OTEMDLVANY-100.000000
    TAITIEN(泰艺)
    SMD7050_6P
    有源晶振
OTEMDLVANY-100.000000 数据手册
OT-M Type 7.0 x 5.0 mm SMD LVPECL/LVDS Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.45 hermetically sealed ceramic package Very low phase jitter : 0.6 ps, typ. RMS Any frequency between 10 MHz and 1500 MHz. Tri-state enable/disable Fast deliver TYPICAL APPLICATION - High-Speed Gigabit Ethernet, Fiber Channel, Storage Area Network, SONET RoHS Compliant - Enterprise Server, SAS/SATA - Microprocessors/DSP/FPGA - Broadband Access - Smart Grid DIMENSION (mm) SOLDER PAD L AYOUT (mm) OT multiplier [ TOP VIEW ] [ BOTTOM VIEW ] 5.08±0.20 #4 #4 #5 #6 5.08 #2 #3 #3 #2 1.10±0.20 5.00±0.20 #1 #1 0.1µF 1.40±0.20 0.6 1.45±0.15 [ SIDE VIEW ] Function NC/Tri-State Tri-State/NC GND Output Comp.output VDD Pin# 1 2 3 4 5 6 4.00 #5 3.70±0.20 #6 2.00 7.00±0.20 1.80 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION LVPECL 3.3 V 2.5 V Min. Max. Min. Max. Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Supply Current 10 MHz Fo 1500 MHz Output High Output Level Output Low Transition Time: Rise/Fall Time+ Start Time Tri-State(Input to Pin 2 or Pin 1) Enable (High voltage or floating) Disable (Low voltage or GND) 2.5 V Max. unit VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% RMS Phase Jitter (Integrated 12 KHz ~ 20 MHz) (At Integer Mode) Phase Noise @ 156.25 MHz LVDS 3.3 V Min. Max. Min. 100Hz 1 kHz 10 kHz 10 1500 10 1500 10 1500 10 1500 106.25, 125, 133.33, 150, 155.52, 156.25, 187.5, 212.5, 312.5, 622.08 _ _ _ _ 50 50 50 50 _ _ _ _ 2.275 1.475 1.6 1.6 _ _ _ _ 0.9 1.68 0.88 0.9 _ _ _ _ 1.0 1.0 1.0 1.0 _ _ _ _ 10 10 10 10 _ _ _ Aging (@ 25°C 1st year) Storage Temp. Range _ 2.31 _ 1.2 _ -94 -113 -122 ±3 125 -55 _ 1.75 0.99 _ -55 _ 1.2 _ -94 -113 -122 ±3 125 _ 2.31 0.75 _ _ 1.2 _ -94 -113 -122 -55 ±3 125 _ -55 MHz mA V nSec mSec _ 1.75 0.99 V V 0.75 1.2 -94 -112 -122 pSec dBc/Hz ±3 125 ppm °C + Transition times are measured between 20% and 80% of VDD. FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm -10 ~ +60 -20 ~ +70 -40 ~ +85 -40 ~ +105 ±25 ±50 * ○: Available △:Conditional X: Not available * Inclusive of calibration @ 25 °C, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration Note: not all combination of options are available. Other specifications may be available upon request. 62 www.taitien.com sales@taitien.com.tw Rev(14) 11/2022
OTEMDLVANY-100.000000 价格&库存
很抱歉,暂时无法提供与“OTEMDLVANY-100.000000”相匹配的价格&库存,您可以联系我们找货
