E2SB26E000005E
E2SB26E000005E
    HOSONIC(鸿星)
    SMD2520_4P
    26.000MHZ ±10PPM 9PF
E2SB26E000005E 数据手册
SMD CRYSTAL UNIT SPECIFICATIONS Issue Rev. Page Dec 11 2013 1.0 9 Customer Customer P/N Product 2520 Seam Sealing X’tal Nominal Frequency 26.00000MHz HOSONIC P/N Drawn E2SB26E000005E Checked Approved Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:1 Revised Record Rev. Rev. Date 1.0 2013-12-11 Item Content Remark Initial released Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:2  ELECTRICAL PARAMETERS No. Item Symb. Electrical Specification Min. Typ. Max. Units 1 Nominal Frequency F0 26.0000 2 Mode of Vibration 3 Frequency Tolerance △F/F0 -10 - 10 ppm 4 Operating Temperature Range TOPR -20 - 70 ℃ 5 Frequency Stability TC -10 - 10 6 Storage Temperature TSTG -55 - 125 ppm ℃ 7 Load capacitance CL - 9 - pF 8 Equivalent Series Resistance ESR - - 80 Ω 9 Drive Level DL - 50 100 μW 10 Insulation Resistance IR 500 - - MΩ 11 Shunt Capacitance C0 - - 3 pF 12 Aging Per Year Fa -2 - 2 ppm 13 Package type HCX-2SB Remark MHz Fundamental Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com at 25℃±3℃ At 100VDC First Year Format:HOS-4-058,Ver.:B/0 Page:3  OUTLINE DIMENSIONS (UNIT: mm)  MARKING e.g. 26.000 = 26.00000 26.000 350 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:4  PRODUCT LAYOUT NO. 1 PART LID MATERIAL KOVAR(Fe+Co+Ni alloy) REMARK 2 PKG Al2O3 Base 3 Blank SiO2 Quartz 4 Adhesive paste Ag/Silicon Support 5 Electrode Noble metal Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:5  REFLOW PROFILES Profiles Feature Average Ramp-up Rate (Ts max to Tp) Preheat ■ Temperature Min (Ts min) ■ Temperature Max (Ts max) ■ Time (ts min to ts max) Time maintained above ■ Temperature (TL) ■ Time (tL) Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature (tp) Ramp-down rate Time 25℃ to Peak Temperature Suggest reflow times Pb-Free Assembly 3℃/second max. 125℃ 200℃ 60~180 seconds 217℃ 60~150 seconds 260℃ 20~40 seconds 6℃/second max. 8 minutes max. 3 Times max Remark:To reference JEDEC J-STD-020C Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:6  PACKAGE Tape Dimensions(unit : mm) A B C D E F L1 W t 1.50 4.0 4.0 3.5 8.0 1.0 2.75 2.25 0.2 Reel Dimensions(unit: mm) M K J L G H I J K L M 2.5 13.5 21.6 60.0 178 9.5 1.6 *3000pcs/Reel Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:7 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:8 Carton Dimension (unit : mm) 25 130 50 25 45 25 50 25 80 50 70 180 45 180 485 1 reel = 1 Inner box 180 230 180 150 180 420 20 Inner boxes = 1 Carton 60kpcs = 1 Carton Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:9  RELIABILITY SPECIFICATIONS No. 1 Test Item High Temperature Storage Test Conditions Temperature: 125℃±5℃ Time: 1000±12 Hours Reference MIL-STD-883E-1016 Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ 2 Temperature Cycle 3 Solder Heat Resistance 4 Drop Test 5 High Temperature, High Humidity Storage Temperature change between T1 and T2 at soonest Run 1000 cycles, maintain T1 and T2 5minutes each in one cycle Pre-heat: 125℃ 60~120 Seconds Solder Temperature: 260℃±5℃ Time: 30 Seconds 3 Times Free Fall from 75cm height table to 3cm thickness hard wood board Temperature: 85℃±5℃ Relative Humidity: 80%--85% Time: 250Hours±24 Hours Temperature: 97℃±5℃ 6 Steam Aging Time: 24 Hours 260℃ solder pot to check solderability 7 Solderability Dip in flux 5~10 seconds Temperature: 245℃±5℃ Time: 10 Seconds 8 Aging Temperature: 85℃±5℃ Time: 250±12Hours JESD22 Method JA-104 MIL-STD-202F 210 E MIL-STD-202F-203B MIL-STD-202F-103B MIL-STD-883 C-1008.2B MIL-STD-202F-208H MIL-STD-202 F-108A Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ 9 10 Thermal Shock Vibration Temperature change between T1 and T2: 5 seconds 100 cycles, maintain T1 and T2 for 30 minutes each in one cycle Frequency Range: 10Hz~2000Hz Amplitude: 1.5mm or 20G 4Hours in each direction, total 12Hours Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com MIL-STD-883E-1011.9B MIL-STD-202F-204D Format:HOS-4-058,Ver.:B/0 Page:10
E2SB26E000005E 价格&库存
很抱歉,暂时无法提供与“E2SB26E000005E”相匹配的价格&库存,您可以联系我们找货
E2SB26E000005E
    • 1+1.45109
    • 10+1.15172
    • 30+1.02341
    库存:12
