E2SB54E000000E
E2SB54E000000E
    HOSONIC(鸿星)
    SMD2520_4P
    54MHZ ±10PPM 10PF
E2SB54E000000E 数据手册
SMD CRYSTAL UNIT SPECIFICATIONS Issue Rev. Page Customer Oct 21 2013 1.0 9 立创 Customer P/N Product 2520 Seam Sealing X’tal Nominal Frequency 54.0000MHz HOSONIC P/N Drawn E2SB54E000000E Checked Approved Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:1 Revised Record Rev. 1.0 Rev. Date 2013-10-21 Item Content Initial released Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Remark Format:HOS-4-058,Ver.:B/0 Page:2  ELECTRICAL PARAMETERS Electrical Specification No. Item 1 Nominal Frequency 2 Mode of Vibration 3 Frequency Tolerance Operating Temperature 4 Range Symb. F0 Min. Typ. Max. Units 54.0000 MHz Remark Fundamental △F/F0 -10 - 10 ppm TOPR -20 - 70 ℃ at 25℃±3℃ 5 Frequency Stability TC -10 - 10 ppm 6 Storage Temperature TSTG -55 - 125 ℃ 7 Load capacitance CL - 10 - pF 8 Equivalent Series Resistance ESR - - 80 Ω 9 Drive Level DL - 50 100 μW 10 11 Insulation Resistance Shunt Capacitance IR C0 500 - - 3 MΩ pF At 100VDC 12 Aging Per Year Fa -2 - 2 ppm First Year 13 Package type HCX-2SB Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:3  OUTLINE DIMENSIONS (UNIT: mm)  MARKING 20.000 342 e.g. 20.000 = 20.00000 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:4  PRODUCT LAYOUT NO. PART MATERIAL REMARK 1 LID 2 PKG KOVAR(Fe+Co+Ni alloy) Al2O3 Base 3 4 Blank Adhesive paste SiO2 5 Electrode Noble metal Ag/Silicon Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Quartz Support Format:HOS-4-058,Ver.:B/0 Page:5  REFLOW PROFILES Profiles Feature Average Ramp-up Rate (Ts max to Tp) Preheat ■ Temperature Min (Ts min) ■ Temperature Max (Ts max) ■ Time (ts min to ts max) Time maintained above ■ Temperature (TL) ■ Time (tL) Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature (tp) Ramp-down rate Time 25℃ to Peak Temperature Suggest reflow times Pb-Free Assembly 3℃/second max. 125℃ 200℃ 60~180 seconds 217℃ 60~150 seconds 260℃ 20~40 seconds 6℃/second max. 8 minutes max. 3 Times max Remark: To reference JEDEC J-STD-020C Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:6  PACKAGE Tape Dimensions(unit : mm) A B C D E F L1 W t 1.50 4.0 4.0 3.5 8.0 1.0 2.75 2.25 0.2 Reel Dimensions(unit: mm) M H JK I G G 2.5 *3000pcs/Reel L H I J K L M 13.5 21.6 60.0 178 9.5 1.6 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:7 Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:8 Carton Dimension (unit : mm) 25 130 50 25 45 2 5 180 180 45 25 80 50 50 70 180 485 1 reel = 1 Inner box 150 1 8 0 250 180 180 2 3 0 150 300 420 20 Inner boxes = 1 Carton 60kpcs = 1 Carton Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:9  RELIABILITY SPECIFICATIONS No. Test Item High Temperature 1 Storage 2 3 4 5 Temperature Cycle Solder Heat Resistance Drop Test High Temperature, High Humidity Storage 6 7 Steam Aging Solderability 8 Aging 9 Thermal Shock 10 Vibration Test Conditions Temperature: 125℃±5℃ 1000±12 Hours Time: Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ Temperature change between T1 and T2 at soonest Run 1000 cycles, maintain T1 and T2 Reference MIL-STD-883E-1016 JESD22 Method JA-104 5minutes each in one cycle Pre-heat: 125℃ 60~120 Seconds Solder Temperature: 260℃±5℃ MIL-STD-202F 210 E Time: 30 Seconds 3 Times Free Fall from 75cm height table to 3cm thickness hard wood MIL-STD-202F-203B board Temperature: 85℃±5℃ Relative Humidity: 80%--85% Time: 250Hours±24 Hours Temperature: 97℃±5℃ Time: 24 Hours 260℃ solder pot to check solderability Dip in flux 5~10 seconds Temperature: 245℃±5℃ Time: 10 Seconds Temperature: 85℃±5℃ 250±12Hours Time: Temperature 1: -55℃±5℃ Temperature 2: 125℃±5℃ Temperature change between T1 and T2: 5 seconds 100 cycles, maintain T1 and T2 for 30 minutes each in one cycle Frequency Range: 10Hz~2000Hz Amplitude: 1.5mm or 20G MIL-STD-202F-103B MIL-STD-883 C-1008.2B MIL-STD-202F-208H MIL-STD-202 F-108A MIL-STD-883E-1011.9B MIL-STD-202F-204D 4Hours in each direction, total 12Hours Add: No. 242, Liangbo Road, Liangzhu Town, Hangzhou, Zhejiang 311113, China. Tel: 86-571-88778189, Fax: 86-571-88778857 http://www.hosonic.com Format:HOS-4-058,Ver.:B/0 Page:10
E2SB54E000000E
物料型号为E2SB54E000000E,是Hosonic电子有限公司生产的2520 Seam Sealing X'tal。
该器件的标称频率为54.0000MHz,振动模式为基频模式,频率容差为±10ppm,工作温度范围为-20至70℃。
封装类型为HCX-2SB。
引脚分配如下: - #1和#3引脚连接至晶体。
- #2和#4引脚连接至地线。
参数特性包括: - 负载电容为10pF。
- 等效串联电阻为80Ω。
- 驱动水平为50至100mW。
- 绝缘电阻为500MΩ(在100VDC下)。
- 并联电容为3pF。
- 首年老化率为±2ppm。
功能详解包括: - 存储温度范围为-55至125℃。
- 频率稳定性为±10ppm。
应用信息: - 该器件适用于需要精确频率和稳定性的应用。
封装信息: - 封装类型为HCX-2SB,尺寸为2.5mm x 2.0mm x 0.10mm。
可靠性规格包括高温存储、温度循环、焊热抗力、跌落测试、高温高湿存储、蒸汽老化、焊料性、老化和热冲击测试。
所有测试均按照MIL-STD标准进行。
E2SB54E000000E 价格&库存
很抱歉,暂时无法提供与“E2SB54E000000E”相匹配的价格&库存,您可以联系我们找货
E2SB54E000000E
    • 1+0.42613
    • 10+0.25007
    • 30+0.11775
    • 100+0.10865
    库存:1298
