E2SB40E00000RE
E2SB40E00000RE
    HOSONIC(鸿星)
    SMD2520_4P
    40MHZ ±30PPM 20PF
E2SB40E00000RE 数据手册
SMD CRYSTAL UNIT SPECIFICATIONS Customer 立创 Customer P/N Product 2520 Seam Sealing Crystal Nominal Frequency 40.000000MHz HOSONIC P/N E2SB40E00000RE Version 10C0 Issue Date 2014/12/17 Drawn LUCY HOSONIC Checked Approved ZOE JOHN Approved By Customer : Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:1 Revised Record Rev. 1.0 Rev. Date 2014-12-17 Item Content Remark Initial released Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:2  ELECTRICAL PARAMETERS No. Item Symb. Electrical Specification Min. Typ. Max. Units 1 Nominal Frequency F0 40.000000 2 Mode of Vibration 3 Frequency Tolerance △ F/F0 -30 - 30 ppm 4 Operating Temperature Range TOPR -40 - 85 ℃ 5 Frequency Stability TC -30 - 30 6 Storage Temperature TSTG -55 - 125 ppm ℃ 7 Load capacitance CL - 20 - pF 8 Equivalent Series Resistance ESR - - 100 Ω 9 Drive Level DL - 50 100 μW 10 Insulation Resistance IR 500 - - MΩ 11 Shunt Capacitance C0 - - 3 pF 12 Aging Per Year Fa -2 - 2 ppm 13 Package type HCX-2SB Remark MHz Fundamental At 25℃±3℃ Ref. to 25℃ At 100VDC First Year NOTE:Storage Temperature is only for the product itself,the temperature for the packing material is -4~40℃. Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:3  OUTLINE DIMENSIONS (UNIT: mm)  M ARKING e.g. 16.000 = 16.000000 16.000 451 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:4  PRODUCT LAYOUT NO. 1 PART LID MATERIAL KOVAR(Fe+Co+Ni alloy) REMARK 2 PKG Al2O3 Base 3 Blank SiO2 Quartz 4 Adhesive paste Ag/Silicon Support 5 Electrode Noble metal Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:5  REFLOW PROFILES Profiles Feature Average Ramp-up Rate (Ts max to Tp) Preheat ■ Temperature Min (Ts min) ■ Temperature Max (Ts max) ■ Time (ts min to ts max) Time maintained above ■ Temperature (TL) ■ Time (tL) Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature (tp) Ramp-down rate Time 25℃ to Peak Temperature Suggest reflow times Pb-Free Assembly 3℃/second max. 125℃ 200℃ 60~180 seconds 217℃ 60~150 seconds 260℃ 20~40 seconds 6℃/second max. 8 minutes max. 3 Times max Remark:To reference JEDEC J-STD-020C Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:6  PACKAGE Tape Dimensions(unit : mm) A B C D E F L1 W t 1.50 4.0 4.0 3.5 8.0 1.0 2.75 2.25 0.2 Reel Dimensions(unit: mm) J K M L G H I J K L M 2.5 13.5 21.6 60.0 178 9.5 1.6 *3000pcs/Reel Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:7 Carton Dimension (unit : mm) 25 130 50 25 45 25 50 25 80 50 70 180 45 180 485 1 reel = 1 Inner box 180 230 180 150 180 420 20 Inner boxes = 1 Carton 60kpcs = 1 Carton Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:C/0 Page:8  RELIABILITY SPECIFICATIONS No. Test Item High Temperature Storage Test Conditions Temperature: 125℃±5℃ Time: 1000±12 Hours 2 Temperature Cycle Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ Temperature change between T1 and T2 at soonest Run 1000 cycles, maintain T1 and T2 5minutes each in one cycle JESD22 Method JA-104 3 Solder Heat Resistance Pre-heat: 125℃ 60~120 Seconds Solder Temperature: 260℃±5℃ Time: 30 Seconds MIL-STD-202F 210 E 4 Drop Test 5 High Temperature, High Humidity Storage 1 3 Times Free Fall from 75cm height table to 3cm thickness hard wood board Temperature: 85℃±5℃ Relative Humidity: 80%--85% Time: 250Hours±24 Hours Reference MIL-STD-883E-1016 MIL-STD-202F-203B MIL-STD-202F-103B Steam Aging Temperature: 97℃±5℃ Time: 24 Hours 260℃ solder pot to check solderability 7 Solderability Dip in flux 5~10 seconds Temperature: 245℃±5℃ Time: 10 Seconds 8 Aging Temperature: 85℃±5℃ Time: 250±12Hours MIL-STD-202 F-108A 9 Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ Temperature change between T1 and T2: 5 seconds 100 cycles, maintain T1 and T2 for 30 minutes each in one cycle MIL-STD-883E-1011.9B 10 Vibration Frequency Range: 10Hz~2000Hz Amplitude: 1.5mm or 20G 4Hours in each direction, total 12Hours MIL-STD-202F-204D 6 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com MIL-STD883 C1008.2B MIL-STD-202F-208H Format:HOS-4-058,Ver.:C/0 Page:9
E2SB40E00000RE
物料型号:E2SB40E00000RE
器件简介:2520 Seam Sealing Crystal,由Hosonic Electronic Co., Ltd.生产,符合RoHS标准。
引脚分配: - Pin #1, #3: X'tal - Pin #2, #4: GND
参数特性: - 标称频率:40.000000MHz - 振动模式:基础模式 - 频率容差:-30到30ppm,25°C+3°C - 工作温度范围:-40°C至85°C - 频率稳定性:-30到30ppm,参考25°C - 存储温度:-55°C至125°C - 负载电容:20pF - 等效串联电阻:100Ω - 驱动电平:50至100mW - 绝缘电阻:500MΩ,100Vpc - 并联电容:3pF - 年老化率:-2到2ppm,第一年
功能详解:文档中未提供详细的功能详解
应用信息:文档中未提供具体的应用信息
封装信息: - 封装类型:HCX-2SB - 外形尺寸:2.5mm x 2.0mm x 0.8mm - 推荐焊盘图案:XAMG9.0
E2SB40E00000RE 价格&库存
很抱歉,暂时无法提供与“E2SB40E00000RE”相匹配的价格&库存,您可以联系我们找货
