E1SB48E00001JE
E1SB48E00001JE
    HOSONIC(鸿星)
    SMD2016_4P
    48MHZ ±10PPM 15PF
E1SB48E00001JE 数据手册
E1SB Series 2.0*1.6 Seam Sealing Crystal FEATURES Very compact and thin (2.0*1.6*0.5mm max.) Frequency range of 16 to 62.5M with Fund Ideal for smartphone applications with limited design space, miniaturized wireless module devices, RFID application, and other consumer based products Lead-free. Meets the requirements for re-flow profiling using lead-free solder Item Frequency Range E1SB Type F0 16 to 18.999MHz Mode of Vibration Load Capacitance Frequency Tolerance 19 to 24.999MHz 25 to 29.999MHz 30 to 62.500MHz Fundamental CL 8 to 16pF △F/ F0 ±10ppm,±15ppm,±30ppm(At 25℃) 200Ω max. 80Ω max. 100Ω max. Equivalent Series Resistance ESR Temperature Stability TC ±10ppm,±15ppm,±30ppm(Refer to 25℃) Operating Temperature Range TOPR -20~+70℃,-30~+85℃ Option Storage Temperature Range TSTG -55~+125℃ Shunt Capacitance C0 3pF max. Insulator Resistance IR 500MΩ min. (At 100VDC) Drive Level DL 50µW(100µW max.) Aging Fa Packing Unit 60Ω max. ±2ppm max. (At 25℃,First year) 3000pcs/reel **Please contact us for inquiries regarding other Specifications 4
E1SB48E00001JE 价格&库存
很抱歉,暂时无法提供与“E1SB48E00001JE”相匹配的价格&库存,您可以联系我们找货
