E3SB27E000800E
E3SB27E000800E
    HOSONIC(鸿星)
    SMD3225_4P
    27.000MHZ ±10PPM 12PF
E3SB27E000800E 数据手册
该文档是极速PDF编辑器生成, 如果想去掉该提示,请访问并下载: http://www.jisupdfeditor.com/ SMD CRYSTAL UNIT SPECIFICATIONS Customer Customer P/N 502G270001G A Product 3225 Seam Sealing Crystal Nominal Frequency 27.000000MHz HOSONIC P/N E3SB27E000800E Version 10C0 Issue Date 2015/4/29 Drawn Drawn LUCY HOSONIC Checked Approved ZOE JOHN Approved By Customer : ________________________________ Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:1 Revised Record Rev. Rev. Date 1.0 2015-04-29 Item Content Remark Initial released Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:2 l ELECTRICAL PARAMETERS No. Item Symb. 1 Nominal Frequency 2 Mode of Vibration 3 Frequency Tolerance △F/F0 4 Operating Temperature Range TOPR 5 Frequency Stability 6 Electrical Specification Min. F0 Typ. Max. 27.000000 Units Remark MHz Fundamental -10 - 10 ppm 0 - 85 ℃ TC -10 - 10 ppm Storage Temperature TSTG -55 - 125 ℃ 7 Load capacitance CL - 12 - pF 8 Equivalent Series Resistance ESR - - 30 Ω 9 Drive Level DL - 100 200 μW 10 Insulation Resistance IR 500 - - MΩ 11 Shunt Capacitance C0 - - 3 pF 12 Aging Per Year Fa -2 - 2 ppm 13 Package type HCX-3SB At 25℃±3℃ Ref. to 25℃ At 100VDC First Year NOTE:Storage Temperature is only for the product itself,the temperature for the packing material is -4~40℃. Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:3 l l OUTLINE DIMENSIONS (UNIT: mm) MARKING e.g. 27.000 = 27.000000 27.000 518 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:4 l PRODUCT LAYOUT NO. Part Material 1 LID KOVAR(Fe+Co+Ni alloy) 2 PKG Al2O3 Base 3 Blank SiO2 Quartz 4 Adhesive paste Ag/Silicon Support 5 Electrode Noble metal Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Remark Format:HOS-4-058,Ver.:C/0 Page:5 l REFLOW PROFILES Profiles Feature Average Ramp-up Rate (Ts max to Tp) Preheat ■ Temperature Min (Ts min) ■ Temperature Max (Ts max) ■ Time (ts min to ts max) Time maintained above ■ Temperature (TL) ■ Time (tL) Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature (tp) Ramp-down rate Time 25℃ to Peak Temperature Suggest reflow times Pb-Free Assembly 3℃/second max. 125℃ 200℃ 60~180 seconds 217℃ 60~150 seconds 260℃ 20~40 seconds 6℃/second max. 8 minutes max. 3 Times max Remark:To reference JEDEC J-STD-020C Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:6 l PACKAGE(reference to EIA-481) Tape Dimensions(unit : mm) A B C D E F L1 W t 1.50 4.0 4.0 3.5 8.0 1.0 3.4 2.7 0.3 Reel Dimensions(unit: mm) M J G K I H L G H I J K L M 2.5 13.5 21.6 60.0 178 9.5 1.6 *3000pcs/Reel Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:7 Carton Dimension (unit : mm) 180 130 50 25 45 18 0 25 50 25 80 50 70 25 45 180 485 1 reel = 1 Inner box 0 230 0 30 25 180 15 0 150 180 180 420 20 Inner boxes = 1 Carton 60kpcs = 1 Carton Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:8 l RELIABILITY SPECIFICATIONS No. Test Item Test Conditions Reference 1 High Temperature Storage Temperature: 125℃±5℃ Time: 1000±12 Hours MIL-STD-883E-1016 2 Temperature Cycle Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ Temperature change between T1 and T2 at soonest Run 1000 cycles, maintain T1 and T2 5minutes each in one cycle JESD22 Method JA-104 3 Solder Heat Resistance Pre-heat: 125℃ 60~120 Seconds Solder Temperature: 260℃±5℃ Time: 30 Seconds MIL-STD-202F 210 E 4 Drop Test 3 Times Free Fall from 75cm height table to 3cm thickness hard wood board MIL-STD-202F-203B 5 High Temperature, High Humidity Storage Temperature: 85℃±5℃ Relative Humidity: 80%--85% Time: 250Hours±24 Hours MIL-STD-202F-103B 6 Steam Aging Temperature: 97℃±5℃ Time: 24 Hours 260℃ solder pot to check solderability MIL-STD-883 C-1008.2B 7 Solderability Dip in flux 5~10 seconds Temperature: 245℃±5℃ Time: 10 Seconds MIL-STD-202F-208H 8 Aging Temperature: 85℃±5℃ Time: 250±12Hours MIL-STD-202 F-108A Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ Temperature change between T1 and T2: 5 seconds 100 cycles, maintain T1 and T2 for 30 minutes each in one cycle MIL-STD-883E-1011.9B Vibration Frequency Range: 10Hz~2000Hz Amplitude: 1.5mm or 20G 4Hours in each direction, total 12Hours MIL-STD-202F-204D 9 10 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:9
E3SB27E000800E 价格&库存
很抱歉,暂时无法提供与“E3SB27E000800E”相匹配的价格&库存,您可以联系我们找货
E3SB27E000800E
    • 1+1.10808
    • 10+0.87956
    • 30+0.78149
    库存:4
