OR-M3052
OR-M3052
    ORIENT(奥伦德)
    OC-4P_3.85X4.4MM_SM
    双向可控硅 无过零电路 1通道
OR-M3052 数据手册
Shenzhen Orient Components Co ., Ltd OR-M305X ORIENT Photo coupler Product Data Sheet Part Number: OR-M305X Customer: Date: SHENZHEN ORIENT COMPONENTS CO ., LTD Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2019 Orient .All rights Reserved 1 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 1. Features (1) High isolation voltage between input and output (Viso:3750 V rms ) (2) 4pin non zero-cross optoisolators triac driver output (3) High repetitive peak off-state voltage VDRM : Min. 600V (4) High critical rate of rise of off-state voltage( dV/dt : MIN. 1000V / s ) (5) Tape and reel packaging. (6) Operating temperature -40 ℃to +110 ℃ 2. Description The OR-M305X consists of a non zero crossing photo triac, optically coupled to a gallium arsenide infrared emitting diode. The OR-M305X is housed in the SOP-4 package and guarantees insulation thickness.Therefore,the OR-M305X meets the reinforced insulation class requirements of international safety standards. 3. Application Range • AC Motor Drives • Lighting Controls • Temperature Controls •AC Motor Starters •Solenoid/Valve Controls •Static power switch •Solid State Relays 4. Absolute Maximum Ratings (Ta=25℃) Parameter Input Forward Current Junction Temperature Reverse Voltage Power Dissipation Off-State Output Terminal Voltage Peak Repetitive Surge Current Output (PW=1ms,120 pps) Junction Temperature Collector Power Dissipation Total Power Dissipation *1 Insulation Voltage Working Temperature Deposit Temperature *2 Soldering Temperature Symbol Rated Value Unit IF TJ VR P 50 125 6 100 mA ℃ V mW V DRM 600 V I TSM 1 A TJ PC Ptot Viso Topr Tstg Tsol 125 300 330 5000 -40 ~ + 110 -55 ~ + 125 260 ℃ mW mW Vrms ℃ Notes: *1 AC for 1 minute, R.H.= 40 ~ 60% R.H. In this test, pins 1, 2&3 are shorted together, and pins 4, 6 are shorted together. * 2 For 10 seconds Copyright© 2019 Orient .All rights Reserved 2 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 5. Electrical Optical Characteristics at Ta=25°C Parameter Input Output Symbol Condition Forward Voltage VF IF=20mA --- 1.2 1.6 V Reverse Current IR VR=6V --- --- 5 μA 1.Peak Blocking Current, Either Direction IDRM V DRM = 600V --- 10 100 nA Peak On-State Voltage, Either Direction VTM ITM=100mA Peak --- 1.7 3.0 V 2.Critical rate of Rise of Off-State Voltage dv/dt Vin=240Vrms 1000 --- --- V/us --- --- 30 --- --- 15 --- --- 10 --- --- 5 --- 200 --- OR-M3020 3. Led Trigger Current,Current Required to Latch Output, Either Direction Couple OR-M3021 IFT OR-M3022 OR-M3023 IH Holding Current, Either Direction Main Terminal Voltage = 3V Min Typ.* Max Unit mA uA *1.Test voltage must be applied within dv/dt rating. *2. This is static dv/dt. Commutating dv/dt is a function of the load-driving thyristor(s) only. *3. All devices are guaranteed to trigger at an IF value less than or equal to max IFT . Therefore,recommended operating IF lies between max IFT , 30 mA for OR-M3050, 15 mA for OR-M3051, 10 mA for OR-M3052, 5 mA for ORM3053, and absolute max IF (50mA). Copyright© 2019 Orient .All rights Reserved 3 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 6. Order Information Part Number OR-M305X-Z Note X = IFT Rank (0 ,1 , 2 ,3 ). Z = Tape and reel option (TP or TP1). * Halogen Free can be selected. * VDE Code can be selected. Option Description Packing quantity TP Surface mount lead form (low profile) + TP tape & reel option 3000 units per reel TP1 Surface mount lead form (low profile) + TP1 tape & reel option 3000 units per reel Copyright© 2019 Orient .All rights Reserved 4 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 7. Naming Rule NOTE: (1) ORIENT . (2) 305 denotes Part Number. (3) denotes Year Code. (4) denotes Week Code. (5) denotes Day Code. (6) Anode. * If the photo coupler is Free from Halogen,there will be a‘ G’ mark in the upper left corner. * VDE Code can be selected. Copyright© 2019 Orient .All rights Reserved 5 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 8. Package Dimension OR-M305X 9. RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm Copyright© 2019 Orient .All rights Reserved 6 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 10.Taping Dimensions (1)OR-M305X-TP (2)OR-M305X-TP1 Description Symbol Dimension in mm (inch) Tape wide W 12±0.3(0.472) Pitch of sprocket holes P0 4±0.1(0.157) F 5.5±0.1(0.217) P2 2±0.1(0.079) P1 8±0.1(0.315) Distance of compartment Distance of compartment to compartment Package Type TP/TP1 Quantities(pcs) 3000 Copyright© 2019 Orient .All rights Reserved 7 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 11.Package Dimension (1) package dimension (2)Packing Label Sample 1. 2. 3. 4. 5. MTL NO:Contents with "Order Information" in the specification. LOT NO:The production cycle of the product. BATCH:The CTR RANK of the product. Quantity:Product packaging quantity. Product Data: The data when product be made. Copyright© 2019 Orient .All rights Reserved 8 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 12.Reliability Test Copyright© 2019 Orient .All rights Reserved 9 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 13.Temperature Profile Of Soldering (1).IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat Temperature Min (TSmin ) 150˚C - Temperature Max (TSmax ) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone 217˚C - Temperature (TL ) - Time (tL ) 60 sec Peak Temperature(TP) 260˚C Ramp-up rate 3˚C / sec max. Ramp-down rate Copyright© 2019 Orient .All rights Reserved 3~6˚C / sec 10 A0 Shenzhen Orient Components Co ., Ltd OR-M305X (3) .Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 5 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Temperature 380+0/-5˚C Time 3 sec max Copyright© 2019 Orient .All rights Reserved 11 A0 Shenzhen Orient Components Co ., Ltd OR-M305X 14.CHARACTERISTICS CURVES (TYPICAL PERFORMANCE) Copyright© 2019 Orient .All rights Reserved 12 A0 Shenzhen Orient Components Co ., Ltd OR-M305X Basic Operation Circuit Medium/High Power Triac Drive Circuit Copyright© 2019 Orient .All rights Reserved 13 A0
OR-M3052 价格&库存
很抱歉,暂时无法提供与“OR-M3052”相匹配的价格&库存,您可以联系我们找货
OR-M3052
  • 1+0.92950
  • 200+0.64130
  • 1500+0.58300
  • 3000+0.54450
库存:2300
OR-M3052
库存:112
