SCM Series
Series-Connected Super Capacitor Modules
This new series of electrochemical, double-layer, series-connected SuperCapacitor modules
offers excellent pulse power handling characteristics based on the combination of very high
capacitance and very low ESR. Used by themselves or in conjunction with primary or secondary
batteries, they provide extended back up time, longer battery life, and provide instantaneous
power pulses as needed. Offers great solutions to hold up, energy harvesting, pulse power
applications, and battery replacement.
FEATURES
APPLICATIONS
• High Pulse Power Capability
• Low ESR
• Low Leakage Current
• Plastic, Moisture Resistant Version
Camera Flash Systems
Energy Harvesting
GSM/GPRS Pulse Applications
UPS/Industrial
Wireless Alarms
Remote Metering
Scanners
Toys and Games
HOW TO ORDER
SCM
Series
SuperCap
Module
R
Diameter
Q = 6.3mm
R = 8mm / 9.5mm**
S = 10mm
T = 12.5mm
U = 16mm
14
C
Case
Length
Two digits
represent
case
length
in mm
Voltage
Code
C = 5.0V
D = 5.4V
F = 5.5V
G = 7.5V
H = 6.0V
J = 8.1V
L = 9.0V
474
P
Capacitance Code
Tolerance
1st two digits
P = +100%/-0%
represent significant S = +30%/-10%
figures 3rd digit
represents multiplier
(number of zeros to
follow)
R
Package/Lead Format
R = Shrink Wrap/Radial
S = Plastic/Radial
B
Package
B = Bulk
T = Tray*
A
Balancing
Lead Orientation
A = Unbalanced
B = Passive
Balanced
0 = Straight Leads
1 = Bent Leads*
*Inquire about availability
**Plastic/Radial version
QUALITY INSPECTION
TERMINATION
Parts are tested for life cycle, high temperature load life, temperature
characteristics, vibration resistance, and humidity characteristics.
See pages 2-5 for more information.
These SuperCapacitors are compatible with hand soldering, as well
as reflow and wave soldering processes, so long as appropriate
precautions are followed. See page 11 for more information.
LEAD-FREE COMPATIBLE
COMPONENT
For RoHS compliant products, please
select correct termination style.
1
011519
5.4V/5.0V SCM Series
Series-Connected SuperCapacitors Modules
AVX Part Number
Diameter
(mm)
Length
(mm)
Rated
Capacitance
(F)
Capacitance
Tolerance
Rated
Voltage (V)
Rated
Temperature
(°C)
ESR Max
DCL Max @
ESR Max @
@ 1000 Hz
72 Hrs (µA)
DC (mΩ)
(mΩ)
Peak
Current
(A)
Power
Max Energy
Density (W/
(Wh)
kg)
Energy
Density
(Wh/kg)
SCMQ14C474PRBA0
6.3
14
0.47
+100%/-0%
5.0/4.2*
65/85*
2
400
1000
0.80
2143
0.0016
1.17
SCMQ14C474PRTA0
6.3
14
0.47
+100%/-0%
5.0/4.2*
65/85*
2
400
1000
0.80
2143
0.0016
1.17
SCMQ14D474PRBB0
6.3
14
0.47
+100%/-0%
5.4/4.6*
65/85*
6
400
1000
0.86
2499
0.0019
1.36
SCMQ14D474PRTB0
6.3
14
0.47
+100%/-0%
5.4/4.6*
65/85*
6
400
1000
0.86
2499
0.0019
1.36
SCMR14C474PRBA0
8
14
0.47
+100%/-0%
5.0/4.2*
65/85*
2
300
1000
0.80
1429
0.0016
0.78
SCMR14D474PRBB0
8
14
0.47
+100%/-0%
5.4/4.6*
65/85*
6
300
1000
0.86
1666
0.0019
0.91
SCMR18C105PRBA0
8
18
1
+100%/-0%
5.0/4.2*
65/85*
6
200
720
1.45
1667
0.0035
1.39
SCMR18D105PRBB0
8
18
1
+100%/-0%
5.4/4.6*
65/85*
10
200
720
1.57
1944
0.0041
1.62
SCMR22C155PRBA0
8
22
1.5
+100%/-0%
5.0/4.2*
65/85*
10
190
580
2.01
1669
0.0052
1.68
Shrink Wrap / Radial Lead
SCMR22D155PRBB0
8
22
1.5
+100%/-0%
5.4/4.6*
65/85*
15
190
580
2.17
1946
0.0061
1.96
SCMS22C255PRBA0
10
22
2.5
+100%/-0%
5.0/4.2*
65/85*
360
3.29
1852
0.0087
1.93
SCMS22D255PRBB0
10
22
2.5
+100%/-0%
5.4/4.6*
65/85*
25
140
360
3.55
2113
0.0101
2.20
SCMT22C505PRBA0
12.5
22
5
+100%/-0%
5.0/4.2*
65/85*
25
100
150
7.14
2740
0.0174
2.38
SCMT22D505PRBB0
12.5
22
5
+100%/-0%
5.4/4.6*
65/85*
30
100
150
7.71
3069
0.0203
2.66
SCMT32C755SRBA0
12.5
32
7.5
+30%/-10%
5.0/4.2*
65/85*
65
70
160
8.52
1953
0.0260
2.71
SCMT32D755SRBB0
12.5
32
7.5
+30%/-10%
5.4/4.6*
65/85*
70
70
160
9.20
2209
0.0304
3.07
*with appropriate voltage derating operating temperature can be extended to 85°C
OPERATING TEMPERATURE RANGE
-40°C to +65°C @ 5.4V Balanced, 5.0V Unbalanced
-40°C to +85°C @ 4.6V Balanced, 4.2V Unbalanced
QUALIFICATION TEST SUMMARY
Test
Test Method
Parameter
Limits
Life Cycle
Capacitors are cycled between rated voltage and half-rated voltage under constant current
at +25°C for 500,000 cycles
Capacitance Change
ESR
Appearance
≤30% of initial value
≤2 times initial value
No remarkable defects
High Temperature Load
Life
Voltage: Rated Voltage
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Temperature: +65°C
Test Duration: 2,000 hours
Storage Duration: 2 year
Storage Temperature
Characteristics
No Load
Temperature: +35°C
Amplitude: 1.5mm
Vibration Resistance
Frequency: 10 ~ 55Hz
Direction: X, Y, Z for 2 hours each
Humidity
RH: 90%
Temperature: +60°C
Test Duration: 1,500 hours
2
011519
6.0V/5.5V SCM Series
AVX Part Number
Diameter
(mm)
Length
(mm)
Rated
Capacitance
(F)
Capacitance
Tolerance
Rated
Voltage (V)
SCMQ14F474PRBA0
6.3
14
0.47
+100%/-0%
5.5/4.6*
SCMQ14H474PRBB0
6.3
14
0.47
+100%/-0%
6.0/5.0*
SCMR14F474PRBA0
8
14
0.47
+100%/-0%
SCMR14H474PRBB0
8
14
0.47
SCMR18F105PRBA0
8
18
SCMR18H105PRBB0
8
SCMR22F155PRBA0
Rated
Temperature
(°C)
DCL Max
@ 72 Hrs
(µA)
ESR Max
@ 1000 Hz
(mΩ)
ESR Max @
DC (mΩ)
Peak
Current
(A)
Power
Density
(W/kg)
Max Energy
(Wh)
Energy
Density
(Wh/kg)
65/85*
6
500
3000
65/85*
7
500
3000
0.54
864
0.0020
1.41
0.59
1029
0.0024
5.5/4.6*
65/85*
6
380
1.68
1720
0.71
1005
0.0020
+100%/-0%
6.0/5.0*
65/85*
7
0.94
380
1720
0.78
1196
0.0024
1
+100%/-0%
5.5/4.6*
65/85*
1.12
6
250
720
1.60
2017
0.0042
18
1
+100%/-0%
6.0/5.0*
1.68
65/85*
12
250
720
1.74
2400
0.0050
8
22
1.5
+100%/-0%
2.00
5.5/4.6*
65/85*
12
200
560
2.24
2091
0.0063
SCMR22H155PRBB0
8
22
1.5
2.03
+100%/-0%
6.0/5.0*
65/85*
18
200
560
2.45
2488
0.0075
SCMS22F255PRBA0
10
22
2.42
2.5
+100%/-0%
5.5/4.6*
65/85*
24
180
340
3.72
2373
0.0105
SCMS22H255PRBB0
10
2.33
22
2.5
+100%/-0%
6.0/5.0*
65/85*
30
180
340
4.05
2762
0.0125
SCMS32F505PRBA0
2.72
10
32
5
+100%/-0%
5.5/4.6*
65/85*
30
120
150
7.86
3580
0.0210
3.11
SCMS32H505PRBB0
10
32
5
+100%/-0%
6.0/5.0*
65/85*
36
120
150
8.57
4235
0.0250
3.68
SCMT22F505PRBA0
12.5
22
5
+100%/-0%
5.5/4.6*
65/85*
30
120
150
7.86
3176
0.0210
2.76
SCMT32F755SRBA0
12.5
32
7.5
+30%/-10%
5.5/4.6*
65/85*
78
90
120
10.86
3151
0.0315
3.28
SCMT32H755SRBB0
12.5
32
7.5
+30%/-10%
6.0/5.0*
65/85*
84
90
120
11.84
3600
0.0375
3.75
SCMU33F156SRBA0
16
33
15
+30%/-10%
5.5/4.6*
65/85*
85
35
50
23.57
4033
0.0630
3.50
SCMU33F156SRBB0
16
33
15
+30%/-10%
5.5/4.6*
65/85*
90
35
50
23.57
3946
0.0630
3.43
Plastic / Radial Lead
SCMR14F474PSBA0
9.5
16
0.47
+100%/-0%
5.5/4.6*
65/85*
3
380
1720
0.71
541
0.0020
0.51
SCMR14H474PSBB0
9.5
16
0.47
+100%/-0%
6.0/5.0*
65/85*
7
380
1720
0.78
644
0.0024
0.60
SCMR18F105PSBA0
9.5
+100%/-0%
5.5/4.6*
65/85*
7
250
720
1.60
1096
0.0042
0.91
SCMR18H105PSBB0
9.5
+100%/-0%
6.0/5.0*
65/85*
12
250
720
1.74
1304
0.0050
1.09
SCMR22F155PSBA0
9.5
24
1.5
+100%/-0%
5.5/4.6*
65/85*
12
200
560
2.24
1179
0.0063
1.15
SCMR22H155PSBB0
9.5
24
1.5
+100%/-0%
6.0/5.0*
65/85*
18
200
560
2.45
1403
0.0075
1.36
-40°C to +65°C @ 6.0V Balanced, 5.5V Unbalanced
-40°C to +85°C @ 5.0V Balanced, 4.6V Unbalanced
Test
Test Method
Parameter
Limits
Life Cycle
current at +25°C for 500,000 cycles
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Temperature: +65°C
High Temperature
Load Life
Storage Duration: 2 years
Storage Temperature
Characteristics
No Load
Temperature: +35°C
Amplitude: 1.5mm
Humidity
RH: 90%
Temperature: +60°C
3
081419
7.5V SCM Series
AVX Part Number
Diameter
(mm)
Length
(mm)
Rated
Capacitance
(F)
Capacitance
Tolerance
Rated
Voltage
(V)
SCMR14G334SRBA0
8
14
0.33
+30%/-10%
7.5/6.4*
SCMR14G334SRBB0
8
14
0.33
+30%/-10%
SCMR18G604SRBA0
8
18
0.6
SCMR18G604SRBB0
8
18
SCMR22G105SRBA0
8
SCMR22G105SRBB0
8
Rated
Temperature
(°C)
DCL Max @
72 Hrs (µA)
ESR Max
@ 1000 Hz
(mΩ)
ESR Max @
DC (mΩ)
Peak
Current
(A)
Power
Density
(W/kg)
Max
Energy
(Wh)
Energy
Density
(Wh/kg)
65/85*
2
450
900
0.95
2419
0.0026
0.83
7.5/6.4*
65/85*
6
450
900
0.95
2419
0.0026
0.83
+30%/-10%
7.5/6.4*
65/85*
6
225
450
1.77
3947
0.0047
1.23
0.6
+30%/-10%
7.5/6.4*
65/85*
10
225
450
1.77
3846
0.0047
1.20
22
1
+30%/-10%
7.5/6.4*
65/85*
10
180
360
2.76
4076
0.0078
1.70
22
1
+30%/-10%
7.5/6.4*
65/85*
15
180
360
2.76
3989
0.0078
1.66
-40°C to +65°C @ 7.5V
-40°C to +85°C @ 6.4V
Test
Test Method
Parameter
Limits
Life Cycle
Capacitance Change
ESR
Appearance
Life
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Temperature: +65°C
Storage Temperature
Characteristics
No Load
Temperature: +35°C
Amplitude: 1.5mm
Humidity
RH: 90%
Temperature: +60°C
4
011519
9.0V/8.1V SCM Series
AVX Part Number
Diameter
(mm)
Length
(mm)
Rated
Capacitance
(F)
Capacitance
Tolerance
Rated
Voltage (V)
SCMR14J334SRBA0
8
14
0.33
+30%/-10%
8.1/6.9*
SCMR14J334SRBB0
8
14
0.33
+30%/-10%
8.1/6.9*
SCMR14L334SRBB0
8
14
0.33
+30%/-10%
SCMR18J604SRBA0
8
18
0.6
SCMR18J604SRBB0
8
18
SCMR18L604SRBB0
8
SCMR22J105SRBA0
Rated
Temperature
(°C)
DCL Max
@ 72 Hrs
(µA)
ESR Max
@ 1000 Hz
(mΩ)
ESR Max @
DC (mΩ)
Peak
Current
(A)
Power
Density
(W/kg)
Max Energy
(Wh)
Energy
Density
(Wh/kg)
65/85*
3
500
2850
0.69
897
0.0030
0.98
65/85*
6
500
2850
0.69
869
0.0030
0.95
9.0/7.6*
65/85*
7
500
2850
0.77
1072
0.0037
1.17
+30%/-10%
8.1/6.9*
65/85*
7
400
1080
1.47
1934
0.0055
1.45
0.6
+30%/-10%
8.1/6.9*
65/85*
15
400
1080
1.47
1869
0.0055
1.40
18
0.6
+30%/-10%
9.0/7.6*
65/85*
12
400
1080
1.64
2308
0.0068
1.73
8
22
1
+30%/-10%
8.1/6.9*
65/85*
12
350
840
2.20
1986
0.0091
1.93
SCMR22J105SRBB0
8
22
1
+30%/-10%
8.1/6.9*
65/85*
15
350
840
2.20
1894
0.0091
1.84
SCMR22L105SRBB0
8
22
1
+30%/-10%
9.0/7.6*
65/85*
18
350
840
2.45
2338
0.0113
2.27
SCMR14J334SSBA0
9.5
16
0.33
+30%/-10%
8.1/6.9*
65/85*
3
500
2850
0.69
498
0.0030
0.54
SCMR14L334SSBB0
9.5
16
0.33
+30%/-10%
9.0/7.6*
65/85*
7
500
2850
0.77
598
0.0037
0.65
SCMR18J604SSBA0
9.5
+30%/-10%
8.1/6.9*
65/85*
7
400
1080
1.47
1063
0.0055
0.80
SCMR18L604SSBB0
9.5
+30%/-10%
9.0/7.6*
65/85*
12
400
1080
1.64
1286
0.0068
0.96
SCMR22J105SSBA0
9.5
24
1
+30%/-10%
8.1/6.9*
65/85*
12
350
840
2.20
1129
0.0091
1.10
SCMR22L105SSBB0
9.5
24
1
+30%/-10%
9.0/7.6*
65/85*
18
350
840
2.45
1361
0.0113
1.32
-40°C to +65°C @ 9.0V Balanced, 8.1V Unbalanced
-40°C to +85°C @ 7.6V Balanced, 6.9V Unbalanced
Test
Test Method
Parameter
Limits
Life Cycle
Capacitance Change
ESR
Appearance
≤30% of initial spec value
≤2 times initial spec value
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Capacitance Change
ESR
Appearance
Temperature: +65°C
Life
Storage Temperature
Characteristics
No Load
Temperature: +35°C
Amplitude: 1.5mm
Humidity
RH: 90%
Temperature: +60°C
5
011519
SCM Series
QUALITY AND RELIABILITY
Capacitance vs. Temperature
Percent of 25°C Reading
200%
150%
100%
50%
0%
-40°C
-20°C
0°C
20°C
40°C
60°C
80°C
Temperature (ºC)
Leakage Current vs. Temperature
700%
600%
500%
400%
300%
200%
100%
0%
-40°C
-20°C
0°C
20°C
40°C
60°C
80°C
60°C
80°C
Temperature (ºC)
Equivalent Series Resistance vs. Temperature
300%
250%
200%
150%
100%
50%
0%
-40°C
-20°C
0°C
20°C
Temperature (°C)
6
011519
40°C
SCM Series
MECHANICAL SPECIFICATIONS
5.4V, 6.0V Shrink Wrap Type - Straight Leads
5.4V, 6.0V Shrink Wrap Type - Bent Leads
D±1.0mm
D±1.0mm
L±1.5mm
L±1.5mm
3.0±0.5mm
d±0.05mm
фd±0.05mm
W±1.0 mm
P±0.5mm
W±1.0 mm
P±0.5mm
15 mm min
(-) Negative Polarity
B mm± 0.5mm
4mm min
Cap (F)
D (mm)
W (mm)
L (mm)
P (mm)
d (mm)
B (mm)*
0.47
6.3
13.6
14.0
9.0
0.6
2.0
0.47
8.0
16.0
14.0
11.5
0.6
2.0
1
8.0
16.0
18.0
11.5
0.6
2.0
1.5
8.0
16.0
22.0
11.5
0.6
2.0
2.5
10.0
20.0
22.0
15.5
0.6
2.0
5
10.0
20.0
32.0
15.5
0.6
2.0
5
12.5
25.0
22.0
18.0
0.6
2.0
7.5
12.5
25.0
32.0
18.0
0.6
2.0
15
16.0
32.0
33.0
23.7
0.8
2.0
*for version with bent leads
7.5V, 9.0V Shrink Wrap Type - Straight Leads
7.5V, 9.0V Shrink Wrap Type - Bent Leads
D±1.0mm
D±1.0mm
3.0±0.5mm
d±0.05mm
d±0.05mm
P±0.5mm
W±1.0 mm
W±1.0 mm
P±0.5mm
15 mm min
B mm± 0.5mm
L ± 1.5
4mm min
L ± 1.5
Cap (F)
D (mm)
W (mm)
L (mm)
P (mm)
d (mm)
B (mm)*
0.33
8.0
24.0
14.0
13.5
0.6
2.0
0.6
8.0
24.0
18.0
13.5
0.6
2.0
1
8.0
24.0
22.0
13.5
0.6
2.0
7
011519
SCM Series
6.0V Plastic Type - Straight Leads
6.0V Plastic Type - Bent Leads
L±1.5mm
L±1.5mm
D±1.0mm
D±1.0mm
3.0±0.5mm
d±0.05mm
d±0.05mm
W±1.0 mm
P±0.5mm
W±1.0 mm
P±0.5mm
15 mm min
B
4mm min
Cap (F)
D (mm)
W (mm)
L (mm)
P (mm)
d (mm)
B (mm)*
0.47
9.5
18.5
16.0
11.5
0.6
2.0
1
9.5
18.5
20.0
11.5
0.6
2.0
1.5
9.5
18.5
24.0
11.5
0.6
2.0
9.0V Plastic Type - Straight Leads
L±1.5mm
9.0V Plastic Type - Bent Leads
L±1.5mm
D±1.0mm
D±1.0mm
P±0.5mm
W±1.0 mm
P±0.5mm
W±1.0 mm
15 mm min
3.0±0.5mm
d±0.05mm
d±0.05mm
B
4mm min
Cap (F)
D (mm)
W (mm)
L (mm)
P (mm)
d (mm)
B (mm)*
0.33
9.5
26.6
16.0
13.5
0.6
2.0
0.6
9.5
26.6
20.0
13.5
0.6
2.0
1
9.5
26.6
24.0
13.5
0.6
2.0
8
070819
SCM Series
TEST METHODS
IEC Capacitance Test Method
• Capacitance is measured using a Keithley 2400 or 2602 Meter
• Procedure
• Charge Capacitor to Rated Voltage at room temperature
• Disconnect parts from voltage to remove charging effects
• Discharge cells with a constant current I determined by
4 * C * VR
• Noting V1, t1, V2, t2 and performing the calculation for C
Voltage
(V)
30 min
VR
V3 ESR Drop
V1
Initial ESR Measurement @ 25°C
• Using an Agilent 4263B LCR Meter and a Kelvin connection
• Measure at frequency of 1000 Hz
• Measurement Voltage of 10mV
DC ESR Measurement
• Six steps capacity and ESRDC Test Method is used as illustrated in
the figure right.
• Tests are carried out by charging and discharging the capacitor
for two cycles at rated voltage and half rated voltage
• C = (CDC1+CDC2) / 2
• ESRDC = (ESRDC1 + ESRDC2) / 2
Where: CDC1 = I2*(t5-t4)/(V3-V4)
CDC2 = I2*(t11-t10)/V9-V10)
ESRDC1 = (V5-V4)/I2
ESRDC2 = (V11-V10)/I2
I1 = I2 = 75mA/F
V2
Cycle 1
1 V1 V2
I
VR
t1
t2
Times (s)
for 72 Hours
• Disconnect parts from Voltage by opening switch 1
(Stabilize for 10 Min)
• Measure Voltage across a known Valued Resistor (1K Ohm)
• Calculate DCL = V/R
Multimeter
DC
Power
Supply
1k Ω
7 V8
Cycle 2
1
3
V
I
Step 4
Step 6
Step 1
V
4
V
5
Step 6
Step 3
Step 1
V
6
10
V
Step 5
I
1
t
9
Step 4
Step 3
V
Step 2
Step 2
I – Discharge Current [mA], 4 * C * VR VR – Rated Voltage
V1 – Initial Test Voltage, 80% of VR
V2 – Final Test Voltage, 40% of VR
t1 – Initial Test time
t2 – Final Test time
C = I * (t2 – t1) / (V1 – V2)
DCL Measurement @ 25°C
• DCL is measured using a Multimeter with high internal impedance across a resistor
V
t
2
t
3
t
4
11
V
Step 5
2
t
5 t6
7
t
t
8
I2
9 t10 t11 t12
t
Maximum Operating Current
• This is the maximum current when capacitor temperature rise of the
capacitor during its operation is less than 15°C
Maximum Peak Current
• This is the maximum current in less than 1 sec
Watt Density
• Watt Density = (0.12*V² / RDC) / mass
Energy Density
• Energy density = (½ CV²) / (3600*mass)
1
9
011519
SCM Series
POLARITY / REVERSE VOLTAGE
For product consistency and optimum performance, it is recommended that the capacitor be connected with polarity indicated. Reversing polarity
could result in permanent damage to the circuit including much higher leakage current for a short duration of time and the life time of the
supercapacitors will be reduced.
LIFE TIME AND TEMPERATURE PERFORMANCE
The life of a SuperCapacitor is impacted by a combination of operating
voltage and the operating temperature according to the following equation:
time to failure, t ∞ Vn * exp (-Q / k*T) …………..(1) where V is the
voltage of operation, Q is the activation energy in electron volts (eV), k is the
Boltzmann’s constant in eV and T is the operating temperature in °K (where
K is in degrees Kelvin). Typical values for the voltage exponent, n, is between
2.5 - 3.5, and Q is between 1.0 - 1.2 eV in the normal operating temperature
range of 40° to 65°C. The industry standard for SuperCapacitor end of life
is when the equivalent series resistance, ESR, increases to 200% of the
original value and the capacitance drops by 30%. Typically a SuperCapacitor
shows an initial change in the ESR value and then levels off. If the capacitors are
exposed to excessive temperatures the ESR will show a continuous degradation
In the extreme case, if the temperatures or voltages are substantially higher,
than the rated voltage, this will lead to cell leakage or gas leakage and the
product will show a faster change in the ESR which may increase to many
times the original value.
Expected Lifetime at Various Voltages
SCM Series, 5.4V/5.0V, 6.0V/5.5V, 7.5V, 9.0V/8.1V Rated
90
100%Vrated
80
90%Vrated
70
80%Vrated
70%Vrated
Temperature (°C)
60
50
40
30
1.0 10.0 100.0
MTTF (years)
SCM Series, 4.6V/4.2V, 5.0V/4.6V, 6.4V, 7.6V/6.9V Rated
90
100%Vrated
80
90%Vrated
70
80%Vrated
70%Vrated
Temperature (°C)
60
50
40
30
1.0
10.0
MTTF (years)
10
011519
100.0
SCM Series
SOLDERING RECOMMENDATIONS
When soldering SuperCapacitors to a PCB, the temperature & time
that the body of the SuperCapacitor sees during soldering can have a
negative effect on performance. We advise following these guidelines:
• Do not immerse the SuperCapacitors in solder. Only the leads should
come in contact with the solder.
• Ensure that the body of the SuperCapacitor is not in contact with the
PCB or other components during soldering. Temperature cycling
during soldering may cause the case to shrink or crack, potentially
damaging the PCB or other components.
WAVE SOLDERING
Only use wave soldering on Radial type SuperCapacitors. The PCB
should be preheated for no longer than 60 seconds, with temperature
at, or below, 100°C. Soldering tin should be 0.8mm or thicker.
Solder Temperature
HAND SOLDERING
Keep some distance between the SuperCapacitor body and the tip
of the soldering iron; contact between SuperCapacitor body and
soldering iron will cause extensive damage to the SuperCapacitor. It is
recommended that the soldering iron temperature should be less than
350°C, and contact time should be limited to no more than 4 seconds.
Too much exposure to terminal heat during soldering can cause heat
to transfer to the body of the SuperCapacitor, potentially damaging the
SuperCapacitor.
SAFETY RECOMMENDATIONS
Suggested Solder
Time (s)
Time (s)
220
7
9
240
7
9
250
5
7
260
3
5
REFLOW SOLDERING
Infrared or conveyor over reflow techniques can be used on these
SuperCapacitors. Do not use a traditional reflow oven without clear
rated reflow temperature for SuperCapacitors.
Warnings
Regulatory
• To avoid short circuit, after usage or test, SuperCapacitor
voltage needs to discharge to ≤ 0.1V
• Do not apply over-voltage, reverse charge, burn or heat higher
than 150°C, explosion-proof valve may break open
• Do not press, damage or disassemble the SuperCapacitor,
housing could heat to high temperature causing burns
• If you observe overheating or burning smell from the capacitor
disconnect power immediately, and do not touch
• UL 810A
• RoHS Compliant
• Reach Compliant / Halogen Free
Emergency Applications
• If housing is leaking:
• Skin contact: use soap and water thoroughly to wash the
area of the skin
• Eye contact: flush with flowing water or saline, and
immediately seek medical treatment
• Ingestion: immediately wash with water and seek medical
treatment
Transportation
Maximum Solder
(ºC)
Storage
• Capacitors may be stored within the operating temperature range
of the capacitor
• Lower storage temperature is preferred as it extends the shelf
life of the capacitor
• Do not store the SuperCapacitors in the following environments
• High temperature / high humidity environments
>40°C / 70% RH
• Direct sunlight
• In direct contact with water, salt oil or other chemicals
• In direct contact with corrosive materials, acids, alkalis, or
toxic gases
• Dusty environment
• In environment with shock and vibration conditions
Not subjected to US DOT or IATA regulations
UN3499,
