RoHS
Compliant
SMD CRYSTAL UNITS
E2SB Series
Pb
Free
2.5*2.0 Seam Sealing Crystal
FEATURES
Very Compact and thin (2.5*2.0*0.65mm max.)
Frequency range of 12M to 62.5M with Fund
Excellent electrical performance, ideal for OA (office automation),
AV (audiovisual), Bluetooth and Wireless LAN applications
Excellent heat resistance and shock resistance
Lead-free. Meets the requirements for re-flow profiling using lead
-free solder
Electrical Specifications
E2SB
Type
Item
Frequency Range
F0
12 to 15.999MHz
Mode of Vibration
16 to 19.999MHz
20 to 25.999MHz
Fundamental
Load Capacitance
Frequency Tolerance
CL
8 to 16pF
△F/ F0
±10ppm,±15ppm,±30ppm(At 25℃)
120Ω max.
100Ω max.
80Ω max.
Equivalent Series Resistance
ESR
Temperature Stability
TC
±10ppm,±15ppm,±30ppm(Refer to 25℃)
Operating Temperature Range
TOPR
-20~+70℃,-30~+85℃ Option
Storage Temperature Range
TSTG
Shunt Capacitance
C0
3pF max.
Insulator Resistance
IR
500MΩ min. (At 100VDC)
Drive Level
DL
Aging
Fa
50µW(100µW max.)
±2ppm max. (At 25℃,First year)
3000pcs/reel
Packing Unit
**Please contact us for inquiries regarding other Specifications
Mechanical Dimensions(mm)
Top View
2.50±0.10
4
0.90
0.80
3
4
3
1
2
MARKING
AREA
1
2
Recommended Solder Pattern
1.00
5
26 to 62.500MHz
0.70
1.00
50Ω max.
很抱歉,暂时无法提供与“E2SB16E00000VE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.87675
- 50+0.67976
- 150+0.58126
- 500+0.50739
