BK13C06-10DS/2-0.35V(895) 数据手册
COUNT
DESCRIPTION OF REVISIONS
CHKD DATE
BY
COUNT
BY
CHKD
DATE
APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
30 V AC/DC
RATING VOLTAGE
Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
STORAGE
TEMPERATURE RANGE
APPLICABLE
CONNECTOR
-55℃ TO +85℃(note1)
-10℃ TO +60℃
BK13C06-32DP/2-0.35V(**)
SIGNAL CONTACT 0.3A
POWER CONTACT 5.0A
CURRENT
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT AT
CONSTRUCTION
GENERAL EXAMINATION
CONFIRMED VISUALLY AND BY MEASURING
INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
X
X
X
X
ELECTRICAL CHARACTERISTICS
CONTACT RESISTANCE
20mV AC OR LESS 1kHz, 1mA
SIGNAL CONTACT : 90mΩ MAX
POWER CONTACT : 30mΩ MAX
X
INSULATION RESISTANCE
100V DC
50MΩ MIN
X
VOLTAGE PROOF
100V AC FOR 1min.
NO FLASHOVER OR BREAKDOWN
X
X
X
X
X
X
X
MECHANICAL CHARACTERISTICS
MECHANICAL
OPERATION
VIBRATION
SHOCK
① CONTACT RESISTANCE:
② NO DAMAGE, CRACK OR LOOSENESS
OF PATRS.
10 TIMES INSERTIONS AND EXTRACTIONS.
FREQUENCY 10 TO 55 TO 10 Hz, APPROX 5min
SINGLE AMPLITUDE 0.75mm, 10CYCLES,
FOR 3 DIRECTIONS.
① NO ELECTRICAL DISCONTINUITY OF 1μs.
OF PARTS.
OF PARTS.
490 m/s² DURATION OF PULSE 11ms AT 3 TIMES
FOR 3 DIRECTIONS.
ENVIRONMENTAL CHARACTERISTICS
RAPID CHANGE OF
TEMPERATURE
DAMP HEAT
(STEADY STATE)
SULPHUR DIOXIDE
TEMPERATURE -55 → +85℃
TIME
30 → 30 min
UNDER 5 CYCLES.
(RELOCATION TIME TO CHAMBER: WITHIN2~3 MIN)
② INSULATION RESISTANCE:
50MΩ MIN
③ NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
25MΩ MIN
OF PARTS.
OF PARTS.
EXPOSED AT 40±2℃, 90 TO 95%, 96h.
EXPOSED IN 25 PPM FOR 96h, 25℃, 75±5%RH.
(Test standard : JIS C 60068)
REMARKS
Note 1 : INCLUDE THE TEMPERATURE RISING BY CURRENT.
DRAWN
DESIGNED
CHECKED
APPROVED
J.M.YEOM
J.M.YEOM
H.W.JO
H.W.JO
RELEASED
ENG
20.09.21
Unless otherwise specified, refer to JIS C 5402 and IEC 60512
Note
QT: QUALIFICATION TEST
AT: ASSURANCE TEST
HIROSE KOREA CO.,LTD.
CODE NO.(OLD)
20.09.21
20.09.21
20.09.21
20.09.21
DEPT
X: APPLICABLE TEST
SPECIFICATION SHEET
DRAWING NO.
ELC3-632775-95
PART NO.
BK13C06-32DS/2-0.35V(895)
1
CODE NO.
CL 6665-0012-4-895
1
BK13C06-10DS/2-0.35V(895) 价格&库存
很抱歉,暂时无法提供与“BK13C06-10DS/2-0.35V(895)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.45600
- 10+3.38040
- 30+3.32640
- 100+3.27240
- 国内价格 香港价格
- 1000+5.964431000+0.76429
- 2000+5.679742000+0.72781
- 3000+5.519603000+0.70729
- 5000+5.324315000+0.68227
- 7000+5.199497000+0.66627
- 10000+5.0704010000+0.64973
- 国内价格 香港价格
- 1+8.662781+1.11006
- 10+7.3762010+0.94520
- 25+6.9092625+0.88536
- 50+6.5783750+0.84296
- 100+6.26340100+0.80260
- 250+5.87114250+0.75234
- 500+5.59060500+0.71639
- 国内价格 香港价格
- 1+9.550451+1.22381
- 10+8.1013010+1.03811
- 25+7.7652725+0.99505
- 50+7.6025050+0.97420
- 100+7.27085100+0.93170
- 250+6.61015250+0.84704
- 500+5.94913500+0.76233
