E3SB40E000030E
E3SB40E000030E
    HOSONIC(鸿星)
    SMD3225_4P
    40MHZ 8PF ±10PPM
E3SB40E000030E 数据手册
SMD CRYSTAL UNIT SPECIFICATIONS Customer 立创 Customer P/N Product 3225 Seam Sealing Crystal Nominal Frequency 40.000000MHz HOSONIC P/N E3SB40E000030E Version 10C0 Issue Date 2015/9/6 Drawn LUCY HOSONIC Checked ZOE Approved JOHN Approved By Customer : Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:1 Revised Record Rev. 1.0 Rev. Date 2015-09-06 Item Content Initial released Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Remark Format:HOS-4-058,Ver.:C/0 Page:2  ELECTRICAL PARAMETERS No. Item Symb. Electrical Specification Min. Typ. Max. Units 1 2 Nominal Frequency Mode of Vibration F0 3 Frequency Tolerance △F/F0 -10 - 10 ppm 4 Operating Temperature Range TOPR -30 - 85 ℃ 5 6 Frequency Stability Storage Temperature TC TSTG -10 -55 - 10 125 ppm ℃ 7 Load capacitance CL - 8 - pF ESR - - 50 Ω DL IR 500 100 - 200 - μW MΩ At 100VDC - - 3 -2 - 2 pF ppm First Year 9 10 Equivalent Series Resistance Drive Level Insulation Resistance 11 Shunt Capacitance 12 Aging Per Year C0 Fa 13 Package type HCX-3SB 8 40.000000 Fundamental Remark MHz At 25℃±3℃ Ref. to 25℃ NOTE:Storage Temperature is only for the product itself,the temperature for the packing material is -4~40℃. Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:3   OUTLINE DIMENSIONS (UNIT: mm) MARKING e.g. 26.000 = 26.000000 12.000 537 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:4  PRODUCT LAYOUT NO. 1 2 3 Part LID PKG Blank 4 5 Adhesive paste Electrode Material KOVAR(Fe+Co+Ni alloy) Remark Al2O3 SiO2 Ag/Silicon Noble metal Base Quartz Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Support Format:HOS-4-058,Ver.:C/0 Page:5  REFLOW PROFILES Profiles Feature Average Ramp-up Rate (Ts max to Tp) Preheat ■ Temperature Min (Ts min) ■ Temperature Max (Ts max) ■ Time (ts min to ts max) Time maintained above ■ Temperature (TL) ■ Time (tL) Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature (tp) Ramp-down rate Time 25℃ to Peak Temperature Suggest reflow times Pb-Free Assembly 3℃/second max. 125℃ 200℃ 60~180 seconds 217℃ 60~150 seconds 260℃ 20~40 seconds 6℃/second max. 8 minutes max. 3 Times max Remark:To reference JEDEC J-STD-020C Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:6  PACKAGE Tape Dimensions(unit : mm) A 1.50 B 4.0 C 4.0 D 3.5 E 8.0 F 1.0 L1 3.4 W 2.7 t 0.3 Reel Dimensions(unit: mm) K J M L G 2.5 H 13.5 I 21.6 J 60.0 K 178 L 9.5 M 1.6 *3000pcs/Reel Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:7 Carton Dimension (unit : mm) 25 130 50 25 45 25 50 25 80 50 70 180 45 180 485 1 reel = 1 Inner box 180 230 180 150 180 420 20 Inner boxes = 1 Carton 60kpcs = 1 Carton Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:8  RELIABILITY SPECIFICATIONS No. 1 Test Item High Temperature Storage Test Conditions Temperature: 125℃±5℃ Time: 1000±12 Hours Reference MIL-STD-883E-1016 Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ 2 Temperature Cycle 3 Solder Heat Resistance 4 Drop Test 5 High Temperature, High Humidity Storage Temperature change between T1 and T2 at soonest Run 1000 cycles, maintain T1 and T2 5minutes each in one cycle Pre-heat: 125℃ 60~120 Seconds Solder Temperature: 260℃±5℃ Time: 30 Seconds 3 Times Free Fall from 75cm height table to 3cm thickness hard wood board Temperature: 85℃±5℃ Relative Humidity: 80%--85% Time: 250Hours±24 Hours Steam Aging Temperature: 97℃±5℃ Time: 24 Hours 260℃ solder pot to check solderability 7 Solderability Dip in flux 5~10 seconds Temperature: 245℃±5℃ Time: 10 Seconds 8 Aging Temperature: 85℃±5℃ Time: 250±12Hours 6 JESD22 Method JA-104 MIL-STD-202F 210 E MIL-STD-202F-203B MIL-STD-202F-103B MIL-STD883 C1008 2B MIL-STD-202F-208H MIL-STD-202 F-108A Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ 9 Thermal Shock 10 Vibration Temperature change between T1 and T2: 5 seconds 100 cycles, maintain T1 and T2 for 30 minutes each in one cycle Frequency Range: 10Hz~2000Hz Amplitude: 1.5mm or 20G 4Hours in each direction, total 12Hours Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com MIL-STD-883E-1011.9B MIL-STD-202F-204D Format:HOS-4-058,Ver.:C/0 Page:9
E3SB40E000030E 价格&库存
很抱歉,暂时无法提供与“E3SB40E000030E”相匹配的价格&库存,您可以联系我们找货
E3SB40E000030E
    • 1+1.21360
    • 10+0.96326
    • 30+0.85590
    • 100+0.72209
    • 500+0.66248
    • 1000+0.62662
