 2) C 10 CL0480-0896-0-00 BK13C06-32DS/2-0.35V(800) B CL0480-0720-0-00 BK13C06-12DS/2-0.35V(800) BK13C06-24DS/2-0.35V(800) A Power Contact CL0480-0799-0-00 BK13C06-16DS/2-0.35V(800) No. of Pos. Signal Contact BK13C06-6DS/2-0.35V(800) (Note 1, 2) BK13C06-10DS/2-0.35V(800) (Note 2) Unit : mm 9.32 Purchase Unit 2.32 3.37 4.77 6.17 7.57 9.32 11.07 1,000pcs per reel BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Receptacle Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Recommended PCB Layout ● Recommended Metal Mask Dimensions (Mask Thickness : 0.08mm) Part No. BK13C06-6DS/2-0.35V(8##) Signal Contact 6 BK13C06-10DS/2-0.35V(8##) 10 BK13C06-16DS/2-0.35V(8##) 16 BK13C06-12DS/2-0.35V(8##) BK13C06-24DS/2-0.35V(8##) BK13C06-32DS/2-0.35V(8##) BK13C06-40DS/2-0.35V(8##) BK13C06-50DS/2-0.35V(8##) BK13C06-60DS/2-0.35V(8##) (Note) This connector has no polarity. 12 24 32 40 50 60 No. of Pos. Unit : mm B D E 2 0.70 3.545 1.42 2 1.75 4.595 2.47 Power Contact 2 2 2 2 2 2 2 8 1.40 2.45 3.85 5.25 6.65 8.40 10.15 4.245 5.295 6.695 8.095 9.495 11.245 12.995 2.12 3.17 4.57 5.97 7.37 9.12 10.87 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Packaging Specifications Diagram Header Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Embossed Tape Dimensions Part No. HRS No. BK13C06-32DP/2-0.35V(800) BK13C06-40DP/2-0.35V(800) BK13C06-50DP/2-0.35V(800) BK13C06-60DP/2-0.35V(800) Part No. CL0673-0142-0-00 CL0480-0663-0-00 CL0480-0665-0-00 CL0480-0725-0-00 CL0480-0727-0-00 HRS No. BK13C06-40DP/2-0.35V(895) BK13C06-50DP/2-0.35V(895) BK13C06-60DP/2-0.35V(895) I 6 2 12.0 5.5 2.46 13.5 17.5 380 80 12 2 16.0 7.5 3.51 17.5 21.5 380 80 24 32 40 50 60 2 2 2 I 2 12.0 5.5 2.46 13.5 17.5 180 60 2 16.0 7.5 3.51 17.5 21.5 180 60 CL0480-0725-0-95 CL0480-0727-0-95 40 50 60 2 2 2 2 2 2 16.0 16.0 16.0 7.5 7.5 7.5 24.0 11.5 24.0 11.5 24.0 24.0 9 11.5 11.5 3.16 4.21 5.61 7.01 8.41 10.16 11.91 25.5 25.5 17.5 17.5 17.5 25.5 25.5 25.5 25.5 29.5 29.5 29.5 21.5 21.5 21.5 29.5 29.5 29.5 29.5 380 80 H 11.91 25.5 29.5 380 E 16 32 21.5 D 11.5 8.41 25.5 80 C CL0480-0721-0-95 24 17.5 380 80 B 24.0 11.5 7.01 21.5 380 A 2 2 12 5.61 17.5 21.5 10.16 24.0 No. of Pos. 6 7.5 4.21 17.5 11.5 2 10 CL0480-0665-0-95 16.0 7.5 3.16 24.0 2 CL0480-0719-0-95 CL0480-0663-0-95 16.0 7.5 11.5 Power Contact CL0673-0144-0-00 16.0 24.0 Signal Contact CL0480-0895-0-95 BK13C06-32DP/2-0.35V(895) H 16 BK13C06-12DP/2-0.35V(895) BK13C06-24DP/2-0.35V(895) E CL0480-0721-0-00 CL0480-0798-0-95 BK13C06-16DP/2-0.35V(895) D 2 BK13C06-6DP/2-0.35V(895) BK13C06-10DP/2-0.35V(895) C 10 CL0480-0895-0-00 BK13C06-24DP/2-0.35V(800) B CL0480-0719-0-00 BK13C06-12DP/2-0.35V(800) BK13C06-16DP/2-0.35V(800) A Power Contact CL0480-0798-0-00 Unit : mm No. of Pos. Signal Contact BK13C06-6DP/2-0.35V(800) BK13C06-10DP/2-0.35V(800) ● Reel Dimensions 380 380 380 180 180 180 180 180 180 180 80 80 80 80 60 60 60 60 60 60 60 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Packaging Specifications Diagram Receptacle Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Embossed Tape Dimensions Part No. HRS No. BK13C06-32DS/2-0.35V(800) BK13C06-40DS/2-0.35V(800) BK13C06-50DS/2-0.35V(800) BK13C06-60DS/2-0.35V(800) Part No. CL0673-0143-0-00 CL0480-0664-0-00 CL0480-0666-0-00 CL0480-0726-0-00 CL0480-0728-0-00 HRS No. BK13C06-40DS/2-0.35V(895) BK13C06-50DS/2-0.35V(895) BK13C06-60DS/2-0.35V(895) I 2 12.0 5.5 3.4 13.5 17.5 380 80 12 2 16.0 7.5 4.45 17.5 21.5 380 80 24 32 40 50 60 2 2 2 CL0480-0726-0-95 CL0480-0728-0-95 40 50 60 17.5 21.5 I 2 12.0 5.5 3.4 13.5 17.5 180 60 2 16.0 7.5 4.45 17.5 21.5 180 60 2 2 2 2 2 2 16.0 16.0 16.0 7.5 4.10 7.5 5.15 7.5 24.0 11.5 24.0 11.5 24.0 24.0 10 12.85 11.5 11.5 6.55 7.95 9.35 11.10 12.85 25.5 25.5 25.5 17.5 17.5 17.5 25.5 25.5 25.5 25.5 29.5 29.5 29.5 21.5 21.5 21.5 29.5 29.5 29.5 29.5 380 80 H 11.5 9.35 29.5 380 E 24.0 11.5 25.5 80 D 24.0 7.95 380 C 16 CL0480-0666-0-95 6.55 21.5 80 B CL0480-0722-0-95 32 7.5 17.5 380 A 2 2 24 5.15 21.5 11.10 10 CL0480-0664-0-95 7.5 17.5 11.5 2 CL0480-0720-0-95 CL0673-0145-0-00 16.0 4.10 24.0 2 Power Contact 12 16.0 7.5 11.5 No. of Pos. 6 16.0 24.0 Signal Contact CL0480-0896-0-95 BK13C06-32DS/2-0.35V(895) H 16 BK13C06-12DS/2-0.35V(895) BK13C06-24DS/2-0.35V(895) E CL0480-0722-0-00 CL0480-0799-0-95 BK13C06-16DS/2-0.35V(895) D 2 BK13C06-6DS/2-0.35V(895) BK13C06-10DS/2-0.35V(895) C 10 CL0480-0896-0-00 BK13C06-24DS/2-0.35V(800) B CL0480-0720-0-00 BK13C06-12DS/2-0.35V(800) 6 Unit : mm A Power Contact CL0480-0799-0-00 BK13C06-16DS/2-0.35V(800) No. of Pos. Signal Contact BK13C06-6DS/2-0.35V(800) BK13C06-10DS/2-0.35V(800) ● Reel Dimensions 380 380 380 180 180 180 180 180 180 180 80 80 80 80 60 60 60 60 60 60 60 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Usage Precautions 1. Recommended Solder Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature Profile [Conditions] 1. Peak Temperature : Maximum of 250℃ 3. Preheated Section : 150 to 180℃, 90 to 120 seconds 2. Heated Section 4. Number of Reflow Cycles : 220℃ Min., within 60 seconds : Maximum of 2 cycles (Note 1) The ‌ temperature is the surface temperature of the PCB in the vicinity of the connector lead part. (Note 2) When ‌ using nitrogen reflow process, please mount the product with an oxygen concentration at a minimum of 1,000ppm. Please contact a Hirose representative if the concentration is below 1,000ppm 2. ‌Recommended Manual Soldering Conditions 3. Recommended Metal Mask Thickness and Open Area Ratio to PCB Pattern Area 4. PCB Warpage 5. Cleaning 6. Notes Soldering iron temperature : 340±10℃ Soldering time : within 3 seconds Thickness : 0.08mm Aperture ratio : 100% on the header side, 100% on the receptacle side A maximum of 0.02mm at the center of the connector with reference to both ends of the connector. Not recommended. If this product is cleaned, please evaluate the performance before using it. Cleaning may cause a change in the mating/unmating properties as well as environmental resistance. ・ ‌Insertion or removal prior to board mounting may result in contact deformation. ・ ‌Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ・ ‌Avoid excessive prying mating/unmating as it may result in damage. ・ ‌During manual soldering, do not apply flux which will cause solder wicking. ・ ‌This product may have slight color differences due to production lot variability, but this does not have any effect on the performance. ・ ‌Please refer to the next page for mating/unmating precautions. ・ ‌It is advised to secure the mated connectors to the board with housings and cushioning materials because the product can disengage if dropped, by other impact or by FPC routing. ・ ‌Caution! Do not use the connector outside of the specifications.(i.e., rated current, rated voltage, PCB design and operating environment, etc.).Such usage could lead to material outgassing, ignition, or short-circuit, etc. ・ ‌Please use a proper stiffener on the back of the FPC. We recommend using a glass epoxy material with a minimum thickness of 0.3mm or a stainless steel material with a minimum of thickness of 0.2mm. 11 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A Connector Handling Precautions 【Connector Mating Precautions】 Header Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle 1. Locate ‌ the guides and align the connectors to the appropriate mating position. The connector has guide ribs on the receptacle for proper mating alignment. Align the connectors with the guide ribs. Metal cover guide (Outside) Metal cover guide (Inside) 2. When the connector comes to the appropriate position, the connector will lower into place as indicated by the change in mated height. 3. ‌When the connectors has lowered into place, the connector pair will be parallel to each other and cannot be moved back and forth or left and right. Please complete mating from this state by applying force. (Please align the connectors) (Please align the connectors) 4. P  lease make sure connectors are mated completely. If one side is floating or the connectors are mated at an angle, please unmate and then redo the mating procedure following the steps described. 12 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A 【Connector Un- Mating Precautions】 Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. It ‌ is recommended to remove the connector by pulling perpendicular to the connector mounted surface. However, unmating FPC-to-board connectors can become more difficult with higher pin count connectors and thinner FPCs. 2. If ‌ is difficult to remove the connector parallel to the mounting surface, remove it diagonally towards the pitch direction. Do not remove the connector towards the width direction as it may put a large amount of stress on the contacts. 3. If ‌ the FPC is not rigid enough, there is a possibility of solder peeling or connector damage. Please check the repetitive operation of the FPC planned to be used in advance, such as during the early stage build. Please do not remove the FPC by holding one corner and pulling at a diagonal as this will put a great amount of stress on the contacts. 13 BK13 Series / 0.35mm Pitch, 0.6mm Stacking Height, 1.9mm Width, Low-Profile Hybrid FPC-to-Board Connector Supporting 5A While Taking into Consideration Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Specifications mentioned in this catalog are reference values. When considering to order or use this product, please review the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, the warranty of the product may be affected. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ ※ The contents of this catalog are current as of date of 08/ 2023. Contents are subject to change without notice for the purpose of improvements. ※ The HRS logo and " HIROSE" are trademarks of HIROSE ELECTRIC CO. , LTD. 14
BK13C06-32DS/2-0.35V(895) 价格&库存
很抱歉,暂时无法提供与“BK13C06-32DS/2-0.35V(895)”相匹配的价格&库存,您可以联系我们找货
  • 1000+8.018211000+1.04199
  • 2000+7.635582000+0.99227
  • 3000+7.420313000+0.96429
  • 5000+7.157865000+0.93019
  • 7000+6.990087000+0.90838
  • 10000+6.8165210000+0.88583
库存:582
  • 1+13.105851+1.70314
  • 10+11.1016810+1.44269
  • 25+10.4051125+1.35217
  • 50+9.9072650+1.28748
  • 100+9.43387100+1.22596
  • 250+8.84241250+1.14910
  • 500+8.42015500+1.09422
库存:582
