OTEMDLVANY-125.000000 数据手册
OT-M Type
7.0 x 5.0 mm SMD LVPECL/LVDS Crystal
Oscillator
Actual Size
FEATURE
Typical 7.0 x 5.0 x 1.45 hermetically sealed ceramic package
Very low phase jitter : 0.6 ps, typ. RMS
Any frequency between 10 MHz and 1500 MHz.
Tri-state enable/disable
Fast deliver
TYPICAL APPLICATION
- High-Speed Gigabit Ethernet, Fiber Channel, Storage Area Network, SONET
RoHS Compliant
- Enterprise Server, SAS/SATA
- Microprocessors/DSP/FPGA
- Broadband Access
- Smart Grid
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
OT multiplier
[ TOP VIEW ]
[ BOTTOM VIEW ]
5.08±0.20
#4
#4
#5
#6
5.08
#2
#3
#3
#2
1.10±0.20
5.00±0.20
#1
#1
0.1µF
1.40±0.20
0.6
1.45±0.15
[ SIDE VIEW ]
Function
NC/Tri-State
Tri-State/NC
GND
Output
Comp.output
VDD
Pin#
1
2
3
4
5
6
4.00
#5
3.70±0.20
#6
2.00
7.00±0.20
1.80
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
LVPECL
3.3 V
2.5 V
Min.
Max.
Min.
Max.
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency
Supply Current 10 MHz Fo 1500 MHz
Output High
Output Level
Output Low
Transition Time: Rise/Fall Time+
Start Time
Tri-State(Input to Pin 2 or Pin 1)
Enable (High voltage or floating)
Disable (Low voltage or GND)
2.5 V
Max.
unit
VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5%
RMS Phase Jitter (Integrated 12 KHz ~ 20 MHz)
(At Integer Mode)
Phase Noise @ 156.25 MHz
LVDS
3.3 V
Min.
Max.
Min.
100Hz
1 kHz
10 kHz
10
1500
10
1500
10
1500
10
1500
106.25, 125, 133.33, 150, 155.52, 156.25, 187.5, 212.5, 312.5, 622.08
_
_
_
_
50
50
50
50
_
_
_
_
2.275
1.475
1.6
1.6
_
_
_
_
0.9
1.68
0.88
0.9
_
_
_
_
1.0
1.0
1.0
1.0
_
_
_
_
10
10
10
10
_
_
_
Aging (@ 25°C 1st year)
Storage Temp. Range
_
2.31
_
1.2
_
-94
-113
-122
±3
125
-55
_
1.75
0.99
_
-55
_
1.2
_
-94
-113
-122
±3
125
_
2.31
0.75
_
_
1.2
_
-94
-113
-122
-55
±3
125
_
-55
MHz
mA
V
nSec
mSec
_
1.75
0.99
V
V
0.75
1.2
-94
-112
-122
pSec
dBc/Hz
±3
125
ppm
°C
+ Transition times are measured between 20% and 80% of VDD.
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
-10 ~ +60
-20 ~ +70
-40 ~ +85
-40 ~ +105
±25
±50
○: Available △:Conditional X: Not available
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
62
www.taitien.com
sales@taitien.com.tw
Rev(14) 11/2022
OTEMDLVANY-125.000000 价格&库存
很抱歉,暂时无法提供与“OTEMDLVANY-125.000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+41.0611750+5.33601
